PowerShot SX520 HS
- 42x Optical Zoom and 24mm Wide-Angle lens.
- 16.0 Megapixel sensor combined with the DIGIC 4+ Image Processor for exceptional performance.
- Shoot 1080p Full HD video with a dedicated movie button.
- High Speed AF for impressive focus speed.
- PowerShot SX520 HS Digital Camera
- Battery Pack NB-6LH
- Battery Charger CB-2LY
- Lens Cap (with strap)
- Neck Strap NS-DC11
- (USB Interface Cable and Digital Camera Solution CD-ROM are not included.)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Remarkable Zoom. Amazing Power.
*Image processing may cause a decrease in the number of pixels.
**32 predefined shooting situations for still images, and 21 predefined shooting situations for video.
There's a whole new world to see when you step up to PowerShot SX520 HS. Experience breathtaking quality and unlimited versatility with the camera's 42x Optical Zoom (241008mm) and 24mm Wide-Angle lens. Say goodbye to the frustration of shooting with a camera that keeps you stuck in one place. This powerful zoom lets you capture the proud smile of a graduate from the back row of an auditorium, architectural details atop an imposing structure, and memorable candids of children and pets without interrupting the scene. Advanced Canon optics bring depth and resonance to shots at any zoom length, giving you the freedom to go beyond the ordinary to create images and preserve memories any way you want. The lens's Optical Image Stabilizer helps ensure that every image you capture will be sharp and steady.
The PowerShot SX520 HS camera's 16.0 Megapixel* High-Sensitivity CMOS sensor is the highest resolution CMOS sensor used in any PowerShot camera. The difference this makes in your everyday photography is remarkable. The large sensor takes in more light, so images are clear and beautifully detailed. High ISO shots are particularly impressive, with less noise and expanded dynamic range. And the 16.0 Megapixel resolution gives you the flexibility to be more creative with your shots: crop and enlarge any part of an image you can be confident that the detail and resolution you need are there.
The Canon DIGIC 4+ Image Processor powers the PowerShot SX520 HS camera's advanced functions and capabilities, including Hybrid Auto, Creative Shot, and Full HD video shooting at 30p. Its accelerated processing speed creates fast, responsive performance, for a shooting experience that's easy and natural. The DIGIC 4+ Image Processor also enhances image quality in several ways. Processing of high ISO shots has been shortened by approximately 60% compared to the DIGIC 4 Image Processor. This significantly reduces noise for brilliant color, smooth gradations, and beautiful detail even in low light. The processor also allows for the integration of electronic Dynamic IS. This advanced system compensates for multiple motion types, effectively preventing angular blur, shift blur, and blur caused by parallel movement and tilt shift. The result is images that are reliably sharp and clear at all lengths of the camera's powerful zoom. The processor's highly efficient design also extends battery life.
Canon HS SYSTEM helps provide excellent low-light performance
The compact PowerShot SX520 HS gives you the power to capture beautifully detailed, naturally lit images even in low light reducing the need for flash and the occasionally unwelcome effects it produces. That's because the camera's 16.0 Megapixel* High-Sensitivity CMOS sensor works with the camera's DIGIC 4+ Image Processor to create the Canon HS SYSTEM, specifically engineered for spectacular low-light performance. With the Canon HS SYSTEM, you'll experience excellent tracking performance even in low light, and achieve gorgeous still image quality at ISO speeds up to ISO 3200; beautiful low-light shots are possible with minimal noise and maximum detail in highlight and shadow areas.
*Image processing may cause a decrease in number of pixels.
Simply touch the dedicated movie button on the PowerShot SX520 HS to start recording video in 1080p Full HD that is breathtakingly vivid and realistic. You're free to use the full range of the zoom in movie mode to get the video you want. You can also view and share your video on an HDTV to enjoy.
The latest advance in Canon Optical Image Stabilization technology, Intelligent IS, analyzes camera movement and applies the best shake correction method for the shooting situation. For stills, the system selects from Normal IS, Panning IS, Macro (Hybrid) IS and Tripod modes. When shooting video, the system selects from Dynamic IS, Powered IS, Macro (Hybrid) IS and Active Tripod IS modes. With Intelligent IS, you can concentrate on image capture, letting the camera make the most effective IS settings to help capture the steadiest possible image.
| Still Image Shooting | ||
Normal IS Corrects for a wide range of camera movement when shooting stills.
Panning IS Panning motion is detected so that IS does not interfere with desired camera movement.
Macro (Hybrid) IS Corrects for shift-type camera shake, which typically occurs in macro (close-up) shooting.
Tripod When tripod use is detected, the Image Stabilizer is stopped because it is not needed.
| Video Recording | ||
Dynamic IS Effective for video shooting at wide-angle focal lengths, eliminating the unwanted shaking that typically occurs while walking.
Powered IS Compensates for hand movement when shooting video at the telephoto end of the zoom range, where camera shake is magnified.
Macro (Hybrid) IS Corrects for motion blur that is likely to occur when shooting video while walking. Also compensates for the shift-type camera shake common in macro shooting.
Active Tripod IS When shooting video while using a tripod, the image stabilization is active to compensate for slight camera shake.
With its 42x Optical Zoom lens, the PowerShot SX520 HS camera has the telephoto reach to capture subjects a long distance away. At maximum telephoto, however, it can be challenging to track a moving subject. The Zoom Framing Assist seek function makes it much easier to use the camera's powerful zoom lens. When you press and hold the Zoom Framing Assist button, the camera will automatically zoom out to include a wider angle of view, enabling you to more easily locate your moving subject. Once you find it, releasing the button will cause the lens to return to its original zoom position, intelligently keeping the subject in focus until you're ready to shoot and capture the perfect close-up moment. You can even make zoom adjustments while the button is pressed, with an animated assist frame that makes viewing easy. When the button is released, the lens will return to the adjusted zoom position. And with the Zoom Framing Assist Lock, the camera will lock onto and automatically track a subject, intelligently keeping them in the center of the frame until you're ready to capture the perfect close-up shot.
Zoom Framing Assist offers a new seek assist function that detects when you're panning (for instance, to search for the location of a soccer ball) and automatically zooms out to help; stop panning, and the zoom returns to its original position. Zoom Framing Assist keeps your subject's face the same size in your frame no matter how they move. Tap the Zoom Framing Assist function button to detect your subject's face. As your subject retreats and advances the camera automatically zooms in and out so their face remains the same size. It's especially useful for capturing the expressions of fast-moving children. The system has been further enhanced by letting you choose the subject's size: choices include face, upper body, whole body, manual or off for superior assistance and control. And, for even more convenience, all Zoom Framing Assist functions are also available when shooting video.
The PowerShot SX520 HS camera is equipped with Canon's latest advancements in autofocus (AF) technology. Canon's advanced AF achieves a significant increase in speed for a shooting experience that's spontaneous and natural. The remarkably responsive High Speed AF lets you capture great shots as they happen, with reduced lag time.
Several engineering breakthroughs contributed to this major enhancement to speed. In addition to improved AF algorithms, the camera can process multiple sequences simultaneously, and takes advantage of reworked controls between AF and the start of shooting.
The Creative Shot mode featured on the PowerShot SX520 HS can help anyone create images with artistic flair. Rather than randomly applying filters, Creative Shot mode takes advantage of advanced Canon technologies to analyze the individual scene, subject and exposure to apply any of 46 filter options. In addition to the original shot, the camera automatically produces and saves five additional variations of the composition. Filter choices are grouped into Retro, Monochrome, Special and Natural categories to make exploring the world of artistic photography fun and easy, or simply select Auto to access the full range of effects. With Creative Shot mode, the result is stunning artistic photos that are perfect for sharing.
Hybrid Auto records up to four seconds of video every time you shoot a still image, then automatically joins the clips and pictures* into a video that captures the essence of special days: vacations, important occasions, or any time you're shooting many shots in a day. In this mode, Hybrid Auto automatically recognizes the scene and optimizes camera settings to capture the highest possible image quality. The resulting 1080 HD video is properly exposed, crisp and steady, so your “highlight reel” is stunningly beautiful.
*Pictures can be withheld from the resulting video via menu settings.
Smart AUTO is a sophisticated Canon technology that makes getting that great shot as simple as pressing the shutter button. It automatically detects scenes by assessing various factors in both the background and the subject. Detected scenes are analyzed using predefined shooting situations. The camera then makes optimal settings to ensure the best possible image capture, whether you're shooting stills or video. With Smart AUTO, all you have to do is frame your shot and capture away.
Canon developed an innovative new grip for the PowerShot SX520 HS, optimized specifically for the camera's powerful zooming capability. The invitingly curved grip fits effortlessly into your hand. Without any strain, your fingers comfortably and naturally reach the shutter and dial, minimizing the potential for shake at long zoom lengths.
Convenient Front Dial
The PowerShot SX520 HS shares a feature with higher end cameras: a convenient front dial. The dial's placement puts important adjustments easily within your reach without releasing your hold on the secure grip, further stabilizing shooting at the camera's long zoom lengths.
Shooting Modes
PowerShot cameras offer shooting modes that make it easy to take impressive photos in a wide range of shooting situations by providing intelligent presets with optimized settings.
Manual You have complete control of exposure, selecting both aperture and shutter speed manually.
Aperture-Priority You set the aperture, controlling depth-of-field. The camera automatically selects the shutter speed.
Shutter-priority You select the shutter speed to stop or blur action, and the camera finds the appropriate aperture. With slow exposure times, Canon's noise reduction system activates to ensure low image noise.
Program Access advanced exposure compensation features while shooting mostly automatically.
Live View Control Enables Brightness, Color, and Tone adjustments to your images using easy-to-understand controls.
Hybrid Auto Automatically selects shooting settings for optimal quality and records a video clip every time you capture a still image. One day's worth of clips are then combined into a single video.
Smart AUTO The camera automatically selects the best shooting settings for optimal quality based on subjects and environmental factors to provide point-and-shoot simplicity.
Creative Shot Analyzes the scene and applies a number of creative filters to automatically create five variations in addition to the original image.
Portrait The camera sets a large aperture, focusing on the subject and artistically blurring the background to make your subject “pop.”
Smart Shutter The camera automatically takes the photo when people smile, wink, or get into frame.
High-Speed Burst Captures rapid action frame by frame, by shooting continuously at a high speed while the shutter button is held down.
Low Light For high quality image capture in an amazing range of dimly lit situations.
Creative Filters This setting provides easy access to special filter effects and scene modes, such as Toy Camera Effect, Poster Effect, Monochrome and more.
Fisheye Effect Add a classic photo distortion without a fisheye lens.
Miniature Effect for Movies & Stills Emphasizes perspectives for a miniature effect by blurring upper and lower portions of the image.
Toy Camera Effect Simulates photos taken with “toy” or pinhole cameras, darkening the image at the edges to create a vignette effect.
Monochrome Choose from three single-tone effects: Black-and-White, Sepia, or Blue.
Super Vivid Super Vivid intensifies existing hues, saturating the scene with bright colors.
Poster Effect Poster Effect combines several similar shades into one color, turning subtle gradations into eye-catching, scene-popping contrasts.
Snow Shoot clear snow scenes without darkened subjects or an unnatural bluish tint.
Fireworks Grab brilliant images of skyrocketing fireworks.
Movie Record video in stereo sound. Unwanted scenes can be deleted in playback mode.
Actual results may vary from examples shown above.
Final image may vary depending on picture composition.
| Type Of Camera | Compact Digital Still Camera With Built-In Flash, 42x Optical, 4x Digital And 168x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 16.0 Megapixel, 1/2.3-Inch Cmos | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 16.8 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 16.0 Megapixels* *Image Processing May Cause A Decrease In The Number Of Pixels. |
| Focal Length | 4.3 (W) - 180.6 (T) Mm (35mm Film Equivalent: 24-1008mm) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | 4.0x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Normal: 2.0 In. (5cm) - Infinity (W), 4.3 Ft. (1.3m) - Infinity (T) Auto/Manual: 0.0 In. (0cm) - Infinity (W), 4.3 Ft. (1.3m) - Infinity (T) Macro Af: 0.0 In. - 1.6 Ft. (0-50cm) (W) |
| Autofocus | Ttl Autofocus, Manual Focus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch Tft Color Lcd With Wide Viewing Angle | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 461,000 Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/3.4 (W), F/6.0 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1-1/2000 Sec. 15-1/2000 Sec. (In Tv And M Modes) |
| Sensitivity | Auto, Iso 100-3200 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Light Metering Method | Evaluative*, Center-Weighted Average, Spot** * Facial Brightness Is Evaluated In Face Detection Af. ** Metering Frame Is Fixed To The Center. |
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, Ae Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±2 Stops In 1/3-Stop Increments Videos: ±2 Stops In 1/3-Stop Increments (Not Available During Shooting) |
| White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Camera Automatically Sets The Optimal Iso Speed According To Shooting Mode. |
| Built In Flash | Auto, Flash On, Slow Synchro, Flash Off
| Flash Range | 1.6 Ft. - 18 Ft. (W), 4.3 - 9.8 Ft. (T) (50cm - 5.5m (W), (1.3m - 3.0m (T)) Image Brightness May Diminish Depending On The Shooting Distance. |
| Recycling Time | 10 Sec. Or Less (Battery Voltage: 3.7 V) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | M, Av, Tv, P, Live View Control, Hybrid Auto, Auto, Creative Shot, Scn*1, Creative Filters*2, Movie*3
| Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color * *Adjustment Of Contrast, Sharpness, Color Saturation, Red, Green, Blue And Skin Tone Are Available |
| Self Timer | Approx. 10-Sec. Delay/Approx. 2-Sec. Delay/Custom* *Delay Time (0-15 Sec. (In One-Second Increments), 20/25/30 Sec.) And Number Of Shots (1-10 Shots (In One-Shot Increments)) Can Be Specified. |
| Wireless Control | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | Normal: Approx. 1.6 Shots/Sec. (In P Mode) Normal: Approx. 10 Shots/Sec. (In High-Speed Burst Mode)
| Storage Media | Sd Memory Card, Sdhc Memory Card, Sdxc Memory Card | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System, Dpof (Version 1.1) Compliant | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif. 2.3 (Jpeg) Video: Mov (Image: H.264; Audio: Linear Pcm (Stereo)) |
| Number Of Recording Pixels | Still Images: 1) 16:9 - Large: 4608 X 2592; Medium 1: 3264 X 1832; Medium 2: 1920 X 1080; Small: 640 X 360 2) 3:2 - Large: 4608 X 3072; Medium 1: 3264 X 2176; Medium 2: 2048 X 1368; Small: 640 X 424 3) 4:3 - Large: 4608 X 3456; Medium 1: 3264 X 2448; Medium 2: 2048 X 1536; Small: 640 X 480 4) 1:1 - Large: 3456 X 3456; Medium 1: 2448 X 2448; Medium 2: 1536 X 1536; Small: 480 X 480 *2304 X 1728 (M) When In High-Speed Burst Or Low Light |
| Content |
* When In Low Light Or High-Speed Burst. • The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Content |
*2 Actual Frame Rate Is 29.97 Fps. |
| Playback Modes File | Stills & Videos: Auto Rotate (Automatic Vertical/Horizontal Detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, Smart Shuffle, Group Playback, Slideshow (Repeat, Interval, Effect) Still Images: Single, Index (6-100 Thumbnails), Magnification (2-10x), Information Display, Red-Eye Correction, I-Contrast, Resize, My Colors, Histogram, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2
| Erase Modes | Select Image, Select Range, Select All Images
| Video Out | Ntsc/Pal (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video), Mini-Hdmi Connector | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Stereo (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | Usb, Sd Memory Card Slot; Direct Connection To Canon Selphy, Pixma Photo Printers & Pictbridge Compatible Printers | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Source | Battery Pack Nb-6lh, Compact Power Adapter Ca-Dc10 (Included With Ac Adapter Kit Ack-Dc40) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Capacity Bp 511 | Approx. 210 Shots Approx. 290 Shots In Eco Mode Video Recording Time: Approx. 50 Min |
| Playback Time Bp 511 512 | Approx. 5 Hours | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32-104°F/0-40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10-90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.72 X 3.22 X 3.62in. / 120.0 X 81.7 X 91.9mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | 15.6 Oz. / 441g (Cipa Standard) 14.7 Oz. / 417g (Camera Body Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
