RF 100-500mm f/4.5-7.1L IS USM
- RF 100-500mm f/4.5-7.1L IS USM
- Lens cap E-77 II
- Lens hood ET-83F (WIII)
- Lens case LZ1328
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The RF 100-500mm f/4.5-7.1L IS USM super telephoto zoom lens delivers a superb combination of cutting-edge performance, compact construction and brilliant resolving power specifically designed for the EOS R system. The versatile range of 100mm to 500mm is ideal for sports, wildlife, and even aviation photography while maintaining a compact, travel-ready size and weight. The lens features one Super UD and six UD lenses. Fluorine coated front and rear lens elements provide resistance to dirt, moisture and oils, while L-series construction with dust and weather resistance provide reliability even in challenging conditions. With its built-in, 3-mode, and up-to 5-stop optical image stabilization system, and high-speed Dual Nano USM autofocus motors, the RF 100-500mm f/4.5-7.1L IS USM will prove its superb optical performance, over and over again.
The RF 100-500mm f/4.5-7.1L IS USM lens is a highly portable option for EOS R series camera users from professionals to advanced amateurs shooting sports, wildlife, photo journalism, aviation subjects and more, providing a wide zoom range from medium telephoto to super telephoto, with high quality results.
The RF 100-500mm f/4.5-7.1L IS USM lens is designed to work in conjunction with EOS R series cameras, with both the camera and the lens sharing data to dramatically reduce camera-shake blur, regardless of the situation, whether shooting video or stills. With up to 5 stops* of optical image stabilization, it delivers impressively clear results.
Three image stabilization modes (standard, panning, and during exposure only) provide corrective camera shake functions for outstanding results in a wide range of shooting situations. These include when shooting stationary subjects like portraits (IS Mode 1); helping to correct vertical camera shake when panning horizontally, or horizontal camera shake when panning vertically, depending on the camera’s orientation (IS Mode 2); and when tracking movement during a sporting event, for example (IS Mode 3).
The RF 100-500mm f/4.5-7.1L IS USM lens uses two NANO USM focus motors which provide a near-silent, power saving, and high-speed auto focus operation so fast moving subjects can more accurately be tracked and captured without missing the moment for both stills and movies.
With a minimum focusing distance of 2.95ft./0.9m (at 100mm or 3.9 ft./1.2m at 500mm), the RF 100-500mm f/4.5-7.1L IS USM lens is capable of capturing sharp and detailed images from various distances. Whether you're photographing birds, landscapes or a sporting event, the RF 100-500mm f/4.5-7.1L IS USM lens' combination of impressive minimum focusing distance and a maximum magnification of 0.33x at 500mm provides outstanding versatility and impressively sharp images.
Rotation-type zoom ring allows you to adjust from Smooth to Tight for more precise composition and excellent balance when handholding.
Designed to quickly communicate shooting data, the RF 100-500mm f/4.5-7.1L IS USM features the 12-pin communication system inherent in all RF lenses. This helps coordinate complex processes requiring high-speed communication and large data transfer, such as fast AF response with broader AF area, Image Stabilization, the Digital Lens Optimizer, and even the adjustment of the customizable Lens Control Ring for a quick and efficient user experience.
For reliable performance even when weather conditions get difficult, the RF 100-500mm f/4.5-7.1L IS USM lens features a dust-and weather-resistant construction in the lens mount, switch panel and all rings. Sealing is applied to lens joining sections, and switch panels to help prevent water and dust from entering into the lens.
The RF 100-500mm f/4.5-7.1L IS USM lens features fluorine coatings on the front and rearmost surfaces to help prevent oil and water from adhering to the lens, making it easy to clean smudges and fingerprints off.
The RF 100-500mm f/4.5-7.1L IS USM lens features an optical design built specifically for the RF mount. This includes one Super UD lens, plus six UD elements to reduce both axial chromatic aberration and chromatic aberration of magnification to achieve high image quality throughout the zoom range. Additionally the inclusion of Air Sphere coating is employed to alleviate flare and ghosting.
The lens hood features a sliding side window for easy operation and adjustment of specialty filters such as PL filters even with the hood attached.
When used in combination with the Extender RF 1.4x or RF 2x, you’ll be able to reach even further subjects that would traditionally require much longer focal lengths. With the RF 1.4x attached it is possible to achieve a range of 420-700mm at f/8-10, or a range of 600-1000mm at f/11-14 with RF 2x attached.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 500mm using the EOS R camera.
** 2.95 ft. / 0.9m (at 100mm), 3.9ft. / 1.2m (at 500mm).
*** Extenders can only be used from a 300-500mm range (cannot be used from 100-299mm).
| Focal Length Maximum Aperture | 100-500mm, F/4.5-7.1 |
| Lens Construction | 20 Elements In 14 Groups |
| Closest Focusing Distance | At 100mm: 2.95 Ft. / 0.9m At 300 Mm: 3.28 Ft. / 1m At 500mm: 3.94 Ft. / 1.2m |
| Aperture Control | 9 |
| Filter Size | Ø77 Mm |
| Max Diameter X Length Weight | Shortest (Wide): Approx. 3.69 In X 8.17 In. / 93.8mm X 207.6mm Longest (Tele): Approx. 3.69 In X 11.71 In. / 93.8mm X 297.6mm Approx. 3.0 Lbs. / 1365g (No Tripod Mount) Approx. 0.35 Lbs / 160g (Tripod Only) |
Lens Case LZ1328
Use this lens case to easily transport your lens to your next shoot and to protect it from the elements.
Lens Hood ET-83F (WIII)
A lens hood for your lens with a sliding opening for easy operation, helps to block sunlight or other light sources to prevent glare and lens flare, as well as help protect the lens itself from scratches.
Lens Cap E-77 II
The Lens Cap E-77 II is newly designed and fits Canon EF lenses with a 77mm filter size. It helps protect the front glass from dust and scratches.
Lens Dust Cap RF
Helps protect the front glass from dust and scratches.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
