CP2025-005 Vulnerabilities Remediation for Certain Printer Drivers for Production Printers, Office/Small Office Multifunction Printers and Laser Printers
Updated: Updated: March 13, 2026
Date: September 25, 2025
Canon Inc.
Description:
Multiple vulnerabilities were found in certain printer drivers for production printers, office/small office multifunction printers, and laser printers. These vulnerabilities may potentially allow out-of-bounds memory access and/or Denial-of-Service (DoS) attacks when printing is processed by a malicious application.
Affected Printer Drivers:
- Generic Plus PCL6 Printer Driver – V3.30 and earlier
- Generic Plus UFR II Printer Driver - V3.30 and earlier
- Generic Plus LIPS4 Printer Driver - V3.30 and earlier
- Generic Plus LIPSLX Printer Driver - V3.30 and earlier
- Generic Plus PS Printer Driver - V3.30 and earlier
- UFRII LT Printer Driver - V31.05 and earlier
- FAX Driver - V10.67 and earlier
- PCL Printer Driver – V15.00 and earlier
- PS Printer Driver – V15.00 and earlier
- UFRII Printer Driver – V15.00 and earlier
Remediation:
Printer drivers designed to address the issue are available on the websites of your local Canon sales representatives. We advise that our customers install the latest printer drivers available.
- Generic Plus PCL6 Printer Driver – V3.31 and higher
- Generic Plus UFR II Printer Driver - V3.31 and higher
- Generic Plus LIPS4 Printer Driver - V3.31 and higher
- Generic Plus LIPSLX Printer Driver - V3.31 and higher
- Generic Plus PS Printer Driver - V3.31 and higher
- UFRII LT Printer Driver - V31.10 and higher
- FAX Driver - V10.70 and higher
- PCL Printer Driver – V15.01 and higher
- PS Printer Driver – V15.01 and higher
- UFRII Printer Driver – V15.01 and higher
CVE/CVSS:
CVE-2025-7698: Out-of-bounds read vulnerabilities in print processing of Generic Plus PCL6 Printer Driver / Generic Plus UFR II Printer Driver / Generic Plus LIPS4 Printer Driver / Generic Plus LIPSLX Printer Driver / Generic Plus PS Printer Driver / PCL Printer Driver / PS Printer Driver / UFRII LT Printer Driver / FAX Driver / UFRII Printer Driver CVSS v4 CVSS:4.0/AV:N/AC:H/AT:P/PR:N/UI:A/VC:H/VI:N/VA:L/SC:N/SI:N/SA:N Base Score: 5.9 CVSS v3 CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:H/I:N/A:L Base Score: 5.9
CVE-2025-9903: Out-of-bounds write vulnerabilities in print processing of Generic Plus PCL6 Printer Driver / Generic Plus UFR II Printer Driver / Generic Plus LIPS4 Printer Driver / Generic Plus LIPSLX Printer Driver / Generic Plus PS Printer Driver / PCL Printer Driver / PS Printer Driver / UFRII LT Printer Driver / FAX Driver / UFRII Printer Driver CVSS v4 CVSS:4.0/AV:N/AC:H/AT:P/PR:N/UI:A/VC:N/VI:H/VA:L/SC:N/SI:N/SA:N Base Score: 5.9 CVSS v3 CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:N/I:H/A:L Base Score:5.9
CVE-2025-9904: Unallocated memory access vulnerability in print processing of Generic Plus PCL6 Printer Driver / Generic Plus UFR II Printer Driver / Generic Plus LIPS4 Printer Driver / Generic Plus LIPSLX Printer Driver / Generic Plus PS Printer Driver / PCL Printer Driver / PS Printer Driver / UFRII LT Printer Driver / FAX Driver / UFRII Printer Driver CVSS v4 CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N Base Score: 6.9 CVSS v3 CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L Base Score: 5.3
Thank you to Microsoft Offensive Research and Security Engineering Team (MORSE) for reporting the out-of-bounds read vulnerability (CVE-2025-7698).
