PowerShot G7 X Mark II
- PowerShot G7 X Mark II
- Battery Pack NB-13L
- Battery Charger CB-2LH
- Wrist Strap WS-DC12
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Illuminate Your Passion
Stay inspired with the PowerShot G7 X Mark II camera, which combines exhilarating speed and performance with a smart, compact design. It can be ideal for travel, events and anywhere on the go, or as a secondary camera, and features a high-performance 1.0-inch 20.1 Megapixel1 CMOS sensor as well as a bright f/1.8–2.8 lens to help capture impressive images whenever your creativity sparks, even in low light conditions. The new DIGIC 7 Image Processor immediately pays dividends with improved auto focus tracking, enhanced IS and superb image clarity even when shooting with a high ISO. For increased flexibility, the PowerShot G7 X Mark II offers high-speed continuous shooting up to 8 fps in RAW2, JPEG and RAW+JPEG2 modes, and is equipped with Full HD capability, built-in Wi-Fi®3 and NFC4 and in-camera RAW conversion, giving you everything you need to capture inspiring images and video and share them with ease.
The PowerShot G7 X Mark II camera features a large 1.0-inch, 20.1 Megapixel* CMOS sensor that helps capture high-quality images and videos. Its wide dynamic range helps ensure both bright and dark parts of an image are fully captured, like the shadowy side of a building on a bright sunny day, or streetlights on a dark night. 20.1 Megapixels* means photos with enough detail to print, or enjoy on high-resolution monitors and mobile devices. It also gives additional flexibility during editing, giving you the option of cropping in on your subject for improved composition while still having a detailed, high-resolution image. Smooth gradations from light to dark keeps unrealistic banding in solid colors to a minimum. Thanks to an available ISO of up to 12800 (expandable to 25600) and the power of the new DIGIC 7 Image Processor, extremely low-light photos and videos are possible, with minimal image noise. Using a high ISO also allows for a faster shutter speed, which lowers the possibility of blur caused by excessive hand-held camera shake. For added flexibility, both JPEG and RAW images can be captured and saved.
The new DIGIC 7 Image Processor’s enhanced tracking and detection capabilities help keep subjects in focus, while ensuring each image has a high level of sharpness and minimum picture noise. Whether you’re capturing a fast-moving athlete or a feisty puppy, the DIGIC 7 Image Processor in the PowerShot G7 X Mark II camera can stay locked on throughout the action. Improved face tracking helps keep your friend or family member the subject of the photo. Even in extreme cases, like in low saturation or low-light dusk, dawn or darkened interior moments, the DIGIC 7 Image Processor helps keep what you’re photographing in focus. It also features the new Dual Sensing IS, which uses data from the image itself to help minimize the blur caused by camera shake and body movement. This results in clear, precise pictures even at slow shutter speeds. All this is in addition to upgraded detail and noise reduction abilities, especially in low light with high ISO settings. Powerful all around, the DIGIC 7 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal unwanted noise or grain.
Canon HS System
The Canon HS SYSTEM lets you take bright, clear photos as they happen. Beautiful low-light shots are possible with minimal noise and truly impressive detail in both highlight and shadow areas. The system is the result of two technologies in the PowerShot G7 X Mark II camera: the large format 1.0-inch High-Sensitivity CMOS sensor, which captures more light; and the DIGIC 7 Image Processor, which actively reduces noise at high ISO speeds up to 12800 and processes images at high speed, even at full resolution. Experience the freedom of using higher shutter speeds in far more situations, allowing you to capture images with outstanding clarity and detail.
The remarkable lens on the PowerShot G7 X Mark II camera takes full advantage of the camera's large sensor, giving your photography a wide range of expression. With a bright aperture value of f/1.8 at the wide angle and f/2.8 when fully zoomed to a factor of 4.2x (24100mm), this lens not only puts more in your frame, but is equipped to capture an incredible variety of situations with artistry and precision. Equipped with a 9-blade iris diaphragm, the lens lets you achieve a beautiful background defocus with shapes that are nearly round. Capture macro shots from as close as 2.0 in. (telephoto at 1.3 ft.). From a design perspective, each of the 11 glass lenses on the PowerShot G7 X Mark II has a multi-layer coating on it, which is similar to the Super Spectra Coating technology developed by Canon for EF lenses. These coatings have features like a high transmission factor, ultraviolet protection, resistant surface hardness, and stable characteristics. The coating also maximizes suppression of unwanted reflected light from ghosting or flaring to deliver clear images with high image quality.
Intelligent IS
Equipped with Canon's innovative Intelligent IS, the PowerShot G7 X Mark II camera helps you capture clear, steady images even in low light without using a tripod. The system automatically analyzes camera movement and applies the best shake correction method for the shooting situation allowing you to focus on framing and capturing your shot. For stills, the system selects from Normal IS, Panning IS, Macro (Hybrid) IS and Tripod modes. When shooting video, the system selects from Dynamic IS, Powered IS, Macro (Hybrid) IS and Active Tripod IS modes. Icons clearly mark the image stabilization mode, whether you're shooting still images or video.
When the action happens fast, the PowerShot G7 X Mark II camera can move fast with it. With the ability to shoot continuously at up to 8 fps, it can help you capture incredible images with nearly no time wasted. Whether you’re trying to catch the moment a player hits the ball, a bird taking flight or the start of any special moment, you can be sure you can capture the photo you want. Offering the flexibility to suit your specific needs, the PowerShot G7 X Mark II can shoot continuously in RAW mode2, JPEG mode and RAW+JPEG mode2. When used with the camera’s built-in RAW conversion, it provides extensive adjustment options for the images you capture.
The PowerShot G7 X Mark II camera has a large, high-resolution, 3.0" LCD monitor that tilts up 180° and down 45°, ideal for composing not only self portraits, but also for taking pictures at high and low angles with ease. The multi-angle LCD encourages creative framing because it's easy to achieve a flexible array of camera angles. Capacitive touch-panel operation feels familiar: simply touch to access quick control settings, focus and shutter release right on screen. A resolution of 1.04 million dots makes the virtually glare-free display ultra crisp and clear, so it's easy to compose your shots, choose camera settings and review and share your images.
Whether you're creating artistic film clips or capturing special occasions, the advanced video capabilities of the PowerShot G7 X Mark II camera can catch them in the quality they deserve. Incredibly realistic 1080p Full HD video is recorded at 60 fps with stereo sound in convenient MP4 format. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera's HDMI output. The MP4 format's small file size lets you fit more on a single memory card, and makes downloading and sharing quicker and easier. Manual movie mode is also available: adjust Av, Tv, and ISO speed and even select focus points by using the touch panel LCD screen. You can do this either before or during video capture to express your vision your way in a wider variety of situations all from a compact camera that is easily portable.
Built-in Wi-Fi® technology allows for on-the-go convenience when you want to share your photos and videos with friends and family. Easily post your images to select social networking and media sites Facebook®, Twitter®, YouTube™, Flickr®, and Google Drive™ through CANON iMAGE GATEWAY5 directly from your PowerShot G7 X Mark II camera, or save them to the online photo album to share anytime, anywhere. The camera can also connect directly to both compatible iOS® and Android™ devices3, and upload images via the free Canon Camera Connect app3 without a computer. You can control the destination of your uploads to share with everyone or to select groups, and even add comments. Sharing video is also easy with Wi-Fi® equipped PowerShot cameras, which record video using the easy-to-share MP4 format. Wi-Fi® capability makes posting in real time possible, so you can keep everyone up to date with photos and video even as events unfold. Wi-Fi® technology also allows you to transfer images to other Wi-Fi® equipped PowerShot cameras or print your photos directly to a PictBridge (Wireless LAN) certified printer. Thanks to the newly added Wi-Fi Button, you can now connect in both Shooting mode and Playback mode for quick and easy operation. You can even turn on the camera and connect at the same time with just one press of the button, helping you get right to sharing and managing your files when you like.
Built-in NFC (Near Field Communication) Technology
PowerShot digital cameras with built-in NFC (Near Field Communication) technology provide fast connectivity with a single tap. Simply touch the NFC icon on your camera to your compatible Android™ device4, and the Camera Connect app will launch automatically for quick, easy sharing of your images. Built-in NFC technology also makes it simpler to install the app. If the app hasn't been installed yet, once you touch the devices together for the first time, the download screen will display automatically. Simply touch the camera against an NFC-equipped device with the Canon Camera Connect app3 installed, and a Wi-Fi® connection is established no camera operations required. Even if your camera is off, NFC turns the camera on and establishes the connection (confirming the camera's nickname and privacy settings before the first connection is required).
Remote Shooting with the Camera Connect App
Remote shooting functions of the PowerShot G7 X Mark II camera through your compatible smartphone or tablet have been vastly improved with the Canon Camera Connect app. Now a variety of the camera's expressive capabilities are available to you: use different shooting modes (P, Av, Tv, M, Custom); enjoy multi-aspect shooting and display; choose AF frame modes (single-point/face detection); shoot in continuous shooting mode; and utilize the AF button. In addition, the Camera Connect app is now universal to PowerShot and EOS cameras with built-in Wi-Fi®, so if you switch between cameras, operation is easy and familiar.
Image Sync Function
In addition to wirelessly transferring photos and videos through CANON iMAGE GATEWAY5 to your computer, you can now view and download them from your compatible smartphone.6 Take them where you like, when you like, and use your familiar smartphone operations to view and share them.
Compatibility with Canon Connect Station CS100
The PowerShot G7 X Mark II camera is fully compatible with Canon's photo and video storage device: Connect Station CS100. By simply tapping with NFC, photos and videos are wirelessly transferred to the Connect Station, where up to 1TB of hard drive space and simple menus make them easy to store, manage and sort by albums, date or device name. From there, images and videos can be viewed in Full HD on an HDTV (via an HDMI cable), sent to compatible wireless printers, viewed/uploaded/downloaded from smartphones and tablets or PCs, and shared with other Canon Connect Stations and on social networking sites.
The Picture Style function, just like on EOS series digital cameras, lets you choose between eight presets that adjust color, contrast and other aspects of the image to help you fine-tune how your picture looks. For example, if you’re taking a photo of a friend, you can use Portrait mode, which keeps the subject in focus while artistically blurring the background for a soft feel. If you’re looking to capture some stunning mountain peaks, you can use Landscape mode, which helps ensure the image is in focus and the colors are vibrant. There are eight styles to choose from, plus you can download additional styles and even create your own with the Picture Style Editor.
The PowerShot G7 X Mark II camera’s powerful in-camera RAW conversion lets you adjust multiple aspects of an image after you capture it, without using a computer. If an image is a little darker than you’d hoped, you can Increase the brightness, or let the Auto Light Optimizer analyze the photo and change the levels accordingly. You can also fine-tune the white balance for a cool or warm look, change the Picture Style and more. When you’re satisfied with the results, switch between the original and adjusted image to check your work, then save the result as a JPEG for later use.
The versatile control ring is a quick and convenient way to manually adjust photos and navigate camera menus. A selection lever lets you switch between step ring and continuous ring movement. Step ring movement makes changing settings, like switching between Picture Styles, tweaking aperture or modifying shutter speeds, fast and easy. Continuous ring movement lets you smoothly change focus with minimal sound, even while recording movies, so you’re able to decide what part of the image is sharp while on the go.
Time-Lapse Movie mode captures an image every few seconds, then combines these multiple images into a single movie. The sun dropping over the horizon, boats navigating a harbor, cars twisting through streets during rush hour can all be compressed in time, while maintaining gorgeous image quality. Movement appears fast, like reality has been accelerated. Intervals of 1- to 30-seconds between photos are available.
By using a slow shutter speed and Canon’s advanced image stabilization, the PowerShot G7 X Mark II camera’s Panning mode can help you capture fast-moving subjects in an artistic and striking fashion. Athletes, cars, trains and more can be kept in focus while the background is smoothly blurred, creating an intense appearance of motion.
2. UHS-I compatible 16GB card based on Canon’s testing standards. The number of shots can vary according to the subject and brand of card, etc.
3. Compatible with iOS® versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
4. Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
5. One-time registration is required on CANON iMAGE GATEWAY online photo album.
6. With the download of the free Canon Online Photo Album app. The images and videos utilizing Image Sync can be viewed and downloaded with your smartphone or tablet within 30 days.
| Type Of Camera | Digital Camera With Built-In Flash, 4.2x Optical, 4x Digital And 17x Combined Zoom With Optical Image Stabilizer | |||||||||||||||||||||||||
| Type | 20.1 Megapixel*, 1.0-Inch CMOS (Sensor Aspect Ratio: 3:2) * Image Processing May Cause A Decrease In The Number Of Pixels. |
| Total Pixels | Approx. 20.9 Megapixels | |||||||||||||||||||||||||
| Effective Pixels | Approx. 20.1 Megapixels | |||||||||||||||||||||||||
| Focal Length | 8.8 (W) - 36.8 (T) Mm (35mm Film Equivalent: 24-100mm) | |||||||||||||||||||||||||
| Optical Zoom | 4.2x | |||||||||||||||||||||||||
| Digital Zoom | 4x | |||||||||||||||||||||||||
| Focusing Range | Normal/Auto: 2.0 In. (5 Cm) - Infinity (W), 1.3 Ft. (40 Cm) - Infinity (T) Macro/Underwater Macro: 2.0 In. - 1.6 Ft. (5-50 Cm) (W) Quick: 5.0-65.6 Ft. (1.5-20m) (W), 5.0-65.6 Ft. (1.5-20m) (T) |
| Autofocus | TTL Autofocus, Manual Focus | |||||||||||||||||||||||||
| Optical Viewfinder | N/A | |||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch Tilt-Type TFT Color Liquid Crystal, With Biaxial Tilt For Low And High Angle Shooting | |||||||||||||||||||||||||
| Lcd Pixels | Approx. 1.04 Million Dots | |||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | |||||||||||||||||||||||||
| Maximum Aperture | F/1.8 (W), F/2.8 (T) | |||||||||||||||||||||||||
| Shutter Speed | 1-1/2000 Sec. (In Auto Mode) 15 -1/2000 Sec. (In All Shooting Modes) BULB (In M Mode Only) 1/8 Minimum In Manual Movie Mode |
| Sensitivity | ISO 125-6400 (In Auto Mode) Max. ISO Speed In P Mode Is ISO 12800 (Expanded ISO: 25600) |
| Light Metering Method | Evaluative, Center Weighted Average, Spot | |||||||||||||||||||||||||
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | |||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±3 Stops In 1/3-Stop Increments Videos: ±3 Stops In 1/3-Stop Increments (Not Available During Shooting) |
| White Balance Control | Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater WB, Kelvin Settings, Custom 1-2 | |||||||||||||||||||||||||
| Built In Flash | Auto, On, Slow Synchro, Off | |||||||||||||||||||||||||
| Flash Range | 1.6 Ft. (50 Cm) - 23 Ft. (7.0 M) (W), 1.3 Ft. (40 Cm) - 13 Ft. (4.0 M) (T) Image Brightness May Diminish Depending On The Shooting Distance |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Increments | |||||||||||||||||||||||||
| Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-Eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Underwater, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, IFrame Movie | |||||||||||||||||||||||||
| Self Timer | Off, 2 Sec., 10 Sec., Custom | |||||||||||||||||||||||||
| Wireless Control | Wi-Fi® / NFC | |||||||||||||||||||||||||
| Continuous Shooting | One Shot H: Approx. 8.0 Shots/Sec. (Max. 30 Shots) One Shot L: Approx. 4.0 Shots/Sec. Servo H: Approx. 5.4 Shots/Sec. (Max. 46 Shots) Servo L: Approx. 4.0 Shots/Sec. |
| Storage Media | SD/SDHC/SDXC And UHS-I Memory Cards | |||||||||||||||||||||||||
| File Format | Design Rule For Camera File System (DCF) Compliant; DPOF (Version 1.1) Compatible | |||||||||||||||||||||||||
| Image Recording Format | Fine / Normal | |||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif. 2.3 (JPEG), RAW (Canon Original: 14-Bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo)) |
| Number Of Recording Pixels |
| Description | List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-Up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump With Control Ring/Front Dial, Set Touch Actions, Playback Information Display | |||||||||||||||||||||||||
| Audio Out | Stereo | |||||||||||||||||||||||||
| Other | Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers | |||||||||||||||||||||||||
| Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging Via USB Cable Available Through Compact Power Adapter CA-DC30* (Charging Time: Approx. 5 Hrs.)** * To Use CA-DC30, IFC-600PCU Is Necessary. ** Charging Time Varies Considerably Depending On The Remaining Battery Power. |
| Shooting Capacity Bp 511 | Approx. 265 Shots With Screen On (CIPA Compliant) Approx. 355 Shots With ECO Mode |
| Playback Time Bp 511 512 | Approx. 5 Hours | |||||||||||||||||||||||||
| Operating Temperature | 32-104°F/0-40°C | |||||||||||||||||||||||||
| Operating Humidity | 10-90% | |||||||||||||||||||||||||
| Dimensions W X H X D | 4.15 X 2.40 X 1.65 In. / 105.5 X 60.9 X 42.0mm | |||||||||||||||||||||||||
| Weight | Approx. 11.3 Oz. / 319g (Including Battery And Memory Card) Approx. 10.4 Oz. / 294g (Camera Body Only) |
High-Power Flash HF-DC2
Powerful slave flash, fired by the camera's pre-flash. Effectively doubles the flash range of the camera. Comes with mounting bracket.
Interface Cable IFC-600PCU
Conveniently charge the battery in your PowerShot by connecting the camera to your computer using the IFC-600PCU cable
Leather Case PSC-5500
Waterproof Case WP-DC55
The WP-DC55 waterproof case allows you to take great underwater shots and be worry-free during inclement weather. Dustproof and waterproof up to 130ft (40m). Supplied accessories include a neck strap and silicone grease.
AC Adapter Kit
ACK-DC110
Provides AC power to the camera with uninterrupted power for shooting or downloading.
Battery Charger for NB-13L Li-Ion Batteries.
Compact Power
Adapter CA-DC30
An alternative option for charging the battery in your PowerShot camera. Plugs into standard wall outlet and works with Canon Interface Cable IFC-600PCU or with a standard Micro-USB to USB cable.
Battery Pack NB-13L
Lithium-Ion Battery Pack for selected G-series models.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
