Service Notice: VIXIA HF S10/HF S100 Firmware Update Version 1.0.4.0
Thank you for using Canon products.
Firmware
Details of Version 1.0.4.0 Firmware Update
This firmware adds the ability to record, playback, and copy movies in MXP and FXP modes with SD or SDHC memory cards that have an SD Speed Class of Class 10.
This notification is intended for customers who use Class 10 SD cards only; if you are using Class 4 or Class 6 cards, you can continue to use them as is without performing this firmware update.
How to update the firmware
This firmware can only updated by Canon Service Centers. Should you wish to have the firmware of your HF S10/HF S100 updated, please contact our customer support centers and Authorize Service Facilities of your region.
Please note that, once the camcorder is updated to the latest version, it cannot be restored to a previous version.
| How to identify units that are covered by this firmware update Firmware versions covered by this update If the firmware for your camcorder is currently version 1.0.0.0 through 1.0.3.0, please perform this update. If the firmware version is already 1.0.4.0, this update does not apply. You can check the firmware version of your camcorder by following the procedure below. | |
| 1. Set the camcorder to photo playback mode. | |
| 2. Press the FUNC. (function) button, and then select Menu. | |
| 3. Operate the joystick to select the System Settings tab. | |
| 4. Check the version shown in Firmware. (1.0.x.0) | |
Affected Products
VIXIA HF S10
VIXIA HF S100
Contact Information
If you have any inquiry about the firmware update, please contact the authorize service facilities of your region.
| Country | Telephone | Schedule | ||||||
| Argentina | 0800-222-2056 | Monday - Friday 10:00-19:00 | ||||||
| Bolivia | 0800-100-943 | Monday - Friday 9:00 - 18:00 | ||||||
| Brasil | 0800-60-22666 | Monday - Friday 8:30 - 17:30 | Brasil other regions | |||||
| Brasil | 11 - 4083-7003 | Monday - Friday 8:30 - 17:30 | São Paulo | |||||
| Chile | 800 470 855 | Monday - Friday 8:30 - 18:30 | Santiago | |||||
| Chile | (56 2) 462 2157 | Monday - Friday 8:30 - 18:30 | Chile other regions | |||||
| Colombia | 01-800-518-1730 | Monday - Friday 8:00 - 17:00 | ||||||
| Costa Rica | 0800-507-1025 | Monday - Friday 7:00 - 16:00 | ||||||
| Ecuador | 1800-000029 | Monday - Friday 8:00 - 17:00 | ||||||
| El Salvador | 800-622 | Monday - Friday 7:00 - 16:00 | ||||||
| Guatemala | 1-800-299-0029 | Monday - Friday 7:00 - 16:00 | ||||||
| Honduras | 1-800-279-19078 | Monday - Friday 7:00 - 16:00 | ||||||
| México | 01800 710 7168 | Monday - Friday 8:30 - 19:30 | ||||||
| Nicaragua | 1-800-507-0016 | Monday - Friday 7:00 - 16:00 | ||||||
| Panamá | 800-2040 | Monday - Friday 8:00 - 17:00 | ||||||
| Paraguay | 009 800 05420065 | Monday - Friday 9:00 - 18:00 | ||||||
| Perú | 0800-54-803 | Monday - Friday 8:00 - 17:00 | ||||||
| Rep. Dominicana | 1-800-751-2686 | Monday - Friday 9:00 - 18:00 | ||||||
| Uruguay | 000-405-4410 | Monday - Friday 10:00 - 19:00 | ||||||
