PowerShot G1 X Mark II
- Canon 1.5-inch, 12.8 Megapixel High-Sensitivity CMOS sensor and DIGIC 6 Image Processor.
- 5x Optical Zoom plus a new f/2.0 - f/3.9, 24mm Wide-Angle lens with Optical Image Stabilizer.
- Built-in Wi-Fi for convenient sharing of images and video to compatible mobile devices.
- Built-in Near Field Communication (NFC) for easy Wi-Fi connectivity.
- PowerShot G1 X Mark II
- Battery Pack NB-12L
- Battery Charger CB-2LG
- Neck Strap NS-DC11
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Mark of PowerShot Excellence
Almost as large as the APS-C CMOS sensor found in many EOS digital SLRs, and bigger than those found in 4/3 system cameras, the PowerShot G1 X Mark II's sensor sets the standard for sensitivity and resolving power in compact cameras. Each cell area is 4.5x the size of those found in 1/1.7 type sensors and is thus able to capture more light at the pixel level. This means better detail, even at higher ISOs, with minimal noise and distortion and, thanks to the sensor's wide cell pitch, breathtaking dynamic range. The PowerShot G1 X Mark II camera natively captures images in the 3:2 aspect ratio, which is the same as Canon EOS SLR cameras. The PowerShot G1 X Mark II also features a new Aspect Ratio function, enabling RAW image capture in both 3:2 and 4:3 aspect ratios while maintaining the same angle of view.
Canon DIGIC 6 Image Processor
The PowerShot G1 X Mark II camera is equipped with the very latest Canon proprietary processor, the DIGIC 6 Image Processor, which makes several important advancements to image quality both in stills and video. Improved light sensitivity allows for higher resolution with less noise when shooting in dark conditions, and Dynamic IS now detects and compensates for tilt and parallel movement (shift blur) to create video that's exceptionally free of distortion. The DIGIC 6 Image Processor also enhances the performance capabilities of the PowerShot G1 X Mark II, powering full resolution high-speed continuous still shooting and the advanced Star shooting modes. Video recording has also been improved with MP4 recording for better compatibility with mobile devices and tablets. Highly compressed MP4 video not only preserves space on your memory card but also improves playback on mobile devices. Plus, with MF Peaking possible thanks to the new processor, you'll have a pro-level focusing tool at your disposal.
Canon HS SYSTEM
The Canon HS SYSTEM lets you take bright, clear photos in an even wider range of shooting situations. Beautiful low-light shots are possible with minimal noise and maximum detail in highlight and shadow areas. The system is the result of two technologies in the PowerShot G1 X Mark II: the amazing 1.5-inch High-Sensitivity CMOS imaging sensor, which is able to capture more light; and the DIGIC 6 Image Processor, which actively reduces noise at high ISO speeds and processes images at high speed, even at full resolution. Thus, the Canon HS SYSTEM allows you to use higher shutter speeds to capture clearer images with reduced noise and blur in more situations.
Developed specifically for the PowerShot G1 X Mark II, this large aperture lens offers the highest specifications for any camera in this class, and incorporates dramatic improvements on all fronts based upon the feedback of PowerShot G1 X users. It offers a 5x zoom factor with a 24–120mm equivalent range that's perfect for any number of shooting scenarios, and it has an incredibly bright aperture value of f/2.0 at wide angle and f/3.9 fully zoomed. It has a newly designed inner focusing system which enables fast AF speed with minimal lens movement, a reduced focusing distance of 5cm, features 14 elements in 11 groups and has a 9-blade aperture diaphragm for beautiful background blur. Engineered to perform and deliver gorgeous images every time, it's the perfect lens for the PowerShot G1 X Mark II camera's amazing sensor. And, in response to the overwhelming requests from PowerShot G1 X users, it has an integral lens cap.
Handheld shooting can often lead to camera shake, making photos and videos blurry. Canon's Optical Image Stabilizer is a sophisticated system that uses lens-shift technology to correct for unwanted camera movement. It makes handheld photography more practical in more shooting situations, providing excellent image quality in many difficult situations: outdoors at dusk, inside without a flash, and even at the telephoto end of the zoom range without a tripod. For still photos, it enables shooting at slower shutter speeds, accommodating more low-light shooting situations than ever before without having to boost ISO sensitivity. With camera shake and vibration reduced, you get a sharper, steadier image. And because it is an optical system, there is none of the image degradation typical with electronic image stabilizers.
The PowerShot G1 X Mark II is equipped with built-in Wi-Fi® technology for convenient sharing and transferring of your still images and video. Easily post your images to social networking and media sites – Facebook®, Twitter®, YouTube™, Flickr® and now Google Drive™ – through CANON iMAGE GATEWAY# directly from your PowerShot camera, or save them to the online photo album to share anytime, anywhere. The camera can also connect directly to both iOS® and Android™ devices*, and upload images via the free Canon CameraWindow app** without a computer. You can control the destination of your uploads to share with everyone or to selected groups, and even add comments. Sharing video is also easy with the PowerShot G1 X Mark II, which records video using the MP4 format with minimal file size. Enhanced Wi-Fi® makes posting in real time possible, so you can keep everyone up to date with amazing photos and video even as events unfold. The built-in Wi-Fi® technology on the PowerShot G1 X Mark II also allows you to transfer images to other Wi-Fi® equipped PowerShot cameras or print your photos directly to a PictBridge (Wireless LAN) certified printer.
One-touch connection to your mobile device or computer is also made possible on the PowerShot G1 X Mark II with the camera's dedicated Mobile Device Connect Button. You can choose to transfer images to your smartphone or tablet for immediate sharing with the CameraWindow app**, or to your computer on the same network with Image Sync to make saving and organizing your images easier. When the camera finds a linked computer on the same wireless network, images are sent directly to it. Otherwise, images are temporarily stored on CANON iMAGE GATEWAY# then transferred once a connection is made, eliminating the need for cables.
Remote Shooting
With the built-in Wi-Fi® on the PowerShot G1 X Mark II, you can use your smartphone or tablet* to remotely control the camera. Simply connect wirelessly to your device and access the free Canon CameraWindow app**. Your device will show a live image of the camera's capture for easy composition – perfect for wildlife and nighttime shots, group photos and all kinds of situations. The camera's versatile zoom, flash, self-timer and shutter are all under your control, with images being saved to your camera as usual.
The PowerShot G1 X Mark II camera supports NFC (Near Field Communication) technology, eliminating the need to find and open the Canon CameraWindow app** on your mobile device. Simply touch the NFC icon on your camera to your compatible Android device***, and the CameraWindow app will launch automatically for remote shooting and quick, easy sharing of your images. Built-in NFC technology also makes it simpler to install the app. If the app hasn't been installed yet, once you touch the devices together for the first time, the download screen will display automatically.
Preserving your important memories and creative film clips in stunning quality is easy with Full HD recording on the PowerShot G1 X Mark II camera and its dedicated movie button. With the camera's advanced DIGIC 6 Image Processor, the camera records Full HD video in MP4 that is breathtaking even when played back on a large-screen HDTV via the camera's HDMI output. Video is recorded at 30 frames per second* with stereo sound and because clips are recorded in MP4, you can fit more on a single memory card. The smaller file size also makes it easier to download to a computer and share with family and friends.
Additionally, the PowerShot G1 X Mark II also records video in the Apple iFrame® format, which is a computer-friendly standard that speeds up importing and editing of videos. It keeps file sizes small, making it more convenient to upload or e-mail high-quality videos. The iFrame format enjoys native support in compatible Mac and Windows video applications, making it unnecessary to perform time-consuming and often quality-degrading conversions.
* Actual frame rate is 29.97 fps.
The PowerShot G1 X Mark II features an entirely new 1.04 million pixel capacitive screen that can tilt up 180 degrees and down 45 degrees for flexible shooting in any number of situations and angles. Touch-sensitive, it delivers intuitive touch panel operation and review. Menu and quick control settings can be accessed, and focus point and shutter release can be activated with the touch of a fingertip using Touch AF. Displaying fine detail, it's the perfect screen for composing and reviewing images. The screen is designed so that reflections are minimized and colors are realistically reproduced, and the display can be viewed, without glare, from any number of angles. And because the aspect ratio of recording has been set to 3:2, the aspect ratio of the LCD monitor has also been set to 3:2.
The PowerShot G1 X Mark II camera's lens features two control rings on the lens barrel designed to enhance operability with quick, intuitive customizable functions. The inner ring is stepped and can be directed to set aperture value, shutter speed and exposure compensation. The outer, continuous ring has an easily recognizable different texture and makes fine tune adjustments simple, even enabling full-time manual focus that operates similarly to the focus rings found on typical SLR lenses. Working in tandem with the PowerShot G1 X Mark II camera's rear-mounted control dial, virtually every shooting function can be accessed and customized to any photographer's favorite specifications.
9-Blade Aperture
Thanks to the combination of its large sensor and large aperture lens, the PowerShot G1 X Mark II can easily be directed to capture images with great or very shallow depth-of-field. And thanks to the PowerShot G1 X Mark II's new 9-blade aperture diaphragm, blurred areas are particularly gorgeous, with subtle detail and blurred forms that appear almost completely circular.
Powered by the DIGIC 6 Image Processor, the PowerShot G1 X Mark II camera gives you a seamless, pro-like continuous shooting experience that's fully available in P, Tv, Av, M and Auto modes. Shooting and processing are now performed in tandem, eliminating buffering time to deliver high shooting speeds. With the significantly higher AF speed due to the newly improved Canon 1.5-inch CMOS sensor, streamlined processing also makes the camera's High Speed AF the fastest in Canon compact camera history, achieving focus nearly the instant the camera is aimed. With no separate mode setting and no reduction in image quality, you can freeze brilliant action shots with ease.
The PowerShot G1 X Mark II offers a host of shooting and recording modes ranging from fully automatic to fully manual, plus Full HD movies and full-resolution high speed continuous shooting. The camera recognizes 58 shooting situations, automatically optimizing settings for achieving the highest quality shots on the go. Alternatively, you can exert complete creative control over the look and feel of your images. 14-bit signal processing, just as in EOS-series cameras, gives images notably rich detail and smooth gradation, and RAW images are available in a choice of 3:2 or 4:3 aspect ratios. Compared with 12-bit processing, 14-bit offers a 4x increase in RAW data for a visible impact, giving images rich detail in both highlights and shadows as well as smoother, more natural tonal gradation for outstanding image quality.
Starry skies were formerly out of reach to all but experienced SLR camera users, but star shooting modes on the PowerShot G1 X Mark II camera make these wonderfully impressive images accessible to all. With just a tripod and simple settings, you can capture exquisite Star Nightscapes, Star Trails, Star Time-Lapse Movies and Star Portrait. The new Star Portrait mode, which consecutively takes two shots of the subject plus one of the night sky and then merges them into a single image, enables beautiful portraits with a starry background. The modes can be performed fully automatic or with manual controls for extra versatility. Support functions including Night Display, Color Adjustment and Star Emphasis make any starry sky easier to capture.
New for the PowerShot G1 X Mark II, the optional Electronic Viewfinder EVF-DC1 offers a high-resolution view and displays all shooting information in a brilliant and easily attached accessory. Mounted on the accessory shoe, the electronic viewfinder has a high eyepoint – perfect for those wearing glasses – and has a high precision XGA resolution LCD with 2.36 Million dots and displays the exact information found on the camera's LCD screen. It offers a dioptric adjustment range of -3.0 to +1.0 and can tilt up to 90°, helping to enable steady shooting even on an angle. The camera can be directed to switch automatically between the LCD and the viewfinder with an eyepiece sensor, or can be set manually with a dedicated button. Brightness can be set independently from the camera's screen, perfect for discreet operation.
The PowerShot G1 X Mark II is also compatible with an optional customizable grip*, perfect for photographers with particularly large or small hands.
* Custom Grip GR-DC1A will be available exclusively on the Canon Online Store.
With 31 easily selectable focus points arranged in an expanded, wide pattern across the image plane, the PowerShot G1 X Mark II focuses with admirable speed and precision. With smaller focus frame sizes, AiAF focus is more accurate, and with an expanded focus area, the camera has the ability to track focus, accurately and quickly, even when subjects are off center. The PowerShot G1 X Mark II also supports 1-point and Touch AF.
New Selectable Multiple Aspect Ratio
Whereas the original PowerShot G1 X was only able to record RAW images in the 4:3 aspect ratio, the PowerShot G1 X Mark II is equipped with a new Aspect Ratio Function that can switch between 3:2 and 4:3 aspect ratios. When shooting in ratios of 3:2 and 16:9, the PowerShot G1 X Mark II will record a RAW file in a 3:2 ratio, and when shooting in 4:3, 1:1 and 4:5, the camera will record a RAW in 4:3.
Intelligent IS
It's easy to capture clear, steady images with the PowerShot G1 X Mark II, even in low light without using a tripod. That's because the camera is equipped with Canon's innovative Intelligent IS. The system automatically analyzes camera movement and applies the best shake correction method for the shooting situation – allowing you to focus on framing and capturing your shot. For stills, the system selects from Normal IS, Panning IS, Macro (Hybrid) IS and Tripod modes. When shooting video, the system selects from Dynamic IS, Powered IS, Macro (Hybrid) IS and active Tripod IS modes. New icons clearly mark the image stabilization mode, whether you're shooting still images or video.
| Still Image Shooting | ||
Normal IS Corrects for a wide range of camera movement when shooting stills.
Panning IS Panning motion is detected so that IS does not interfere with desired camera movement.
Macro (Hybrid) IS Corrects for shift-type camera shake, which typically occurs in macro (close-up) shooting.
Tripod When tripod use is detected, the Image Stabilizer is stopped because it is not needed.
| Video Recording | ||
Dynamic IS Effective for video shooting at wide-angle focal lengths, eliminating the unwanted shaking that typically occurs while walking.
Powered IS Compensates for hand movement when shooting video at the telephoto end of the zoom range, where camera shake is magnified.
Macro (Hybrid) IS Corrects for motion blur that is likely to occur when shooting video while walking. Also compensates for the shift-type camera shake common in macro shooting.
Active Tripod IS When shooting video while using a tripod, the image stabilization is active to compensate for slight camera shake.
Compatible with Canon Speedlite flashes
The PowerShot G1 X Mark II digital camera gives you access to exciting EOS accessories including all of the Canon Speedlite flashes, long revered by professional photographers. The high output of Speedlite flashes brings out the depth and texture of your images in full, natural beauty. The ultra-lightweight Canon Speedlite 270EX II is a compact, high-performance flash unit that's fun and easy to use, with adjustable illumination angle and guide number; the versatile Speedlite 320EX features an LED light on the front of the flash body that can be used to illuminate nearby subjects in dim light, ideal for shooting video.
High Dynamic Range scene mode
Shooting in high contrast environments can often result in photos with overexposed and underexposed sections. In order to tackle this problem, Canon developed the High Dynamic Range shooting mode to make shooting even more intuitive. Under High Dynamic Range the camera will shoot three different exposures in succession (underexposed, overexposed and normal) and then merge them into a single image. Underexposed areas are combined with the overexposed and vice versa, resulting in an evenly detailed image with flattering shadows and highlights. The PowerShot G1 X Mark II allows you to use this mode without a tripod and features four sub-modes in addition to Natural – Art Standard, Art Vivid, Art Bold and Art Embossed – which provide striking effects that add to the creativity of your compositions.
** With the download of the free Canon CameraWindow app. This software enables you to upload images to social network services. Before uploading images, please be aware that image files may contain privacy related information such as people and places. If necessary, please delete such information. Canon does not obtain, collect or use such images or any information included in such images through this software.
*** Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
**** The PowerShot G1 X Mark II can continuously shoot until the memory card is full when using an SDHC/SDXC UHS-I card based on Canon's standard test method.
# One-time registration is required on CANON iMAGE GATEWAY online photo album.
| Type Of Camera | Compact Digital Still Camera With Built-In Flash, 5x Optical, 4x Digital, And 20x Combined Zoom With Optical Image Stabilizer | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 12.8 Megapixels, 1.5-Inch CMOS | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 15.0 Megapixels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 12.8 Megapixels (3:2); Approx. 13.1 Megapixels (4:3) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focal Length | 12.5mm (W) - 62.5mm (T) (35mm Film Equivalent: 24-120mm) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Zoom | 5x | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | 4x | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Normal/Auto: 2.0 In. (5 Cm) - Infinity (W), 1.3 Ft. (40 Cm) - Infinity (T); Macro/Underwater Macro: 2.0 In. - 1.6 Ft. (5-50 Cm) (W); Quick: 4.9-66.0 Ft. (1.5-20 M) (W, T) |
| Autofocus | TTL Autofocus (Full-Time Manual Focus Available) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Optional Electronic Viewfinder EVF-DC1 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch Tilt, Capacitive Touch Panel LCD (3:2) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 1,040,000 Dots | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/2.0 (W), F/3.9 (T) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1 - 1/4000 Sec. 15 - 1/4000 Sec. (In Tv Mode) 60 - 1/4000 Sec. (In M Mode)
| Sensitivity | Auto*, ISO 100/125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/ 4000/5000/6400/8000/10000/12800 (When In P Mode) *Optimal ISO Speed Is Automatically Set Depending On The Shooting Mode. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Light Metering Method | Evaluative*1, Center-Weighted Average, Spot*2 *1 Facial Brightness Is Evaluated (Face Detect AE) In Face Detect. *2 Fixed To Center, Linked To AF Frame |
| Exposure Control Method | AE Lock | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | ±3 Stops In 1/3-Stop Increments | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| White Balance Control | Auto*, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom 1, Custom 2, Multi-Area White Balance * Facial Color Is Evaluated In Face Detect (Face Detect WB).
| Built In Flash | Auto, On, Slow Synchro, Off
| Flash Range | 1.6 - 22 Ft. (W), 4.6 - 11 Ft. (T) / (50cm - 6.8m (W), 1.4 - 3.5m (T))
| Recycling Time | 10 Seconds Or Less (Battery Voltage: 3.7 V) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | ±2 Stops In 1/3 Increments | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | C1, C2, M, Av, Tv, P, Auto, Hybrid Auto, Creative Shot*1, SCN*2, Creative Filters*3, Movie*4
| Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* * Adjustment Of Contrast, Sharpness, Saturation, Red, Green, Blue And Skin Tone Are Available.
| Self Timer | Approx. 10-Sec. Delay, Approx. 2-Sec. Delay, Custom | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Wireless Control | Not Available | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | Normal: Approx. 5.2 Shots/Sec. (In P Mode) AF: Approx. 3.0 Shots/Sec. (In P Mode) LV: Approx. 3.1 Shots/Sec. (In P Mode)
| Storage Media | SD/SDHC/SDXC/UHS-I Memory Cards | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System, DPOF (Version 1.1) Compliant | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | JPEG (Superfine, Fine), RAW | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif 2.3 JPEG, RAW (14 Bit, CR2 (Canon Original)) Video: MP4 (Image Data: MPEG-4 AVC/H.264; Audio Data: MPEG-4 AAC-LC (Stereo)) |
| Number Of Recording Pixels | Still Images (JPEG, RAW): 1) 16:9 - Large: 4352 X 2448; Medium 1: 3072 X 1728; Medium 2: 1920 X 1080; Small: 640 X 360 2) 3:2 - Large: 4352 X 2904; Medium 1: 3072 X 2048; Medium 2: 2048 X 1368; Small: 640 X 424 3) 4:3 - Large: 4160 X 3120; Medium 1: 3072 X 2304; Medium 2: 2048 X 1536; Small: 640 X 480 4) 1:1 - Large: 3120 X 3120; Medium 1: 2304 X 2304; Medium 2: 1536 X 1536; Small: 480 X 480 5) 4:5 - Large: 2496 X 3120; Medium 1: 1840 X 2304; Medium 2: 1232 X 1536; Small: 384 X 480 Videos: Full HD 1920 X 1080: 30 Fps (29.97) Full HD, Star Time-Lapse Movie 1920 X 1080: 15 Fps (14.985), 30 Fps (29.97) IFrame Movie 1920 X 1080: 30 Fps (29.97) HD 1280 X 720: 30 Fps (29.97) Digest Movie 1280 X 720: 30 Fps (29.97) Miniature Effect 1280 X 720*1: 6 Fps, 3 Fps, 1.5 Fps Miniature Effect 640 X 480*1: 6 Fps, 3 Fps, 1.5 Fps 640 X 480: 30 Fps (29.97) *1 Playback: 30 Fps (29.97) |
| Content |
Note: SF=Superfine / F=Fine • The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Content |
*1 Playback Frame Rate Is 30 Fps*2. |
| Playback Modes File | Still Images & Videos: Auto Rotate, Transition Effects (Off, Fade), Scroll Display, Rotate, Favorites, Search Jump*1 (Favorites, Date, Still Images, Movies, Digest, Jump 10 Images, Jump 100 Images), Smart Shuffle, Group Playback, Movie Digest, Filtered Playback, Slideshow *1 Can Also Be Controlled With Front Dial Still Images: Single, Index, Magnification (Approx. 2x-10x), Thumbnails, Information Display, Histogram, Overexposure Warning, Resume Playback, Red-Eye Correction, Cropping, I-Contrast, Resize, My Colors, Videos: Normal Playback, Skip Backward, Previous Frame, Next Frame, Skip Forward, Resume Playback, Erase Clip, Edit Digest Movie |
| Erase Modes | Select*1, Select Range, Select All Images
| Video Out | Analog: NTSC Or PAL, Digital: HDMI (HDMI™ Micro Connector) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Stereo | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | SD Memory Card Slot; Direct Connection To Canon SELPHY, PIXMA And PictBridge-Compatible Printers | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Source | Battery Pack NB-12L, AC Adapter Kit ACK-DC100 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Capacity Bp 511 | Approx. 240 Shots Approx. 200 Shots With Optional Electronic Viewfinder EVF-DC1 Approx. 300 Shots In ECO Mode |
| Playback Time Bp 511 512 | Approx. 5 Hours | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32-104°F/0-40°C | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10-90% | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.58 X 2.91 X 2.61 In. / 116.3 X 74.0 X 66.2mm | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | Approx. 19.5 Oz. / 553g (CIPA Standard) Approx. 18.2 Oz. / 516g (Body Only) |
Lens Hood LH-DC80
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
Filter Adapter FA-DC58E
This adapter is required for use of the 58mm lens filters.
Video Cable AVC-DC400ST
Enables direct image display from the EOS to an HD television or a similar display device.
Interface Cable IFC-400PCU
The Canon IFC-400PCU USB Interface Cable enables you to transfer your camera pictures to a computer fast. The cable connects to your camera and to the USB port on your PC or MAC Computer.
Deluxe Soft Case PSC-6100
This specially designed soft carrying case provides stylish protection to your PowerShot camera while on the go, or for storage.
Waterproof Case WP-DC53
Take great underwater shots and be worry-free during inclement weather with the WP-DC44. Waterproof to 130ft. Neck strap and silicone grease included.
Battery Charger for NB-12L Li-Ion Batteries.
Custom Grip GR-DC1A
Optional Custom Grip provides better grasp, similar to grips found on DSLR cameras.
Battery Pack NB-12L
Battery Pack for selected N-series models.
This optional electronic viewfinder, with a high precision resolution LCD, attaches to the accessory shoe.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
