PowerShot G5 X
- 1.0-inch, 20.2 Megapixel High-Sensitivity CMOS sensor.
- A bright f/1.8 (W) - f/2.8 (T), 4.2x Optical Zoom.
- Built-in 2.36 million pixel, high-definition Electronic Viewfinder.
- Equipped with an exposure compensation dial, front dial, control ring and control dial.
- PowerShot G5 X
- Neck Strap NS-DC12
- Battery Pack NB-13L
- Battery Charger CB-2LH
- Strap Adapters
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The first PowerShot G-Series camera to incorporate a full-featured 2.36 million dot electronic viewfinder, the amazing PowerShot G5 X camera makes it simple to compose, set and capture high-quality stills and video without taking your eye away from the camera. For photography in the glare of bright sunlight, recording HD Video in an auditorium and other situations where the lighting is difficult or using the LCD monitor is inconvenient, the PowerShot G5 X’s electronic viewfinder helps enable unfettered operation. Full control is made simple with dedicated dials situated around the camera that let you easily customize and control the settings. What’s more, helpful features like a built-in accessory hot shoe and a multi-angle, capacitive touch screen monitor serve to create an experience as unique as the subject being recorded. With its phenomenal and large imaging sensor, its marvelous electronic viewfinder and comprehensive operation, the PowerShot G5 X can deliver performance that’s easy to see.
At the heart of the PowerShot G5 X camera is a brilliant 1.0-inch 20.2 Megapixel* High-Sensitivity CMOS sensor. Physically larger than the sensors found in most compact cameras, the PowerShot G5 X's sensor works in tandem with Canon's DIGIC 6 Image Processor to quickly deliver gorgeous, high-resolution images with nuanced details, plus impressive low-light performance with a low signal-to-noise ratio and minimal noise and distortion. Suitable for tremendous enlargements, significant cropping and many other applications appealing to the advanced photographer, images and video captured on the PowerShot G5 X's sensor are engineered to impress even the most critical eye.
Canon DIGIC 6 Image Processor
The PowerShot G5 X camera is powered by the latest iteration of Canon's proprietary processor, the DIGIC 6 Image Processor, which takes still and video image quality to a beautiful level. Improved light sensitivity allows for higher resolution with less noise when shooting in dark conditions, and Dynamic IS now detects and compensates for tilt and parallel movement (shift blur) to create video that's exceptionally free of distortion. The DIGIC 6 Image Processor also enhances the performance capabilities of the PowerShot G5 X, powering full-resolution, high-speed continuous still shooting (even in P, Av, Tv and M modes) and the advanced star shooting modes. The processor allows for MP4 video recording for better compatibility with mobile devices and tablets. Highly compressed MP4 video not only preserves space on your memory card but also improves playback on mobile devices. The processor also supports an MF Peaking function, giving you a pro-level focusing tool.
Canon HS SYSTEM
The Canon HS SYSTEM lets you take bright, clear photos as they happen. Beautiful low-light shots are possible with minimal noise and truly impressive detail in both highlight and shadow areas. The system is the result of two technologies in the PowerShot G5 X camera: the large format 1.0-inch High-Sensitivity CMOS sensor, which captures more light; and the DIGIC 6 Image Processor, which actively reduces noise at high ISO speeds up to 12800 and processes images at high speed, even at full resolution. Experience the freedom of using higher shutter speeds in far more situations, allowing you to capture images with exceptional clarity and detail.
* Image processing may cause a decrease in the number of pixels.
To take advantage of its large, 1.0-inch imaging sensor, the PowerShot G5 X camera has a sharp and versatile 4.2x Optical Zoom lens. With a 35mm equivalent range of 24100mm it's equally suitable for landscapes, portraits, group photographs and even close-up photography. Designed to perform in numerous lighting situations, the PowerShot G5 X's lens has a bright maximum aperture of f/1.8 for low light performance, a 9-blade aperture for beautiful, blurred background detail and is engineered to focus from distances as close as 2.0 in. The PowerShot G5 X's lens works in concert with the camera's sensor and image processor to reliably deliver sharp images from edge to edge and from wide-angle to telephoto, all tailored to meet the exacting standards of even critical photographers.
Intelligent IS
Equipped with Canon's innovative Intelligent IS, the PowerShot G5 X camera helps you capture clear, steady images even in low light without using a tripod. The system automatically analyzes camera movement and applies the best shake correction method for the shooting situation allowing you to focus on framing and capturing your shot. For stills, the system selects from Normal IS, Panning IS, Macro (Hybrid) IS and Tripod modes. When shooting video, the system selects from Dynamic IS, Powered IS, Macro (Hybrid) IS and Active Tripod IS modes. Icons clearly mark the image stabilization mode, whether you're shooting still images or video.
The PowerShot G5 X camera's defining feature is its unique, high-definition electronic viewfinder. It's great for photographers who prefer to hold the camera up to their eye, and is a veritable lifesaver in bright light and when composing on the camera's LCD screen is inconvenient or overly conspicuous. Featuring 2.36 million dots, and with a wide color gamut, it provides a high-contrast, realistic and smooth edge-to-edge view for image composition, adjustment and review. Designed for sustained use, it delivers 100% image coverage, a smooth refresh rate up to 120 frames-per-second (Smooth Mode) and a flexible information display that can enable comfortable camera operation throughout the day. Its 22mm eyepoint delivers excellent visibility, even when wearing glasses, and a built-in eye sensor helps the PowerShot G5 X to transfer quickly between the viewfinder display and Live View on the camera's LCD.
Convenient Controls Help Provide for Quick Control of Shooting Settings
Designed for speedy operation while looking through the viewfinder, the PowerShot G5 X features a host of controls for quick, accurate settings and adjustments. Beyond its Vari-angle touch panel LCD monitor, the PowerShot G5 X camera features a front dial situated on the front of the camera for operation with the index finger, a top-mounted, thumb-operated exposure compensation dial, a rear-mounted control dial plus a control ring around the camera's lens. Eminently customizable, each dial has an optimized operating torque that helps to identify it by feel, for sustained, intuitive and near-silent operation in quiet situations like weddings and performances.
The PowerShot G5 X camera's hot shoe enables expanded operations for advanced photography. It's compatible with all Speedlite flashes for the EOS System, so bounce flash and multiple-flash photography is easy to achieve. Whether attaching a Speedlite flash or the Remote Switch RS-60E3 for long exposures or night scenes, the PowerShot G5 X's hot shoe can help provide shooting opportunities far beyond the scope of most compact cameras.
For composing photos and movies from any angle and for easy self-portraits, the PowerShot G5 X camera features a high-resolution, Vari-angle, capacitive LCD screen that can not only tilt out and rotate up to 270°, but can also be turned around and closed when using the camera's electronic viewfinder or when the camera is not in use. Its touch-panel operation makes it simple to access quick control settings, focus and shutter release right on the screen.
With its large sensor and high performance lens the PowerShot G5 X camera creates spectacular 1080p Full HD video, but this premium model takes video-making even further with several high-end features. Set video capture to your shooting needs: 24p, 30p or 60p, with MP4 format available for easy sharing. Advanced audio includes expanded dynamic range and a better S/N ratio. Improved Dynamic IS significantly reduces shaking caused by handheld shooting. Manual controls (Av, Tv and ISO) can be set prior to and during shooting for full creative expression, and Manual Focus is also available. Shooting to commercial specifications is now possible with HDMI Live Out for checking images on an external monitor and an advanced tripod socket for smooth panning and tilting.
Built-in Wi-Fi® technology is included for on-the-go convenience when you want to share your photos and videos with friends, family and the whole world. Easily post your images to social networking and media sites Facebook®, Twitter®, YouTube™, Flickr®, and Google Drive™ through CANON iMAGE GATEWAY^ directly from your PowerShot camera, or save them to the online photo album to share anytime, anywhere. The camera can also connect directly to both iOS® and Android™ devices**, and upload images via the free Canon Camera Connect app** without a computer. You can control the destination of your uploads to share with everyone or to selected groups, and even add comments. Sharing video is also easy with Wi-Fi® equipped PowerShot cameras, which record video using the easy-to-share MP4 format. Enhanced Wi-Fi® makes posting in real time possible, so you can keep everyone up to date with photos and video even as events unfold. Wi-Fi® technology also allows you to transfer images to other Wi-Fi® equipped PowerShot cameras or print your photos directly to a PictBridge (Wireless LAN) certified printer.
Built-in NFC (Near Field Communication)
PowerShot digital cameras with built-in NFC (Near Field Communication) technology eliminates the need to manually find and open the Canon Camera Connect app** on your mobile device. Simply touch the NFC icon on your camera to your compatible Android™ device***, and the Camera Connect app will launch automatically for quick, easy sharing of your images. Built-in NFC technology also makes it simpler to install the app. If the app hasn't been installed yet, once you touch the devices together for the first time, the download screen will display automatically. Now, NFC helps ensure a seamless connection to a compatible Android™ device.*** Simply touch the camera against an NFC-equipped device with the Canon Camera Connect app installed, and the Wi-Fi® connection is established no camera operations required. Even if your camera is off, NFC turns the camera on and establishes the connection (confirming the camera's nickname and privacy settings before the first connection is required).
Remote Shooting with the Camera Connect App
Remote shooting functions of the PowerShot G5 X camera through your smartphone or tablet have been vastly improved with the Canon Camera Connect app. Now a variety of the camera's expressive capabilities are available to you: use different shooting modes (P, Av, Tv, M, Custom); enjoy multi-aspect shooting and display; choose AF frame modes (single-point/face detection); shoot in continuous shooting mode; and utilize the AF button. In addition, the Camera Connect app is now universal to PowerShot and EOS cameras with built-in Wi-Fi®, so if you switch between cameras, operation is easy and familiar.
Mobile Device Connect Button
The camera's dedicated Mobile Device Connect Button gives you one-touch access to your compatible mobile device or computer (utilizing Image Sync function). You can transfer photos and videos to your smartphone or tablet for immediate sharing to a computer on the same network. When the camera finds a linked computer on the same wireless network, images are sent directly to it. Otherwise, images are temporarily stored on CANON iMAGE GATEWAY^ then transferred once a connection is made very convenient when you're on vacation or out for the day.
Image Sync Function
The Image Sync Function has been improved and expanded. In addition to wirelessly transferring photos and videos through CANON iMAGE GATEWAY^ to your computer, now you can view and download them from your smartphone.^^ Take them anywhere, anytime, and use your familiar smartphone operations to view and share them.
Compatibility with Canon Connect Station CS100
The PowerShot G5 X camera is fully compatible with Canon's photo and video storage device: Connect Station CS100. By simply tapping with NFC, photos and videos are wirelessly transferred to the Connect Station, where up to 1 TB of hard drive space and simple menus make them easy to store, manage and sort by albums, date or device name. From there, images and videos can be viewed in Full HD on an HDTV (via an HDMI cable), sent to compatible wireless printers, viewed/uploaded/downloaded from smartphones and tablets or PCs, and shared with other Canon Connect Stations and on social networking sites.
Starry skies were formerly out of reach to all but experienced SLR camera users, but the star shooting modes on the PowerShot G5 X camera make these wonderfully impressive images accessible to all. With just a tripod and simple settings, you can capture exquisite Star Nightscapes, Star Trails and Star Time-Lapse Movies. The modes can be performed fully automatically or with manual controls for extra versatility. Support functions including Night Display, Color Adjustment and Star Emphasis make any starry sky easier to capture.
** Compatible with iOS® versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
^ One-time registration is required on CANON iMAGE GATEWAY online photo album.
^^ With the download of the free Canon Online Photo Album app. The images and videos utilizing Image Sync can be viewed and downloaded with your smartphone or tablet within 30 days.
| Type Of Camera | Digital Camera With Built-In Flash, 4.2x Optical, 4x Digital And 17x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 20.2 Megapixel*, 1.0-Inch CMOS (Sensor Aspect Ratio: 3:2) *Image Processing May Cause A Decrease In The Number Of Pixels. |
| Total Pixels | Approx. 20.9 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 20.2 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focal Length | 8.8 (W) - 36.8 (T) Mm (35mm Film Equivalent: 24-100mm) Optical Zoom Approx. 4.2x |
| Optical Zoom | Approx. 4.2x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | Approx. 4x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Auto/Manual: 2.0 In. (5cm) - Infinity (W), 1.3 Ft. (40cm) - Infinity (T) Normal: 2.0 In. (5cm) - Infinity (W), 1.3 Ft. (40cm) - Infinity (T) Macro: 2.0 In. - 1.6 Ft. (5-50cm) (W) |
| Autofocus | TTL Autofocus, Manual Focus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Electronic Viewfinder (Approx. 2.36 Million Dots) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Type TFT Color Liquid Crystal (Vari-Angle) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 1.04 Million Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/1.8 (W), F/2.8 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1-1/2000 Sec. (In Auto Mode) 30-1/2000 Sec. (In Tv, M, And Manual Movie Modes) BULB (In M Mode Only) 1/8 Minimum In Manual Movie Mode |
| Sensitivity | Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/4000/5000/6400 (When In Auto Mode) Max. ISO Speed 12800 (When In P Mode) |
| Light Metering Method | Evaluative, Center Weighted Average, Spot | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±3 Stops In 1/3-Stop Increments Videos: ±3 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| White Balance Control | Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Custom1-2 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Built In Flash | Auto, On, Slow Synchro, Off | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Range | 1.6 (50cm) -23 Ft. (7.0m) (W), 1.6 Ft. (50cm) - 13 Ft. (4.0m) (T) Image Brightness May Diminish Depending On The Shooting Distance. |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Creative Shot, Portrait, Self Portrait, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, Fireworks, High Dynamic Range, Nostalgic, Fish-Eye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect, Standard Movie, Short Clip, Manual Movie, IFrame Movie C, M, Av, Tv, P, Hybrid Auto, Auto, Creative Shot, Sports, SCN*1, Creative Filters*2, Movie*3
*1. Portrait, Smart Shutter *4, Star *5, Handheld Night Scene, Snow, Fireworks *2. High Dynamic Range, Nostalgic, Fish-Eye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect *3. Standard Movie, Short Clip, Manual Movie, IFrame Movie *4. Smile, Wink Self-Timer, Face Self-Timer *5. Star Nightscape, Star Trails, Star Time-Lapse Movie |
| Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | Off, Approx. 2 Sec. Delay, Approx. 10 Sec. Delay, Custom | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Wireless Control | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | One Shot: Approx. 5.9 Shots/Sec. Servo: Approx. 4.4 Shots/Sec. |
| Storage Media | SD/SDHC/SDXC And UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | SD/SDHC/SDXC And UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif 2.3 (DCF 2.0), RAW (Canon Original: 14-Bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
| Number Of Recording Pixels | Still Images: 1) 16:9 - Large: 5472 X 3080; Medium 1: 4320 X 2432; Medium 2: 1920 X 1080; Small: 720 X 408 2) 3:2 - Large: 5472 X 3648, Medium 1: 4320 X 2880, Medium 2: 2304 X 1536, Small: 720 X 480 3) 4:3 - Large: 4864 X 3648, Medium 1: 3840 X 2880, Medium 2: 2048 X 1536, Small: 640 X 480 4) 1:1 - Large: 3648 X 3648; Medium 1: 2880 X 2880; Medium 2: 1536 X 1536; Small: 480 X 480 Videos: Full HD 1920 X 1080: 59.94 Fps Full HD IFrame: 1920 X 1080: 29.97 Fps Full HD Star Time-Lapse Movie: 1920 X 1080: 14.985 Fps / 29.97 Fps HD 1280 X 720: 29.97 Fps 640 X 480: 29.97 Fps Miniature Effect: 1280 X 720: 6 Fps (5x Speed) / 3 Fps (10x Speed) / 1.5 Fps (20x Speed) Miniature Effect: 640 X 480: 6 Fps (5x Speed) / 3 Fps (10x Speed) / 1.5 Fps (20x Speed) Short Clip: 1280 X 720: 29.97 Fps |
| Content | Approx. Number Of Shots Recordable To 16 GB Memory Card
Note: SF=Superfine F=Fine
| Content |
*1 Using An SD Speed Class 10 / UHS-I Compatible Memory Card. |
| Playback Modes File | Playback Function Menu: Story Highlights, Protect, Favorites, Erase, Print, Group Playback, Play Movie, List/Play Digest Movies, Image Search, Slideshow, Rotate, Album Playback, Play Creative Shot Movies, Short Clip Mix, I-Contrast, Resize, Cropping, Red-Eye Correction, My Colors, Face ID Info, Print Settings, Photobook Set-Up, Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump With Control Ring/Front Dial, Set Touch Actions |
| Erase Modes | Select Image, Select Range, Select All Images
| Computer Interface | Wired USB (Micro-B), HDMI (Type D) Wireless Specifications: IEEE 802. 11b/G/N Frequency: 2.4 GHz Channels: 1-11 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) |
| Video Out | NTSC/PAL | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Stereo | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | Remote Switch Terminal Available; Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Source | Battery Pack NB-13L, AC Adapter Kit CA-DC10 (ACK-DC110) In-Camera Charging Via USB Cable Available Through Compact Power Adapter CA-DC30 (Charging Time: Approx. 5 Hr.)* * Charging Time Varies Considerably Depending On The Remaining Battery Power. |
| Shooting Capacity Bp 511 | Approx. 210 Shots With Screen On Approx. 215 Shots With Viewfinder On Approx. 320 Shots With ECO Mode |
| Playback Time Bp 511 512 | Approx. 4 Hr. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32-104°F / 0-40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10-90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.43 X 3.01 X 1.74 In. / 112.4 X 76.4 X 44.2mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | 13.3 Oz. / 377g (Including Battery And Memory Card) 12.5 Oz. / 353g (Camera Body Only) |
High-Power Flash HF-DC2
Powerful slave flash, fired by the camera's pre-flash. Effectively doubles the flash range of the camera. Comes with mounting bracket.
Compact remote switch replicating all of the functions of the shutter release button.
Off Shoe Camera Cord OC-E3
The Off-Camera Shoe Cord OC-E3 is convenient for using your flash apart from the camera. Also allows for Remote Triggering of the flash.
Interface Cable IFC-600PCU
Conveniently charge the battery in your PowerShot by connecting the camera to your computer using the IFC-600PCU cable
AC Adapter Kit
ACK-DC110
Provides AC power to the camera with uninterrupted power for shooting or downloading.
Battery Charger for NB-13L Li-Ion Batteries.
Compact Power
Adapter CA-DC30
An alternative option for charging the battery in your PowerShot camera. Plugs into standard wall outlet and works with Canon Interface Cable IFC-600PCU or with a standard Micro-USB to USB cable.
Battery Pack NB-13L
Lithium-Ion Battery Pack for selected G-series models.
Speedlite Transmitter ST-E3-RT
Facilitating radio controlled, two-way wireless transmission up to 98.4 ft. / 30 meters, among up to five groups or fifteen individual Speedlites, the ST-E3-RT represents the next generation in wireless flash systems.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
