Firmware Notice: Canon 4K Camcorder VIXIA/LEGRIA GX10 Firmware Version 1.0.2.0
| Thank you for using Canon products. Phenomenon Changes in the Firmware Firmware Version 1.0.2.0 incorporates the following fixes:
Affected Products
Support Download Firmware Version 1.0.2.0 for VIXIA GX10 camcorder. Preparations for a firmware update: After the firmware update has been performed, the camera's menu settings will be reset. It is recommended that users save their menu settings as settings data to an SD card, separate from the one that will be used to carry out the update, before starting update operations. This saved data can be loaded into the camera and the settings can be changed after the update has been completed. For further information on this, please refer to the section in the unit's Instruction Manual titled "Saving and Loading Camera Settings". The downloaded folder contains the firmware (file name: VNA2.FIM / file size: 29,818,912 bytes), and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish and Simplified Chinese). Before starting the firmware update operations, please be sure to carefully confirm your understanding of these instructions. The following items are required to perform this firmware update:
Changes in Firmware Version 1.0.1.0.
Should you have any questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region. |
