VIXIA HF R500
- 57x Advanced Zoom and SuperRange Optical Image Stabilizer helps provide outstanding steady video.
- Canon 3.28 Megapixel Full HD CMOS Image Sensor.
- DIGIC DV 4 Image Processor captures video at 1920 x 1080 resolution and helps provide exceptional imaging performance.
- Record Full HD video directly to a removable SD memory card.
- VIXIA HF R500
- Battery Pack BP-718
- Compact Power Adapter CA-110
- USB Interface Cable IFC-300PCU
- Mini-HDMI Cable HTC-100
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Discover a world of new shooting possibilities with VIXIA HF R500 camcorder's giant 57x Advanced Zoom! Get up close from virtually anywhere and feel free to walk while shooting: the camcorder's SuperRange Optical Image Stabilizer will keep your video sharp and steady. Capture truly impressive, amazingly realistic 1920 x 1080 Full HD video with the Canon 3.28 Megapixel Full HD CMOS Image Sensor and DIGIC DV 4 Image Processor. Even the fastest moving subjects are rendered with crisp detail thanks to 1080/60p recording in easy-to-share MP4 (35 Mbps) and AVCHD Progressive (28 Mbps) formats, and video is recorded directly to a convenient, removable SD memory card. Parents take note: Advanced Baby Mode gives you an easy, organized way to track the daily development of up to three children. Just pick up the camcorder and start shooting: there's no need to worry about settings in this mode - every precious moment is automatically captured with the best possible quality for the shooting conditions. Not only is this camcorder easy to control with its 3.0-inch capacitive touch panel LCD and fast, intuitive interface, but it also incorporates lots of ways to make your video polished, creative and of the highest quality. Intelligent IS optimizes image stabilization for the given conditions, while Smart AUTO chooses the best camcorder settings based on 38 predefined shooting situations. You'll record outstanding audio even under difficult conditions with Audio Scene Select, and give your video a unique creative spin with seven beautiful Cinema-Look Filter effects that can be added during or after shooting. And to keep the fun and memory-making going longer, the VIXIA HF R500 features a high capacity battery pack.
57x Advanced Zoom
You won't miss any of the action when shooting video with the VIXIA HF R500 camcorder and its impressive 57x Advanced Zoom range. Long-range shooting allows you to create videos with dynamic variety, and is less likely to disrupt the action you're shooting. It's perfect for formal ceremonies, animals in the wild, candid family videos and more. Advanced Zoom, available in manual mode, has been achieved with more efficient use of the effective imaging area. It takes the camcorder's telephoto power from 32.5mm all the way to 1,853mm (35mm equivalent) for extraordinary flexibility in shooting. For more convenient shooting and better creative control over your videos, the camcorder offers continually variable Zoom Speed settings, with 15 levels available.
SuperRange Optical Image Stabilization
Canon's sophisticated SuperRange Optical Image Stabilizer corrects camera shake instantly, so even handheld video taken at long focal lengths is sharp and steady. Providing continuous adjustment throughout the entire zoom range to correct a broad range of motion, with extra compensation applied at wide-angle focal lengths, the Dynamic Image Stabilization system on the VIXIA HF R500 stabilizes rotational camera shake. Controlling rotational camera shake – horizontal, vertical and roll axis – ensures smooth, distortion-free video, even when you're walking while shooting.
The VIXIA HF R500 camcorder is equipped with a 3.28 Megapixel Full HD CMOS Image Sensor to capture your memories in true 1920 x 1080 resolution. Canon's advanced, high-resolution HD CMOS Image Sensor features extra sensitivity that delivers beautifully lifelike Full HD video with natural color, even in low light. On-chip noise reduction brings bright clarity to every frame. Video is rich, clear and amazingly detailed anywhere you view it, even when played back on a large HDTV.
The VIXIA HF R500 incorporates the latest and most advanced Canon HD Image Processor, the DIGIC DV 4 Image Processor, for exceptional imaging performance. The DIGIC DV 4 Image Processor features dramatically increased processing power and captures more light, for brighter, noise-free images even in dark scenes.
Record to Removable SD Memory Cards
The VIXIA HF R500 camcorder records Full HD video directly to a removable SD memory card. Widely available in several capacities, SD memory cards let you share your videos quickly and easily. In addition to SD memory cards, the VIXIA HF R500 also lets you use super-high capacity SDXC cards. The same size as a standard SD card, a SDXC card can hold up to 2,048 GB, and provides ultra-fast data transfer.
| VIXIA RECORDING TIME CHART*1 | ||||
| AVCHD | Recording Mode | |||
| 1920 x 1080 Recording | 1440 x 1080 Recording | |||
| Memory Capacity | NTSC: 60P (Approx. 28 Mbps)*2 | MXP (Approx. 24 Mbps)*2 | FXP (Approx. 17 Mbps)*2 | LP (Approx. 5 Mbps)*2 |
| 8GB | 35 min. | 40 min. | 1 hr. 00 min. | 3 hrs. 00 min. |
| 16GB | 1 hr. 15 min. | 1 hr. 25 min. | 2 hrs. 05 min. | 6 hrs. 05 min. |
| 32GB | 2 hrs. 30 min. | 2 hrs. 55 min. | 4 hrs. 10 min. | 12 hrs. 15 min. |
| 64GB | 5 hrs. 05 min. | 5 hrs. 55 min. | 8 hrs. 20 min. | 24 hrs. 30 min. |
| 128GB | 10 hrs. 10 min. | 11 hrs. 55 min. | 16 hrs. 45 min. | 49 hrs. 00 min. |
| MP4 | Recording Mode | |||
| 1920 x 1080 Recording | 1280 x 720 Recording | |||
| 35 Mbps*2 | 24 Mbps*2 | 17 Mbps*2 | 4 Mbps*2 | |
| 8GB | 30 min. | 40 min. | 1 hr. 00 min. | 4 hrs. 20 min. |
| 16GB | 1 hr. 00 min. | 1 hr. 25 min. | 2 hrs. 05 min. | 8 hrs. 40 min. |
| 32GB | 2 hrs. 00 min. | 2 hrs. 55 min. | 4 hrs. 10 min. | 17 hrs. 20 min. |
| 64GB | 4 hrs. 00 min. | 5 hrs. 55 min. | 8 hrs. 20 min. | 34 hrs. 45 min. |
| 128GB | 8 hrs. 00 min. | 11 hrs. 55 min. | 16 hrs. 45 min. | 69 hrs. 30 min. |
| *1 Variable Bit Rate *2 When AVCHD/MP4 recording has continued for 12 hours, it will automatically stop and then start. |
MP4 (35 Mbps) or AVCHD Progressive (28 Mbps) Recording
The VIXIA HF R500 gives you the highest quality recording, whether you're capturing MP4 or AVCHD files. 1080/60p recording captures twice the amount of information as 60i, and with images captured at a rate of 60 frames per second, diagonal noise is eliminated so even fast moving subjects show up crisply with motion and patterns clearly recorded. This greater sense of detail and faithful rendering of moving edges, plus enhanced color and fine tonal gradation, gives your video everything Full HD has to offer. AVCHD Progressive records at a bit rate of 28 Mbps, which is the highest in the AVCHD standard, and MP4 files are captured at a bit rate of 35 Mbps, so regardless of the format you're shooting or viewing, image quality is as high as can be.
3.0-inch Capacitive Touch Panel LCD
The VIXIA HF R500 features a 3.0-inch Capacitive Touch Panel LCD screen, making shooting and other operations easy. Simply open the panel and the power is on. The display is clear and vivid, and just as with your smartphone or tablet, a gentle touch activates intuitive functions. Choose a focal point, track moving subjects, control exposure for selected areas, and operate camcorder controls from the screen, all with a simple touch. In addition, the easy-to-use user interface makes your shooting experience simpler and more fun. The Home button is on the menu screen, and provides quick access to all functions. Clear explanations for key settings pop up when selecting shooting modes and recording formats, so you can be confident in the decisions you make.
Baby Mode
A complete solution for capturing, tracking, organizing and sharing every precious moment of your baby's development, Baby Mode on the VIXIA HF R500 camcorder has been advanced to allow you to follow the growth of up to three children. A custom control button on the shooting screen activates the mode, and optimal settings for the shooting conditions, including Intelligent IS and more, are automatically selected. Simply pick up the camcorder and start recording, knowing capture will be of the highest quality. Videos shot in Baby Mode are automatically saved into a dedicated Baby Album so they'll never get lost among your other videos. You can then view the Baby Album chronologically for a seamless way to relive and share your baby's growth with friends and relatives.
When you're shooting in Baby Mode, the camcorder's Pre-Record (Pre REC) function is always on. This places the camcorder in a stand-by “pre-roll” mode, where it continuously records three seconds of video to memory before you even press the record button. When you start recording, the additional video is recorded too, so it's easier than ever to capture the baby's “firsts” and every special moment.
Touch Decoration in Baby Mode includes stamps to mark each video with your baby's current height and weight. And with a single registration of the baby's birth date, the camcorder will automatically calculate the number of days old and stamp videos accordingly, creating an exact diary of developmental milestones for years to come. The number of decorations has been vastly increased on the VIXIA HF R500 so it's even easier to make a fun video commemorating your baby's special moments. The camcorder's other Touch Decoration options, including your own drawings, captions, animations and more, are fully available in Baby Mode, and all can easily be appended to previously shot video as well.
High Capacity Battery
The VIXIA HF R500 is powered by a high capacity battery pack. The rechargeable lithium-ion battery not only lets you shoot for long periods, but features intelligent technology that accurately indicates remaining battery time down to the minute, for extra insurance that you'll never miss an important shooting opportunity.
Intelligent IS
Intelligent IS makes it easy to shoot clear, sharply focused video, even in situations that typically cause camera shake. The Intelligent IS system analyzes the shooting situation for you, then automatically switches to the image stabilization method best able to produce sharp, steady video. Four IS systems cover the gamut of shooting situations. Dynamic IS corrects minor movement and the shaking caused by walking while shooting. Macro IS delivers perfectly steady close-up shots. Powered IS comes into play when you're using the VIXIA HF R500 camcorder's powerful zoom, correcting shake that can occur in telephoto shots. Tripod Mode stops IS when the camcorder is stationary.
Audio Scene Select
Audio Scene Select on the VIXIA HF R500 makes it even easier to capture clear, high quality audio with a choice of five audio modes to choose from based on your shooting situation: Standard, Music, Speech, Forest and Birds, and Noise Suppression. Each of these modes has pre-determined optimized settings best suited for the shot you're capturing, resulting in outstanding video with realistic, immersive audio. Audio settings can also be custom set to meet your shooting needs.
Smart AUTO and Auto Tele Macro
Smart AUTO lets you capture clear, bright, well-focused video while the camcorder takes care of all the details. The system recognizes 38 shooting situations based on numerous factors, then automatically chooses the optimal settings for the situation. When you shoot a nearby subject in telephoto zoom mode, Auto Tele Macro gives your video the high-end artistic effect of a well-focused subject against a beautifully blurred background.
Cinema-Look Filter Effects
The VIXIA HF R500 allows you to create cinematic looks with the use of Cinema-Look Filters. This feature offers a choice of seven varied built-in adjustable filters, which give the look of a variety of cinematic styles by compensating for the color, gamma and other aspects of the image's quality. The looks can be previewed in the LCD display while shooting, and also applied post-capture for additional convenience and versatility. Choose from:
Cinema Standard – Recreates the warm tones and muted highlights of classic film |
Cool – Adds a bluish tint for cool, futuristic-looking scenes |
Dramatic B&W – Creates bold black-and-white video with high contrast and grain |
Old Movies – Gives video the aged look of old cinema |
Nostalgic – Recreates the look of old ‘70s TV programs |
Sepia – Applies a sepia tint for an antique, faded look |
Vivid – Accentuates primary colors for a bright, cheerful look |
The brightness of each filter can be adjusted low, medium or high, for even greater control. When Cinema Standard is selected, color depth, softening, and contrast can also be adjusted.
Genuine Canon Face Detection
The same high quality Face Detection technology used in Canon digital cameras is available in Canon high definition camcorders. Up to 35 faces can be tracked automatically, ensuring razor-sharp focus and natural, accurate exposure. Of the faces tracked, 9 detection frames can be displayed at one time.
In fact, the system is so intelligent that it will recognize faces turned downwards or sideways. In addition, a specific face may be selected as the main subject for continuous tracking. This feature is convenient in searching for clips that feature the specific subject's face. In search and playback, use of the Face Index will display those frames with the chosen face as a thumbnail in each shot in which it appears. Your selected face can also be linked as a timeline to further identify footage containing your subject.
Video Snapshot
Video Snapshot allows you to capture the highlights of a once-in-a-lifetime trip or a family milestone with the same ease as taking photos. Simply record a series of short video clips – or select your favorite clips while in Playback Mode – and blend in your favorite background music to create an exciting movie that will grab everyone's attention. Video Snapshot on the VIXIA HF R500 allows selectable recording time (2, 4, or 8 seconds). Additionally, audio from an external source such as an MP3 player can be played along with the Snapshot movie, and playback can be controlled from that source.
24p Cinema and 30p Progressive Shooting Modes
The VIXIA HF R500 camcorder's sophisticated shooting mode options offer superior creativity and functionality. 24p Cinema Mode gives your video a film-like feel, making it look as if it were shot at the same frame rate as movie film, with a frame capture rate of 24p recorded at 60i. The camcorder also gives you the option of recording in 30p Progressive Mode, which is ideal for clips you intend to post online.
Accessories Get the Most from Your Camcorder
Canon helps you get more out of your camcorder with a wide range of accessories that inspire your creativity and productivity alike. The Wireless Microphone WM-V1 streams audio wirelessly from subjects up to 164 feet away. It's perfect for adding your subject's voice at times when you can't get in close to shoot, and can also be used as a stand-alone transceiver to cue shooting and more.
| Std Def High Def | High Definition |
| Television System | NTSC |
| Video Recording System | AVCHD/MPEG-4 |
| Image Sensor | 1/4.85-Inch CMOS, RGB Primary Color Filter |
| Number Of Recording Pixels | Approx. 3.28 Megapixels |
| Effective Pixels | Video: Approx. 2.07 Megapixels (1920 X 1080) Photo: Approx. 2.07 Megapixels (1920 X 1080) |
| Maximum Recording Time | 32GB SD Memory Card In AVCHD:* 32GB SD Memory Card In MP4: * When Recording Has Continued For 12 Hours, It Will Automatically Stop And Then Start. |
| Lens | Zoom Ratio: 57x Advanced*/32x Optical/1140x Digital *Manual Mode/Cinema Mode Only Focal Length: 2.8-89.6mm 35mm Film Equivalent:: Optical Zoom: 38.5-1232mm / Advanced Zoom Off: 38.5-1232mm / Advanced Zoom On: 32.5-1853mm Zoom Speed: Variable / 3 Fixed Zoom Speeds; Max. F/Stop: F/1.8-4.5 |
| Focusing System | TTL (Through The Lens) |
| Manual Exposure | Available |
| Programmed Ae | Smart Auto, Manual Mode*1, Cinema Mode*2, Baby Mode, *1P, SCN*3, *2Cinema Standard, Vivid, Cool, Nostalgia, Sepia, Old Movies, Dramatic B&W, *3Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks |
| Max Shutter Speed | Movie: 1/2000 Sec. Still Image: 1/500 Sec. |
| Minimum Focusing Distance | Auto Mode: 10mm (AF Linkage: WIDE End), 1m In Intermediate Zoom Range, Approx. 50 Cm At TELE End All Other Modes: 10mm (WIDE End), 1m Across Entire Zooming Range (From Edge Of Lens). However, Approx. 50cm At Tele Macro Setting Established At This Time (Automatic Movement To TELE End) |
| White Balance | Auto, Daylight, Tungsten, Manual |
| Frame Rate | NTSC: AVCHD: 60i/PF30/60P MP4: 24P/30P/60P |
| Minimum Illumination | NTSC: 5 Lux Low Light Mode: 0.4 Lux |
| Image Stabilization | Optical System (Lens-Shift System) + Electronic Stabilization Intelligent IS In Auto/Baby Mode:
IS Modes Other Than Intelligent IS; Dynamic IS And Powered IS Settings Can Be Made Manually In Manual*1/Cinema Mode:
*Angle Detection And Sensor-Based Movement Vector Detection (Hybrid Supported) |
| Filter Diameter | Not Supported |
| Viewfinder | Not Available |
| Lcd Screen | 3.0-Inch Capacitive Touch Panel Widescreen Color LCD (Approx. 230,000 Dots) |
| Recording Media | 1 SD/SDHC/SDXC Memory Card Slot *Use Of Class 4 Or Above (4, 6 Or 10) Memory Cards Is Recommended For Recording MXP Or FXP (1920 X 1080 Pixel Recording) Movies. For Other Recording Formats, A Class 2 Or Higher Card Is Recommended. Also, Movie (AVCHD/MP4) Recording Requires Cards With 128MB Of Memory Or More. |
| Usb Terminal | Mini-AB: Hi-Speed USB Supported |
| Video Terminal | Composite (Output) |
| Audio | AVCHD Satisfied: Dolby Digital AC3 (2 Channel) MP4 Satisfied: MPEG-2 AAC-LC (2 Channel) Sampling Frequency: 48 KHz |
| Accessory Shoe | Not Available |
| Supplied Video Editing Software | Not Available |
| Hdmi Terminal | Available; Mini Connector (Output Only) |
| Microphone Terminal | 3.5 Mm Diameter Stereo Mini-Jack |
| Av Mini Terminal Headphone Terminal | 3.5mm Diameter 4 Pole Mini-Jack (Video/Audio Output Only) |
| Operating Temperature Range | 23° To 113°F (-5° To 45°C); 60% Relative Humidity / 32° To 104°F (0° To 40°C); 85% Relative Humidity (Performance) |
| Dimensions | 2.1 X 2.2 X 4.6 In. / 53 X 57 X 116mm (Not Including Grip Belt) |
| Weight | Approx. 8.3 Oz. / 235g (Body, Not Including Grip Belt) Approx. 10.1 Oz. / 285g (Including Battery BP-718, Memory Card And Grip Belt) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
