Firmware Notice: EOS-1D X Firmware Update, Version 2.1.0
| Thank you for using Canon products. Phenomenon Changes in the Firmware Firmware Version 2.1.0 incorporates the following improvement and fixes:
Support Firmware Version 2.1.0 is for cameras with firmware up to Version 2.0.9. If the camera's firmware is already Version 2.1.0, it is not necessary to update the firmware. When updating the firmware of the camera, please review the instructions thoroughly before you download the firmware. Notes:
Windows After the downloaded compressed file (.zip) is extracted, a firmware folder is created. *Extracting the downloaded file: Right-click the zip file, and then select Extract All to extract the file. The extracted folder contains the firmware (File name: 1DX000210.FIR, File Size: xx,xxx,xxx bytes) and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish, and Simplified Chinese). Before starting the firmware update operations, please confirm the contents of the download, and carefully read through the firmware update procedures. Macintosh After the downloaded compressed file (.dmg file) is extracted, a firmware folder is created. *Extracting the downloaded file: The downloaded folder is automatically extracted, and a firmware folder is created. If the download folder cannot be automatically extracted, double-click the folder. La carpeta extraída contiene el firmware (nombre del archivo: The extracted folder contains the firmware (File name: 1DX00210.FIR, File Size: xx,xxx,xxx bytes) and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish, and Simplified Chinese). Before starting the firmware update operations, please confirm the contents of the download, and carefully read through the firmware update procedures. The following is the history of past firmware updates: Q: Are the improvements from previous firmware versions included in Firmware Version 2.1.0? A: Yes, the following improvements from the previous version are included: (Previous) Version 2.0.9 improvements: Corrects a phenomenon in which when using the camera with the EF 70-300mm f/4-5.6 IS II USM lens, even if lens aberration correction is set to “Enable”, correction will not be applied. (Previous) Version 2.0.8 improvements:
Should you have any questions about the announcement, please contact the Authorized Service Facility in your area or you may contact the Call Center within your region. |
