PowerShot G5 X Mark II
- PowerShot G5 X Mark II
- Battery Pack NB-13L
- Battery Charger CB-2LH
- Wrist Strap WS-DC12
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Premium Performance On the Go
Want DSLR-level results but don’t want to carry the camera and various lenses around? The compact PowerShot G5 X Mark II gives you stunning image quality while conveniently letting you carry it on any adventure. It has a 20.1-Megapixel 1.0-inch Stacked CMOS sensor and powerful DIGIC 8 processor for fast and gratifying results. The 5x Optical Zoom with image stabilization provides range and clear, steady images and video, while a built-in pop-up EVF lets you frame your subjects with ease. For variety, you can shoot 4K 30p or Full HD 120p video, be creative with Panoramic and Star Shooting Modes, and shoot continuously up to 20 fps (or 30 fps with RAW burst mode). With the PowerShot G5 X Mark II camera, quality and creativity doesn’t have to be left behind just because your DSLR was.
The PowerShot G5 X Mark II camera features a new 1.0-inch 20.1 Megapixel stacked CMOS sensor, which helps achieve high image quality and high performance at the same time, delivering gorgeous, detailed images. It also enables fast continuous shooting and fast autofocus that helps you capture important moments.
DIGIC 8 Image Processor
The DIGIC 8 Image Processor helps produce high image quality and fast operation, even in in low light. When using high ISO settings, the image processor helps keep results sharp and detailed in virtually any lighting situation. Powerful all around, the DIGIC 8 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal noise or grain.
With a 5x optical zoom lens, a range of 24–120mm, advanced Optical Image Stabilization and an aperture range of f/1.8(wide)- f/2.8 (telephoto), the PowerShot G5 X Mark II camera is suitable for group photographs, landscapes, and even close-up photography. The PowerShot G5 X Mark II’s lens works in conjunction with the camera's sensor and image processor to deliver sharp images from edge to edge and from wide-angle to telephoto.
With the help of the DIGIC 8 image processor, and the stacked CMOS sensor, enjoy recording non-cropped 4K movies at a frame rate of up to 30p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can be created in 4K simply and easily with the dedicated Time-lapse Movie mode.
FHD 120p Video
Ideal for smooth, slow-motion playback videos, Full HD movies can also be recorded at a high-frame rate of approx. 120 frames per second. Designed to capture fun, beautiful videos, The PowerShot G5 X Mark II camera helps ensure you can see the unique expressions of your friends or family's faces in close-up movies.
The PowerShot G5 X Mark II camera features a 0.39-inch OLED (Organic Light-Emitting Diode) built-in pop-up EVF with approx. 2.36 million dots – making the camera compact in size. The electronic viewfinder (EVF) provides a bright, sharp and colorful view of the subject at hand, and shows a crisp and vivid image with minimal distortion, even when the eye moves off the center of the visual field.
Touch and Drag AF
Equipped with Touch and Drag AF, the PowerShot G5 X Mark II camera makes it easy to select a focus point quickly without taking your eye away from the viewfinder. Using the Touchscreen LCD, it's as simple as pointing to the desired area of focus. The chosen AF point is then displayed in the camera's EVF for quick confirmation.
With autofocus tracking on to help keep your shots sharp, you can maintain the speed and shoot at up to 20.0 fps. The PowerShot G5 X Mark II can also shoot at up to 30.0 fps during RAW burst mode – ideal for sports, wildlife, moving subjects or anything unpredictable.
The PowerShot G5 X Mark II camera is compatible with the USB Power Adapter PD-E1 for in-camera charging via USB. Featuring an industry standard USB-C connector, the optional USB Power Adapter PD-E1 makes for easy charging without the necessity to remove the battery from the camera. You can even record up to 8 hours continuously when recording time is set to "unlimited".
The PowerShot G5x Mark II camera is designed to make using Wi-Fi®* connectivity fast and easy. It can transfer files directly to a compatible smart device using the free Canon Camera Connect app. Simply connect to the Camera Connect app* to transfer images to your smart device, then share and upload from the device directly to various social media sites and web services or print directly to compatible wireless Canon printers.
Built-in Bluetooth®** Capability
Bluetooth®** pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. This low-energy wireless connection helps preserve battery life while allowing remote control of the PowerShot G5x Mark II camera. It also sends continuously updated GPS^^ location data from your phone, letting you geotag what you've captured so you can know precisely where you took that stunning vacation photo.
Remote Shooting
Wireless capabilities also allow you to use your compatible smart devices with the Canon Camera Connect app* to remotely control the camera, which is useful for self-portraits and group shots or for shooting from a distance (as long as the camera is in wireless range).
* Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.1 or later and the Camera Connect App Ver. 2.5.0. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^^ In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
Canon's Digital Photo Professional Express makes speedy processing of JPEGs and CR3 RAW files on a compatible handheld device a breeze. Working with Canon's Camera Connect app^^ to create a streamlined wireless workflow, DPP Express lets you adjust settings right on your mobile device, saving files to the cloud, a PC or your camera.
^^ Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
The PowerShot G5 X Mark II camera is designed to make panoramic photography enjoyable yet intriguing. Whether capturing vertical or horizontal pictures, it's easy to switch to the dedicated Panoramic Shot Mode and start shooting by pushing down the shutter button and panning the camera.
Star Shooting Mode
Make any starry sky easier to capture with the help of the star shooting mode on the PowerShot G5 X Mark II camera. With just an optional tripod, you can capture exquisite Star Trails and Star Time-Lapse Movies. The modes can be performed fully automatically or with manual controls for extra versatility.
* Compatible with iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS®; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth®; version 4.1 and the Camera Connect App Ver. 2.5.0. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
| Type Of Camera | Digital Camera With Built-In Flash, 5x Optical, 4x Digital And 20x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 20.1 Megapixel*, 1.0-Inch Stacked CMOS (Sensor Aspect Ratio: 3:2) * Image Processing May Cause A Decrease In The Number Of Pixels. |
| Total Pixels | Approx. 20.9 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 20.1 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focal Length | 8.8 (W) – 44.0(T) Mm (35mm Film Equivalent: 24–120mm) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Zoom | Approx. 5x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | Approx. 4x Optical Zoom |
| Focusing Range | Auto/Manual: 2.0 In. (5cm) – Infinity (W), 7.9 In. (20cm) – Infinity (T) Normal: 2.0 In. (5cm) – Infinity (W), 7.9 In. (20cm) – Infinity (T) Macro: 2.0 In. – 1.6 Ft. (5–50cm) (W) |
| Autofocus | TTL Autofocus, Manual Focus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Electronic Viewfinder (Approx. 2.36 Million Dots) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Type TFT Color Liquid Crystal (Vari-Angle) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 1.04 Million Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/1.8 (W), F/2.8 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1–1/2000 Sec. (In Auto Mode) 15–1/2000 Sec. (In Tv, M, And Manual Movie Modes) 1/4000 Sec. (Movie Shooting) 1/2000 Sec. (Time-Lapse Movie) |
| Sensitivity | When In Auto Mode - Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/ 2500/3200/4000/5000/6400 When In P Mode - Max. ISO Speed 12800 |
| Light Metering Method | Evaluative, Center Weighted Average, Spot (Still Image Only) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±3 Stops In 1/3-Stop Increments Videos: ±3 Stops In 1/3-Stop Increments |
| White Balance Control | Auto (Ambience & White Priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Built In Flash | Auto, On, Slow Synchro, Off | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Range | 1.6 Ft.(50cm) –24.6 Ft. (7.5m) (W), 1.6 Ft. (50cm) – 14.8 Ft. (4.5m) (T) Image Brightness May Diminish Depending On The Shooting Distance. |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | C, M, Av, Tv, P, Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def.1-3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Photo Effects | Grainy B/W, Soft Focus, Fish-Eye Effect, Art Bold Effect, Water Painting Effect, Toy Camera Effect, Miniature Effect *Applicable Only To Images Taken With Same Model. |
| Self Timer | Off, 2 Sec., 10 Sec., Custom, Remote Shooting | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Wireless Control | Unavailable Electronic Level: |
| Continuous Shooting | JPEG, RAW, C-RAW: One Shot AF: Approx. 20 Shots/Sec. JPEG Servo AF: Approx. 8 Shots/Sec. RAW Burst Mode: Approx. 30 Shots/Sec. |
| Storage Media | SD/SDHC/SDXC And UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System (DCF) Compliant; DPOF (Version 1.1) Compatible | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif 2.3 (DCF 2.0), RAW (Canon Original: 14-Bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
| Number Of Recording Pixels | Still Images:
Panoramic Shooting:
| Content | Approx. Number Of Shots Recordable To 32 GB Memory Card:
Note: F=Fine N=Normal |
| Content | Time Of Recordable Videos:
*1 Using An SD Speed Class 10 / UHS-I Compatible Memory Card. |
| Playback Modes File | Story Highlights, Protect, Favorites, Erase, Print, Play Movie, Image Search, Slideshow, Rotate, Play Creative Shot Movies, Short Clip Mix, Resize, Red-Eye Correction, Print Settings, Photobook Set-Up, Group Images, Auto Rotate, Resume, Image Jump With Control Ring/Front Dial, Set Touch Actions | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Video Out | NTSC | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Stereo | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | Wired: USB (Micro-B), HDMI (Type D) Wireless: Bluetooth: Ver. 4.1 Wi-Fi®* Specifications: IEEE 802. 11b/G/N Frequency: 2.4 GHz Channels: 1–11 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) * Compatible With IOS® Versions 9.3/10.3/11.2-11.4/12.2, Android™ Smartphone And Tablet Versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data Charges May Apply With The Download Of The Free Canon Camera Connect App. This App Helps Enable You To Upload Images To Social Media Services. Please Note That Image Files May Contain Personally Identifiable Information That May Implicate Privacy Laws. Canon Disclaims And Has No Responsibility For Your Use Of Such Images. Canon Does Not Obtain, Collect Or Use Such Images Or Any Information Included In Such Images Through This App. Remote Switch Terminal Available; Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers |
| Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging Via USB Cable Available Through USB Power Adapter PD-E1 (Charging Time: Approx. 110 Min.)* * Charging Time Varies Considerably Depending On The Remaining Battery Power |
| Shooting Capacity Bp 511 | Still Images: Approx. 230 Shots With Screen On Approx. 180 Shots With Viewfinder On Approx. 320 Shots With ECO Mode Movie Recording Time: Approx. 55 Min. With Screen On Approx. 45 Min. With Viewfinder On |
| Playback Time Bp 511 512 | Approx. 4 Hr. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32–104°F / 0–40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10–90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.37 X 2.4 X 1.81 In. / 110.9 X 60.9 X 46.0mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | 12 Oz. / 340g (Including Battery And Memory Card) 11.1 Oz. / 316g (Camera Body Only) |
Wireless Remote Control BR-E1
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Interface Cable IFC-100U
USB interface cable to connect to a computer or other USB device. Approx. 3.3 ft.
Battery Charger for NB-13L Li-Ion Batteries.
Allows you to charge the battery inside your camera by way of USB.
Battery Pack NB-13L
Lithium-Ion Battery Pack for selected G-series models.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
