VIXIA HF R400 Black
- VIXIA HF R400 Camcorder
- Battery Pack BP-718
- Compact Power Adapter CA-110
- USB Interface Cable IFC-300PCU
- Mini HDMI Cable HTC-100
- Bundled CD ROM:
- ImageBrowser EX/Image Mix/Music Data
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Experience the excitement of ultra zooming power! Compact and easy-to-use, the VIXIA HF R400 is equipped with a Genuine Canon HD Video Lens with 53x Advanced Zoom for incredible range and reach. You'll not only shoot more, but your video will be clear and steady even at the wide end of the zoom, and even when you're walking while shooting, thanks to SuperRange Optical Image Stabilization with improved Dynamic IS. Canon's exclusive 3.28 Megapixel Full HD CMOS Image Sensor and all new DIGIC DV 4 Image Processor bring your video to life with more light, depth and detail than ever before. Record Full HD video directly to a removable SD memory card that is widely available and easy to use. New 1080/60p recording in easy-to-share MP4 (35 Mbps) and AVCHD Progressive (28 Mbps) captures even the fastest moving action with smooth, clear detail. The VIXIA HF R400 has a bright, beautifully clear 3.0-inch capacitive Touch Panel LCD that makes operation feel familiar right away. New Baby Mode has everything parents need to shoot, organize and share chronological video of their baby's development, with a dedicated Baby Album, age, height and weight stamps and more. Audio Scene Select makes it easy to capture realistic, immersive audio in a wide range of common situations, and Smart AUTO automatically recognizes and sets the camcorder to capture the best possible quality effortlessly.
You won't miss any of the action when shooting video with the VIXIA HF R400 camcorder. The camcorder's wide-angle area has been expanded to 38.5mm (35mm equivalent), making it easier than ever before to catch all the action in the frame. Like every Canon camcorder, the VIXIA HF R400 is equipped with a Genuine Canon HD Video Lens. Canon's high definition video lenses use aspherical lens technology to achieve low chromatic aberration with high resolution while maintaining compact dimensions. Super spectra coating technology lowers flare and ghosting. The big news about the VIXIA HF R400 is the camcorder's impressive 53x Advanced Zoom. Long-range shooting allows you to create videos with dynamic variety, and is less likely to disrupt the action you're shooting. It's perfect for formal ceremonies, animals in the wild, candid family videos and more. Advanced Zoom, available in manual mode, has been achieved with more efficient use of the effective imaging area. It takes the camcorder's telephoto power all the way to 1,723mm (35mm equivalent) for extraordinary flexibility in shooting. For more convenient shooting and better creative control over your videos, the camcorder offers continually variable Zoom Speed settings, with 15 levels available.
SuperRange Optical Image Stabilization with Improved Dynamic Image Stabilization
Canon's sophisticated SuperRange Optical Image Stabilizer corrects camera shake instantly, so even handheld video taken at long focal lengths is sharp and steady. Now for the VIXIA HF R400, the power of Canon's new DIGIC DV 4 Image Processer has made possible a significantly improved new Dynamic Image Stabilization mode. In addition to providing continuous adjustment throughout the entire zoom range to correct a broad range of motion, with extra compensation applied at wide-angle focal lengths, the system now stabilizes rotational camera shake. Controlling rotational camera shake horizontal, vertical and roll axis ensures smooth, distortion-free video, even when you're walking while shooting.
| 3.28 Megapixel Full HD CMOS Image Sensor The VIXIA HF R400 camcorder is equipped with a 3.28 Megapixel Full HD CMOS Image Sensor for true 1920 x 1080 resolution. Canon's advanced, high-resolution HD CMOS Image Sensor features extra sensitivity that delivers beautifully lifelike Full HD Video with natural color, even in low light. Original on-chip noise reduction brings bright clarity to every frame. Video is rich, clear and amazingly detailed anywhere you view it, even when played back on a large HDTV. |
The VIXIA HF R400 incorporates the latest and most advanced Canon HD Image Processor, the DIGIC DV 4 Image Processor, which is a significant upgrade on several fronts. The DIGIC DV 4 Image Processor captures more light, for brighter, noise-free images even in dark scenes. Dramatically increased processing power lets you record in both AVCHD and easy-to-share MP4 formats simultaneously. Improved image stabilization means you'll capture smooth, blur-free video even if you're shooting while walking.
The VIXIA HF R400 camcorder records Full HD Video directly to a removable SD memory card. Widely available in several capacities, SD memory cards let you share your videos quickly and easily. In addition to SD memory cards, the VIXIA HF R400 lets you use super-high capacity SDXC cards. The same size as a standard SD card, an SDXC card can hold up to 2,048 GB, and provides ultra-fast data transfer.
| VIXIA RECORDING TIME CHART*1 | ||||
| AVCHD | Recording Mode | |||
| 1920 x 1080 Recording | 1440 x 1080 Recording | |||
| Memory Capacity | NTSC: 60P (Approx. 28 Mbps)*2 | MXP (Approx. 24 Mbps)*2 | FXP (Approx. 17 Mbps)*2 | LP (Approx. 5 Mbps)*2 |
| 8GB | 35 min. | 40 min. | 1 hr. 00 min. | 3 hrs. 00 min. |
| 16GB | 1 hr. 15 min. | 1 hr. 25 min. | 2 hrs. 05 min. | 6 hrs. 05 min. |
| 32GB | 2 hrs. 30 min. | 2 hrs. 55 min. | 4 hrs. 10 min. | 12 hrs. 15 min. |
| 64GB | 5 hrs. 05 min. | 5 hrs. 55 min. | 8 hrs. 20 min. | 24 hrs. 30 min. |
| 128GB | 10 hrs. 10 min. | 11 hrs. 55 min. | 16 hrs. 45 min. | 49 hrs. 00 min. |
| MP4 | Recording Mode | |||
| 1920 x 1080 Recording | 1280 x 720 Recording | |||
| Memory Capacity | 35 Mbps*2 | 24 Mbps*2 | 17 Mbps*2 | 4 Mbps*2 |
| 8GB | 30 min. | 40 min. | 1 hr. 00 min. | 4 hrs. 20 min. |
| 16GB | 1 hr. 00 min. | 1 hr. 25 min. | 2 hrs. 05 min. | 8 hrs. 40 min. |
| 32GB | 2 hrs. 00 min. | 2 hrs. 55 min. | 4 hrs. 10 min. | 17 hrs. 20 min. |
| 64GB | 4 hrs. 00 min. | 5 hrs. 55 min. | 8 hrs. 20 min. | 34 hrs. 45 min. |
| 128GB | 8 hrs. 00 min. | 11 hrs. 55 min. | 16 hrs. 45 min. | 69 hrs. 30 min. |
| *1 When AVCHD/MP4 recording has continued for 12 hours, it will automatically stop and then start. *2 Variable Bit Rate |
The VIXIA HF R400 gives you the highest quality recording, whether you're capturing AVCHD or MP4 files. 1080/60p recording captures twice the amount of information as 60i, and with images captured at a rate of 60 frames per second, diagonal noise is eliminated so even fast moving subjects show up crisply with motion and patterns clearly recorded. This greater sense of detail and faithful rendering of moving edges, plus enhanced color and fine tonal gradation, gives your video everything Full HD high image quality has to offer. 1080/60p recording means that the still images you extract are extremely high quality as well. A new bit rate of 28 Mbps is the highest in the AVCHD standard, and MP4 files are captured at a bit rate of 35 Mbps, so regardless of the format you're shooting or viewing, image quality is as high as can be.
The VIXIA HF R400 features a new 3.0-inch Capacitive Touch Panel LCD screen, making shooting and other operations easier than ever. Simply open the panel and the power is on. The improved display is clear and vivid, and just as with your smartphone or tablet, a gentle touch activates intuitive functions. Choose a focal point, track moving subjects, control exposure for selected areas, and operate camcorder controls from the screen, all with a simple touch. In addition, the user interface has been updated to make your shooting experience easier and more fun. The Home button is now on the menu screen, and provides quick access to all functions. Clear explanations for key settings pop up when selecting shooting modes and recording formats, so you can be confident in the decisions you make.
The VIXIA HF R400 features the new Baby Mode a complete solution for capturing, tracking, organizing and sharing every precious moment of your baby's development. A custom control button on the shooting screen activates the mode, and optimal settings for the shooting conditions, including Intelligent IS and more, are automatically selected. Simply pick up the camera and start recording, knowing capture will be of the highest quality. Videos shot in Baby Mode are automatically saved into a dedicated Baby Album so they'll never get lost among your other videos. You can then view the Baby Album chronologically for a seamless way to relive and share your baby's growth with friends and relatives.
When you're shooting in Baby Mode, the camcorder's Pre-Record (Pre REC) function is always on. This places the camcorder in a stand-by "pre-roll" mode, where it continuously records three seconds of video to memory before you even press the record button. When you start recording, the additional video is recorded too, so it's easier than ever to capture the baby's "firsts" and every special moment.
Touch Decoration in Baby Mode includes stamps to mark each video with your baby's current height and weight. And with a single registration of the baby's birth date, the camcorder will automatically calculate the number of days old and stamp videos accordingly, creating an exact diary of developmental milestones for years to come. The camcorder's other Touch Decoration options, including your own drawings, captions, animations and more, are fully available in Baby Mode, and all can easily be appended to previously shot video as well.
The VIXIA HF R400 is powered by a new, higher capacity battery pack. The rechargeable lithium-ion battery not only lets you shoot longer, but features intelligent technology that accurately indicates remaining battery time down to the minute, for extra insurance that you'll never miss an important shooting opportunity.
Intelligent IS makes it easy to shoot clear, sharply focused video, even in situations that typically cause camera shake. The Intelligent IS system analyzes the shooting situation for you, then automatically switches to the image stabilization method best able to produce sharp, steady video. Four IS systems cover the gamut of shooting situations. Dynamic IS corrects minor movement and the shaking caused by walking while shooting. Macro IS delivers perfectly steady close-up shots. Powered IS comes into play when you're using the camcorder's powerful zoom, correcting shake that can occur in telephoto shots. Tripod Mode stops IS when the camcorder is stationary.
The VIXIA HF R400 camcorder's audio is an excellent match for its pristine image quality. The microphone has updated elements that increase clarity at medium and low frequencies, so even faint sounds are recorded clearly. Three microphone positions let you adjust recording to suit the position of the zoom or your subjects: front for monaural recording; regular for normal stereo effect; and rear for a wider, more enhanced stereo effect. Frequency response characteristics can be adjusted for the scene with several options. You can balance all frequencies for normal recording, emphasize low frequencies for impactful live music recording, attenuate low frequencies to reduce ambient noise, emphasize mid frequencies to focus on voices, or emphasize low and high frequencies to record live music with balanced lows and highs.
Normal |
Records with a balance throughout all frequencies. |
Emphasize Low Frequencies |
Record scenes of live music or the like with impact. |
Attenuate Low Frequencies |
Reduce ambient noise and sound of traffic outdoors (wind, cars, etc.) |
Emphasize Mid Frequencies |
Record focusing on people's voices |
Emphasize Low and High Frequencies |
Record live music with balanced lows and highs |
Audio Scene Select
Audio Scene Select offers five modes that automatically optimize settings based on the recording situation, making it easy to record realistic, immersive audio in a range of situations.
Smart AUTO and Auto Tele Macro
Smart AUTO lets you capture clear, bright, well-focused video while the camcorder takes care of all the details. The system recognizes 38 shooting situations based on numerous factors, then automatically chooses the optimal settings for the situation. When you shoot a nearby subject in telephoto zoom mode, Auto Tele Macro gives your video the high-end artistic effect of a well-focused subject against a beautifully blurred background.
Other cinematic looks can be had through the use of Cinema-Look Filters. This feature offers a choice of seven varied built-in adjustable filters, which give the look of a variety of cinematic styles by compensating for the color, gamma and other aspects of the image's quality. The looks can be previewed in the LCD display while shooting, and also applied post-capture for additional convenience and versatility. Choose from:
Cinema Standard — Recreates the warm tones and muted highlights of classic film |
Cool — Adds a bluish tint for cool, futuristic-looking scenes |
Dramatic B&W — Creates bold black-and-white video with high contrast and grain |
Old Movies — Gives video the aged look of old cinema |
Nostalgic — Recreates the look of old ‘70s TV programs |
Sepia — Applies a sepia tint for an antique, faded look |
Vivid — Accentuates primary colors for a bright, cheerful look |
The brightness of each filter can be adjusted low, medium or high, for even greater control. When Cinema Standard is selected, color depth, softening, and contrast can also be adjusted.
Open and Shoot
Advanced Quick Start is a new convenience that allows you to start shooting immediately whenever the action starts. Just open the LCD screen and the power is on. Shut down is just as easy: simply close the screen.
Ultra Clear Viewing
The display quality of the camcorder's LCD screen has been significantly boosted with new technology. Vivid Clear View is just that: a sharp, bright, beautifully detailed display that helps you create your best videos.
Video SnapShot
Video Snapshot allows you to capture the highlights of a once-in-a-lifetime trip or a family milestone with the same ease as taking photos. Simply record a series of short video clips or select your favorite clips while in Playback Mode and blend in your favorite background music to create an exciting movie that will grab everyone's attention. Video Snapshot on the VIXIA HF R400 allows selectable recording time (2, 4, or 8 seconds). Additionally, audio from an external source such as an MP3 player can be played along with the Snapshot movie, and playback can be controlled from that source.
| Std Def High Def | High Definition |
| Television System | NTSC |
| Video Recording System | AVCHD/MPEG-4 |
| Image Sensor | 1/4.85-Inch, RGB Primary Color Filter |
| Number Of Recording Pixels | Approx. 3.28 Megapixels |
| Effective Pixels | Video: Approx. 2.07 Megapixels (1920 X 1080) Photo: Approx. 2.07 Megapixels (1920 X 1080) |
| Maximum Recording Time | 32GB SD Memory Card In AVCHD:* 32GB SD Memory Card In MP4: * When Recording Has Continued For 12 Hours, It Will Automatically Stop And Then Start. |
| Lens | Zoom Ratio: 53x Advanced*/32x Optical/1060x Digital (*Manual Mode/Cinema Mode Only) Focal Length: 2.8-89.6mm 35mm Film Equivalent:: Optical Zoom: 38.5-1232mm / Advanced Zoom Off: 38.5-1232mm / Advanced Zoom On: 32.5-1723mm Zoom Speed: Variable / 3 Fixed Zoom Speeds; Max. F/Stop: F/1.8-4.5 |
| Focusing System | TTL (Through The Lens) |
| Manual Exposure | Yes |
| Programmed Ae | Smart Auto, Manual Mode1, Cinema Mode2, Baby Mode 1 P, SCN3 |
| Max Shutter Speed | Movie: 1/2000 Sec. Still Image: 1/500 Sec. |
| Minimum Focusing Distance | Auto Mode: 10mm (AF Linkage: WIDE End), 1m In Intermediate Zoom Range, Approx. 50 Cm At TELE End All Other Modes: 10mm (WIDE End), 1m Across Entire Zooming Range (From Edge Of Lens). However, Approx. 50cm At Tele Macro Setting Established At This Time (Automatic Movement To TELE End) |
| White Balance | Auto, Daylight, Tungsten, Manual |
| Frame Rate | NTSC: AVCHD: 60i/PF30/60P MP4: 24P/30P/60P |
| Minimum Illumination | NTSC: 5 Lux Low Light Mode: 0.4 Lux |
| Image Stabilization | Optical System (Lens-Shift System) Intelligent IS In Auto/Baby Mode:
IS Modes Other Than Intelligent IS; Dynamic IS And Powered IS Settings Can Be Made Manually In Manual1/Cinema Mode:
*Angle Detection And Sensor-Based Movement Vector Detection (Hybrid Supported) |
| Filter Diameter | Not Supported |
| Viewfinder | Not Available |
| Lcd Screen | 3.0-Inch Capacitive Touch Panel Widescreen Color LCD (Approx. 230,000 Dots) |
| Recording Media | 1 SD/SDHC/SDXC Memory Card Slot *Use Of Class 4 Or Above (4, 6 Or 10) Memory Cards Is Recommended For Recording MXP Or FXP (1920 X 1080 Pixel Recording) Movies. For Other Recording Formats, A Class 2 Or Higher Card Is Recommended. Also, Movie (AVCHD/MP4) Recording Requires Cards With 128MB Of Memory Or More. |
| Usb Terminal | Mini-AB: Hi-Speed USB Supported |
| Video Terminal | Composite (Output) |
| Audio | AVCHD Satisfied: Dolby Digital AC3 (2 Channel) MP4 Satisfied: MPEG-2 AAC-LC (2 Channel) Sampling Frequency: 48 KHz |
| Accessory Shoe | Not Available |
| Supplied Video Editing Software | Pixela Video Browser / Network Utility Disc |
| Hdmi Terminal | Available; Mini Connector (Output Only) |
| Microphone Terminal | 3.5 Mm Diameter Stereo Mini-Jack |
| Av Mini Terminal Headphone Terminal | 3.5 Mm Diameter 4 Pole Mini-Jack (Video/Audio Output Only) |
| Operating Temperature Range | 23° To 113°F (-5° To 45°C); 60% Relative Humidity / 32° To 104°F (0° To 40°C); 85% Relative Humidity (Performance) |
| Dimensions | (W X H X D) 2.1 X 2.2 X 4.6-Inch (53 X 57 X 116mm). Excluding Grip Belt. |
| Weight | Approx. 8.3 Oz. / 235g (Body, Not Including Grip Belt) Approx. 10.1 Oz. /285g (Including Battery BP-718, Memory Card, And Grip Belt) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
