PowerShot A3500 IS
- PowerShot A3500 Digital Camera
- Wrist Strap WS-800
- Battery Pack NB-11L
- Battery Charger CB-2LF
- USB Interface Cable IFC-400PCU
- Digital Camera Solution CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Type Of Camera | Compact Digital Camera With Built-In Flash, 5x Optical, 4x Digital, And 20x Combined Zoom With Optical Image Stabilizer |
| Type | 16.0 Megapixel 1/2.3-Inch CCD |
| Total Pixels | 16.6 Megapixels |
| Effective Pixels | 16.0 Megapixels |
| Focal Length | 5.0 (W) - 25.0 (T) Mm (35mm Film Equivalent: 28 (W) - 140 (T) Mm) |
| Digital Zoom | 4x |
| Focusing Range | Normal: 1.2 In. (3cm) - Infinity (W), 3.9 Ft. (1.2m) - Infinity (T) Macro: 1.2 In. - 1.6 Ft. (3-50cm) (W) |
| Autofocus | TTL Autofocus |
| Optical Viewfinder | N/A |
| Lcd Monitor | 3.0-Inch TFT Color LCD With Wide-Viewing Angle |
| Lcd Pixels | Approx. 230,000 Dots |
| Lcd Coverage | Approx. 100% |
| Maximum Aperture | F/2.8 (W) - F/6.9 (T) |
| Shutter Speed | 1 - 1/2000 Sec. 15 - 1/2000 Sec. (Total Shutter Speed Range) |
| Sensitivity | Auto, ISO 100/200/400/800/1600 (In P Mode)/6400 (In Low Light Mode) |
| Light Metering Method | Evaluative*1, Center-Weighted Average, Spot*2 *1 Facial Brightness Is Evaluated In Face Detect (Face Detect AE). *2 Fixed To Center. |
| Exposure Control Method | AE Lock |
| Exposure Compensation | +/-2 Stops In 1/3 Stop Increments (Not Available When Shooting Movies) |
| White Balance Control | Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom |
| Built In Flash | Auto, On, Slow Synchro, Off Facial Brightness Is Also Evaluated In Face Detect. |
| Flash Range | 1.6 - 9.8 Ft. (W), 3.9 - 6.6 Ft. (T) / 50cm - 3.0m (W), 1.2m - 2.0m (T) |
| Recycling Time | 10 Seconds Or Less (Battery Voltage: 3.7 V) |
| Flash Exposure Compensation | N/A |
| Shooting Modes | Auto, P, Live View Control, Digital IS, Portrait, Face Self-Timer, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Snow, Fireworks, Long Shutter - Shooting Movies Is Possible With The Movie Button. |
| Photo Effects | N/A |
| Self Timer | Approx. 10-Sec Delay/Approx 2-Sec Delay/Custom* * Delay Time (0 - 15 Sec. (In One-Second Increments), 20/25/30 Sec.) And Number Of Shots (1 - 10 Shots (In One-Shot Increments) Can Be Specified. |
| Wireless Control | N/A |
| Continuous Shooting | Approx: 0.8 Shots/Sec. (In P Mode) Approx. 2.9 Shots/Sec. (In Low Light Mode) |
| Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
| File Format | Design Rule For Camera File System, DPOF (Version 1.1) Compatible |
| Jpeg Compression Mode | Still Images: Exif 2.3 (JPEG) Movies: MOV (Image Data: H.264; Audio Data: Linear PCM (2 Channel Monoaural)) |
| Number Of Recording Pixels | Still Images: [Large]: 4608 X 3456 [Medium 1]: 3264 X 2448 [Medium 2]: 1600 X 1200 [Small]: 640 X 480 [Widescreen]: 4608 X 2592 * 2304 X 1728 When In Low Light Mode Movies: [Miniature Effect] 1280 X 720*1, 640 X 480*2 [Other Than The Above] 1280 X 720 (25 Fps), 640 X 480 (30 Fps*3) *1 Shooting: 5 Fps / 2.5 Fps / 1.25 Fps Playback: 25 Fps. *2 Shooting: 6 Fps / 3 Fps / 1.5 Fps Playback: 30 Fps*3 *3 Actual Frame Rate Is 29.97 Fps. |
| Content |
*When Shooting In Low Light • The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Content |
*1 Playback Frame Rate Is 25 Fps. *2 Playback Frame Rate Is 30 Fps*3. *3 Actual Frame Rate Is 29.97 Fps. • The Approximate Number Of Videos Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Playback Modes File | Still Images And Movies: Auto Rotate, Rotate, Search (Date, Movies, Still Images) Still Images: Single, Index (4-100 Thumbnails), Magnification (Approx. 2x-10x), Information Display (Histogram, Overexposure Warning), Resume Playback, Transition, Red-Eye Correction, I-Contrast, Resize, Photobook Set-Up Movies: Normal Playback*1, Pause, Slow Motion, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 - Displays Playback Position And Shooting Time *1 Audio Settings Available In 5 Levels *2 Approximately 4 Seconds *3 Rewind And Fast-Forward Are Also Available |
| Erase Modes | Single Image*, Erase All The Image Data In The Memory Card Stored With The Design Rule For Camera File Systems Format Can Be Erased (However, Protected Images Cannot Be Erased). * Movies Can Be Erased Individually. |
| Computer Interface | Hi-Speed USB (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video) |
| Video Out | NTSC/PAL (Unified Type Dedicated Connector (Female)) With Digital, Audio And Video |
| Audio Out | Monaural (Unified Type Dedicated Connector (Female)) With Digital, Audio And Video |
| Other | Memory Card Slot; Direct Connection To Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers And PictBridge-Compatible Printers Via Camera's USB 2.0 Hi-Speed Cable |
| Power Source | Rechargeable Lithium-Ion Battery NB-11L |
| Shooting Capacity Bp 511 | Normal: Approx. 220 Shots ECO Mode: Approx. 300 Shots |
| Playback Time Bp 511 512 | Approx. 5 Hours |
| Operating Temperature | 32-104°F/0-40°C |
| Operating Humidity | 10-90% |
| Dimensions W X H X D | 3.85 X 2.20 X 0.78 In. / 97.7 X 56.0 X 19.8mm |
| Weight | Approx. 4.23 Oz. / 120g (Body Only) Approx. 4.76 Oz. / 135g (CIPA Standard) |
imageRUNNER ADVANCE Platform Brochure
4.1 MB
imagePROGRAF iPF 750 755 650 655 Brochure
4.8 MB
imagePROGRAF iPF825/815 Brochure
4.3 MB
imagePROGRAF iPF 9400/8400/6450/6400 Brochure
7.9 MB
imagePROGRAF MPF M40 Brochure
5 MB
imagePROGRAF iPF765 /760 Brochure
3.3 MB
imagePROGRAF PRO-4000 / 2000 Brochure
277.6 MB
imagePROGRAF iPF 605/610/510/5100 Brochure
4.1 MB
imagePROGRAF iPF9400S Brochure
0.5 MB
imageRUNNER ADVANCE C7500i III Series Brochure
0.8 MB
imageRUNNER ADVANCE C5500i III Series Brochure
0.9 MB
imageRUNNER ADVANCE C3500i III Series Brochure
0.9 MB
imageRUNNER C1030 C1030iF Brochure
0.9 MB
imageRUNNER C3125i Data Sheet
0.5 MB
imageRUNNER ADVANCE C3300 Series Brochure
1.5 MB
imageRUNNER ADVANCE C5500i Series Brochure
4.6 MB
imageRUNNER C3025i Brochure
2.9 MB
imageRUNNER ADVANCE C475iF III Brochure
0.9 MB
Canon imageRUNNER ADVANCE C7500 Series Bro
1 MB
imageRUNNER ADVANCE DX C3700 Series Brochure
9.2 MB
PIXMA MG2410 Brochure
0.6 MB
Canon imageCLASS MF240 Series Spec Sheet
5.9 MB
PIXMA MG3510 Brochure
0.7 MB
PIXMA iX6510 Brochure
8.4 MB
iWEMC Accounting Management Plug-in Brochure
6.5 MB
Uniflow_5_4_Brochure.pdf
4.8 MB
EFI PrintMe Brochure
06.16.25
06.16.25
16.06.25
3.3 MB
imageWARE Secure Audit Manager Brochure
5.4 MB
imageWARE Scan Manager DS Brochure
3.2 MB
Cloud Portal imageRUNNER Brochure
4.2 MB
Canon Mobile Print Brochure
3.4 MB
imageWARE Document Server Brochure
4.3 MB
Authorized Send Lite Brochure
4.8 MB
AA-PRINT Brochure
10.7 MB
Object Generator for AS/400 Flyer
2.3 MB
uniFLOW Serverless Secure Print Brochure
2.2 MB
imageWARE EMC Brochure
4.2 MB
eCopy ShareScan Brochure
9.6 MB
Canon See Impossible ThereforeTM 2017 Product Brochure
2.2 MB
AA PROX Brochure
2.7 MB
PIXMA MG2510 Brochure
0.6 MB
PIXMA MX451 Brochure
1.9 MB
PIXMA Pro100 Brochure
2 MB
Color imageCLASS LBP712Cdn / LBP712Cx
3.9 MB
PIXMA MX391 Brochure
1.8 MB
PIXMA MG6410 Brochure
1.2 MB
imageCLASS MF419dw / MF416dw / MF414dw
4.3 MB
PIXMA MX721 Brochure
0.7 MB
PIXMA iP2700 Brochure
1.9 MB
PIXMA MX521 Brochure
0.7 MB
PIXMA MG7110 Brochure
1.2 MB
imageRUNNER ADVANCE C3300 Series Specs Sheet
0.6 MB
imageRUNNER ADVANCE C3300 Series Data Sheet
1.6 MB
imageRUNNER ADVANCE C5500 Series Spec Sheet
4.2 MB
Color imageRUNNER C1335iF/C1325iF Office Solutions
3.4 MB
imageRUNNER ADV C7200 Brochure
17.8 MB
imageRUNNER ADV C9200 Brochure
15.1 MB
Universal Login Manager Brochure
0.9 MB
Canon Therefore 2018 Product Brochure
3.1 MB
Therefore 2019 Brochure
2.1 MB
Therefore New Features
06.16.25
06.16.25
16.06.25
1 MB
Workflow Composer with MEAP Connector Brochure
3.1 MB
imageRUNNER ADV Desktop Brochure
3.4 MB
EOS Posibilidades Ilimitadas
3.5 MB
Especificaciones de los imageRUNNER ADVANCE 4500i III
0.5 MB
imageRUNNER 2630 Especificaciónes
0.3 MB
Especificaciones de los imageRUNNER ADVANCE 6500i III
0.4 MB
Hoja de especificaciones de la imageRUNNER ADVANCE C356i_C256i
0.5 MB
Hoja de especificaciones de la serie imageRUNNER ADVANCE C3500i III
0.5 MB
Hoja de especificaciones para la Serie imageRUNNER ADVANCE C7500i II
0.6 MB
Especificaciones de los imageRUNNER ADVANCE C5500i III
0.5 MB
Folleto de la Arizona 6100
0.8 MB
Folleto de la impresora Colorado 1640 de Océ
7.2 MB
Folleto de ColorWave 700
6.5 MB
Folleto de PlotWave 750
1.4 MB
Folleto de ColorWave 500
4.4 MB
Folleto de Océ PlotWave 450/550
7.3 MB
Folleto de Océ PlotWave 345/365
7.1 MB
Especificaciones de PlotWave 750
0.6 MB
Folleto de la Serie imageRUNNER ADVANCE 715iF II
0.4 MB
imageRUNNER 2202N Brochure
06.16.25
06.16.25
16.06.25
3.7 MB
Folleto de imageRUNNER ADV 8200
3.6 MB
Folleto de la Serie imageRUNNER ADVANCE DX 4700
7.5 MB
Folleto de los imageRUNNER ADVANCE 8500i IIII
0.8 MB
Folleto de imageRUNNER 1700 Series
1.4 MB
Folleto de imageRUNNER ADV 500i/iF-400i/iF
16 MB
Folleto de la serie imageRUNNER ADVANCE 1643
0.6 MB
Folleto de los imageRUNNER ADVANCE 4500i III
0.8 MB
Folleto de imageRUNNER 2530/2525/2521
1.3 MB
Folleto de imageRUNNER2422L
2 MB
Folleto para la Serie imageRUNNER ADVANCE 6500
0.4 MB
Folleto de imageRUNNER ADV 6200
4.1 MB
Folleto de imageRUNNER 2545/2545i/2535/2535i
1.3 MB
Folleto de la serie imageRUNNER 1400
2.1 MB
Folleto de imageRUNNER ADV 4000
1.8 MB
Folleto de los imageRUNNER ADVANCE 6500i III
0.7 MB
imageRUNNER 2630
0.3 MB
Folleto para la Serie imageRUNNER ADVANCE 8500
0.9 MB
Folleto de Serie imageRUNNER 1435+
1.9 MB
Serie WG7100 Impresoras comerciales de inyección de tinta
4 MB
Folleto de Canon imageCLASS LBP162dw
0.5 MB
Folleto imageRUNNER ADVANCE C5235A / C5240A
13.7 MB
Folleto de la imageCLASS LBP35X
3 MB
Folleto de Color imageCLASS LBP62X
7.2 MB
Folleto de imageCLASS MF419dw/MF416dw/MF414dw
4.1 MB
Folleto de la imageCLASS LBP214dw de Canon
5.7 MB
imageCLASS MF445dw Brochure
5.1 MB
imageCLASS LBP253dw/LBP253x Folleto
2.9 MB
Folleto de imageCLASS MF426dw/424dw
6.8 MB
Folleto de la imageCLASS LBP215dw
6.2 MB
Hoja de especificaciones de la Color imageCLASS LBP312dn de Canon
9.2 MB
imageCLASS LBP6030w Folleto
1 MB
Folleto de la imageCLASS LBP664Cdw
7.9 MB
imageCLASS MF449dw/MF449x
6.8 MB
Folleto de Color imageCLASS MF746
7.2 MB
Folleto de Color imageCLASS MF64X
8.1 MB
Folleto de imageCLASS MF264dw/MF269dw
7.1 MB
Hoja de especificaciones de la Color imageCLASS LBP612Cdw de Canon
6.5 MB
imageCLASS LBP228dw/LBP228x
5.9 MB
Folleto de imageCLASS MF113w
3.1 MB
Hoja de especificaciones de la Color imageCLASS LBP654Cdw de Canon
7.2 MB
Folleto Color imageCLASS LBP7110Cw
1.6 MB
Folleto Color imageRUNNER LBP5480
4.8 MB
Folleto de imageCLASS MF4770n/MF4870dn/MF4890dw
7.3 MB
Folleto de la imageCLASS MF429dw
6.4 MB
91928_iR1025Bro
0.5 MB
imageCLASS LBP226dw
3.4 MB
Folleto de imageCLASS MF525dw
6.5 MB
G2110/G2610 Getting Started
4.9 MB
G3000 Getting Started 1
1.9 MB
PIXMA iP7210 Para Começar
4 MB
TS3100/E3100 Getting Started
4.8 MB
MG7700 Getting Started 1
1.6 MB
MG3600 Getting Started 1
1.7 MB
TS6100 Getting Started
5.9 MB
MG5700 Getting Started 1
1.7 MB
TS200/E200 Getting Started
0.9 MB
TS5100 Getting Started
6.1 MB
MG6800 Getting Started 1
1.7 MB
MB5400/MB5100/MB2700 Getting Started 1
1.9 MB
PIXMA PRO-10 Para Começar
4.1 MB
G4000 Getting Started
10.5 MB
TS8000 Getting Started
5.6 MB
MB2100 Getting Started 1
1.6 MB
E300 Getting Started
5.7 MB
G1000 Getting Started 1
1.9 MB
iP110 Getting Started 1
2.3 MB
iB4100 Getting Started 1
1.7 MB
G3110/G3610 Getting Started
6.4 MB
MX490/E480 Getting Started 1
1.6 MB
G4110 Getting Started
6.5 MB
G1110 Getting Started
4.9 MB
iP8700 Getting Started
2.4 MB
PRO-1000 Getting Started 1
2.1 MB
iX6800 Getting Started
2.5 MB
new
0.8 MB
GUFRII Driver V2.15 (32-bit)
16.7 MB
EOS Unlimited Possibilities (Spanish Only)
06.16.25
06.16.25
16.06.25
3.5 MB
imageRUNNER ADVANCE 4500 III Spec Sheet
0.6 MB
imageRUNNER 2630 Specifications
0.4 MB
imageRUNNER ADVANCE C6500i III Series Spec Sheet
0.5 MB
imageRUNNER ADVANCE C356i_C256i SpecSheet
0.4 MB
imageRUNNER ADVANCE C3500i III Series Spec Sheet
0.6 MB
imageRUNNER ADVANCE C7500i II Series Spec Sheet
0.6 MB
imageRUNNER ADVANCE C5500 III Series Spec Sheet
0.6 MB
Arizona 6100 Brochure
0.2 MB
Océ Colorado 1640 Printer Brochure
7.2 MB
ColorWave 700 Brochure
6.5 MB
PlotWave 750 Brochure
1 MB
ColorWave 500 Brochure
4.4 MB
Océ PlotWave 450/550 Brochure
7.3 MB
Océ PlotWave 345/365 Brochure
7.1 MB
PlotWave 750 Specifications
0.3 MB
imageRUNNER ADVANCE 715iF III Series Brochure
0.8 MB
4.1 MB
imageRUNNER ADV 8200 Brochure
3.5 MB
imageRUNNER ADVANCE DX 4700 Series Brochure
7.7 MB
imageRUNNER ADVANCE 8500i II Series Brochure
0.9 MB
imageRUNNER ADV 500i/iF-400i/iF Brochure
2.9 MB
imageRUNNER 1643 Series Brochure
0.6 MB
imageRUNNER ADVANCE 4500i III Brochure
0.8 MB
imageRUNNER 2530/2525/2520 Brochure
1.3 MB
imageRUNNER ADVANCE 6500 Series Brochure
0.4 MB
imageRUNNER ADV 6200 Brochure
4.1 MB
imageRUNNER 2545/2545i/2535/2535i Brochure
1.3 MB
iR1400 Series brochure
2 MB
imageRUNNER ADV 4000 Brochure
1.9 MB
imageRUNNER ADVANCE 6500i III Brochure
0.7 MB
imageRUNNER 2630
0.3 MB
imageRUNNER ADVANCE 8500 Series Brochure
0.9 MB
imageRUNNER 1435+ Series Brochure
1.9 MB
WG7100_Brochure.pdf
11.8 MB
folleto de PIXMA MG2510
0.7 MB
Folleto de PIXMA MG2410
0.7 MB
Folleto de PIXMA MX451
0.8 MB
Folleto de PIXMA Pro100
0.9 MB
3.9 MB
Folleto de PIXMA MX391
0.7 MB
Folleto de PIXMA MG6410
1.2 MB
Hoja de especificaciones para la serie imageCLASS MF240 de Canon
6 MB
4.1 MB
Folleto de PIXMA MX721
0.8 MB
Folleto de PIXMA iP2700
1.9 MB
Folleto de PIXMA MX521
0.8 MB
Folleto de PIXMA MG3510
0.7 MB
Folleto de PIXMA MG7110
1.2 MB
Folleto de PIXMA iX6510
9.2 MB
Folleto de la imagePROGRAF iPF8400SE/6400SE de Canon
4.4 MB
Folletos imagePROGRAF iPF830/840/850
3.2 MB
Folleto de imagePROGRAF iPF 750/755/650/655
4.8 MB
Folleto de imagePROGRAF iPF785/780/685/680
2.4 MB
imageFORMULA PRO-6100S / 4100S
4.9 MB
Folleto de imagePROGRAF iPF825/815
4.3 MB
Folleto de la imagePROGRAF TX
14.9 MB
iPF_Le_Series_Brochure.pdf
3.4 MB
folleto de imagePROGRAF iPF 9400/8400/6450/6400
7 MB
Folleto de la imagePROGRAF PRO-4000/2000
46.8 MB
Folleto de imagePROGRAF MPF M40
5.1 MB
Folleto de imagePROGRAF iPF 765/760
3.4 MB
Folleto de la Serie imagePROGRAF TM
4 MB
Folleto de serie imagePROGRAF PRO-4000 / 2000
2.5 MB
Folleto de imagePROGRAF iPF 605/610/510/5100
4.1 MB
Hoja de especificaciones de TA 20
0.4 MB
Hoja de especificaciones de TA 30
5 MB
Folleto de imagePROGRAF iPF770/670
2.4 MB
Folleto de imagePROGRAF iPF 9400S
3.7 MB
Datos de la Serie imageRUNNER ADVANCE C3300
1.6 MB
Hoja de Especificaciones de la Serie imageRUNNER ADVANCE C5500
4.2 MB
Color imageRUNNER C1335iF/C1325iF Soluciones Para Oficina
2.1 MB
Folleto de imageRUNNER ADV C7200
17.9 MB
Folleto de imageRUNNER ADV C9200
15 MB
imageFORMULA ScanFront 330 Brochure
0.4 MB
DR2020UBro
0.7 MB
DR2020UBro
0.3 MB
DR2020UBro
0.4 MB
imageFORMULA DR-M1060 Brochure
1.8 MB
imageFORMULA DR-M160II Brochure
0.7 MB
Layout 1
2.2 MB
Canon imageFORMULA CR-L1 Brochure
0.8 MB
Canon imageFORMULA CR-150 Compact Check Transport Brochure
5.8 MB
Canon imageFORMULA ScanFront 400 Brochure
1 MB
iF DR-C130
0.3 MB
Canon imageFORMULA DR-C230 Brochure
4.4 MB
imageFORMULA DR-C240 Brochure
1.3 MB
Layout 1
3.6 MB
Canon imageFORMULA DR-C255 II/C255W II Brochure
6.4 MB
DR2020UBro
0.4 MB
imageFORMULA DR-6010C Brochure
3.5 MB
DR2020UBro
0.4 MB
Layout 1
0.4 MB
imageFORMULA DR-F120 Brochure
0.6 MB
imageFORMULA DR-G1100 Brochure
1.1 MB
Canon imageFORMULA DR-S150 Scanner Brochure
1.1 MB
imageFORMULA P-215II Brochure
1.1 MB
Layout 1
0.4 MB
DR2020UBro
0.4 MB
imageFORMULA DR-C225 Brochure
0.6 MB
Canon imageFORMULA DR-G2090 USB Brochure
4.2 MB
DR2020UBro
2.3 MB
Canon imageFORMULA DR-G2110 Brochure
4.3 MB
Canon imageFORMULA DR-G2140 Brochure
3.9 MB
DR-X10C Brochure
1 MB
imageFORMULA P-201 Brochure
1.4 MB
imageFORMULA P-208II Brochure
0.8 MB
Canon imageFORMULA CR-120 Compact Check Transport Brochure
3.2 MB
imageFORMULA P-208 Brochure
1.2 MB
Canon imageFORMULA DR-M260 Brochure
3.8 MB
imageFORMULA CR-190i-II Brochure
0.5 MB
imageFORMULA DR-G1130 Brochure
1.5 MB
Canon imagePROGRAF iPF8400SE/6400SE Brochure
4.4 MB
imagePROGRAF iPF770/670 Brochure
2.4 MB
imagePROGRAF iPF785/780/685/680 Series Brochure
2.4 MB
imagePROGRAF PRO6100S/4100S Brochure
4.9 MB
imagePROGRAF TX Brochure
15.6 MB
Canon See Impossible iPF MFP Le Series Brochure
3.4 MB
imagePROGRAF PRO-4000/2000 Brochure
46.8 MB
imagePROGRAF TM Series Brochure
4.9 MB
imagePROGRAF iPF830/840/850 Brochure
3.2 MB
TA 20 Spec Sheet
2.5 MB
TA 30 Spec Sheet
5 MB
LBP5280/7680x Brochure
5.4 MB
imageCLASS MF8580Cdw / MF8280Cw Brochure
3.9 MB
LBP3480/6680x Brochure
5.4 MB
Layout 1
0.9 MB
Canon imageCLASS LBP162dw Brochure
0.5 MB
13.7 MB
imageCLASS LBP35X Brochure
5.2 MB
Canon imageCLASS LBP622Cdw Brochure
7.3 MB
imageCLASS MF419dw/MF416dw/MF414dw Brochure
4.3 MB
Canon imageCLASS LBP214dw Brochure
6.5 MB
5.1 MB
imageCLASS MF426dw/424dw Brochure
7.5 MB
imageCLASS LBP215dw Brochure
6.2 MB
LaserShot LBP6300 Brochure
0.3 MB
Canon Color imageCLASS LBP312dn Spec Sheet
9.5 MB
LBP3580 LBP6780x Brochure
5 MB
imageCLASS LBP6030w Brochure
1 MB
imageCLASS LBP664Cdw Brochure
7.9 MB
95357_Brochure_r2.qxd:Layout 1
1.5 MB
imageCLASS MF449dw Brochure
6.8 MB
imageCLASS MF746Cdw Brochure
8 MB
imageCLASS MF644Cdw Brochure
8.1 MB
imageCLASS MF269dw/MF267dw/MF264dw Brochure
7.2 MB
Canon Color imageCLASS LBP612Cdw Spec Sheet
7.3 MB
imageRUNNER ADVANCE C250iF / C350iF Brochure
12.5 MB
imageCLASS LBP228dw Brochure
6.7 MB
Canon imageCLASS MF113 Brochure
6.4 MB
LaserShot LBP6200d Brochure
0.3 MB
LaserShot LBP6000 Brochure
0.2 MB
Canon Color imageCLASS LBP654Cdw Spec Sheet
7.3 MB
Color imageCLASS LBP7110Cw Brochure
0.5 MB
Color imageRUNNER LBP5480 Brochure
4.8 MB
imageCLASS MF4770n/MF4870dn/MF4890dw Brochure
3.6 MB
imageCLASS MF429dw Brochure
6.4 MB
imageCLASS LBP253dw/LBP253x Brochure
2.9 MB
iR1025_eng
0.9 MB
Canon imageCLASS LBP226dw Brochure
2.5 MB
imageCLASS MF525dw Brochure
7.3 MB
imageRUNNER 1700 Series Brochure
1.6 MB
imageRUNNER 2422L Brochure
2.9 MB
imagePASS A2/B2 Brochure
3.8 MB
ColorPASS-GX400 Brochure
7.3 MB
imagePRESS C1+II Brochure
11.9 MB
imagePRESS C65 Brochure
1 MB
imagePRESS 1135 /1125 /1110 Brochure
7.1 MB
imagePRESS C7010VP Brochure
18.4 MB
varioPRINT 135/120/110 Monochrome Digital Press Brochure
14.2 MB
Canon imagePRESS Lite C165 Brochure
2.9 MB
imagePRESS C910 Brochure
2 MB
Digital Color Production Press - imagePRESS C10000VP/C8000VP
12.4 MB
varioPRINT 140/130/115 Brochure
2.3 MB
Océ VarioPrint 6000 TITAN Series Brochure
2.1 MB
Canon imagePRESS C650 Brochure
1.2 MB
iPC800_C700 Brochure
15.7 MB
Canon imagePRESS C850 and C750 Brochure
2.1 MB
imageRUNNER ADV C5200 Brochure
17.4 MB
imageRUNNER ADV C2200 Brochure
15.5 MB
BB-125_CANON_L90_SpecSheet
0.8 MB
Folleto de iWEMC Accounting Management Plug-in
6.3 MB
Uniflow_5_4_BrochureSPA.pdf
4.7 MB
Folleto de EFI PrintMe
3.3 MB
Folleto de imageWARE Secure Audit Manager
5.2 MB
Folleto de imageWARE Scan Manager DS
3.2 MB
Folleto de Universal Login Manager
0.9 MB
Folleto de Cloud Portal imageRUNNER
4.3 MB
Folleto de A-Send
1.1 MB
Folleto de Canon Mobile Print
3.4 MB
Folleto de uniFLOW Online de Canon
4.3 MB
folleto de imageWARE Document Server
4.3 MB
Folleto de Authorized Send Lite
4.3 MB
Folleto del producto de Therefore 2018 de Canon
5.4 MB
Folleto de Therefore 2019
2.1 MB
folleto de AA-PRINT
10.7 MB
Object Generator
2.2 MB
Nuevas funciones de Therefore
1 MB
Folleto de uniFLOW Serverless Secure Print
2.3 MB
Folleto de Workflow Composer with MEAP Connector
3.1 MB
Folleto de imageWARE EMC
4.2 MB
Folleto de eCopy PDF Pro Office
1.1 MB
Folleto de imageRUNNER ADV Desktop
3.4 MB
Folleto de eCopy ShareScan
9.6 MB
Folleto del producto de Therefore 2017, Vea más allá de lo imposible con Canon
2 MB
folleto de AA PROX
2.7 MB
Folleto imageFORMULA ScanFront 330
0.5 MB
DR2020UBro
0.4 MB
DR2020UBro
0.3 MB
DR2020UBro
0.4 MB
Folleto imageFORMULA DR-M1060
0.7 MB
Folleto imageFORMULA DR-M160II
0.7 MB
Folleto de imageFORMULA CR-80
0.7 MB
Folleto de imageFORMULA CR-L1 de Canon
0.8 MB
Folleto del dispositivo compacto para el transporte de cheques imageFORMULA CR-150 de Canon
5.5 MB
Folleto de la imageFORMULA ScanFront 400 de Canon
3.5 MB
DR2020UBro
2.4 MB
Folleto de imageFORMULA DR-C230 de Canon
3.8 MB
Folleto de imageFORMULA DR-C240
1.3 MB
Layout 1
3.6 MB
Folleto del imageFORMULA DR-C255 II/C255W II de Canon
6.2 MB
DR2020UBro
0.4 MB
DR2020UBro
0.4 MB
Layout 1
0.4 MB
Folleto imageFORMULA DR-F120
0.6 MB
Folleto imageFORMULA DR-G1100
1.1 MB
Folleto del escáner imageFORMULA DR-S150 de Canon
0.6 MB
imageFORMULA DR-6010C Folleto
3.4 MB
imageFORMULA P-215II Folleto
1.1 MB
Folleto de imageFORMULA CR-50
0.7 MB
DR2020UBro
0.4 MB
Folleto imageFORMULA DR-C225
0.6 MB
Folleto del imageFORMULA USB DR-G2090 de Canon
3.5 MB
DR2020UBro
2.3 MB
Folleto de imageFORMULA DR-C2110 de Canon
3.9 MB
Folleto de imageFORMULA DR-G2140 de Canon
3.9 MB
Folleto imageFORMULA DR-X10C
2.4 MB
Folleto de serie imageFORMULA P-201
1.4 MB
Folleto imageFORMULA P-208II
0.7 MB
Folleto del dispositivo compacto para el transporte de cheques imageFORMULA CR-120
3.3 MB
Folleto de imageFORMULA P-208
1.2 MB
Folleto de imageFORMULA DR-M260 de Canon
3.4 MB
Folleto de imageFORMULA CR-190i II
0.5 MB
folleto de imageFORMULA DR-G1130
1.4 MB
Folleto de la plataforma imageRUNNER ADVANCE
4.5 MB
Folleto de imagePASS A2/B2
3.6 MB
Folleto de ColorPASS-GX400
7.4 MB
Folleto de imagePRESS C1+II
6.5 MB
Folleto de la imagePRESS C65
0.8 MB
Folleto de imagePRESS 1135 /1125/1110
7.4 MB
Folleto de imagePRESS C7010VP
18.2 MB
Folleto de la imprenta digital monocromática varioPRINT 135/120/110
13.8 MB
Folleto de la imagePRESS Lite C165 de Canon
2.8 MB
Folleto de la imagePRESS C910/C810/C710
2 MB
Imprentas Digitales de Producción en Color - imagePRESS C10000VP/C8000VP
12.5 MB
Folleto de varioPRINT 140/130/115
2.2 MB
Folleto de la Serie VarioPrint 6000 TITAN de Océ
2.1 MB
Folleto de la imagePRESS C650 de Canon
1.1 MB
imagePRESS C800/C700 Folleto
15.7 MB
Folleto de la imagePRESS C850 y C750 de Canon
2.6 MB
Folleto de la serie imageRUNNER ADVANCE C7500i III
0.9 MB
Especificaciones de la Serie imageRUNNER ADVANCE C3300
0.4 MB
Folleto de los imageRUNNER ADVANCE C5500i III
0.8 MB
Folleto de la serie imageRUNNER ADVANCE C3500i III
0.8 MB
folleto de imageRUNNER C1030 C1030iF
1 MB
imageRUNNER C3125i
0.5 MB
Folleto de la serie imageRUNNER C3300
1.6 MB
Folleto de la Serie imageRUNNER ADVANCE C5500i
4.6 MB
Folleto de imageRUNNER C3025i
0.7 MB
Folleto Serie iR ADVC 4200
15.6 MB
El folleto de la serie imageRUNNER ADVANCE C475iF III
0.7 MB
Folleto para la Serie imageRUNNER ADVANCE 4200
15.6 MB
Folleto de la Serie imageRUNNER ADVANCE C7500 de Canon
0.9 MB
Folleto de serie imageRUNNER ADV C5200
17.4 MB
folleto de imageRUNNER ADV C2200
15.5 MB
Folleto de la Serie imageRUNNER ADVANCE DX C3700
9.1 MB
Folleto de LBP5280/7680x
5.4 MB
Folleto de imageCLASS MF8580Cdw/MF8280Cw
4 MB
Folleto de LaserShot LBP6300
0.3 MB
folleto de LBP3580 LBP6780x
5 MB
Folleto imageRUNNER ADVANCE C250iF / C350iF
15.3 MB
folleto de LaserShot LBP6200d
0.3 MB
Folleto de LaserShot LBP6000
0.2 MB
Folleto de LBP3480/6680x
4.7 MB
Layout 1
0.9 MB
