| Model Name
VarioPrint 135/120/110 |
| Type
DirectPress |
| Printing Resolution
Engine: 600 X 2400 Dpi / 200lpi PCL: 600 X 600 Dpi Adobe PostScript 3: 600 X 2400 Dpi, 1200 X 1200 Dpi (Enhanced) |
| Letter
(Simplex / Duplex:) 120/110/100 Ipm / 135/120/110 Ipm |
| Ledger
(Simplex / Duplex:) 63/57/52 Ipm / 70/63/57 Ipm |
| First Copy Time
3.9 Seconds |
| Maximum Original Size
12.6" X 19.2" (320 X 488 Mm) |
| Standard Paper Capacity
4000 Sheets (80 Gsm) Trays 1 & 2: 1500 Sheets( Ltr) Tray 3: 500 Sheets From 5.5" X 7.17" (140x 182mm) To 12.6" X 17" (320 X 432 Mm) Tray 4: 500 Sheets From 5.5" X 7.17" (140 X 182 Mm) To 12.6" X 19.2" (320 X 488 Mm)Feeding Technology (IPIM - Internal Paper Input Module): Roller Fed 14 Lb. Bond - 110 Lb. Cover (50-300 Gsm) |
| Duplexing
Up To 300 Gsm |
| Power Requirements
208V/20A |
| Dim
56.3" X 44.5" X 30.1" (1430mm X 1130mm X 765mm) |
| Weight
579.8 (263 Kg) |
| Estimated Toner Yield
96,000 / Per 2 Bottles* |
| Description
Color Image Reader (Single-Pass Duplex Automatic Document Feeder And Black & White/Color Scanner) |
| Acceptable Originals
Statement, Letter, Legal, 11" X 17"Custom Sizes ADF: 5.5" X 5.04" (140 X 128mm) To 17" X 12" (432 X 305 Mm) |
| Scanning Speed
BW/Color: Up To 120 Ipm (300 X 300 Dpi) BW: Up To 100 Ipm (600 X 600 Dpi) Color: Up To 105 Ipm (600 X 300 Dpi) Up To 25 Ipm (600 X 600 Dpi) |
| Capacity
300 Sheets (20 Lb. Bond) |
| Power Source
From Main Unit |
| Description
EPIM (External Paper Input Module) |
| Paper Capacity
4600 Sheets (20 Lb. Bond) / Tray 1& 2: 600 Sheets / Tray 3 & 4: 1700 Sheets |
| Paper Sizes
8" X 8" (203 X 203 Mm) To 12.6" X 19.2" (320 X 488 Mm) |
| Paper Weights
14 Lb. Bond - 110 Lb. Cover (50-300 Gsm)Feeding Technology: Air Separation, Suction Feeding |
| Paper Source
120V/15A |
| Dimensions
40.9" X 38.6" X 29.5" (1040mm X 980mm X 750mm) |
| Weights
440.9 Lbs (200 Kg) |
| Description
Document Insertion Unit-F1 (Optional) |
| Paper Capacity
400 Sheets (200 X 2) (20 Lb. Bond) |
| Paper Sizes
13" X 19.2" |
| Paper Weights
14 Lb. Bond To 110 Lb. Cover (50gsm To 300gsm) |
| Paper Source
120V/15A |
| Dimensions
55.37" X 29.37" X 31.25" (1407mm X 746mm X 793mm) |
| Weights
134 Lb. (61kg) |
| Description
Finisher-AK1/Saddle Finisher-AK2 (Optional) |
| Paper Weights
Finisher: 14 Lb. Bond To 110 Lb. Cover (52gsm To 300gsm) Saddle Finisher: 14 Lb. Bond To 110 Lb. Cover (50gsm To 300gsm) |
| Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Sheet Stacking: Up To 13" X 19.2" Saddle Finisher: Letter-R, Legal, 11" X 17", 12" X 18", Custom Sizes Up To 13" X 19.2" |
| Top Tray
Up To 3,000 Sheets (20 Lb. Bond) |
| Lower Tray
2,000 (20 Lb. Bond) |
| Saddle Stitch Tray
30 Booklets Or Limitless |
| Staple Positions
Corner-Stapling, Double-Stapling |
| Stapling Capacity
Up To 100 Sheets (Letter) Up To 25 Sheets Saddle-Stitched |
| Power Source
120V/15A |
| Dimensions
46.5" X 31.25" X 35.37" (1180mm X 800mms X 792mm) |
| Weight
Finisher: 287 Lb. (130kg) / Saddle Finisher: 396 Lb. (180kg) |
| Description
Paper Folding Unit-F1 (Optional) |
| Paper Weight
14 Lb. Bond To 28 Lb. Bond (50gsm To 105gsm) |
| Fold Type
Double Parallel Fold: Legal, Letter-R C/Accordion Fold: Letter-R Z-Fold: 11" X 17"Power Source: From Finisher Dimensions (H X W X D): 46.87" X 13.25" X 31.25" (1190mm X 336mm X 793mm) Weight: 157 Lb. (71kg) Puncher Unit-BQ1: (Option For Finisher-AF1/Saddle Finisher-AF2) Paper Weight: 14 Lb. Bond To 73 Lb. Cover (50gsm To 200gsm) Paper Sizes2-Hole: Legal, Letter-R / 3-Hole: 11" X 17", Letter, Executive Punch Speed: Up To 135 Ppm (Depends On Speed Of Marking Engine) Weight: 6.7 Lb. (3kg) Power Source: From Finisher High-Capacity Stacker-E1 (Optional) Offset Stack Capacity: 10,000 Sheets (Letter) (20 Lb. Bond) Top Tray Capacity: 1,000 Sheets (20 Lb. Bond) Maximum Paper Size: 13" X 19.2" Paper Weight: 14 Lb. Bond To 110 Lb. Cover (50gsm To 300gsm) Max. Connectivity: Up To 2 Units At Once Dimensions (H X W X D): 53.62" X 39.25" X 31.25" (1362mm X 997mm X 792mm) Weight: 463 Lb. (210kg) Power Source: 120V/15A Booklet Trimmer-D1 (Optional) Margin Trimming: Fore-Edge Trim Trim Amount: 0.08" To 0.78" (2mm To 20mm) Trim Thickness: 100 Sheets Waste Tray Capacity: 1,500 Sheets With 0.78" Trim(20 Lb. Bond) Paper Weight: 14 Lb. Bond To 110 Lb. Cover (50gsm To 300gsm) Output Tray Capacity: 30 Booklets Dimensions (H X W X D): 41" X 62" X 30.37" (1040mm X 1575mm X 770mm) Weight: 335 Lb. (152kg) Power Source: From Saddle Finisher Two-Knife Trimmer-A1 (Optional) Margin Trimming: Top And Bottom Trim Trim Amount: 0.08" To 0.59" (2mm To 15mm) Trim Thickness: 100 Sheets Waste Tray Capacity: 750 Sheets (Two-Sided Trimmed) Paper Weight: 14 Lb. Bond To 110 Lb. Cover (50gsm To 300gsm) Output Tray Capacity: 30 Booklets Dimensions (H X W X D): 41" X 21.12" X 30.37" (1040mm X 536mm X 770mm) Weight: 319 Lb. (145kg) Power Source: 120V/15A Perfect Binder-C1 (Optional) Cutting Method: Stack Rotation 3-Direction Or 1-Direction Cut Finished Book Width: 8" To 11.62" (203mm X 297mm) Finished Book Length: 5.37" To 8.5" (138mm X 216mm) (After 3-Direction Cut) Body Paper Weight: 14 Lb. Bond To 90 Lb. Index (52gsm To 163gsm) Cover Weight: 24 Lb. Bond To 110 Lb. Cover (90gsm To 300gsm) Book Thickness: 10 To 200 Sheets (20 Lb. Bond) (Up To 25mm) Glue Warm-Up Time: 440 Seconds Trim Range: Adjustable In .0197" (0.5mm) Increments Side: 0.26" To 1.94" (6.5mm To 49mm) Top And Bottom: 0.52" To 3.11" (13mm To 79mm) Dimensions (H X W X D): 51.25" X 36.97" X 31.12" (1300mm X 922mm X 791mm) Weight: 675 Lb. (306kg) Power Source: 208V/15A * Estimated Yield Based On Letter Pages At 6% Coverage. Specifications Subject To Change Without Notice. |
