Thank you for using Canon products. Phenomenon Firmware Version 2.0.0 incorporates the following fixes and improvements:
- Fixes a phenomenon in which, in rare cases, the signal acquisition indicator on the GPS Receiver GP-E2 displays “Slow blinking (Signal acquired)” even if a signal is not yet acquired.
- Fixes a phenomenon in which new log files may not be saved correctly if the built-in memory of the GPS Receiver GP-E2 becomes full.
- Support for the EOS Rebel T6s / EOS 760D and EOS Rebel T6i / EOS 750D cameras has been added.
- Support for the EOS 5Ds and EOS 5Ds R cameras has been added.
Firmware Version 2.0.0 is for GPS Receiver GP-E2 with firmware up to Version 1.0.9. If the GPS Receiver GP-E2’s firmware is already Version 2.0.0 or Version 2.0.1, it is not necessary to update the firmware. Affected Products
Support When updating the firmware of the GPS Receiver GP-E2, please review the instructions thoroughly before you download the firmware. Please note: To update the firmware of this product, Canon’s Map Utility software that is bundled with GPS Receiver GP-E2 is required. Furthermore, before updating the firmware, use Map Utility to save any GPS log files in the GP-E2’s built-in memory to your computer. After the GPS log files are saved to your computer, make sure to delete the log files from the built-in memory of the GPS Receiver GP-E2 before updating the firmware. Contact Information Should you have any questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region. |
