EOS M50 Mark II
- EOS M50 Mark II Body
- Camera Cover R-F-4
- EF-M 15-45mm f/3.5-6.3 IS STM
- Lens Cap E-49
- Lens Dust Cap EB
- Strap EM-200DB
- Battery Charger LC-E12
- Battery Pack LP-E12
- Terminal Cover
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The EOS M50 Mark II carries and builds on the strong performance of the popular EOS M50 with improvements that will be especially notable for content creators like vloggers and more. You still get the impressive image quality of the 24.1 Megapixel CMOS sensor, power of the DIGIC 8 image processor, 4K UHD 24p and HD 120p for slow motion video and more, along with some additional boosts. The autofocus locks onto the subject faster, and Eye Detection is improved so it recognizes the eyes and face further away. Eye Detection can now even be used during video with Movie Servo AF, and you can use both Eye and Face Detection during Servo AF. What you get is added versatility and stability to keep the subject(s) in focus and as the center of attention. For content creators, you can use the EOS M50 Mark II to livestream your content with built-in Wi-Fi®, and use with EOS Webcam Utility software for an easy webcam alternative. When a different angle is needed, you can shoot vertically in addition to horizontally, and the camera even offers clean HDMI output for high-resolution, high frame-rate streaming. When it comes to content, whether stills or video, the EOS M50 Mark II goes far beyond letting you just scratch the surface of your vision.
The EOS M50 Mark II features a powerful 24.1 Megapixel CMOS (APS-C) sensor that can capture high-resolution images and 4K videos. The large CMOS sensor utilizes a sophisticated light-capturing design, helping to shoot images and videos with reduced noise, delivering clear, detailed results even in low light. It also enables fast continuous shooting and fast autofocus for high-speed performance that helps you capture once-in-a-lifetime moments.
Helping to improve autofocus performance, the EOS M50 Mark II features the DIGIC 8 Image Processor, which also ensures that your photos and videos look sharp and detailed with minimal noise or grain, in virtually any lighting. Combined with the Auto Lighting Optimizer, it also helps analyze the image and helps minimize blown-out areas by maintaining color and detail in bright parts of a photo. When set to High, it can even smooth the transitions between colors, assisting you to take impressively lifelike images.
Dual Pixel CMOS AF provides fast, accurate autofocus that helps you get the photo you want right as the moment happens. The EOS M50 Mark II features an expansive focus area of approx. 88% horizontal and 100% vertical^sup>1. With the EOS M50 Mark II, you can easily capture your subject quickly with the improved Eye Detection AF – allowing you to shoot even when the subject is far away. Eye Detection AF can also be used when the subject's full body is in frame, to lock on the eyes from a further distance.
^1 The max AF area available when the following lenses are attached: EF-M 55-200mm f/4.5-6.3 IS STM, EF-M 18-150mm f/3.5-6.3 IS STM, EF-M 28mm f/3.5 Macro IS STM, EF-M 32mm f/1.4 STM and some EF/EF-S lenses. When other lenses are attached, the AF area becomes smaller.
4K UHD* 24p Videos
With the help of the DIGIC 8 image processor, and the 24.1 Megapixel CMOS (APS-C) sensor, enjoy recording 4K movies at a frame rate of up to 24p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can be created in 4K simply and easily with the dedicated Time-lapse Movie mode.
HD 120p** Videos
Ideal for smooth, slow-motion playback videos, HD movies can also be recorded at a high-frame rate of approx. 120 frames per second. Designed to capture fun, beautiful videos, the EOS M50 Mark II camera helps ensure you can see the unique expressions of your friends' or family's faces in close-up movies.
The EOS M50 Mark II camera features a 3.0-inch, 1.04 Megapixel Clear View LCD II Vari-angle Touchscreen LCD. Brightness is adjustable and its extensive flexibility makes it easy to compose and shoot from virtually any angle, making selfies simple and enabling the LCD to fold away when not in use. Touchscreen features include quickly changing settings, reviewing stills and videos, and even AF point selection.
Vertical Video
Ideal for the vlogger guru, the EOS M50 Mark II’s Vertical Video feature*1 allows you to mix up your shot length and angles to make your videos interesting and unique.
*1 Vertical Video Support is available for playback on the following compatible smart devices: iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Vertical Video Support is not available when utilizing the live streaming service available with this product (on YouTube only).
Movie Self-Timer with Touch Record Control
Enjoy creating videos without fumbling to get out of the shot or racing to get into the shot when you press the record button with the EOS M50 Mark II’s Movie-self timer function and [Touch Rec] icon. This feature allows you to select how many seconds (between 2 to 10 seconds) you will need before your video starts to record so you ensure you get the scene and subjects needed in the shot, for the shot.
Movie Digital Zoom
he EOS M50 Mark II supports movie digital zoom, which allows you to magnify the center part of the screen about 3-10 x*2, and shoot for a more intense, up-close look at the subject – not only with a single focal length lens attached, but also with a zoom lens, that may be combined with optical zoom.
*2 Available when the image size is set to Full HD [1920×1080]. Camera shake may happen when handheld; it is recommended to use a tripod.
Clean HDMI Output
Whether you're creating inspiring video clips or capturing special occasions, the advanced video capabilities of the EOS M50 Mark II camera can catch them in the quality they deserve. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera's HDMI output. It is even possible to choose movie output without any information displayed on your screen.
Live Streaming Capable***
Live streaming service*** from the EOS M50 Mark II camera to YouTube™ is now possible. Share must-see moments as they happen directly from the setting that you are in. Whether you are at a concert, or want to vlog your next beauty “how to” video, the compact sized EOS M50 Mark II can help ensure that your videos will have the cinematic image quality you desire.
*** The live streaming service available with this product is for live streaming on YouTube only. To use live streaming, you need to have an active YouTube account and an image.canon account. Please be aware that YouTube may change, stop, or terminate its services, including live streaming, at any time without notice. In accordance with YouTube’s "Restrictions on live streaming" users must have a minimum of 1,000 channel subscribers in order to live stream from a mobile device (including camera products with live streaming capability). For up-to-date information from YouTube on restrictions, please visit https://support.google.com/youtube/answer/2853834?hl=en. Canon makes no representations or warranties with respect to any third party product or service, including live streaming.
Built-in 2.36 Million Dots OLED EVF
The EOS M50 Mark II camera features a high-precision 0.39-inch OLED (Organic Light-Emitting Diode) EVF with approx. 2.36 million dots. The electronic viewfinder (EVF) provides a bright, sharp and colorful 100% view of the subject at hand. Equipped with an aspherical lens, the EVF shows a crisp and vivid image with minimal distortion, even when the eye moves off the center of the visual field.
Touch and Drag AF
In addition to the Touch and Drag AF feature, the [Tap to select for Face+Tracking] function now makes it fast and easy to select a focus point by simply tapping on the desired location on the LCD screen to instantly change it. The chosen AF point is then displayed in the camera's EVF for quick confirmation.
Built-in Wi-Fi^ Technology
The EOS M50 Mark II camera is designed to make connecting to a Wi-Fi®^ network fast and easy. It can exchange data with other Wi-Fi® connected compatible Canon cameras, and transfer files directly to a compatible smart device using the Camera Connect app. The Wi-Fi® capability lets you share and upload directly to various web services like image.canon, Facebook® and YouTube® as well as print directly to compatible wireless Canon printers.
Built-in Bluetooth®^^ Capability
Bluetooth®^^ pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. To customize the Bluetooth® function, simply click on the network icon located on the LCD screen. In addition, Bluetooth® lets you connect to the optional Wireless Remote Control BR-E1 for remote shooting as well as pick up GPS shooting location data from the user’s compatible smartphone while using the GPS receiver GP-E2.
image.canon is a cloud service designed to ease your imaging workflow. Connecting the EOS M50 Mark II camera to the image.canon service will allow you to seamlessly upload all images and movies in their original format and quality, and access them from the dedicated app or through a web browser and automatically forward them to a computer, mobile device, and third-party services.
Whether you are at your child’s school play or your newborn baby is sleeping, the EOS M50 Mark II camera’s Silent Mode helps you make sure that your camera doesn't startle your subject by enabling capture with virtually no shutter sound. This means you can shoot precious moments without worrying about distracting them.
To use the Live Streaming function, your camera will need firmware version 1.0.3 or later.
* Shooting at 23.98p is possible. Shooting takes place by cropping pixels from the center of the sensor. Contrast detection AF is used. 4K movies are cropped.
** AF is fixed. Playback is 1/4 slow motion playback (29.97p).
^ Compatible with iOS® versions 12.4/13.7, Android™ smartphone and tablet versions 6.0/7.0/7.1/8.0/8.1/9.0/10. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
^^ Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen.or later) equipped with Bluetooth® version 4.1 or later and the Camera Connect App Ver. 2.5.10. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
| Type | Digital Single-Lens Non-Reflex AF/AE Camera With Built-In Flash Image Processor |
| Recording Medium | SD/SDHC/SDXC Memory Cards &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp;• UHS-I Compatible |
| Compatible Lenses | Canon EF-M Lens Group &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp;• Using Mount Adapter EF-EOS M: Canon EF Or EF-S Lenses. &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp;• RF Mount Lenses Cannot Be Used. |
| Lens Mount | Canon EF-M Mount |
| Type | CMOS Sensor (Supporting Dual Pixel CMOS AF) |
| Pixels | Effective Pixels: Approx. 24.1 Megapixels Total Pixels: Approx. 25.8 Megapixels |
| Aspect Ratio | 3:2 (Horizontal:Vertical) Screen Size |
| Recording Format | Design Rule For Camera File System 2.0, Exif 2.31 Compliant, Supports Time Difference Information Data Type Recording Pixels 3:2 Aspect Ratio 4:3 Aspect Ratio 16:9 Aspect Ratio 1:1 Aspect Ratio |
| File Numbering | Continuous, Auto Reset Folder Setting Still Photo File Size / Number Of Possible Shots / Maximum Burst For Continuous Shooting
* File Size, Number Of Possible Shots, And Maximum Burst Vary Depending On Shooting Conditions (Including Subject, ISO Speed, Picture Style, And Custom Function). |
| Raw Jpeg Simultaneous Recording | Simultaneous Recording Of Any Combination Of RAW/C-RAW/ And JPEG Image Recording Quality Is Supported Image Processing During ShootingPicture Style
White Balance
*1 Effective Also In Twilight And Sunset. *2 Custom White Balance Is Not Available For Monochrome Images And Images With Creative Filters Applied. Noise Reduction
Automatic Image Brightness Correction Highlight Tone Priority Lens Aberration Correction
Creative Assist |
| Type | Dual Pixel CMOS AF (1-Point AF, Spot AF, Face+Tracking Priority AF, Zone AF) | ||||
| Af Points | Still Photo Shooting: Up To 143 Zones (Maximum) Video Shooting: Up To 117 Zones (Maximum) Focusing Brightness Range AF Operation Touch & Drag AF Tap To Select Subject
| Af Assist Beam | Built-In LED Lamp |
| Metering Modes | 384-Zone (24x16) Metering Using The Image Sensor. |
| Metering Range | Stills: EV -2–20 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) Video: EV 0–20 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) |
| Exposure Control Systems | Via SHOOTING MODE In Menu: • Program AE, Shutter-Priority AE, Aperture-Priority AE, Or Manual (B Is Selected As Shutter Speed Setting In Manual Mode) |
| Iso Speed Range | Stills: ISO 100–25600 (In 1/3-Stop Increments) Video: ISO 100-12800; H: 25600 |
| Exposure Compensation | Manual: &Plusmn;3 Stops In 1/3-Stop Increments |
| Ae Lock | Manual, Auto (Exposure Locked After Focusing, In One-Shot AF With Evaluative Metering) |
| Type | Electronically Controlled Focal-Plane Shutter * Electronic 1st / Mechanical 2nd Curtain * Except When Silent Mode Is Set Rolling Shutter, Using The Image Sensor * Electronic Shutter * When Silent Mode Is Set |
| Shutter Speeds | Creative Zone: 1/4000 To 30 Sec., Bulb * X-Sync At 1/200 Sec. Basic Zone: 1/4000 To 1 Sec. * Varies Depending On Shooting Mode |
| Type | Manual Pop-Up Flash (Max. Guide Number Approx. 16.4 [Ft] / 5.0 [M], At ISO 100) |
| Flash Metering System | Evaluative (Face Priority) / Evaluative / Average |
| Fe Lock | Provided |
| Flash Exposure Compensation | &Plusmn;2 Stops In 1/3-Stop Increments Continuous Shooting Priority (CSP) Mode External Flash |
| Continuous Shooting Speed |
*1 Conditions For Maximum Continuous Shooting Speed Are As Follows: Fully Charged Battery Pack LP-E12, Shutter Speed: 1/1000 Sec. Or Faster, Room Temperature (73°F/23°C), 12 Bit Self-Timer Mode Live View FunctionsAspect Ratio Settings Focus Mode Continuous AF Touch Shutter Grid Display Depth Of Field Preview |
| File Format | Video: MPEG-4 AVC / H.264 • Variable (Averaged) Bit Rate Audio: AAC Recording System Live Streaming Recording Size And Frame Rate
*1The Image Is Cropped Around The Center Of The Image Sensor. |
| Continuous Shooting Time |
* Limitations Of Video Shooting: Continuous Shooting Is Possible Until The Memory Card Becomes Full Or The Recording Length For One Video Reaches Approx. 29 Minutes And 59 Seconds (Or 7 Min. 29 Sec. For A HD High Frame Rate Movie). |
| Exposure Compensation | &Plusmn;3 Stops In 1/3-Stop Increments Movie Exposure Modes Metering Mode ISO Speed (Recommended Exposure Index) Miniature Effect Movie Still Image Shooting Sound Recording Card Performance Requirements
| Type | TFT Color Liquid Crystal Monitor Menu Magnification Brightness Adjust-Ment Angle Of View Hints & Tips |
| Screen Monitor Size | 3.0-Inch Type |
| Pixels | Approx. 1.04 Million Dots |
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
| Image Display Format | • Single Image, Or 4, 9, 36, Or 100-Image Index • Viewing Options Via INFO Button: Full Image, Full Image With Basic Info, Thumbnail Image With Histogram And Detailed Shooting Info, RGB And Brightness Histograms With Lens Info Playback Methods Zoom Magnification Image Browsing Methods
Image Rotate Rating Video Playback Playback Time Slideshow
Post-Processing Of ImagesCreative Filters
Cropping Resize Red-Eye Reduction |
| Compatible Printers | PictBridge |
| Printable Images | • JPEG • RAW / C-RAW |
| Custom Controls | Stills :Shutter Button, AE Lock Button, Multi-Function Button, Movie Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button. Movie:AE Lock Button, Multi-Function Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button Custom Functions Copyright Info |
| Usb Terminal | USB Micro-B (Hi-Speed USB 2.0 Compliant) |
| Video Out Terminal | HDMI Type D (Resolution Switches Automatically) • HDMI Output While Recording (Shooting Screen Without Sound) Provided • CEC Not Supported Wireless Remote Control Wi-Fi® (Wireless LAN)Standards Compliance Transmission Method Transmission Frequency (Central Frequency) Connection Method And Security
(2) Camera Access Point Mode
Network FunctionsSupported Wireless Functions Transfer Images Between Cameras Connection To Smart Phones Wireless Connection Types |
| Battery | Battery Pack LP-E12 | ||||||||||||||||||||||
| Battery Life |
* With A Fully Charged LP-E12 Battery. |
| Dimensions W X H X D | Approx. 4.58 X 3.47 X 2.31 In. (116.3 X 88.1 X 58.7mm) • CIPA Compliant. |
| Weight | Black: Approx. 13.65 Oz. / 387g (Including Battery Pack And Memory Card) Approx. 12.35 Oz. / 350g (Body Only) White: Approx. 13.69 Oz. / 388g (Including Battery Pack And Memory Card) Approx. 12.38 Oz. / 351g (Body Only) * Without Body Cap * 1: Based On CIPA Guidelines |
| Operating Temperature Range | 32-104&Deg;F / 0-40&Deg;C |
| Operating Humidity Range | 85% Or Less |
Directional Microphone
DM-E1
Crisp sound. Superb performance. The new Directional Microphone DM-E1 can help experienced videographers and aspiring filmmakers alike achieve high-quality audio when recording video using a compatible Canon EOS digital camera*.
Stereo Microphone DM-E100
Capture crisp audio with the Stereo Microphone DM-E100 microphone.
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Protecting Cloth PC-E1
The Protecting Cloth is for the purpose of protecting equipment such as a camera and lens from dirt and scratches, etc., but it cannot protect equipment from shocks or pressure.
Protecting Cloth PC-E2
The Protecting Cloth is for protecting equipment such as a camera and lens from dirt and scratches, etc.; it cannot protect equipment from shocks or pressure. Suitable for smaller camera as it is smaller than the Protecting Cloth PC-E1.
Interface Cable IFC-600PCU
Conveniently charge the battery in your PowerShot by connecting the camera to your computer using the IFC-600PCU cable
Compact Power Adapter CA-PS700A
This compact adapter powers your camera from an AC power supply and charges your batteries on the camera. This allows for uninterrupted recording of your special events and keeps your batteries ready to go.
Allows Canon EF and EF-S lenses to be mounted on the Canon EOS M digital camera. Fully compatible with all lens functions including image stabilization and autofocus. Detachable tripod adapter provides support for longer Canon lenses.
Wall battery charger compatible with battery pack LP-E12.
Tripod Grip HG-100TBR
Providing a stable base for compatible cameras, as well as support to attach a compatible external microphone. The Tripod Grip HG-100TBR helps you frame your subject and minimize shake if handheld or provide shake-free results when stationery for great selfies, group shots, and video, even when set to a vertical position. Its compact size means you can easily carry it in virtually any camera bag, and the bundled Wireless Remote Control BR-E1 gives you creative control, even from a distance.
Battery Pack LP-E12
Battery pack for EOS M allows up to 1hr 30 min. of movie shooting time and approximately 230 shots (at 73°F/23°C).
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
