PowerShot A2300 Blue
- PowerShot A2300
- Battery Pack NB-11L
- Battery Charger CB-2LD
- Wrist Strap WS-800
- USB Interface Cable IFC-400PCU
- Digital Camera Solution CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Type Of Camera | Compact Digital Camera With Built-In Flash, 5x Optical, 4x Digital, And 20x Combined Zoom With Optical Image Stabilizer |
Type | 16.0 Megapixel 1/2.3-Inch CCD |
Total Pixels | 16.6 Megapixels |
Effective Pixels | 16.0 Megapixels |
Focal Length | 5.0 (W) - 25.0 (T) Mm (35mm Film Equivalent: 28 (W) - 140 (T) Mm) |
Digital Zoom | 4x |
Focusing Range | Normal: 2.0 In. (5cm) - Infinity (W), 3.9 Ft. (1.2m) - Infinity (T) Auto: 1.2 In. (3cm) - Infinity (W), 3.9 Ft. (1.2m) - Infinity (T) Macro: 1.2 In. - 2.0 Ft. (3-60cm) (W) |
Autofocus | TTL Autofocus |
Optical Viewfinder | N/A |
Lcd Monitor | 2.7-Inch TFT Color LCD With Wide-Viewing Angle |
Lcd Pixels | Approx. 230,000 Dots |
Lcd Coverage | Approx. 100% |
Maximum Aperture | F/2.8 (W) - F/6.9 (T) |
Shutter Speed | 1 - 1/2000 Sec. 15 - 1/2000 Sec. (Total Shutter Speed Range) |
Sensitivity | Auto, ISO 100/200/400/800/1600 (In P Mode) |
Light Metering Method | Evaluative*, Center-Weighted Average, Spot** * Facial Brightness Is Evaluated In Face Detect (Face Detect AE) ** Fixed To Center |
Exposure Control Method | AE Lock |
Exposure Compensation | +/-2 Stops In 1/3 Stop Increments (Not Available When Shooting Movies) |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom *Facial Color Is Evaluated In Face Detect (Face Detect WB) |
Built In Flash | Auto, On, Slow Synchro, Off Facial Brightness Is Also Evaluated In Face Detect. |
Flash Range | 1.6 - 9.8 Ft. (W), 3.3 - 6.6 Ft. (T) (50 Cm - 3.0 M (W), 1.0 - 2.0 M (T) |
Recycling Time | 10 Seconds Or Less (Battery Voltage: 3.7V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto, P, Live View Control, Digital IS, Portrait, Face Self-Timer, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Snow, Fireworks, Long Shutter, Discreet, IFrame Movie* *Shooting Movies Is Possible With The Movie Button. |
Photo Effects | N/A |
Self Timer | Approx. 10-Sec Delay/Approx 2-Sec Delay/Custom* * Delay Time (0 - 15 Sec. (In One-Second Increments), 20/25/30 Sec.) And Number Of Shots (1 - 10 Shots (In One-Shot Increments) Can Be Specified. |
Wireless Control | N/A |
Continuous Shooting | Approx: 0.8 Shots/Sec. (In P Mode) Approx. 2.8 Shots/Sec. (In Low Light Mode) |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design Rule For Camera File System, DPOF (Version 1.1) Compliant |
Jpeg Compression Mode | Still Images: Exif 2.3 (JPEG) Movies: MOV (Image Data: H.264; Audio Data: Linear PCM (2 Channel Monoaural)) |
Number Of Recording Pixels | Still Images: [Large]: 4608 X 3456 Movies: [Miniature Effect] [IFrame Movie] [Other Than The Above] *1 Shooting: 5 Fps / 2.5 Fps / 1.25 Fps |
Content |
*When Shooting In Digital IS Or Low Light *The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
Content |
Playback Modes File | Still Images And Movies: Still Images: Movies: Displays Playback Position And Shooting Time *1 Audio Settings Available In 5 Levels |
Erase Modes | Single Image*, Erase All The Image Data In The Memory Card Stored With The Design Rule For Camera File Systems Format Can Be Erased (However, Protected Images Cannot Be Erased). * Movies Can Be Erased Individually. |
Computer Interface | Hi-Speed USB*1 (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video*2) *1 Use Of USB Logomark Is Not Allowed. *2 Mini-B Compatible. |
Video Out | NTSC/PAL (Unified Type Dedicated Connector (Female)) With Digital, Audio And Video |
Audio Out | Monaural (Unified Type Dedicated Connector (Female)) With Digital, Audio And Video |
Other | Memory Card Slot; Direct Connection To Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers And PictBridge-Compatible Printers Via Camera's USB 2.0 Hi-Speed Cable |
Power Source | 1. Rechargeable Lithium-Ion Battery NB-11L 2. Compact Power Adapter CA-DC10 (Included With AC Adapter Kit ACK-DC90) |
Shooting Capacity Bp 511 | Approx. 210 Shots |
Playback Time Bp 511 512 | Approx. 5 Hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions W X H X D | 3.72 X 2.13 X 0.79 In. (94.4 X 54.2 X 20.1mm) |
Weight | Approx. 4.41 Oz. / 125 G (Including The Battery And Memory Card) Approx. 3.84 Oz. / 109 G (Camera Body Only) |
