| Std Def High Def
High Definition |
| Television System
NTSC |
| Video Recording System
AVCHD/MPEG-4 |
| Image Sensor
1/4.85-Inch CMOS, RGB Primary Color Filter |
| Number Of Recording Pixels
Approx. 3.28 Megapixels |
| Effective Pixels
Video: Approx. 2.07 Megapixels (1920 X 1080) Photo: Approx. 2.07 Megapixels (1920 X 1080) |
| Maximum Recording Time
32GB SD Memory Card In AVCHD*: LP (1440 X 1080)**: 12 Hrs. 15 Min. FXP (1920 X 1080)**: 4 Hrs. 10 Min. MXP (1920 X 1080)**: 2 Hrs. 55 Min. NTSC 60p (1920 X 1080)**: 2 Hrs. 30 Min.
32GB SD Memory Card In MP4*: 4 Mbps (1280 X 720)**: 17 Hrs. 20 Min. 17 Mbps (1920 X 1080)**: 4 Hrs. 10 Min. 24 Mbps (1920 X 1080)**: 2 Hrs. 55 Min. 35 Mbps (1920 X 1080)**: 2 Hrs.
* Variable Bit Rate. ** When Recording Has Continued For 12 Hours, It Will Automatically Stop And Then Start. |
| Lens
Zoom Ratio: 57x Advanced* / 32x Optical / 1140x Digital *Manual Mode/Cinema Mode Only
Focal Length: 2.8–89.6mm
35mm Film Equivalent: Optical Zoom: Approx. 38.5–1232mm Advanced Zoom Off: Approx. 38.5–1232mm Advanced Zoom On: Approx. 32.5–1853mm
Zoom Speed: Variable / 3 Fixed Zoom Speeds Max. F/Stop: F/1.8–4.5 |
| Focusing System
TTL (Through The Lens) |
| Manual Exposure
Available |
| Programmed Ae
Smart AUTO, P, SCN*1, High-Brightness Priority, Cinema Mode*2, Baby Mode
*1 Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks *2 Cinema Standard, Vivid, Cool, Sepia, Old Movies |
| Max Shutter Speed
Movie: 1/2000 Sec. Still Image: 1/500 Sec. |
| Minimum Focusing Distance
Auto Mode: 10mm (AF Linkage: WIDE End), 1m In Intermediate Zoom Range, Approx. 50 Cm At TELE End
All Other Modes: 10mm (WIDE End), 1m Across Entire Zooming Range (From Edge Of Lens). However, Approx. 50cm At Tele Macro Setting Established At This Time (Automatic Movement To TELE End) |
| White Balance
Auto, Daylight, Tungsten, Custom WB |
| Frame Rate
AVCHD: 60i/PF30/60P MP4: 60P/30P/24P |
| Minimum Illumination
P Mode: Approx. 5 Lux Low Light Mode: Approx. 0.4 Lux |
| Image Stabilization
Optical System (Lens-Shift System) + Electronic Stabilization Intelligent IS In Auto/Baby Mode - Dynamic IS (Default)
- Powered IS
- Macro IS
- Tripod Mode
IS Modes Other Than Intelligent IS; Dynamic IS And Powered IS Settings Can Be Made Manually In P/High-Brightness Priority/SCN*1/ Cinema Mode: Angular Velocity Detection (Using Piezoelectric Vibration Sensor) And Hybrid By Sensor Based Movement Vector Detection Supported. *1 Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks |
| Filter Diameter
43mm Diameter |
| Viewfinder
Not Available |
| Lcd Screen
3.0-Inch Capacitive Touch Panel Widescreen Color LCD (Approx. 230,000 Dots) |
| Recording Media
1 SD/SDHC/SDXC/FlashAir Memory Card Slot |
| Usb Terminal
Mini-B: Hi-Speed USB Supported |
| Video Terminal
Composite (Output) |
| Audio
AVCHD: Dolby Digital (2ch) MP4: MPEG-4 AAC-LC (2ch) Sampling Frequency: 48 KHz |
| Accessory Shoe
Not Available |
| Supplied Video Editing Software
Not Available |
| Hdmi Terminal
Available; Mini Connector (Output Only) |
| Microphone Terminal
3.5 Mm Stereo Mini-Jack |
| Av Mini Terminal Headphone Terminal
3.5 Mm 4 Pole Mini-Jack (Video/Audio Output Only) |
| Operating Temperature Range
23° To 113°F (-5° To 45°C) 60% Relative Humidity (Operation) 32° To 104°F (0° To 40°C) 85% Relative Humidity (Performance) |
| Dimensions
Approx. 2.1 X 2.3 X 4.6 In. / 53 X 58 X 116mm (Not Including Grip Belt) |
| Weight
Approx. 8.3 Oz. / 235g (Body, Not Including Grip Belt) Approx. 10.8 Oz. / 305g (Including Battery BP-727, Memory Card, Grip Belt) |
| Content
| Recommended Cards | 60P (NTSC)/50P (PAL) Recording: Memory Cards Of Class 6 Or Higher For Both AVCHD And MP4, Class 4 Or Higher-Speed Memory Cards Are Recommended In The High-Image-Quality And Full-HD Standard Modes. Slow & Fast Motion At 0.5x Speed: Memory Cards Of Class 6 Or Higher Any Class Of Card May Be Used For Photo Shooting. |
