/content/cla/en/cla-test/cla-testing/haibd4-testing
/content/cla/en/cla-test/cla-testing/support/p/Software-Applications/1259B003
imageRUNNER 1024J - Copier Only
The imageRUNNER 1024J is a compact solution for small offices that need reliable copying at their desk. With Auto Duplexing capability as standard you can expect fast and high quality copies at a speed of up to 25 pages per minute (LTR)..
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Model Name | ImageRUNNER 1024J-Copier Only |
| Type | Monochrome Digital, Copier |
| Imaging System | Laser Dry Electrostatic Transfer |
| Developing System | Laser Dry Electrostatic Transfer |
| Fixing System | RAPID Fusing System |
| Image Server Memory | 64MB RAM |
| Max Copy Reservation | 5 Jobs Copying Resolution (Enhanced) 1200 X 600 Dpi |
| Halftone | 256 Levels |
| Letter | Up To 25 Ppm (LTR) - Up To 24 Ppm (LTR) When Feeding From Stack Bypass |
| First Copy Time | Less Than 8 Seconds (From Platen Glass) |
| Multiple Copies | 1 To 99 |
| Magnification | 50% To 200% (In 1% Increments) Preset Reduction/Enlargement: 50%, 64%, 78%, 100%, 129%, 200% |
| Maximum Original Size | Legal / B4 |
| Standard Paper Capacity | 1 X 500-Sheet Paper Cassette (21 Lb.Bond / 80 G/M²) 1 X 100-Sheet Stack Bypass |
| Manual Bypass | (21 Lb. Bond / 80 G/M²) |
| Maximum Paper Capacity | 1,100 Sheets |
| Cassette | 17 Lb. To 24 Lb. Bond / 64 G/M² To 90 G/M² |
| Bypass | 15 Lb. To 34 Lb. Bond / 56 G/M² To 128 G/M² |
| Duplexing | Standard |
| Warm Up Time | Less Than 16 Seconds 1 Second (From Energy Saver Mode)* |
| Exposure Control | Automatic Or Manual (9 Levels) |
| Power Requirements | 230V AC, 60Hz Power Consumption: 1023W (Maximum) |
| Dim | 14-7/8" X 20-1/2" X 18" " (378mm X 520mm X 457mm) |
| Weight | (Including Drum Unit, Excluding Toner Cartridge): Approximately 48.5 Lb. (22 Kg) |
| Estimated Toner Yield | Approximately 8,400 Images At 6% Coverage |
| Drum | OPC |
| Description | Cassette Feeding Module-N2 (Optional) |
| Capacity | 1 X 500 - Sheet Paper Cassette (21 Lb. Bond / 80 G/M²) |
| Paper Weights | 17 Lb. To 24 Lb. Bond / 64 G/M2 To 90 G/M2 Paper Size: Legal, Letter |
| Different Size Originals | Legal/B4, Letter/A4 |
| Dimensions | 6-1/4" X 20-1/2" X 17-3/8" (158mm X 520mm X 440mm) |
| Weight | Approximately 11.46 Lb.(5.2Kg) |
| Description | Cabinet-VI |
| Dimensions | 20-5/8" X 20-1/2" X 19" (525mm X 520mm X 481mm) |
| Weights | 27.9 Lb. (13 Kg) * Warm-Up/First-Copy Time May Differ Depending On The Condition And Environment Of The Device. |
Title
Firmware Update: RF 24-105mm f/4-7.1 IS STM Firmware Version 2.0.4
Advisory Type
Date
07.31.20
Title
Firmware Update: RF 1200mm f/8L IS USM Firmware Version 1.0.4
Advisory Type
Date
04.16.24
Title
Firmware Update: RF 35mm f/1.8 Macro IS STM Firmware Version 2.0.2
Advisory Type
Date
07.31.20
Title
Firmware Notice: RF 35mm f/1.8 Macro IS STM, Firmware version 2.0.0
Advisory Type
Date
02.27.19
Title
Firmware Notice: To Users of certain Canon DLSR cameras together with EF-S 18-135mm f/3.5-5.6 IS USM and EF 70-300mm f/4-5.6 IS II USM Lenses “Notification about Lens Aberration Correction”
Advisory Type
Date
12.05.16
Title
Firmware Update: RF 100-500mm f/4.5-7.1L IS USM Firmware Version 1.1.0
Advisory Type
Date
10.12.21
Title
Firmware Update: RF 100-500mm f/4.5-7.1L IS USM Firmware Version 1.0.9
Advisory Type
Date
03.29.21
Title
Firmware Notice: EF 400mm f/2.8L IS III USM and EF 600mm f/4L IS III USM, Firmware version 1.0.8
Advisory Type
Date
04.02.19
Title
Firmware Update: EF 600mm f/4L IS III USM Firmware Version 1.1.3
Advisory Type
Date
07.31.20
Title
Service Notice: EF 300mm f/2.8L IS II USM and EF 400mm f/2.8L IS II USM lens hood
Advisory Type
Date
01.17.12
Title
Firmware Update: RF 15-35mm f/2.8L IS USM Firmware Version 1.0.7
Advisory Type
Date
07.31.20
Title
Firmware Update: RF 15-35mm f/2.8L IS USM Firmware Version 1.0.8
Advisory Type
Date
12.15.22
Title
Firmware Update: RF 24-70mm f/2.8L IS USM Firmware Version 1.0.7
Advisory Type
Date
07.31.20
Title
Firmware Update: RF 24-70mm f/2.8L IS USM Firmware Version 1.0.8
Advisory Type
Date
12.15.22
Title
Service Notice: To Users of Drop-in Circular Polarizing Filters PL-C52(WII) and Drop-in Circular Polarizing Filters PL-C52
Advisory Type
Date
02.16.16
Title
Firmware Update: RF 24-240mm f/4-6.3 IS USM Firmware Version 1.0.6
Advisory Type
Date
07.31.20
Title
Firmware Notice: EOS R Firmware Version 1.3.0
Advisory Type
Date
09.12.19
Title
Firmware Notice: EOS RP Firmware Version 1.2.0
Advisory Type
Date
09.12.19
Title
Service Notice: The EF200 f/2L IS USM and EF800mm f/5.6L IS USM Lenses with the Canon EOS 5D Mark III Digital SLR Camera.
Advisory Type
Date
05.17.12
Title
Service Notice:To the Users of the EF300, EF400, EF500, and EF600 interchangeable lenses for SLR Cameras
Advisory Type
Date
02.07.12
Title
Firmware Notice: EOS 7D Mark II Firmware Update, Version 1.0.5
Advisory Type
Date
08.25.16
Title
Firmware Update: RF 14-35mm f/4L IS USM Firmware Version 1.0.3
Advisory Type
Date
12.15.22
Title
Service Notice: EF 50mm f/1.2L USM
Advisory Type
Date
03.30.23
Title
Service Notice: Measures to be taken against potential vulnerability in RSA Key generation for Canon Enterprise/Small Office Multifunction Printers and Laser Printers/Inkjet Printers
Advisory Type
Date
03.14.22
Title
Updated notice regarding the MAXIFY GX6010 and MAXIFY GX7010 printers
Advisory Type
Date
11.01.21
Title
Notice regarding the MAXIFY GX6010 and MAXIFY GX7010 printers
Advisory Type
Date
09.13.21
Title
Service Notice Update: Measures to be taken against potential vulnerability in RSA Key generation for Canon Enterprise/Small Office Multifunction Printers and Laser Printers/Inkjet Printers
Advisory Type
Date
04.06.22
Title
Firmware Update: RF 24-105mm f/4L IS USM Firmware Version 2.0.6
Advisory Type
Date
07.31.20
Title
Firmware Notice: RF 24-105mm f/4L IS USM, Firmware version 2.0.0
Advisory Type
Date
02.12.19
Title
Firmware Update: RF 50mm f/1.2L USM Firmware Version 1.0.5
Advisory Type
Date
11.19.20
Title
Service Notice: Canon Mini Print App Version 2.0.2
Advisory Type
Date
09.30.20
Title
Service Notice: Canon Mini Print App Version 3.6.1
Advisory Type
Date
07.20.23
Title
Safety Notice: Reports of Smoke from Inkjet Printers
Advisory Type
Date
06.04.09
Title
Service Notice: IFTTT Web Announcement
Advisory Type
Date
07.15.20
Title
Firmware Notice: Zoemini S Firmware Version 1.1.8
Advisory Type
Date
10.02.20
Title
Service Notice: Canon Mini Print App: Version 1.3.6
Advisory Type
Date
03.31.20
Title
Service Notice: Care and Maintenance of Built-in Battery for Zoemini C Instant Camera Printer
Advisory Type
Date
10.22.20
Title
Firmware Notice: Canon Mini Photo Printer - The firmware will update to either version 1.1.4 or 2.0.11 depending on your device's current firmware specification.
Advisory Type
Date
10.02.20
Title
Feature Usage Notice:To Protect Your Printers From Unauthorized Access
Advisory Type
Date
04.08.15
Title
Firmware Update: EOS C500 Mark II Firmware Version 1.0.1.1.00
Advisory Type
Date
02.20.20
Title
Firmware Update: EOS C200/C200B Firmware Version 1.0.6.1.00
Advisory Type
Date
02.20.20
Title
Firmware Update for Canon WUX450/ WX520/ WUX400ST/ WX450ST Projectors
Advisory Type
Date
03.31.15
Title
Firmware Update: RF 70-200mm f/4L IS USM Firmware Version 1.1.0
Advisory Type
Date
12.01.21
Title
Firmware Update: RF 70-200mm f/4L IS USM Firmware Version 1.1.1
Advisory Type
Date
12.15.22
Title
Firmware Update: RF 400mm f/2.8L IS USM Firmware Version 1.0.6
Advisory Type
Date
04.16.24
Title
Safety Notice: Caution Regarding Counterfeit Canon EF 50mm f/1.8 II Lenses for Digital SLR Cameras
Advisory Type
Date
12.14.16
Title
Firmware Notice: EF40mm f/2.8 STM: Firmware Version 1.2.0
Advisory Type
Date
08.20.12
Title
Firmware Update: EF 400mm f/2.8L IS III USM Firmware Version 1.1.3
Advisory Type
Date
07.31.20
Title
Firmware Update: RF 100-300mm f/2.8L IS USM Firmware Version 1.0.6
Advisory Type
Date
04.16.24
Title
Firmware Update: RF 70-200mm f/2.8L IS USM Firmware Version 1.1.4
Advisory Type
Date
12.15.22
Title
Firmware Update: RF 70-200mm f/2.8L IS USM Firmware Version 1.1.1
Advisory Type
Date
08.31.22
Title
Future Firmware Plan: RF 70-200mm f/2.8L IS USM Lens
Advisory Type
Date
12.20.19
Title
Firmware Update: RF 70-200mm f/2.8L IS USM Firmware Version 1.0.6
Advisory Type
Date
01.07.20
Title
Firmware Update: RF 70-200mm f/2.8L IS USM Firmware Version 1.0.8
Advisory Type
Date
07.31.20
Title
Firmware Update: RF 70-200mm f/2.8L IS USM Firmware Version 1.1.0
Advisory Type
Date
03.29.21
Title
Service Notice: EF 50mm f/1.4 USM Interchangeable Lens for Digital SLR Cameras and Mirrorless Cameras
Advisory Type
Date
09.04.17
Title
Firmware Update: PowerShot G9 X Mark II Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Service Notice: Speedlite 600EX-RT and Speedlite Transmitter ST-E3-RT
Advisory Type
Date
12.09.15
Title
Service Notice: LF Motor Issue
Advisory Type
Date
02.05.20
Title
Firmware Notice: EOS 6D Mark II Firmware Update, Version 1.0.4
Advisory Type
Date
09.04.18
Title
Firmware Update: EOS 6D Mark II Firmware Version 1.0.5
Advisory Type
Date
11.21.19
Title
Firmware Update: EOS 6D Mark II Firmware Version 1.2.0
Advisory Type
Date
05.18.23
Title
Firmware Notice: EOS 6D Mark II Firmware Update, Version 1.0.3
Advisory Type
Date
11.08.17
Title
Firmware Update: PowerShot ELPH 360 HS Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Service Notice: To Users of the IXY 180 / PS ELPH 180 / IXUS 175, 177 Compact Digital Camera
Advisory Type
Date
12.07.16
Title
Firmware Update: EOS 6D Mark II Firmware Version 1.1.1
Advisory Type
Date
02.09.21
Title
Firmware Update: EOS R6 Mark II Firmware Version 1.1.1
Advisory Type
Date
01.18.23
Title
Firmware Notice: EOS 6D Firmware Update, Version 1.1.8
Advisory Type
Date
11.29.17
Title
Firmware Update: EOS 6D Firmware Version 1.1.9
Advisory Type
Date
11.21.19
Title
Firmware Update: PowerShot G1 X Mark II Firmware Version 1.2.0.0
Advisory Type
Date
04.15.20
Title
Service Notice: EOS 6D Firmware Update, Version 1.1.4
Advisory Type
Date
03.19.14
Title
Service Notice: EOS 6D Firmware Update, Version 1.1.6
Advisory Type
Date
12.17.14
Title
Firmware Update: EOS 6D Mark II Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS R6 Firmware Version 1.8.0
Advisory Type
Date
03.08.23
Title
Firmware Update: EOS R6 Firmware Version 1.2.0
Advisory Type
Date
11.19.20
Title
Firmware Update: EOS R6 Mark II Firmware Version 1.1.2
Advisory Type
Date
05.23.23
Title
Firmware Update: PowerShot G1 X Mark III Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Firmware Update: EOS R6 Mark II Firmware Version 1.2.0
Advisory Type
Date
09.26.23
Title
Firmware Update: EOS R6 Firmware Version 1.8.4
Advisory Type
Date
03.26.24
Title
Firmware Update: EOS R6 Firmware Version 1.4.0
Advisory Type
Date
07.09.21
Title
Firmware Update: EOS R6 Firmware Version 1.5.0
Advisory Type
Date
12.01.21
Title
Firmware Update: EOS R6 Firmware Version 1.5.1
Advisory Type
Date
02.17.22
Title
Firmware Update: EOS R6 Firmware Version 1.3.1
Advisory Type
Date
04.01.21
Title
Firmware Update: EOS R6 Firmware Version 1.6.0
Advisory Type
Date
07.21.22
Title
Firmware Update: EOS R6 Firmware Version 1.8.1
Advisory Type
Date
03.14.23
Title
Firmware Update: EOS R6 Firmware Version 1.8.2
Advisory Type
Date
05.31.23
Title
Firmware Update: EOS R6 Firmware Version 1.1.1
Advisory Type
Date
09.09.20
Title
Firmware Update: EOS R6 Firmware Version 1.7.0
Advisory Type
Date
12.07.22
Title
Firmware Update: EOS R5 Firmware Version 1.4.0
Advisory Type
Date
08.19.21
Title
Firmware Update: EOS R5 Firmware Version 1.7.0
Advisory Type
Date
12.07.22
Title
Firmware Update: EOS R5 Firmware Version 1.5.1
Advisory Type
Date
02.17.22
Title
Firmware Update: EOS R5 Firmware Version 1.5.2
Advisory Type
Date
03.17.22
Title
Firmware Update: EOS R5 Firmware Version 1.6.0
Advisory Type
Date
07.21.22
Title
Firmware Update: EOS R5 Firmware Version 1.3.1
Advisory Type
Date
04.14.21
Title
Firmware Update: EOS R5 Firmware Version 1.5.0
Advisory Type
Date
12.01.21
Title
Firmware Update: EOS R5 Firmware Version 1.3.0
Advisory Type
Date
03.29.21
Title
Firmware Update: EOS 77D Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS 77D Firmware Version 1.0.3
Advisory Type
Date
02.13.20
Title
Firmware Update: EOS R5 Firmware Version 1.1.1
Advisory Type
Date
09.09.20
Title
Firmware Update: EOS R5 Firmware Version 1.8.1
Advisory Type
Date
03.30.23
Title
Firmware Update: EOS R5 Firmware Version 2.0.0
Advisory Type
Date
03.26.24
Title
Firmware Update: EOS R5 Firmware Version 1.2.0
Advisory Type
Date
11.19.20
Title
Firmware Update: EOS R5 Firmware Version 1.1.0
Advisory Type
Date
08.26.20
Title
Firmware Update: EOS R5 Firmware Version 1.9.0
Advisory Type
Date
10.17.23
Title
Firmware Update: EOS Rebel T6 Firmware Version 1.1.1
Advisory Type
Date
02.13.20
Title
Firmware Notice: EOS Rebel T5 Firmware Updated, Version 1.0.1
Advisory Type
Date
10.01.15
Title
Firmware Update: EOS M6 Mark II Firmware Version 1.1.1
Advisory Type
Date
01.28.21
Title
Firmware Update: EOS M6 Mark II Firmware Version 1.0.1
Advisory Type
Date
11.21.19
Title
Firmware Notice: Photo and Movie Storage Device “Connect Station CS100” Firmware Update, Version 1.1.2
Advisory Type
Date
10.14.15
Title
Service Update: Error Correction in Macro Ring Lite MR-14 EX II Instruction Manual
Advisory Type
Date
02.25.16
Title
Notification Regarding Use of (AA/R6) Lithium Batteries
Advisory Type
Date
12.22.14
Title
Service Notice: Vulnerability Mitigation for Certain Printer Drivers for Office/Small Office Multifunction Printers and Laser Printers
Advisory Type
Date
Title
Service Notice: Vulnerability Mitigation/Remediation for Small Office Multifunctional Printers and Laser Printers
Advisory Type
Date
Title
CPE2024-003 – uniFLOW Online Device Registration Susceptible To Compromise
Advisory Type
Date
Title
Service Notice: Vulnerability Remediation for Certain Printer Drivers for Production Printers, Office/Small Office Multifunction Printers and Laser Printers
Advisory Type
Date
Title
Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Advisory Type
Service Notice
Date
06.20.25
Title
Service Notice: VIXIA HF M31/ M30/ M300/ M32/ M301
Advisory Type
Date
05.16.11
Title
Service Notice: VIXIA HG20/HG21: Firmware Update Version 1.0.2.0
Advisory Type
Date
06.23.11
Title
Canon PC-3 and PC-5 Compact Personal Copiers
Advisory Type
Date
10.18.10
Title
Firmware Notice: EOS Rebel T2i: Firmware Announcement 1.0.9
Advisory Type
Date
11.25.10
Title
Service Notice: Wireless File Transmitter WFT-E4A: Firmware Update Version 1.0.1
Advisory Type
Date
08.22.11
Title
Firmware Notice: VIXIA HF10/HF100 Firmware Update Version 1.0.3.0
Advisory Type
Date
06.23.11
Title
Service Notice: Product Advisory: Preventative Measure for XHA1/G1, XHA1S/G1S Grip Belt
Advisory Type
Date
09.30.09
Title
Service Notice: EF-S 18-200mm f/3.5-5.6 IS lens : Possible Zoom Operation Malfunction
Advisory Type
Date
02.22.11
Title
Service Notice: VIXIA HF11 Firmware Update Version 1.0.1.0
Advisory Type
Date
06.23.11
Title
Canon PC-1, PC-2, PC-2L and PC-2LX Compact Personal Copiers
Advisory Type
Date
10.18.10
Title
Service Notice: VIXIA HF S10/HF S100 Firmware Update Version 1.0.4.0
Advisory Type
Date
07.06.11
Title
Firmware Notice: VIXIA HF20/HF200 Firmware Update Version 1.0.5.0
Advisory Type
Date
06.23.11
Title
Service Notice: VIXIA HG10: Zoom Lever Problem
Advisory Type
Date
02.09.09
Title
Safety Notice: EOS Rebel T4i Rubber grip changing color
Advisory Type
Date
02.02.12
Title
Service Notice: Rebel T4i: Incorrect model name in EXIF data for captured images 7/05/2012
Advisory Type
Date
07.05.12
Title
Service Notice: EOS C300 / C300PL Cinema EOS Cameras: Firmware Update Version 1.0.6.1.00
Advisory Type
Date
06.21.12
Title
Firmware Update: PowerShot PICK Firmware Version 1.4.0
Advisory Type
Date
01.18.23
Title
Firmware Update: EOS Rebel T100/3000D/4000D Firmware Version 1.0.1
Advisory Type
Date
11.21.19
Title
Safety Recall: PC and NP Copiers Manufactured between 1987 and 1998
Advisory Type
Date
01.18.07
Title
Firmware Update: EOS Rebel T100 Firmware Version 1.1.0
Advisory Type
Date
05.18.23
Title
Service Notice: EOS Utility/Picture Style File Registration Tool applications: USB Connection Issue on macOS 10.15.2
Advisory Type
Date
12.17.19
Title
Service Notice: Vulnerability Mitigation/Remediation for Canon EOS Webcam Utility Pro for Mac OS
Advisory Type
Service Notice
Date
06.26.25
Title
Service Notice: Regarding Vulnerability Against Buffer Overflow for Canon Laser Printer and Small Office Multifunctional Printers
Advisory Type
Date
11.18.22
Title
Service Notice: Canon Laser Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date
02.28.22
Title
Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type
Date
04.19.23
Title
Firmware Update: EOS Rebel T6 Firmware Version 1.2.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS M100 Firmware Version 1.0.1
Advisory Type
Date
02.13.20
Title
Firmware Update: EOS M100 Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS Rebel T6s/760D Firmware Version 1.0.1
Advisory Type
Date
11.21.19
Title
Firmware Notice: Firmware Version 1.2.0 for the Wireless File Transmitter WFT-E7
Advisory Type
Date
06.17.15
Title
Firmware Notice: Firmware Version 2.0.0 for the GPS Receiver GP-E2
Advisory Type
Date
06.18.15
Title
Firmware Update: EOS 5DS Firmware Version 1.1.4
Advisory Type
Date
02.09.21
Title
Firmware Notice: EOS 5DS Firmware Update, Version 1.1.2
Advisory Type
Date
11.29.17
Title
Firmware Notice: To Owners of the EOS 5DS / EOS 5DS R Digital SLR Cameras
Advisory Type
Date
08.25.16
Title
Firmware Notice: Wireless File Transmitter WFT-E7 Firmware Update, Version 1.2.1
Advisory Type
Date
01.27.16
Title
Service Notice: Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions
Advisory Type
Date
08.06.19
Title
Firmware Notice: Speedlite EL-100 Firmware Update, Version 1.0.1
Advisory Type
Date
05.30.19
Title
Firmware Update: EOS 5DS R Firmware Version 1.1.4
Advisory Type
Date
02.09.21
Title
Firmware Notice: EOS 5DS R Firmware Update, Version 1.1.2
Advisory Type
Date
11.29.17
Title
Service Notice: EOS 7D Firmware Update, Version 2.0.3
Advisory Type
Date
12.09.12
Title
Firmware Update: EOS M50 Mark II Firmware Version 1.0.1
Advisory Type
Date
12.13.21
Title
Firmware Update: PowerShot SX720 HS Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Service Notice: EOS 7D Firmware Update, version 2.0.3
Advisory Type
Date
12.09.12
Title
Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers
Advisory Type
Date
01.24.12
Title
Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date
03.20.14
Title
Firmware Update: EOS M50 Mark II Firmware Version 1.0.3
Advisory Type
Date
06.08.22
Title
Firmware Update: EOS R8 Firmware Version 1.1.0
Advisory Type
Date
09.26.23
Title
Firmware Notice: EOS Rebel T5i Firmware Update, Version 1.1.4
Advisory Type
Date
04.14.15
Title
Firmware Update: PowerShot SX420 IS Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Firmware Update: PowerShot SX540 HS Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Firmware Update: PowerShot G5 X Firmware Version 1.1.0.0
Advisory Type
Date
04.15.20
Title
Firmware Update: PowerShot G7 X Mark II Firmware Version 1.2.0.0
Advisory Type
Date
05.18.23
Title
Firmware Update: PowerShot G3 X Firmware Version 1.2.0.0
Advisory Type
Date
04.15.20
Title
Firmware Update: EOS R3 Firmware Version 1.2.0
Advisory Type
Date
07.21.22
Title
Firmware Update: EOS R3 Firmware Version 1.7.1
Advisory Type
Date
03.26.24
Title
Firmware Update: EOS R3 Firmware Version 1.4.0
Advisory Type
Date
03.30.23
Title
Firmware Update: PowerShot SX620 HS Firmware Version 1.1.0.0
Advisory Type
Date
05.18.23
Title
Firmware Update: EOS R3 Firmware Version 1.4.1
Advisory Type
Date
04.20.23
Title
Firmware Update: EOS R3 Firmware Version 1.5.1
Advisory Type
Date
09.26.23
Title
Firmware Update: EOS R3 Firmware Version 1.2.1
Advisory Type
Date
07.29.22
Title
Firmware Update: PowerShot G7 X Mark II Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Notice: Canon PowerShot G7X Mark II Firmware Version 1.0.1.0
Advisory Type
Date
11.07.16
Title
Firmware Update: EOS R3 Firmware Version 1.1.1
Advisory Type
Date
02.08.22
Title
Firmware Update: EOS R3 Firmware Version 1.3.0
Advisory Type
Date
11.22.22
Title
Firmware Update: EOS R3 Firmware Version 1.2.2
Advisory Type
Date
10.12.22
Title
Firmware Update: EOS R6 Firmware Version 1.5.2
Advisory Type
Date
03.17.22
Title
Firmware Update: PowerShot G7 X Mark III Firmware Version 1.3.2
Advisory Type
Date
06.08.22
Title
Firmware Update: PowerShot G7 X Mark III Firmware Version 1.3.0
Advisory Type
Date
09.29.21
Title
Firmware Update: PowerShot G7 X Mark III Firmware Version 1.2.0
Advisory Type
Date
12.12.19
Title
PowerShot G7X Mark III: Plans to release new firmware update to improve video autofocus performance
Advisory Type
Date
09.06.19
Title
Service Notice: To Users of Canon's PowerShot G7X Mark III Compact Digital Camera
Advisory Type
Date
09.25.19
Title
Firmware Update: PowerShot V10 Firmware Version 1.1.0
Advisory Type
Date
09.26.23
Title
Firmware Update: PowerShot V10 Firmware Version 1.0.1
Advisory Type
Date
07.26.23
Title
Firmware Update: PowerShot SX70 HS Firmware Version 1.1.1
Advisory Type
Date
11.21.19
Title
Service Notice: To Users of Compact Digital Cameras
Advisory Type
Date
01.20.15
Title
Service Notice:Canon PowerShot SX50 HS rubber of the viewfinder
Advisory Type
Date
12.31.13
Title
Firmware Update: PowerShot ZOOM Firmware Version 1.1.0
Advisory Type
Date
08.30.21
Title
Service Notice: NFC Function Will Be Discontinued For Selected Models
Advisory Type
Date
07.24.20
Title
Service Notice: PIXMA TS9000 series, TS8000 series and TS6000 series printers, free repair if<br> the feed roller gear becomes disconnected from the printer
Advisory Type
Date
11.26.17
Title
Service Notice: PowerShot ELPH 330HS Compact Digital Camera
Advisory Type
Date
03.06.14
Title
Firmware Update: PowerShot SX530 HS Firmware Version 1.1.0.0
Advisory Type
Date
04.15.20
Title
Firmware Notice: EOS 80D Firmware Update, Version 1.0.3
Advisory Type
Date
08.07.19
Title
Firmware Notice: EOS 80D Firmware Update, Version 1.0.2
Advisory Type
Date
02.21.17
Title
Announcement: PowerShot SX740 HS Firmware Update, Version 1.0.1
Advisory Type
Date
01.31.19
Title
Firmware Update: PowerShot SX740 HS Firmware Version 1.0.2
Advisory Type
Date
11.21.19
Title
Service Notice: To Owners of the EOS-1D X Mark II Digital SLR Camera “Shooting Still Images with a CFast Card Manufactured by SanDisk Corporation”
Advisory Type
Date
06.24.16
Title
Service Notice: EOS-1D X and EOS-1D C
Advisory Type
Date
04.28.14
Title
Safety Notice: Caution When Using Color Filter Holder SCH-E1 with Canon Speedlite 600EX / 600EX-RT
Advisory Type
Date
12.30.14
Title
Firmware Notice: EOS-1D X Firmware Update, Version 2.0.7
Advisory Type
Date
01.29.15
Title
Firmware Notice: EOS-1D X Firmware Update, Version 2.0.8
Advisory Type
Date
09.24.15
Title
Firmware Notice: EOS 5D Mark IV Firmware Version 1.0.3
Advisory Type
Date
12.05.16
Title
Firmware Notice: EOS 7D Mark II Firmware Upgrade, Version 1.1.0
Advisory Type
Date
09.14.16
Title
Product Advisory: Speedlite 600EX-RT flash products
Advisory Type
Date
08.16.15
Title
Service Notice: Canon EOS Rebel T6s/EOS 760D & EOS Rebel T6i/EOS 750D
Advisory Type
Date
05.11.15
Title
Product Advisory: Canon camera or video camcorder products
Advisory Type
Date
08.15.15
Title
Firmware Notice: To Owners of the EOS 7D Mark II Digital SLR Camera
Advisory Type
Date
08.25.16
Title
Firmware Notice: EOS-1D X Mark II Firmware Update, Version 1.0.2
Advisory Type
Date
07.12.16
Title
Service Notice: EOS 5D Mark III Change in Displayed Exposure Value
Advisory Type
Date
06.24.14
Title
Service Notice: EOS-1D X Mark II, "Image corruption with some SanDisk CFast cards"
Advisory Type
Date
06.28.16
Title
Firmware Notice: EOS 7D Mark II Firmware Update, Version 1.0.4
Advisory Type
Date
05.26.15
Title
Service Notice: ROM Upgrade Procedure for PIXMA MG3510
Advisory Type
Date
07.02.14
Title
Firmware Update: EOS-1D X Mark II Firmware Version 1.1.8
Advisory Type
Date
05.27.21
Title
Firmware Update: Wireless File Transmitter WFT-R10A Firmware Version 1.2.1
Advisory Type
Date
02.25.22
Title
Firmware Update: EOS 5D Mark IV Firmware Version 1.3.3
Advisory Type
Date
06.16.21
Title
Firmware Update: EOS Rebel SL3/200D II/250D Firmware Version 1.0.2
Advisory Type
Date
11.21.19
Title
Firmware Update: EOS 5D Mark IV Firmware Version 1.3.1
Advisory Type
Date
02.09.21
Title
Firmware Notice: EOS-1D X Mark II Firmware Version 1.1.3
Advisory Type
Date
02.21.17
Title
Firmware Update: EOS 5D Mark IV Firmware Version 1.3.2
Advisory Type
Date
05.27.21
Title
Firmware Notice: EOS RP Firmware Version 1.3.0
Advisory Type
Date
09.26.19
Title
Firmware Notice: EOS 5D Mark IV Firmware Update, Version 1.1.2
Advisory Type
Date
04.10.18
Title
Service Notice: EF 24-105 mm f/4L IS II USM Lens
Advisory Type
Date
06.01.17
Title
Service Notice: Phenomenon in which Error 70 or Error 80 Occurs Frequently on the EOS 70D Digital SLR Camera
Advisory Type
Date
05.30.18
Title
Service Notice: Customer Support for a Phenomenon in which Error 70 or Error 80 Occurs Repeatedly on the EOS 70D Digital SLR Camera
Advisory Type
Date
06.30.22
Title
Firmware Notice: Canon 4K Camcorder VIXIA/LEGRIA GX10 Firmware Version 1.0.2.0
Advisory Type
Date
07.20.18
Title
Firmware Notice: EOS-1D X Firmware Update, Version 2.1.0
Advisory Type
Date
11.29.17
Title
Firmware Update: EOS R Firmware Version 1.6.0
Advisory Type
Date
12.11.19
Title
Firmware Update: EOS 70D Firmware Version 1.1.3
Advisory Type
Date
11.21.19
Title
Firmware Update: EOS Rebel T7 Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS Rebel T7 Firmware Version 1.2.1
Advisory Type
Date
02.21.24
Title
Service Notice: EOS 5D Mark III Digital SLR Camera LCD panel
Advisory Type
Date
04.25.12
Title
Firmware Update: EOS Rebel T6i Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: XF705 Firmware Version 1.0.2.1
Advisory Type
Date
03.19.20
Title
Service Notice: XF305 / XF300: Firmware Update Version 1.0.4.0
Advisory Type
Date
06.18.12
Title
Firmware Update: EOS RP Firmware Version 1.6.0
Advisory Type
Date
11.19.20
Title
Firmware Update: SELPHY CP1300 Firmware Version 1.0.2.0
Advisory Type
Date
03.26.24
Title
Service Notice: EOS 60D / EOS 60Da Firmware Update, Version 1.1.1
Advisory Type
Date
06.16.12
Title
Firmware Update: Wireless File Transmitter WFT-R10A Firmware Version 1.3.0
Advisory Type
Date
09.26.23
Title
Firmware Update: EOS Rebel T7i Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: RF 600mm f/4L IS USM Firmware Version 1.0.6
Advisory Type
Date
04.16.24
Title
Firmware Update: EOS M50 Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS Rebel SL2 Firmware Version 1.1.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS Rebel T7 Firmware Version 1.2.0
Advisory Type
Date
05.18.23
Title
Advisory Type
Date
02.05.24
Title
Firmware Update: Wireless File Transmitter WFT-R10A Firmware Version 1.3.1
Advisory Type
Date
03.26.24
Title
Firmware Update: EOS R Firmware Version 1.7.0
Advisory Type
Date
07.31.20
Title
Firmware Update: EOS 5D Mark IV Firmware Version 1.3.0
Advisory Type
Date
10.19.20
Title
Firmware Update: EOS 5D Mark IV Firmware Version 1.4.0
Advisory Type
Date
05.18.23
Title
Firmware Update: XF705 Firmware Version 1.0.4.1
Advisory Type
Date
06.17.20
Title
Service Notice: EOS-1D X Firmware Update Version 1.0.6
Advisory Type
Date
08.28.12
Title
Service Notice: PowerShot S100 Lens Issue
Advisory Type
Date
06.28.12
Title
Firmware Update: EOS Rebel T7i Firmware Version 1.0.2
Advisory Type
Date
02.13.20
Title
Firmware Update: Speedlite EL-1 Firmware Version 1.0.2
Advisory Type
Date
03.30.23
Title
Firmware Notice: XF705 Firmware Version 1.0.3.1: May Cause the Camcorder to Freeze
Advisory Type
Date
06.12.20
Title
Service Notice: EOS 5D Mark III AE sensor
Advisory Type
Date
04.17.12
Title
Firmware Update: EOS RP Firmware Version 1.5.0
Advisory Type
Date
07.31.20
Title
Firmware Update: Canon Laser Printer and Small office Multifunctional Printer related to IP Stack protocol
Advisory Type
Date
11.02.20
Title
Firmware Update: EOS R Firmware Version 1.8.0
Advisory Type
Date
11.19.20
Title
Firmware Update: Wireless File Transmitter WFT-R10A Firmware Version 1.1.0
Advisory Type
Date
08.26.20
Title
Firmware Update: EF 100-400mm f/4.5-5.6L IS II USM Firmware Version 1.0.7
Advisory Type
Date
11.05.20
Title
Firmware Notice: EOS R Firmware Update Ver 1.1.0
Advisory Type
Date
02.12.19
Title
Service Notice: XF305 / XF300 Firmware Update, Version 1.0.7.0
Advisory Type
Date
12.22.14
Title
Service Notice: EOS-1D X Firmware Update, Version 1.1.1
Advisory Type
Date
10.18.12
Title
Service Notice: EOS-1D X Firmware Updated, version 1.1.1
Advisory Type
Date
10.18.12
Title
Firmware Notice: Canon XA25, XA20, VIXIA HF G30, Firmware Version 1.0.5.0
Advisory Type
Date
01.18.16
Title
Firmware Notice: EOS 5D Mark III Firmware Update, Version 1.3.3
Advisory Type
Date
01.29.15
Title
Firmware Notice: EOS-1D X Mark II Firmware Update, Version 1.1.4
Advisory Type
Date
11.29.17
Title
Firmware Notice: EOS 5D Mark III Firmware Update, Version 1.3.5
Advisory Type
Date
11.29.17
Title
Firmware Update: EOS Rebel SL3/ EOS 250D / EOS 200D II / EOS Kiss X10 Firmware Update, Version 1.0.1
Advisory Type
Date
08.07.19
Title
Firmware Update: EOS M50 Firmware Version 1.0.3
Advisory Type
Date
11.21.19
Title
Firmware Update: PowerShot G5 X Mark II Firmware Version 1.1.0
Advisory Type
Date
12.12.19
Title
Firmware Update: EOS Rebel T7 Firmware Version 1.0.1
Advisory Type
Date
02.13.20
Title
Firmware Update: EOS R Firmware Version 1.4.0
Advisory Type
Date
09.26.19
Title
Firmware Notice: EOS-1D X Mark II Firmware Version 1.1.6
Advisory Type
Date
04.10.18
Title
Firmware Update: EOS RP Firmware Version 1.4.0
Advisory Type
Date
10.31.19
Title
Firmware Update: EOS 90D Firmware Version 1.1.1
Advisory Type
Date
11.05.19
Title
Firmware Update: EOS Rebel T6i Firmware Version 1.0.1
Advisory Type
Date
02.13.20
Title
Firmware Notice: EOS M50 Firmware Update, Version 1.0.1
Advisory Type
Date
09.04.18
Title
Firmware Update: EOS 7D Mark II Firmware Version 1.1.3
Advisory Type
Date
11.21.19
Title
Firmware Update: EOS Rebel SL2 Firmware Version 1.0.3
Advisory Type
Date
02.13.20
Title
Firmware Notice: Canon 4K Camcorder XF405 / XF400 Firmware Version 1.0.2.0
Advisory Type
Date
07.20.18
Title
Firmware Notice: EOS 5D Mark IV Firmware Version 1.3.2 Discontinued
Advisory Type
Date
06.03.21
Title
Firmware Notice: Canon HD Video Camera XF205 & XF200, Firmware Version 1.0.5.0
Advisory Type
Date
05.18.18
Title
Firmware Notice: EOS M50 Firmware Update, Version 1.0.2
Advisory Type
Date
01.31.19
Title
Safety Notice: EOS 5D Digital SLR cameras whose main mirror has detached
Advisory Type
Date
09.30.15
Title
Advisory Type
Date
02.24.25
Title
Firmware Update: RF 800mm f/5.6L IS USM Firmware Version 1.0.4
Advisory Type
Date
04.16.24
Title
Advisory Type
Date
01.27.25
Title
CPE2024-004 – Multiple MiCard PLUS Card Reader Dropped Characters
Advisory Type
Date
Title
Advisory Type
Date
09.16.24
Title
adv-0901e02481f00740
Advisory Type
Date
Title
Advisory Type
Date
06.10.24
Title
Advisory Type
Date
04.17.25
Title
Service Notice: Firmware Update Request to Address Security Enhancements when Accessing the Canon Cloud Integration Service Operation Servers
Advisory Type
Date
09.27.24
Title
Firmware Notice: Canon PowerShot SX270 HS Firmware Version 1.0.1.0
Advisory Type
Date
11.12.16
Title
Service Notice: Free Repairs for EF-S 18-55mm f/3.5-5.6 IS II and EF-S 18-55mm f/3.5-5.6 III Interchangeable Lenses for Digital SLR and Mirrorless Cameras
Advisory Type
Date
10.31.23
Title
Advisory Type
Date
03.15.24
Title
Firmware Update: PowerShot PICK Firmware Version 1.3.0
Advisory Type
Date
07.01.22
Title
Firmware Update: PowerShot PICK Firmware Version 1.2.0
Advisory Type
Date
03.23.22
Title
Firmware Update: EOS R7 Firmware Version 1.3.1
Advisory Type
Date
05.31.23
Title
Service Notice: Wireless File Transmitter WFT-E2IIA: Firmware Update Version 1.0.4
Advisory Type
Date
08.22.11
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.6.2
Advisory Type
Date
10.18.22
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.7.0
Advisory Type
Date
03.02.23
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.1.0
Advisory Type
Date
04.07.20
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.7.1
Advisory Type
Date
03.30.23
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.6.0
Advisory Type
Date
12.01.21
Title
Firmware Update: EOS R7 Firmware Version 1.2.0
Advisory Type
Date
11.22.22
Title
Firmware Update: EOS R7 Firmware Version 1.3.0
Advisory Type
Date
03.02.23
Title
Firmware Update: EOS R7 Firmware Version 1.1.0
Advisory Type
Date
07.21.22
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.6.1
Advisory Type
Date
02.08.22
Title
Service Notice: DPP High-Performance Noise Reduction Processing in Canon Cloud Imaging Service will be Discontinued
Advisory Type
Date
07.20.21
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.2.0
Advisory Type
Date
08.26.20
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.3.0
Advisory Type
Date
11.19.20
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.8.0
Advisory Type
Date
09.26.23
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.9.0
Advisory Type
Date
03.26.24
Title
Future Firmware Plan: EOS-1D X Mark III
Advisory Type
Date
03.24.20
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.2.1
Advisory Type
Date
10.08.20
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.4.0
Advisory Type
Date
03.29.21
Title
Firmware Update: EOS-1D X Mark III Firmware Version 1.5.0
Advisory Type
Date
07.09.21
Title
Firmware Update: EOS R10 Firmware Version 1.1.0
Advisory Type
Date
07.21.22
Title
Service Notice: Wireless File Transmitter WFT-E5A, Firmware Version 1.0.6
Advisory Type
Date
08.22.11
Title
Firmware Update: EOS R10 Firmware Version 1.2.0
Advisory Type
Date
11.22.22
Title
Firmware Update: EOS R10 Firmware Version 1.3.0
Advisory Type
Date
03.02.23
Title
Service Notice: EOS R10
Advisory Type
Date
03.30.23
Title
Service Notice: Wireless File Transmitter WFT-E5A: Firmware Version 1.0.7
Advisory Type
Date
08.06.12
Title
CP2025-005 Vulnerabilities Remediation for Certain Printer Drivers
Advisory Type
Date
09.25.25
Title
CPE2025-052 - Vulnerability Mitigation/Remediation for Therefore Online and On-Premises
Advisory Type
Date
10.31.25
Title
Service Notice: Regarding Remediation Measure Against Potential Buffer Overflow Vulnerability in Laser Printers and Small Office Multifunctional Printers
Advisory Type
Service Notice
Date
01.15.26
ABOUT CANON
PRODUCT RESOURCES
ABOUT CANON
PRODUCT RESOURCES
Ⓒ 2026
