Wireless File Transmitter WFT-E7A
- Wireless LAN support for IEEE802.11 a/b/g/n, delivering ultra-fast image transfer speed
- Support for wired LAN Ethernet-1000BASE-T for high speed communication
- Media server (DLNA) supported
- Bluetooth compatible GPS devices can be connected wirelessly
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Type | Image Transfer Accessory Compatible With IEEE 802.11a, IEEE 802.11b, IEEE 802.11g And IEEE 802.11n Wireless LAN Support (IPsec-Compatible). Can Support GPS Devices With An Internal Bluetooth Function. | |||||||||
| Compatible Cameras | EOS 5D Mark III | |||||||||
| Ftp Transfer | Transfer Images Over A Network To FTP Servers | |||||||||
| Eos Utility | EOS Utility-Based Control Of Cameras Over A Network | |||||||||
| Wft Server | Browser-Based Remote Capture And Downloading Of Images Over A Network | |||||||||
| Linked Shooting | ·Max. 10 Cameras ·Transmission Range: 328.1 Ft. / 100m From The Master Camera (When Single Strength Is Favorable) ·WFT Server Start: Possible When Connecting Manually To Slave Camera |
| Transmission Range | Linked Shooting: Approx. 328.1 Ft. / 100 M From The Master Camera When Signal Strength Is Favorable Wireless LAN: Approx. 492.1 Ft. / 150 M ·With No Obstructions Between The Transmitting And Receiving Antennas And No Radio Interference ·When A Large, High-Performance Antenna Is Installed At A Wireless LAN Access Point Bluetooth V2.1 + EDR: Approx. 32.8 Ft. / 10 M |
| Camera Connection | USB Terminal | |||||||||
| Wired Lan Connection | Ethernet 10BASE-T, 100BASE-T, 1000BASE-T | |||||||||
| External Device Connection | Available | |||||||||
| Power Supply | Powered By One Battery Pack LP-E6 | |||||||||
| Image Transfer Capacity |
Note: ·Using A Fully Charged LP-E6 ·Under Camera & Imaging Products Association (CIPA) Conditions For Testing Shooting Capacity, When Using Automatic Image Transfer With Images That Are Approx. 6MB. ·Fewer Images Can Be Transferred If The Wireless LAN Transfer Rate Drops, And For Consecutive Image Transfer Over Wireless LAN. ·If The Remaining Battery Level Drops Below 19%, Captured Images Cannot Be Transferred. |
| W H D | 5.3" X 1.2" X 2.4"/134.1mm X 31.1mm X 62.2mm | |||||||||
| Oz G | 5.8oz./165g | |||||||||
| Temperature | 32°F To 104°F/0°C To 40°C | |||||||||
| Humidity | 85% Or Less |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
