PowerShot G7 X Mark III
- PowerShot G7 X Mark III
- Battery Pack NB-13L
- Battery Charger CB-2LH
- Wrist Strap WS-DC12
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Smart. Small. Social.
Thinking about taking your vlogging, or picture taking skills from a smartphone to another level? The compact PowerShot G7 X MARK III camera puts exciting capabilities from Live Streaming services* directly to YouTube™, to vertical video shooting, right in the palm of your hands. Its 20.1 Megapixel 1.0-inch stacked CMOS Sensor combined with the powerful DIGIC 8 Processor helps to produce high image quality for amazing results at a fast operation. Equipped with 4K recording capability, and an external microphone terminal, The PowerShot G7 X Mark III camera delivers crisp, sharp videos with minimal sound distortion. Capture close-ups of your selfies, wide shots and everything in between with its impressive 4.2x Optical Zoom and a lens aperture of f/1.8 (wide) to f/2.8(tele). Combining incredible zoom power with 4K video capabilities, the PowerShot G7 X Mark III camera makes it easy to create stunning videos and still images you will want to share with your friends, Social Media followers, and family.
The PowerShot G7 X Mark III camera features a new 1.0-inch 20.1 Megapixel stacked CMOS sensor, which helps achieve high image quality and high performance at the same time, delivering gorgeous, detailed images. It also enables fast continuous shooting and fast autofocus that helps you capture important moments.
DIGIC 8 Image Processor
The DIGIC 8 Image Processor helps produce high image quality and fast operation, even in in low light. When using high ISO settings, the image processor helps keep results sharp and detailed in virtually any lighting situation. Powerful all around, the DIGIC 8 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal noise or grain.
With a 4.2x optical zoom lens, a range of 24–100mm, advanced Optical Image Stabilization and an aperture range of f/1.8(wide)- f/2.8 (telephoto), the PowerShot G7 X Mark III camera is suitable for group photographs, and even close-up photography. The PowerShot G7 X Mark III’s lens works in conjunction with the camera's sensor and image processor to help deliver sharp images from edge to edge and from wide-angle to telephoto.
With the help of the DIGIC 8 image processor, and the stacked CMOS sensor, enjoy recording non-cropped 4K movies at a frame rate of up to 30p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can be created in 4K simply and easily with the dedicated Time-lapse Movie mode.
FHD 120p Video
Ideal for smooth, slow-motion playback videos, Full HD movies can also be recorded at a high-frame rate of approx. 120 frames per second. Designed to capture fun, beautiful videos, The PowerShot G7 X Mark III camera helps ensure you can see the unique expressions of your friends or family's faces in close-up movies.
The PowerShot G7 X Mark III camera features a high-resolution, 3.0-inch Touch Panel LCD screen that tilts up 180° and down 45°, ideal for taking that picture-perfect selfie at high and low angles with ease. The multi-angle LCD screen encourages creative framing because it's easy to achieve a flexible array of camera angles.
Live streaming service* from the PowerShot G7 X Mark III camera to YouTube™ is now possible. Share must-see moments as they happen directly from the setting that you are in. Whether you are at a concert, or want to vlog your next beauty “how to” video, the compact sized PowerShot G7 X Mark III camera can help ensure that your videos will have the cinematic image quality you desire.
* The live streaming service available with this product is for live streaming on YouTube only. To use live streaming, you need to have an active YouTube account and a CANON iMAGE GATEWAY account. Please be aware that YouTube may change, stop, or terminate its services, including live streaming, at any time without notice. Canon makes no representations or warranties with respect to any third party product or service, including live streaming.
Enjoy creating videos in the vertical position** and sharing to your preferred social media network with the PowerShot G7 X Mark III’s Vertical Video feature. Ideal for the vlogger guru, the vertical video support allows you to mix up your shot length and camera angles to make your videos interesting, and unique.
** Vertical Video Support is available for playback on the following compatible smart devices: iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Vertical Video Support is not available when utilizing the live streaming service available with this product (on YouTube only).
The PowerShot G7 X Mark III camera is compatible with the USB Power Adapter PD-E1 for in-camera charging via USB. Featuring an industry standard USB-C connector, the optional USB Power Adapter PD-E1 makes for easy charging without the necessity to remove the battery from the camera.
For use with an external microphone, the PowerShot G7 X Mark III camera has a stereo mini jack in addition to its built-in stereo microphone. This is particularly useful in loud scenario situations where the sound recordings compliment the quality of the footage captured.
Clean HDMI Output
Whether you're creating inspiring video clips or capturing special occasions, the advanced video capabilities of the PowerShot G7 X Mark III camera can catch them in the quality they deserve. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera's HDMI output. It is even possible to choose movie output without any information displayed on your screen.
With the ability to help capture that perfect shot or multiple shots with practically no time wasted, the PowerShot G7 X Mark III camera is equipped with a DIGIC 8 Image Processor that allows the camera to perform quickly and shoot up to 20.0 frames per second (up to 30.0 fps in RAW burst mode with One Shot AF). Whether you want to show off the delicious meal you prepared, or catch the glow on your face after a beauty tutorial, The PowerShot G7 X Mark III is engineered to capture just the right moment.
The PowerShot G7x Mark III camera is designed to make using Wi-Fi®*** connectivity fast and easy. It can transfer files directly to a compatible smart device using the free Canon Camera Connect app. Simply connect to the Camera Connect app* to transfer images to your smart device, then share and upload from the device directly to various social media sites and web services or print directly to compatible wireless Canon printers.
Built-in Bluetooth®**** Capability
Bluetooth®**** pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. This low-energy wireless connection helps preserve battery life while allowing remote control of the PowerShot G7x Mark III camera. It also sends continuously updated GPS^^ location data from your phone, letting you geotag what you've captured so you can know precisely where you took that stunning vacation photo.
*** Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
**** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.2 and the Camera Connect App Ver. 2.5.0. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^^ In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
To use the Live Streaming function, your camera will need firmware version 1.3.2 or later.
* The live streaming service of this product supports live streaming on YouTube only. To use the live streaming service, registration on CANON iMAGE GATEWAY is needed in advance. In accordance with YouTube's ”Restrictions on live streaming", users must have a minimum of 1,000 channel subscribers in order to live stream from a mobile device. This restriction also applies to the YouTube live-streaming service available via the Canon G7X Mark III. For up-to-date information on restrictions, please visit: https://support.google.com/youtube/answer/2853834?hl=en. Live streaming on YouTube may change, stop, or terminate without notice. Please note in advance that Canon does not assume any responsibilities for services provided by third parties, including live streaming on YouTube.
** Vertical Video Support is available for playback on the following compatible smart devices: iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Vertical Video Support is not available when utilizing the live streaming service available with this product (on YouTube only).
*** Compatible with iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
**** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS®; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth®; version 4.2 and the Camera Connect App Ver. 2.5.0. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
| Type Of Camera | Digital Camera With Built-In Flash, 4.2x Optical, 4x Digital And 17x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 20.1 Megapixel*, 1.0-Inch Stacked CMOS (Sensor Aspect Ratio: 3:2) * Image Processing May Cause A Decrease In The Number Of Pixels. |
| Total Pixels | Approx. 20.9 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 20.1 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focal Length | 8.8 (W) – 36.8 (T) Mm (35mm Film Equivalent: 24–100mm) Optical Zoom |
| Optical Zoom | Approx. 4.2x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | Approx. 4x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Normal/Auto: 2.0 In. (5cm) – Infinity (W), 1.3 Ft. (40cm) – Infinity (T) Macro: 2.0 In. – 1.6 Ft. (5–50 Cm) (W) Quick: 5.0–65.6 Ft. (1.5–20m) (W), 5.0–65.6 Ft. (1.5–20m) (T) |
| Autofocus | TTL Autofocus, Manual Focus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch Tilt-Type TFT Color Liquid Crystal, With Biaxial Tilt For Low And High Angle Shooting | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 1.04 Million Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/1.8 (W), F/2.8 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1–1/2000 Sec. (In Auto Mode) 30–1/25600 Sec. (In Tv, M, And Manual Movie Modes) BULB (In M Mode Only) 1/8 Minimum In Manual Movie Mode |
| Sensitivity | Still Images: ISO 125–3200 (In Auto Mode) Videos:
| Light Metering Method | Evaluative, Center Weighted Average, Spot (Still Images Only) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±3 Stops In 1/3-Stop Increments Videos: ±3 Stops In 1/3-Stop Increments |
| White Balance Control | Auto (Ambience & White Priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Built In Flash | Auto, On, Slow Synchro, Off | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Range | 1.6 (50cm) –23 Ft. (7.0m) (W), 1.6 Ft. (50cm) – 13 Ft. (4.0m) (T) *Image Brightness May Diminish Depending On The Shooting Distance. |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-Eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, IFrame Movie | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Photo Effects | Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1–3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | Off, 2 Sec., 10 Sec., Custom, Remote Shooting | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Wireless Control | Wi-Fi® | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | JPEG: One Shot AF (H): Approx. 20.0 Shots/Sec. One Shot (L): Approx. 3.0 Shots/Sec. Servo AF (H): Approx. 8.3 Shots/Sec. Servo AF (L): Approx. 3.0 Shots/Sec. RAW & C-RAW: One Shot AF (H): Approx. 20.0 Shots/Sec. One Shot (L): Approx. 3.0 Shots/Sec. RAW Burst Mode: Max: Approx. 30.0 Shots/Sec. |
| Storage Media | SD/SDHC/SDXC And UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System (DCF) Compliant; DPOF (Version 1.1) Compatible | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif 2.31 (DCF 2.0), RAW (Canon Original: 14-Bit, CR2) * JPEG/RAW (CR3 Canon Original: 14-Bit RAW Format) RAW Images Are A/D Converted Into 12-Bit Format Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
| Number Of Recording Pixels | Still Images:
Panoramic Shooting:
| Content | Approx. Number Of Shots Recordable To 32 GB Memory Card:
* The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Content | Time Of Recordable Videos:
*1 Using An SD Speed Class 10 / UHS-I Compatible Memory Card. |
| Playback Modes File | List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-Up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump With Control Ring/Front Dial, Set Touch Actions, Playback Information Display | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Stereo | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | Wired: USB Type-C, HDMI (Type D) Wireless: Wi-Fi®* Specifications: IEEE 802. 11b/G/N Frequency: 2.4 GHz Channels: 1–11 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) * Compatible With IOS® Versions 9.3/10.3/11.2-11.4/12.2, Android™ Smartphone And Tablet Versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data Charges May Apply With The Download Of The Free Canon Camera Connect App. This App Helps Enable You To Upload Images To Social Media Services. Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers |
| Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging Via USB Cable Available Through USB Power Adapter PD-E1 (Charging Time: Approx. 110 Min.)* * Charging Time Varies Considerably Depending On The Remaining Battery Power |
| Shooting Capacity Bp 511 | Approx. 235 Shots With Screen On (CIPA Compliant) Approx. 320 Shots With ECO Mode |
| Playback Time Bp 511 512 | Approx. 5 Hrs. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32–104°F / 0–40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10–90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.13 X 2.40 X 1.63 In. / 105.0 X 60.9 X 41.4mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | Black & Silver Models: Approx. 10.7 Oz. / 304g (Including Battery And Memory Card) Approx. 9.9 Oz. / 280g (Camera Body Only) |
Wireless Remote Control BR-E1
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Interface Cable IFC-100U
USB interface cable to connect to a computer or other USB device. Approx. 3.3 ft.
Battery Charger for NB-13L Li-Ion Batteries.
Allows you to charge the battery inside your camera by way of USB.
Battery Pack NB-13L
Lithium-Ion Battery Pack for selected G-series models.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
