Safety Notice: Caution When Using Color Filter Holder SCH-E1 with Canon Speedlite 600EX / 600EX-RT
| To Users of Canon Speedlite 600EX / 600EX-RT “Caution When Using Color Filter Holder SCH-E1” (Workaround When Low Battery Icon Appears and Speedlite Does Not Start) Thank you for using Canon products. Affected Product Speedlite 600EX / 600EX-RT Phenomenon When the flash is powered on with the bundled Color Filter Holder SCH-E1 already attached, there are instances where the low battery icon appears and the flash does not power on, even if the batteries have sufficient power. Workaround When the phenomenon described above occurs, follow the procedure below: 1. Detach the Color Filter Holder SCH-E1 2. Power on the flash 3. Re-attach the Color Filter Holder SCH-E1 If the phenomenon still occurs after the above workaround has been performed, please contact your nearest Canon service center. Contact Information for Inquiries Should you have questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region. |
