The RF 28-70mm f/2L USM is an incredibly bright L series zoom lens designed to bring unparalleled performance to Canon's EOS R full-frame mirrorless camera system.
The RF 28-70mm f/2L USM is an incredibly bright L series zoom lens designed to bring unparalleled performance to Canon's EOS R full-frame mirrorless camera system. Stellar image quality is delivered from corner to corner thanks to the combination of a large 54mm diameter mount and short back focus distance.
A rugged design and consistent f/2 brightness throughout its zoom range make the RF 28-70mm f/2L USM ideal for portraits, wedding photography, landscapes, nightscapes and more. It's made for photographers and moviemakers who want a bright view, sharp detail, gorgeous blur and the professional performance of Canon's L series.
For a stunningly bright f/2 aperture throughout the zoom range, look no further than the amazing RF 2870mm F2 L USM. It is the world's first autofocus zoom lens compatible with 35mm full frame sensors to have a maximum f/2 aperture*. Thanks to the large-diameter RF mount and short back focus design, the RF 2870mm F2 L USM also features a balanced and comfortable size for unfettered operation, amazing performance in low-light areas and sharp images with gorgeous background blur at various focal lengths.
* As of September 5, 2018, based on Canon's research.
High Image Quality at f/2 that Rivals the EF 2470mm f/2.8 at f/2.8
Thanks to an optical design made possible by the RF mount, the RF 2870mm F2 L USM lens is able to render image quality at f/2 that rivals that of the EF 2470mm f/2.8 at f/2.8. With an extra stop of light, this means faster shutter speeds or lower ISOs for enhanced image quality, and marvelous performance when shooting movies.
High Precision and Flexibility to Match Fixed Focal Length Lenses
With a brilliant optical design and speedy performance, the RF 2870mm F2 L USM lens delivers the flexibility, performance and image quality of 28mm, 35mm, 50mm and 70mm fixed focal length lenses in one discreet package. Combining the outstanding performance, brightness and versatility of several focal lengths into one lens, the RF 2870mm F2 L USM lens performs with reassuring consistency, especially in high-pressure situations where quality matters and there's no time for lens changes.
The RF 2870mm F2 L USM lens incorporates a control ring on the lens barrel that can directly adjust numerous settings including shutter speed, aperture, exposure compensation and more.
Located towards the front of the lens and effectively adding a third dial to the EOS R camera's main dial and quick control dial, the control ring has a tactile, easily distinguished surface and features a clicking mechanism that provides tangible feedback for confident use while looking through the viewfinder. For photographers and moviemakers who would prefer a silent control ring, the clicking mechanism can be removed by a Canon service provider for a fee.
High Reliability and Durability for Professional Use
Like all L series lenses, the RF 2870mm F2 L USM lens is built to endure the rigors of professional use. Constructed to be rugged, refined and precise, it can be operated intuitively so concentration can remain on the subject at hand.
Vibration Shock Resistance
Engineered to accommodate its optical system, the RF 2870mm F2 L USM lens features L series level vibration shock resistance in the lens barrel, helping to maintain focus and settings even in turbulent situations.
Dust- and Water-resistant
For reliable performance even when weather conditions get difficult, the RF 2870mm F2 L USM lens features dust- and water-resistant construction in the lens mount, switch panel and all rings.
Fluorine Coating
The RF 2870mm F2 L USM lens features fluorine coatings on the front and rearmost surfaces to help prevent dirt and dust from sticking to the lens, making it easy to clean smudges and fingerprints off.
High-speed Communication with the EOS R Camera
Designed to quickly process data, the RF 2870mm F2 L USM features a 12 pin communication system that is the fastest yet for a Canon lens/camera combination. This accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
Lens Information Display
Another helpful feature, the EOS R camera can display lens information right in the viewfinder, making it easy to confirm the lens's focal length without looking away from the subject at hand.
In-camera Digital Lens Optimizer
The EOS R system's 12 pin communication system enables the Digital Lens Optimizer, which works in-camera to combat aberrations and image deterioration, especially in the edges of the image frame when shooting at a large aperture. Data from the RF 2870mm F2 L USM lens is transferred automatically to the camera body, facilitating near immediate correction for clear, detailed images.
The RF 2870mm F2 L USM features an all-new optical design built specifically for the RF mount. This includes four aspheric lenses that correct for aberrations, distortions and astigmatism, plus two UD elements and one Super UD element to reduce chromatic aberration and achieve high image quality across the board. Strategically placed coatings and a 9-blade aperture help ensure superlative quality images with sharp detail, gorgeous color and minimized distortion throughout the zoom range.
The RF 2870mm F2 L USM lens features Canon's Air Sphere Coating (ASC), which significantly reduces the occurrence of lens flare and ghosting regardless of focal length or the angle of light. This helps provide clean results with minimal distractions and aberrations.
Focal Length Maximum Aperture
28-70mm F/2
Lens Construction
19 Elements In 13 Groups
Diagonal Angle Of View
75°00'-34°00'
Focus Adjustment
Af With Full-Time Manual
Closest Focusing Distance
1.28 Ft. / 0.39m
Filter Size
95mm
Max Diameter X Length Weight
Φ4.09 X 5.50 In., Approx. 3.15 Lbs. / Φ103.8 X 139.8mm, Approx. 1430g
Cases / Lens
Lens Case LP1424
Lens pouch cases are compact, yet keep your lenses looking like new.
Lens / Hoods
Lens Hood EW-103
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
Lens Caps
Lens Dust Cap RF
Helps protect the front glass from dust and scratches.
Lens Cap E-95
Lens Filters
95mm Circular Polarizing Filter PL-C-B
Circular Polarizing filter for use with the RF 28-70mm F2 L USM lens.
95mm Protect Filter
Clear filter that helps to guard your lens from dust, scratches, moisture, and other elements.
