Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Updated: June 20, 2025
Thank you for using Canon products.
Canon U.S.A., Inc. has recently become aware of potential multiple buffer overflow vulnerabilities in the Canon Laser Printers and Small Office Multifunctional Printers listed under “Affected Models” below.
If the product is connected directly to the Internet without using a wired or Wi-Fi router, a third party could potentially execute arbitrary code or the product could be subjected to a Denial-of-Service (DoS) attack.
Listed below are the CVE numbers associated with the potential Buffer Overflow issue:
  • CVE-2024-12647
  • CVE-2024-12648
  • CVE-2024-12649
  • CVE-2025-2146 (added May 23, 2025)
Affected Products
imageCLASS MF Series
  • imageCLASS MF656Cdw*
  • imageCLASS MF654Cdw*
  • imageCLASS MF653Cdw*
  • imageCLASS MF652Cw*
  • imageCLASS MF465dw**
  • imageCLASS MF462dw**
  • imageCLASS MF455dw
  • imageCLASS MF453dw
  • imageCLASS MF452dw
  • imageCLASS MF451dw
  • imageCLASS MF1643iF II
  • imageCLASS MF1643i II
  • imageCLASS MF1440**
  • imageCLASS MF1238 II
imageCLASS LBP Series
  • imageCLASS LBP633Cdw*
  • imageCLASS LBP632Cdw*
  • imageCLASS LBP237dw
  • imageCLASS LBP236dw
  • imageCLASS LBP247dw**
  • imageCLASS LBP246dw**
  • imageCLASS LBP1440**
  • imageCLASS LBP1238 II
* Models Added May 2025
** Models Added June 2025
Note: If we determine that additional products could potentially be impacted by this matter, we will issue an updated Service Notice.
Mitigation/Remediation:
We recommend that our customers set a private IP address for the products and create a network environment with a firewall or wired/Wi-Fi router that can restrict network access.
Please refer here for more details on securing products when connecting to a network.
In addition, we advise that our customers install the latest firmware available using the instructions below.
To update the firmware via the Internet, take the following steps from the printer unit:
<Touch Panel Model>
  1. Select [Update Firmware] on the Home screen.
  2. When a license screen appears, select [Accept].
  3. Select [OK].
<Black and White LCD Model>
  1. Select [Menu] on the Home screen.
  2. Select [Management Settings].
  3. Select [Remote UI Settings/Update Firmware] > [Update Firmware].
  4. Select [Via Internet].
  5. Check the message and select [Yes].
  6. When a license screen appears, press [OK].
  7. Select [OK].
For more information, please refer to the "Updating the Firmware" section in the product’s User Manual.
Contact Information
Should you have any questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region.
GET PRODUCTS
WHERE TO BUY
PRODUCT SUPPORT
GET SERVICE
SERVICE LOCATOR
