VIXIA HF R800
- VIXIA HF R800 Camcorder
- Battery Pack BP-727
- Compact Power Adapter CA-110
- Mini-HDMI Cable HTC-100
- USB Interface Cable IFC-300PCU/S
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Capture your family's most precious memories with the VIXIA HF R800 camcorder. Thanks to its powerful zoom, you can record moments near, far and in between. Exciting new features include Highlight Priority mode with backlight correction to help you get the best shots you can, and improved slow and fast recording options that let you experiment with different ways to record. The lightweight package of the VIXIA HF R800 means you can keep it on hand to record whatever you want, whenever you want, to removable SD cards that provide quick and convenient sharing. Easy to use and bring with you, pick up the VIXIA HF R800 and start making memories.
You won't miss any of the action when shooting video with the VIXIA HF R800 camcorder and its impressive 57x Advanced Zoom range. Long-range shooting allows you to create videos with dynamic variety, and is less likely to disrupt the action you're shooting. It's ideal for formal ceremonies, animals in the wild, candid family videos and more. Available in manual mode, Advanced Zoom takes the camcorder's telephoto power from 32.5mm all the way to 1853mm (35mm equivalent) for amazing flexibility in shooting. For more convenient shooting and better creative control over your videos, the camcorder offers continually variable Zoom Speed settings with 15 levels available.
Canon's sophisticated SuperRange Optical Image Stabilizer helps correct camera shake quickly, so even handheld video taken at long focal lengths can be sharp and steady. Providing continuous adjustment throughout the entire zoom range to correct a broad range of motion, the Dynamic Image Stabilization system on the VIXIA HF R800 camcorder stabilizes rotational camera shake. Controlling rotational camera shake horizontal, vertical and roll axis helps ensure smooth, virtually distortion-free video, even when you're walking while shooting.
The VIXIA HF R800 camcorder is equipped with a 3.28 Megapixel Full HD CMOS Image Sensor to capture your memories in true 1920 x 1080 resolution. Canon's advanced, high-resolution HD CMOS Image Sensor features extra sensitivity that delivers beautifully lifelike Full HD video with natural color, even in low light. On-chip noise reduction brings bright clarity to every frame. Video is rich, clear and amazingly detailed anywhere you view it, even when played back on a large HDTV.
The VIXIA HF R800 camcorder incorporates the powerful DIGIC DV 4 Image Processor for outstanding imaging performance. The DIGIC DV 4 Image Processor captures more light, for brighter, virtually noise-free images even in dark scenes. It also speeds up operation and enables steady image stabilization for clear images even when shooting handheld.
The VIXIA HF R800 camcorder records Full HD video directly to a removable SD memory card. Widely available in several capacities, SD memory cards let you share your videos quickly and easily. In addition to SD memory cards, the VIXIA HF R800 also lets you use super-high capacity SDXC cards. The same size as a standard SD card, a SDXC card can hold up to 2048 GB, and provides ultra-fast data transfer.
| MP4 | VIXIA Recording Time Chart | |||
| 1920 x 1080 Recording | 1280 x 720 Recording | |||
| 35 Mbps* | 24 Mbps* | 17 Mbps* | 4 Mbps* | |
| 8GB | 30 min. | 40 min. | 1 hr. | 4 hrs. 20 min. |
| 16GB | 1 hr. | 1 hr. 25 min. | 2 hrs. 5 min. | 8 hrs. 40 min. |
| 32GB | 2 hrs. | 2 hrs. 55 min. | 4 hrs. 10 min. | 17 hrs. 20 min. |
| 64GB | 4 hrs. | 5 hrs. 55 min. | 8 hrs. 20 min. | 34 hrs. 45 min. |
| 128GB | 8 hrs. | 11 hrs. 55 min. | 16 hrs. 45 min. | 69 hrs. 30 min. |
| When MP4 recording has continued for 12 hours, it will automatically stop and then start automatically. | ||||
* Variable bit rate.
The VIXIA HF R800 camcorder gives you high-quality MP4 recording. 1080/60p recording captures a large amount of information, virtually eliminating diagonal noise so even fast-moving subjects can show up crisply. This great sense of detail and faithful rendering of moving edges, plus enhanced color and fine tonal gradation, helps you take advantage of all that Full HD has to offer. Files are captured at a bit rate of up to 35 Mbps, so image quality is incredibly high.
Keep the VIXIA HF R800 with you for life's unforgettable memories. A lightweight, compact and convenient body means you can have the camcorder ready for those extraordinary moments, with no need to worry about it taking up precious luggage room for your vacations, outings and family trips.
The VIXIA HF R800 camcorder features a 3.0-inch capacitive touch panel LCD screen that's bright and clearly visible, even outdoors in the sun, with rich, natural color reproduction. Its streamlined user interface makes choosing focal points, tracking moving subjects, and shooting and watching your videos easy and fun. Clear explanations pop up when selecting shooting modes and recording formats, so even new videographers can feel confident as they create impressive videos.
The VIXIA HF R800 camcorder is powered by a high capacity Battery Pack BP-727. The rechargeable lithium-ion battery not only lets you shoot for long periods, but features intelligent technology can accurately indicate remaining battery time for extra insurance that you won't miss an important shooting opportunity.
The VIXIA HF R800 camcorder delivers flexible Slow and Fast Motion capabilities for a variety of customizable recording options. You can record slow-motion images at speed settings down to 0.5x, ideal for checking out your golf swing or creating movie-like slow-mo effects. Fast motion has a top speed of 1200x, recording an incredible 20 hours of action in a single one-minute scene. You can even choose new speed settings of 300x and 600x for added flexibility.
Capture your memories exactly as you see them with the improved Highlight Priority Mode, which helps to prevent loss of detail in high brightness areas. Now featuring Backlight Correction, the VIXIA HF R800 camcorder delivers footage that's more balanced and realistic, leaving you with beautiful memories to enjoy for years to come. Designed to be displayed on bright LCD TVs, you can show your videos at a high brightness setting for accurate and pleasing results.
To complement the VIXIA HF R800 camcorder's long-distance recording capability, Zoom Framing Assist helps keep distant subjects in the frame. When you're shooting at the long end of the zoom and you've lost your subject, simply press an icon on the touch screen and the zoom magnification will automatically decrease, making it easy for you to locate and zoom in on the subject. Available in Auto or Manual mode, Zoom Framing Assist helps you accurately track and capture your subject.
With one simple setting, you can keep your videos safe from accidental operational errors. The File Lock function disables deletion, dividing, trimming, copying, MP4 conversion and thumbnail changes with a touch, giving you peace of mind when children or others use your camcorder.
The VIXIA HF R800 camcorder is compatible with Canon's photo and video storage device: the Canon Connect Station CS100. It provides up to 1TB of hard drive space, storing approximately 150,000 photos or approximately 70 hours of video content^^. For ease of use, it features USB connectivity for quick file transfer, as well as simple menus for easy file storage, managing and sorting. Images and videos can then be viewed in Full HD on an HDTV, sent for printing and more.
^^ Calculated with approx. 6.6MB for each photo and with average 32 Mbps Full HD video.
CameraWindow DC software is available as a downloadable application. The software can make it easy to import MP4 and JPEG files from your VIXIA camcorder to a PC or Mac, where they can be shared and edited.
| Std Def High Def | Alta Definición | ||
| Television System | NTSC | ||
| Video Recording System | MPEG-4 | ||
| Image Sensor | CMOS De 1/4.85 De Pulgada, Filtro De Colores Primarios RGB | ||
| Number Of Recording Pixels | Aprox. 3.28 Megapíxeles | ||
| Effective Pixels | Video: Aprox. 2.07 Megapíxeles (1920 X 1080) Fotografía: Aprox. 2.07 Megapíxeles (1920 X 1080) |
| Maximum Recording Time | Tarjeta De Memoria SD De 32 GB En MP4*: * Velocidad De Bits Variable. |
| Lens | Porcentaje De Zoom: Longitud Focal: Equivalente A Película De 35 Mm: Velocidad Del Zoom: |
| Focusing System | TTL (Mediante El Lente) | ||
| Manual Exposure | Disponible | ||
| Programmed Ae | Smart AUTO, P, SCN*1, Prioridad En Tonos De Alto Brillo, Modo Cinematográfico*2 *1 Retrato, Deportes, Nieve, Playa, Atardecer, Nocturno, Poca Luz, Reflector, Fuegos Artificiales |
| Max Shutter Speed | Video: 1/2000 Segundos |
| Minimum Focusing Distance | Modo Automático: 10 Mm (Vínculo De Enfoque Automático [AF]: Extremo Gran Angular), 1 M En El Rango De Zoom Intermedio, Aprox. 50cm En El Extremo Telefoto |
| White Balance | Automático, Luz De Día, Tungsteno, Balance De Blancos Personalizado | ||
| Frame Rate | 60P/30P/24P |
| Minimum Illumination | Modo P: Aprox. 5 Lux |
| Image Stabilization | Estabilizador De Imagen Inteligente En El Modo Automático/Modo Bebé
Modos Del Estabilizador De Imagen Distintos Del Estabilizador De Imagen Inteligente; Se Pueden Realizar Las Configuraciones Del Estabilizador De Imagen Dinámico Y El Estabilizador De Imagen Automatizado De Forma Manual En Los Modos P/Prioridad En Tonos De Alto Brillo/SCN*1/Cinematográfico:
*Son Compatibles La Detección De La Velocidad Angular (Mediante Un Sensor Piezoeléctrico De Vibración) Y La Detección De Vectores De Movimiento Por Sensor (Compatible Con La Opción Híbrida). *1 Retrato, Deportes, Nieve, Playa, Atardecer, Nocturno, Poca Luz, Reflector, Fuegos Artificiales |
| Filter Diameter | Diámetro De 43 Mm | ||
| Viewfinder | No Está Disponible | ||
| Lcd Screen | Pantalla LCD Ancha, De 3.0 Pulgadas (7.51cm), En Colores, Táctil (Aprox. 230,000 Puntos) | ||
| Recording Media | Una Ranura De Tarjeta De Memoria SD/SDHC/SDXC/FlashAir | ||
| Usb Terminal | Mini AB: Es Compatible Con Hi-Speed USB | ||
| Video Terminal | Configuración De Señales: Señal De Video NTSC Estándar En Color Resolución Horizontal |
| Audio | Tipos De Señales: Señal De Audio Estéreo |
| Accessory Shoe | No Está Disponible | ||
| Supplied Video Editing Software | No Está Disponible | ||
| Hdmi Terminal | Miniconector HDMI, Salida Solo Para Imágenes Y Sonido | ||
| Av Mini Terminal Headphone Terminal | Miniconector Estéreo De 3.5 Mm De Diámetro (También Funciona Como Miniterminal AV) |
| Operating Temperature Range | De 23° A 113 °F (De -5° A 45 °C) Humedad Relativa De 60% (Durante El Funcionamiento) De 32° A 104 °F (De 0° A 40 °C) Humedad Relativa De 85% (Rendimiento) |
| Dimensions | Aprox. 2.1 X 2.3 X 4.6 Pulgadas/53 X 58 X 116 Mm (No Incluye La Correa) | ||
| Weight | Aprox. 8.3 Oz/235 G (Cuerpo, No Incluye La Correa) Aprox. 10.8 Oz/305 G (Incluye La Batería BP-727, La Tarjeta De Memoria Y La Correa) |
| Content |
Soft Carrying Case SC-2000
Protect your camcorder with the professional-quality SC-2000 Soft Carrying Case, featuring secure compartments for filters and extra battery packs.
WM-V1 Wireless Microphone
Compact, high performance wireless microphone for recording audio up to 164 feet away (50 meters).
Pan Cradle CT-V1
Enables remote control panning (approx. 200-degree rotation) of select VIXIA ,camcorders using a compatible mobile device. Compatible with the VIXIA mini X and VIXIA HF R50/R52/R500 camcorders.Powered by supplied AC Adapter or two AA batteries.
STV-250N Mini Plug to RCA
Used to connect to a TV or VCR.
HTC-100
Mini-HDMI Cable: connects Canon HD Camcorders/select PowerShot Cameras to HDMI compatible TV.
Interface Cable IFC-400PCU
The Canon IFC-400PCU USB Interface Cable enables you to transfer your camera pictures to a computer fast. The cable connects to your camera and to the USB port on your PC or MAC Computer.
Shoulder Strap SS-600
WRIST STRAP WS-20
Shoulder Strap SS-650
This small but rugged shoulder strap gives you added security with leather reinforced attachments and is convenient for hands free transportation.
Neck Strap NS-10
Neck Strap for your FS Camcorder.
Battery Pack BP-718
Battery pack.
Battery Pack BP-727
High capacity intelligent battery pack.
USB Adapter UA-100
USB Adapter for USB cable to connect to an external HDD
CA-110 Compact Power Adapter
Compact Power Adapter for the BP-110 Battery Pack.
Battery Charger CG-700
Charges Li-Ion Battery 700 Series.
Soft Case SC-A80
Fits most Canon Consumer Camcorders with large front-zippered pockets, two carrying straps with overlapping grip and a removable shoulder strap.
Kata Small Shoulder Bag
Enjoy the convenience of this small shoulder bag, compatible with the following camcorders: DC100, DC40, GL2, VIXIA HF S10 Dual Flash Memory, VIXIA HF S100 Flash Memory, VIXIA HF S11 Dual Flash Memory, VIXIA HF11 Dual Flash Memory, VIXIA HF20 Dual Flash Memory, VIXIA HF200 Flash Memory, VIXIA HG20 Hard Disk Drive, VIXIA HG21 Hard Disk Drive, ZR800, ZR800 miniDV Refurbished
SD Memory Card Wallet SW-10
Enjoy this slim, wallet-style memory card holder.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
