PowerShot ELPH 360 HS
- PowerShot ELPH 360 HS
- Battery Pack NB-11LH
- Battery Charger CB-2LF
- Wrist Strap WS-800
- (USB Interface Cable and Digital Camera Solution CD-ROM are not included)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
For the photo novice looking to save the magic moments that happen in everyday life, the stylish PowerShot ELPH 360 HS camera is slim enough to have with you when and where you need it. The 12x Optical Zoom can help capture a close-up of a child's face on stage, or a wide image of the whole play and audience. Share those memories with friends and family easily thanks to built-in Wi-Fi®* and NFC** capability. The 20.2 Megapixel*** CMOS sensor and DIGIC 4+ Image Processor help deliver detailed images, while Intelligent IS and Optical Image Stabilizer help the images remain sharp with minimal blur. Record unforgettable movies at 1080p Full HD resolution, and see the whole image on a clear 3.0-inch LCD screen to help ensure you have the picture you want. Hybrid Auto mode captures a short video of the seconds before you capture your image. The newly added Story Highlights mode combines your images and video, then adds appropriate effects to create a short movie of the best parts of your day.
The PowerShot ELPH 360 HS camera features a 12x Optical Zoom so spectacular shots are within your reach. You'll love the flexibility it gives you when shooting with an amazing range of 25300mm (35mm equivalent) in a slim, compact camera. Plus, the wide-angle lens captures an expansive image in each shot, adding depth, perspective and grandeur. Landscapes, city scenes, family shots and more all benefit from the extra width. Whether you're shooting wide group shots or zooming to the telephoto end, your images can be bright and clear.
Intelligent IS
It's easy to capture clear, steady images with select PowerShot cameras, even in low light without using a tripod. That's because these cameras are equipped with Canon's innovative Intelligent IS. The system automatically analyzes camera movement and applies the ideal shake correction method for the shooting situation allowing you to focus on framing and capturing your shot. For stills, the system selects from Normal IS, Panning IS, Macro (Hybrid) IS and Tripod modes. When shooting video, the system selects from Dynamic IS, Powered IS, Macro (Hybrid) IS and Active Tripod IS modes. Icons clearly mark the image stabilization mode, whether you're shooting still images or video.
Built-in Wi-Fi® technology helps provide on-the-go convenience when you want to share your photos and videos with friends and family. Easily post your images to social networking and media sites Facebook®, Twitter®, YouTube™, Flickr®, and Google Drive™ through CANON iMAGE GATEWAY* directly from your PowerShot ELPH 360 HS camera, or save them to the online photo album to share anytime, anywhere. The camera can also connect directly to both compatible iOS®** and Android™ devices***, and upload images via the free Canon Camera Connect app** without a computer. You can control the destination of your uploads to share with everyone or to select groups, and even add comments. Wi-Fi® capability makes posting in real time possible, so you can keep everyone up to date with photos and video even as events unfold. Wi-Fi® technology also allows you to transfer images to other Wi-Fi® equipped PowerShot cameras or print your photos directly to a PictBridge (Wireless LAN) certified printer. Thanks to the newly added Wi-Fi Button, you can now connect in both Shooting mode and Playback mode for quick and easy operation. You can even turn on the camera and connect at the same time with just one press of the button, helping you get right to sharing and managing your files when you like.
Built-in NFC (Near Field Communication) Technology for Easy Wireless Connectivity
The PowerShot ELPH 360 HS camera supports NFC (Near Field Communication) technology for fast connectivity with a single tap. Simply touch the NFC icon on your camera to your compatible Android™ device***, and the Canon Camera Connect app** will launch automatically for quick, easy sharing of your images. Built-in NFC technology also makes it simple to install the app. If the app hasn't been installed yet, once you touch the devices together for the first time, the download screen will display automatically.
Image Sync Function
The Image Sync Function allows you to wirelessly transfer photos and videos from the camera to a computer by using CANON iMAGE GATEWAY*. Through CANON iMAGE GATEWAY you can then access your photos and videos through a browser on your compatible smartphone**** to view and download.
Remote Shooting with the Camera Connect App
With the built-in Wi-Fi® on the PowerShot ELPH 360 HS camera, you can use your compatible smartphone or tablet** to remotely control the camera. Simply connect wirelessly to your device and access the free Canon Camera Connect app**. Your device will show a live image of the camera's capture ideal for a commemorative group photo, wildlife shots and all kinds of situations. The camera's versatile 12x Optical Zoom, flash, self-timer and shutter are all under your control, with images being saved to your camera as usual.
* One-time registration is required on CANON iMAGE GATEWAY online photo album.
** Compatible with iOS versions 8.4/9.3/10.2, Android smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with Android smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
**** With the download of the free Canon Online Photo Album app. The images and videos utilizing Image Sync can be viewed and downloaded with your smartphone or tablet within 30 days.
The PowerShot ELPH 360 HS camera employs a 20.2 Megapixel* High-Sensitivity CMOS sensor, which helps to deliver outstanding imaging performance and is optimized for use in compact cameras. Utilizing a sophisticated light-capturing design, it provides high sensitivity for improved high ISO capture with reduced noise. It is also designed to capture photos quickly and is capable of rapidly capturing and moving image data to the processor, enabling fast continuous shooting and autofocus.
* Image processing may cause a decrease in the number of pixels.
The Canon DIGIC 4+ Image Processor powers the PowerShot ELPH 360 HS camera's functions and capabilities, including Hybrid Auto, Creative Shot and Full HD video shooting. Its processing speed creates fast, responsive performance for a shooting experience that's easy and natural. The DIGIC 4+ Image Processor also enhances image quality in several ways. Processing of high ISO shots has been shortened by up to 60% compared to the DIGIC 4 Image Processor. This helps significantly reduce noise for brilliant color, smooth gradations and beautiful detail even in low light. The processor also allows for the integration of electronic Dynamic IS. This advanced system can compensate for multiple motion types, effectively preventing angular blur, shift blur and blur caused by parallel movement and tilt shift. The results are clear and sharp.
Canon HS SYSTEM Helps Provide Excellent Low-light Performance
The slim, compact PowerShot ELPH 360 HS camera gives you the power to capture beautifully detailed, naturally lit images even in low light helping to reduce the need for flash and the occasionally unwelcome effects it produces. That's because the camera's 20.2 Megapixel* High-Sensitivity CMOS sensor works with the DIGIC 4+ Image Processor to create the Canon HS SYSTEM, specifically engineered for spectacular low-light performance. With the Canon HS SYSTEM, you'll experience excellent tracking performance even in low light, and achieve gorgeous still image quality at ISO speeds up to ISO 3200; beautiful low-light shots are possible with minimal noise and maximum detail in highlight and shadow areas.
Gorgeous high-definition video is yours throughout the camera's impressive zoom range, and starts immediately with a touch of the dedicated movie button. The PowerShot ELPH 360 HS camera captures Full HD video, for notably smooth, lifelike quality that is truly at home even on a large-screen HDTV. And now you can record in convenient MP4 format for easy online sharing.
The large, 3.0-inch high-resolution LCD screen makes it easy to both frame and review your shots. A resolution of approximately 461,000 dots helps makes small details clear, and images are viewable even from a wide angle so showing others what you've captured is easy, too.
The PowerShot ELPH 360 HS camera features Hybrid Auto, which records up to four seconds of video every time you shoot a still image, then automatically joins the clips and pictures* into a video that captures the essence of special days: vacations, important occasions or any time you're shooting many shots in a day. With Hybrid Auto, this “highlight reel” can be stunningly beautiful. Hybrid Auto automatically recognizes the scene and optimizes camera settings to help capture incredibly high image quality. The resulting 1080p Full HD video is properly exposed, crisp and steady.
* Pictures can be withheld from the resulting video via menu settings.
Not only is the PowerShot ELPH 360 HS camera a stylish powerhouse, the camera also enables you to easily create artistic images with Creative Shot mode. In Creative Shot mode, the camera captures the original composition, automatically produces and saves five additional copies of the image and uses advanced Canon technologies to apply any of 46 filter options based on the individual scene, subject and exposure. Filter choices are grouped into Retro, Monochrome, Special and Natural categories to make exploring the world of artistic photography fun and easy, or you can simply select Auto to access the full range of effects. With Creative Shot mode, the result can lead to stunning artistic photos that are ideal for sharing.
View your still images and video* as a fun short story with the Story Highlights feature on the PowerShot ELPH 360 HS camera. You can choose to have the camera make one automatically, creating a short video of approximately three minutes** according to date, event or people, or you can customize your Story Highlights reel for a fun, unique video. Story Highlights BGM lets you add background music (choose from three pre-loaded songs) to the clips that Story Highlights automatically generates for a new level of emotive expression. It's all done in camera, without the need for any additional software. Easily access and enjoy your Story Highlights simply press the Story Highlights button to start creating your highlight album. The Story Highlights album can be saved to the camera's memory card for quick replay and also shared with the PowerShot ELPH 360 HS camera's built-in Wi-Fi®.
* Videos must be shot in Hybrid Auto or Short Clip.
** Length of highlight video varies according to the photos and videos added to the Story Highlights album.
** Compatible with Android smartphone and tablet versions 4.0/4.1/4.2/4.3/4.4/5.0/5.1.
*** Image processing may cause a decrease in the number of pixels.
| Type Of Camera | Compact Digital Still Camera With Built-In Flash, 12x Optical, 4x Digital And 48x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 20.2 Megapixel, 1/2.3-Inch CMOS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 21.1 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 20.2 Megapixels* * Image Processing May Cause A Decrease In The Number Of Pixels. |
| Focal Length | 4.5 (W) - 54.0 (T) Mm (35mm Film Equivalent: 25-300mm) Optical Zoom 12x |
| Digital Zoom | 4x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Normal: 2.0 In. (5.0cm) - Infinity (W), 3.3 Ft. (1.0m) - Infinity (T) Auto: 0.4 In. (1.0cm) - Infinity (W), 3.3 Ft. (1.0m) - Infinity (T) Macro: 0.4 In. - 1.6 Ft. (1-50cm) (W) Infinity: 9.8 Ft. (3.0m) - Infinity (W), 9.8 Ft. (3.0m) - Infinity (T) |
| Autofocus | TTL Autofocus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch TFT Color LCD With Wide Viewing Angle (4:3) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 461,000 Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/3.6 (W), F/7.0 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1-1/2000 Sec. 15-1 Sec. (In Long Shutter Mode) |
| Sensitivity | Auto, ISO 80-3200 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Light Metering Method | Evaluative, Center Weighted Average, Spot | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| White Balance Control | Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Built In Flash | Auto, On, Slow Synchro, Off | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Range | 1.6-13.0 Ft. (W), 3.3-6.6 Ft. (T) 50.0cm - 4.0m (W), 1.0-2.0m (T) |
| Shooting Modes | P, Hybrid Auto, Auto, Creative Shot, Portrait, Smile, Wink Self-Timer, Face Self-Timer, High-Speed Burst, Handheld Night Scene, Low Light, Fish-Eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Fireworks, Long Shutter | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | Off / 2 Sec. / 10 Sec. / Custom | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Wireless Control | Built-In Wi-Fi® And NFC | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | Normal Continuous Shooting In Auto/P Modes: Approx. 2.5 Shots/Sec. Normal Continuous High-Speed Burst Mode: Approx. 7.2 Shots/Sec.
| Storage Media | SD/SDHC/SDXC Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System (DCF) Compliant; DPOF (Version 1.1) Compatible | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif. 2.3 (JPEG) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Monaural)) |
| Number Of Recording Pixels | Still Images: 1) 16:9 - Large: 5184 X 2912; Medium 1: 3648 X 2048; Medium 2: 1920 X 1080; Small: 640 X 360 2) 3:2 - Large: 5184 X 3456; Medium 1: 3648 X 2432; Medium 2: 2048 X 1368; Small: 640 X 424 3) 4:3 - Large: 5184 X 3888; Medium 1: 3648 X 2736; Medium 2: 2048 X 1536; Medium: 2592 X 1944; Small: 640 X 480 4) 1:1 - Large: 3888 X 3888; Medium 1: 2736 X 2736; Medium 2: 1536 X 1536; Small: 480 X 480 Videos: Full HD 1920 X 1280: 29.97 Fps HD 1280 X 720: 29.97 Fps 640 X 480: 29.97 Fps |
| Content | Approx. Number Of Shots Recordable To 16 GB Memory Card
Note: SF=Superfine, F=Fine |
| Content | Total Movie Time Recordable To Memory Card
*1 Using An SD Speed Class 10 / UHS-I Compatible Memory Card. |
| Playback Modes File | List/Play Digest Movies, Favorites, Erase, Slideshow, Rotate, Album Playback, I-Contrast, Resize, Cropping, Red-Eye Correction, My Colors, Photobook Set-Up, Scroll Display, Group Images, Auto Rotate, Resume, Transition Effect | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Video Out | NTSC/PAL | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Monaural | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | Hi-Speed USB (Mini-B), HDMI (Type D); Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Source | Battery Pack NB-11LH | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Capacity Bp 511 | Approx. 180 Shots Approx. 265 Shots In ECO Mode Video Recording Time: Approx. 40 Min. |
| Playback Time Bp 511 512 | Approx. 4 Hr. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 32-104°F / 0-40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10-90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 3.92 X 2.28 X 0.90 In. / 99.6 X 58.0 X 22.8mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | 5.19 Oz. / 147g (CIPA Standard) 4.59 Oz. / 130g (Body Only) |
High-Power Flash HF-DC2
Powerful slave flash, fired by the camera's pre-flash. Effectively doubles the flash range of the camera. Comes with mounting bracket.
AV Cable AVC-DC400
The AVC-DC400 Video Interface Cable is used to connect your Canon PowerShot SD Series Digital Camera to most televisions via the RCA type video-in terminals. It allows viewing of recorded images from the Canon Powershot Digital Cameras.
Deluxe Case PSC-3200
Protect your digital camera from scratches, dust and dirt with this deluxe, cowhide leather case.
Battery Pack NB-11L
Lithium-Ion rechargeable battery ( mAh).
Battery Pack for selected ELPH and SX-series models.
Adapter ACK-DC90
Adapter kit for the NB-11L.
Charger for the NB-11L batteries. Compact and lightweight, the CB-2LF plugs directly into an AC outlet.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
