WG7140 Multifunction Printer
- WG7140 Multifunction Printer
- PGI-7100 Series XXL Starter Black Cartridge
- PGI-7100 Series XXL Starter Cyan Cartridge
- PGI-7100 Series XXL Starter Magenta Cartridge
- PGI-7100 Series XXL Starter Yellow Cartridge
- MC50 Maintenance Cartridge (Pre-Installed)
- Power Cord
- RJ11 Telephone Cable
- Driver Installation DVD
- Installation Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Supported file formats include: JPEG, TIFF and PDF.
- "Jam Defying Design" refers to the WG7100 Series straight paper path designed to help reduce and prevent paper jams.
- Print Speed is based on ISO/IEC 24734 including Canon original method. Measured in default mode (General Office Mode: 600dpi) / fast mode (Office Document Mode: 300dpi) using paper cassette 1. Print speed varies depending on system configuration, interface, software, content of document, print mode, media type, weight and used cassette, etc. Print Speed (FPOT) is based on ISO/IEC17629 using paper cassette 1. Print speed varies depending on system configuration, interface, software, content of document, print mode, media type, weight and used cassette etc.
- Average copy time from ADF. Set the original on ADF and measure time from pushing the scanning button to output the copied paper. Based on ISO/IEC 17991 scESAT30secA. Scanning Speed (SEND), measured in Canon original method is based on ISO/IEC 17911, scEFTP30secF. ADF scan speeds/Scanning speed (SEND) vary depending on system configuration, interface, software, etc.
- Requires an Android mobile device with NFC hardware running Android 4.4 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality. Certain exceptions and restrictions may apply.
- Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/1200 inch at minimum.
- Copy Speed is based on Canon original Method. With Canon original chart, execute the continuous copy and calculate copy pages per minute. First-Copy-Out Time is based on ISO/IEC 29183.
- Optical Resolution is based on ISO/IEC 14473. This is the maximum sampling rate when scanning the original. When scanning in high resolution, scanning area size may be limited.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual speed varies depending on document complexity, fax setting at receiving end, and line conditions etc.
- Fax resolution measured as follows; Standard (8 dots/mm × 3.85 lines/mm), Fine (8 dots/mm × 7.7 lines/mm), Super Fine (8 dots/mm × 15.4 lines/mm, and Ultra Fine (16 dots/mm × 15.4lines/mm).
- Fax memory is measured with Canon original FAX testing chart. This number varies depending on the available memory size, content of document and etc.
- AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to Mac running MacOS X 10.9 or later supports AirPrint via USB connection.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
- Requires an Internet connection and the Canon PRINT Business app, available for free on the App Store and at Google Play. Compatible with iPad and iPhone devices running iOS 10.0 or later, and Android mobile devices running Android 4.4 or later. For more information, including compatibility, please visit https://www.cla.canon.com/cla/en/office/MobileApps. Certain exceptions and restrictions may apply.
- Canon Print Service is a print plugin for Android 4.4 smart devices, which enables printing from Android 4.4 devices to many Canon printers via a Wi-Fi network. The plugin does not work as a standalone app, it is designed to work with specific Android print systems. Certain exceptions or restrictions may apply.
- For full functionality of Windows Printer Driver (DSL/PCL/PS), Windows Fax Driver, Windows Scanner Driver/Scan Utility, Windows Printer Driver (v4), Master Installer, and Composite Installer Windows 10 or Windows 8.1 is recommended while utilizing a Windows operating system. Version 3.80 CUPS Driver is required while utilizing a Linux operating system.
- Duty Cycle is defined as the maximum number of printed pages for a single peak month.
- Typical Electricity Consumption (TEC) value: TEC value was calculated assuming the unit will be constantly switched among operational mode, sleep mode, and power-off mode for 5 days, and that it will be either in sleep or power-off mode for the remaining 2 days within the same week. The TEC value of this product is calculated by Canon on their own accord using TEC measurement procedure regulated in International ENERGY STAR Program.
- Print quality might be lower depending on the operating environment.
- Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24711 (test method) and ISO/IEC 24712 (chart). Depending on print mode, print original, environment, user maintenance mode and its frequency etc, this value varies. Page yield is based on the consumption data from the succeeding ink tank but not the first ink tank. Page yield of setup ink tank is based on remaining ink after consuming for initial printer setup.
| Printing Method | Standard: Print, Copy, Scan, Send |
| Print Speed Text | Black/Color: Up To 40 PPM (General Office Mode - 600 Dpi/Simplex) Up To 70 PPM (Office Document Mode - 300dpi/Simplex)3 Up To 20 PPM (General Office Mode - 600 Dpi/Duplex)3 |
| Resolution Text | 1200x1200 Dpi7 |
| Ink Compatibility | PGI-7100 Series XXL 4 Ink Cartridges (1x Black, Cyan, Magenta, Yellow) |
| Paper Sizes | Cassette: 8.5"X11" (Letter), 11.7"X17" (Tabloid/Ledger), A3 , Multi-Purpose Tray: 4"X6" To 13"X19" |
| Automatic Sheet Feeder | Capacity: 100 Sheets (Letter) |
| Print Features | Print Technology FINE (Full-Photolithography Inkjet Nozzle Engineering) Line Print Head Maintenance Cartridges 1 Maintenance Cartridge Ink Type High Density Pigment Ink (Water & Highlighter Resistant) Borderless Printing No Duplex Printing Standard Standard Print Languages PCL6, PDF Direct, PS3 (Postscript Level 3), UFR II, TIFF, JPEG, WSD Printing, XPS Direct Automatic Paper Size Sensor Standard |
| Paper Handling Text | Standard: 2 Cassettes - 1,150 Sheets (550 Sheets/Per Cassette X2) + 50 Sheet Multi-Purpose Tray Optional: 4 Cassettes - 2,250 Sheets (550 Sheets/Per Cassette X4) + 50 Sheet Multi-Purpose Tray |
| Paper Weights | Cassettes 1-4: Minimum Weight: 14 Lb. Bond, Maximum Weight: 80 Lb. Cover/ 121 Lb. Index Plain Paper (64-105gsm), Thin Paper (52-63gsm), Thick Paper (106-220gsm) (Cassette 1 & 2 Only), Thick Paper (106-163gsm) (Cassette 3 Only) Colored Paper (64-82gsm), Recycl |
| Output Tray Capacity | 250 Sheets (Letter) / 100 Sheets (A3) |
| Mono Copy Resolution | Black/Color (Text & Graphics): Up To 600 Dpi7 |
| Mono Copy Speed Up To | Black / Color (ISO/Simplex): Up To 40 PPM8 |
| No Of Copies | Up To 999 Copies |
| First Copy Time | As Fast As 5.8 Seconds (Simplex)8 |
| Reductions Enlargement | 25 - 400% |
| Copy Feature | Page Continuous Scanning, 4-On-1 Reduced Layout, ID Card Copying, Mixed Document Loading, Erase Book Frame, Image Adjustment (Color, Quality & Sharpness Adjustment) |
| Scanner Type | Flatbed, ADF (Single-Pass & Duplex Scanning) |
| Scanning Element | CIS (Contact Image Sensor) X2 |
| Max Resolution Text | Optical: Up To 600 X 600 Dpi, Selectable: Up To 9600 X 9600 Dpi9 |
| Scanner Features | ADF Scan Speed Simplex: Up To 40 Ipm (Color/BW), Duplex: Up To 65 Ipm (Color/BW) Mixed Document Loading Yes Grayscale Levels 256 File Format JPEG, TIFF, PDF ( Normal / Compact), Searchable PDF Digital Sending Standard Features Send Lite (Destinations: I-Fax (Simple), E-Mail, SMB, FTP) |
| Color Depth | 24-Bit (Color) / 8-Bit (Gray) |
| Max Document Size | Flatbed & ADF: 11.7" X 17" (A3) |
| Other Features | 5.0" LCD Touchscreen |
| Os Compatibility | Windows: Windows® 10 (64-Bit), Windows 8.1, Windows 7, Windows Server 2016, Windows Server 2012 / R2, Windows Server 200818 Mac: MacOS V10.13-10.12, Mac OS X V10.11 - 10.8.518 Linux: Fedora 26/27 (64-/32-Bit), Ubuntu 17.04/17.10 Desktop (64-/32-Bit), Debian 9.1/9.2 (64-/32-Bit), CentOS 7.418 |
| Standard Interface | USB 2.0 (PC Connectivity) USB 2.0 (USB Memory)1 Ethernet 10/100/1000 Base-TX Network RJ-11 Modem Port RJ-11 Phone Line |
| Power Source | AC 100 - 240V, 50/60 Hz |
| Power Consumption Approx | Maximum Power Consumption: Approx. 300 W Off: Approx. 0.1 W Sleep/Standby: Approx. 1.9 W TEC (Typical Electricity Consumption): Approx . 1.25 KWh/Week (In Use) |
| Dimension W X D X H | Standard Configuration: 22.1" (W) X 23.3" (D) X 34.7" (H) Fully Configured With Optional CF10 Paper Cassette Feeding Unit: 22.1" (W) X 23.3" (D) X 44.7" (H) |
| Weight | Standard Configuration Weight(S): WG7140: 179.1 Lbs. Fully Configured Weight(S): WG7140: 220.3 Lbs. |
| Operating Temperature | 59 To 86°F |
| Operating Humidity | 20 To 85% RH |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
