Firmware Update: EOS M50 Mark II Firmware Version 1.0.1
| Thank you for using Canon products. Affected Products EOS M50 Mark II Support Changes in firmware: The firmware (version 1.0.1) incorporates the following fix:
Preparations for the Firmware Update: In the folder you downloaded are the firmware (CCF27101.FIR / file size: XX,XXX,XXX bytes) and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish, and Simplified Chinese). Before starting the firmware update operations, please be sure to check the procedure in accordance with the instruction. Contact Information Should you have any questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region. |
