PowerShot ELPH 320 HS Black
- PowerShot ELPH 320 HS (blue shown here)
- Battery Pack NB-11L
- Battery Charger CB-2LD
- Wrist Strap WS-DC10
- USB Interface Cable IFC-400PCU
- Digital Camera Solution CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Super Smart, Elegantly Thin.
The PowerShot ELPH 530 HS is equipped with built-in Wi-Fi® for on-the-go convenience when you want to share with friends, family and the whole world. The camera makes it easy to connect directly to both iOS and Android devices*. Even without a mobile device, you can send images to a PC, share images between Wi-Fi® enabled PowerShot cameras and you can even print in a snap by sending your images wirelessly to a Wi-Fi® compatible printer^.
* Compatible with iOS version 4.3 or later and Android devices version 1.1.1.11 or later. Data charges may apply.
** This software enables you to upload images to social network services. Before uploading images, please be aware that image files may contain privacy related information such as people and places. If necessary, please delete such information. Canon does not obtain, collect or use such images or any information included in such images through this software.
^ DPS over IP certified printer is required.
The Canon HS SYSTEM lets you take bright, clear photos in an even wider range of shooting situations. Beautiful low-light shots are possible with minimal noise and maximum detail in highlight and shadow areas. The system is the result of two technologies brought together in PowerShot cameras: a high-sensitivity imaging sensor, which is able to capture more light; and the DIGIC Image Processor, which actively reduces noise with high-speed image processing. The 16.1 Megapixel Canon CMOS sensor in the PowerShot ELPH 320 HS incorporates advanced light reception technology that enhances sensitivity. The new DIGIC 5 Image Processor provides a major boost in noise reduction, expanding the usable ISO range to an amazing high of ISO 3200. The Canon HS SYSTEM thus lets you use higher shutter speeds to capture clearer images with reduced noise and blur.
Canon DIGIC 5 Image Processor
The latest-generation Canon DIGIC 5 Image Processor brings phenomenal increases in processing speed and power. Improved chip architecture and algorithms deliver greatly expanded functionality with further refinement in image quality. Improved noise reduction produces clearer images when shooting in low light at high ISO speeds. Enhanced i-Contrast performance adjusts differences between light and dark areas to achieve even more natural-looking results. The faster processing speed also results in faster continuous shooting capability while maintaining full image quality. The DIGIC 5 Image Processor also makes possible a new, highly advanced automatic white balance system. Whereas conventional white balance makes an overall adjustment based on a single type of light source, the new Canon Multi-Area White Balance analyzes several areas of the image to determine whether different adjustments are needed, for example, for the main subject and the background.
In addition to the Canon HS SYSTEM, the combination of the advanced CMOS sensor and DIGIC 5 Image Processor in the PowerShot ELPH 320 HS makes it possible to shoot crisp, clear high definition video. Imagine the fun and excitement of being able to shoot spectacular 1080p Full HD video with stereo sound that you can later watch on your HDTV or download to your computer to share with family and friends. In addition to being able to shoot Full HD 1080p video at 24* frames per second, the PowerShot ELPH 320 HS can also shoot 720p HD video at 30** frames per second.
*Actual frame rate is 23.976 fps.
**Actual frame rate is 29.97 fps.
Dedicated Movie Button, Wind filter feature and Optical Zoom for easy video capture
It’s never been easier to shoot videos with a PowerShot digital camera. The PowerShot ELPH 320 HS has a dedicated movie button that lets you start and stop recording instantly. There is no need to go through layers of menus or operate switches or dials to switch to and from video recording mode. The camera is always ready to shoot stills or video whenever you want. The PowerShot ELPH 320 HS also incorporates an electronic wind filter, which suppresses wind noise that can muffle or distort the sound. And unlike less sophisticated point-and-shoot cameras, the PowerShot ELPH 320 HS lets you use the full range of optical zoom when you're shooting a video.
HDTV playback via HDMI output and CEC
It’s easy to enjoy and share the videos you shoot with the PowerShot ELPH 320 HS. Simply connect its HDMI terminal to your HDTV using an HDMI cable. And because the PowerShot ELPH 320 HS supports HDMI-CEC technology, you’ll be able to control the playback of your images and videos on any CEC-enabled HDTV using the TV’s remote control. (CEC – Consumer Electronic Control – is part of the HDMI specification, enabling components in a system to communicate with one another.)
iFrame
With the PowerShot ELPH 320 HS, you can also shoot video in the Apple® iFrame format, which is a computer-friendly standard that speeds up importing and editing of videos. It keeps file sizes small, making it more convenient to upload or e-mail high-quality videos. The iFrame format enjoys native support in compatible Mac and Windows video applications, making it unnecessary to perform time-consuming and often quality-degrading conversions.
At 0.82 inches, the PowerShot ELPH 320 HS is an incredibly slim camera with a 24mm Wide-Angle lens, 5x Optical Zoom, and Optical Image Stabilizer. Its stylish form is enhanced by its lustrous finish, which gives you a choice of four refined colors: Blue, Red, Silver and Black. But real beauty goes beyond skin deep with the PowerShot ELPH 320 HS digital camera. Amazingly, Canon did not sacrifice performance for style.
5x Optical Zoom with 24mm Wide-Angle Lens
The PowerShot ELPH 320 HS features a powerful Genuine Canon 5x Zoom Lens that delivers outstanding optical performance and versatility. Fitting such a high-performance lens with such wide zoom range into a camera so thin would normally be considered an impossible feat. Canon’s expert optical engineering met the challenge by developing a light-folding retractable-prism lens barrel, which achieves outstanding compactness with high zoom power and superb performance. The zoom starts at 24mm wide-angle and extends to 120mm telephoto (35mm equivalent), covering an exceptionally wide range. The telephoto reach gives you the freedom to capture subjects from a considerable distance, while the 24mm wide-angle makes it easy to shoot sweeping landscapes, large groups of people and tall buildings.
Handheld shooting can often lead to camera shake, making photos and videos blurry. Canon’s Optical Image Stabilizer is a sophisticated system that uses lens-shift technology to correct for unwanted camera movement. It makes handheld photography more practical, providing excellent image quality in many difficult shooting situations: outdoors at dusk, inside without a flash, and even at the telephoto end of the zoom range without a tripod. For photos, it enables shooting at slower shutter speeds, accommodating more low-light shooting situations than ever before without having to boost ISO sensitivity. With camera shake and vibration reduced, you get a sharper, steadier image. And because it is an optical system, there is none of the image degradation typical with electronic image stabilizers.
The PowerShot ELPH 320 HS digital camera’s large and bright 3.2-inch PureColor LCD wide screen makes it easy to view and frame your shots in high resolution (461,000 dots). PureColor technology delivers excellent contrast with rich, true-to-life color. Many LCD screens on the market today use a striped arrangement of dots that works great for text and menus, but is not ideal for imagery. The PowerShot ELPH 320 HS’s PureColor System LCD uses a delta arrangement of dots, which works better for the organic nature of photos and videos, allowing you to review your images with exceptional clarity with rich, true-to-life color. Moreover, you can view the LCD screen over a surprisingly wide angle – above, below or to either side – without color shifts and with minimal reflections. A scratchproof hard coating and a dust-repellent fluorine coating ensure a durable screen that dependably displays clear, vibrant images. The wide aspect ratio (16:9) provides ample room for information icons and touch buttons, preventing them from getting in the way of the image, and you can enjoy a brilliant full-screen image when shooting or playing back your Full HD videos.
Touch Panel LCD with Touch Shutter
The PowerShot ELPH 320 HS features touch panel technology that makes using the camera more intuitive and fun. Simply touch the screen to choose and track an AF point, change camera settings, record and play videos and much, much more! It also has an innovative Touch Shutter function that allows you to release the shutter right from the screen. Just touch the desired subject with your finger. An AF box will appear and track the subject as it moves. Then just lift your finger to release the shutter. It’s that simple.
Smart AUTO for the PowerShot ELPH 320 HS has been significantly expanded, making it easier than ever to capture the sharp, bright, colorful images – and videos – you’re looking for. By assessing various factors in both the background and the subject, the system recognizes 58 predefined shooting situations and automatically selects the camera settings that will yield the best possible results. Simply frame the shot you want, and in dozens of common or challenging scenarios the camera takes care of the rest. Hardtocapture shots such as moving subjects, night scenes, backlit subjects, and landscapes at evening or on a bright snowy day are instantly and effortlessly captured as "keeper" shots. Smart AUTO makes the PowerShot ELPH 320 HS ideal for capturing excellent quality still images and video on the go.
Shooting Modes/Special Scene Modes
Smart AUTO The camera automatically selects the best shooting settings for optimal quality based on subjects and environmental factors to provide pointandshoot simplicity.
Program The camera automatically and intelligently selects the aperture/shutter speed combination based on the shooting conditions.
Movie Digest in 720p HD Records a video clip in 720p HD before capturing a still image and then combines one day’s worth of clips into a video.
Portrait Brings the subject into focus while beautifully blurring the background.
Smooth Skin Removes dullness, wrinkles, and harsh shadows for beautiful faces.
Smart Shutter The camera automatically takes the photo when people smile, wink, or get into frame.
HighSpeed Burst Captures rapid action frame by frame, by shooting continuously at a high speed while the shutter button is held down.
Handheld Night Scene Take clear and steady pictures at night without the use of a tripod.
Low Light For high quality image capture in an amazing range of dimly lit situations.
Fisheye Effect Now you can get the fisheye effect — a classic photographic distortion — without a fisheye lens.
Miniature Effect for Stills & Video Give images and video a miniature look with an effect that emphasizes perspective by blurring the top and bottom of the image.
Toy Camera Effect Simulates photos taken with “toy” or pinhole cameras, darkening the image at the edges to create a vignette effect.
Soft Focus Creates a hazy ambiance that’s perfect for portraits and wedding photos.
Monochrome Choose from three singletone effects: BlackandWhite, Sepia, or Blue.
Super Vivid Super Vivid intensifies existing hues, saturating the scene with bright colors.
Poster Effect Poster Effect combines several similar shades into one color, turning subtle gradations into eyecatching, scenepopping contrasts.
Color Accent Choose to retain a single color in your image while other colors turn monochrome.
Color Swap Select a color and replace it with a color you specify for special effects.
Snow Shoot clear snow scenes without darkened subjects or an unnatural bluish tint.
Long Shutter Use to blur moving subjects for artistic effect, ideal for urban night photography.
iFrame Movie The Apple® movie format, iFrame, makes it easier and quicker to import and upload videos while retaining high image quality.
Super Slow Motion Movie Record your clips in high speed (approx. 240 fps), and then watch your videos in slow motion.
Face ID
Face ID is one of the most advanced and exciting new features of the PowerShot ELPH 320 HS, giving you an easy way to improve every shot of the people you love. Simply take a picture of up to 12 faces you would like the camera to register, then enter names and ages. Once a person is registered, the camera will pick him or her out of a group (even against a busy background) and adjust focus and exposure to his or her face, even recognizing faces in profile. Face ID is particularly great for shots of babies and children. The system can pick your baby out of a group of children, focus on your baby when pictured with an adult, and capture her best smile by taking three successive images when the smile is detected. The flash is even disabled so as not to startle the baby and interrupt the moment. Older children in motion are tracked, with focus and exposure continually adjusted with Servo AF; with one shutter press three successive images are captured so the best shot is never missed. And because you’ll identify each face you register, Face ID makes it easy to search images by name.
The latest advance in Canon Optical Image Stabilization technology, Intelligent IS analyzes camera movement and applies the best shake correction method for the shooting situation. For stills, the system automatically selects among Normal, Panning, Macro (Hybrid) and Tripod IS modes. When shooting video, the system automatically selects among Dynamic, Powered, Macro and Tripod IS modes. With Intelligent IS, you can concentrate on image capture, letting the camera make the most effective IS settings to assure the steadiest possible image.
Normal Corrects for a wide range of camera movement when shooting stills.
Panning Panning motion is detected so that IS does not interfere with desired camera movement.
Macro (Hybrid) Corrects for shifttype camera shake, which typically occurs in macro (closeup) shooting.
Dynamic Effective for video shooting at wideangle focal lengths, eliminating the unwanted shaking that typically occurs while walking.
Powered Compensates for hand movement when shooting video at the telephoto end of the zoom range, where camera shake is magnified.
Tripod When tripod use is detected, the Image Stabilizer is stopped because it is not needed.
The camera’s silky-smooth coating provides a luxurious feel and radiates a deep, subtle sheen. And the fact that PowerShot ELPH 320 HS is packed with serious specs and technological advancements doesn’t mean you’re limited to basic black: your color choice is as individual as the images you’ll create. Choose from black, silver, blue, and red.
Type Of Camera | Compact Digital Still Camera With Built-In Flash, 5x Optical, 4x Digital And 20x Combined Zoom With Optical Image Stabilizer |
Type | 16.1 Megapixel, 1/2.3-Inch CMOS |
Total Pixels | Approx. 16.8 Megapixels |
Effective Pixels | Approx. 16.1 Megapixels |
Focal Length | 4.3 (W) - 21.5mm (T) (35mm Film Equivalent: 24 - 120mm) |
Digital Zoom | Approx. 4x |
Focusing Range | Normal: 2.0 In. (5cm) - Infinity (W), 3.0 Ft. (90cm) - Infinity (T) Auto: 1.2 In. (3cm) - Infinity (W), 3.0 Ft. (90cm) - Infinity (T) Macro: 1.2 In. - 1.6 Ft. (3-50cm) (W) |
Autofocus | TTL Autofocus |
Optical Viewfinder | N/A |
Lcd Monitor | 3.2-Inch TFT Touch Panel Color LCD With Wide Viewing Angle |
Lcd Pixels | Approx. 461,000 Dots |
Lcd Coverage | Approx. 100% |
Maximum Aperture | F/2.7 (W) - F/5.9 (T) |
Shutter Speed | 1-1/2000 Sec. 15-1/2000 Sec. (Total Shutter Speed Range) |
Sensitivity | Auto*, ISO 100/200/400/800/1600/3200 (In P Mode) *Camera Automatically Sets The Optimal ISO Speed According To Shooting Mode |
Light Metering Method | Evaluative*, Center Weighted Average, Spot** * Facial Brightness Is Evaluated In Face AiAF. ** Fixed To Center. |
Exposure Control Method | AE Lock |
Exposure Compensation | +/-2 Stops In 1/3-Stop Increments (Not Available When Shooting Movies) |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Facial Color Is Evaluated In Face AiAF - Adjusts The White Balance Separately For The Main Subject And The Background When The Flash Fires. |
Built In Flash | Auto, Flash On, Slow Synchro, Flash Off - Facial Brightness Is Also Evaluated In Face Detect. |
Flash Range | 1.6 - 11 Ft. (W), 3.0 - 6.6 Ft. (T) (50cm - 3.5m (W), 90cm - 2.5m (T)) * Image Brightness May Diminish Depending On The Shooting Distance |
Recycling Time | 10 Seconds Or Less (Battery Voltage: 3.7 V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto*1, P, Movie Digest, Portrait, Smooth Skin, Smart Shutter*2, High-Speed Burst, Handheld Night Scene, Low Light, Fish-Eye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Snow, Long Shutter, IFrame Movie, Super Slow Motion Movie - Shooting Movies Is Possible With The Movie Button *1 Smart Auto Also Available For Movies *2 Smile, Wink Self-Timer, Face Self-Timer |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* *Adjustment Of Contrast, Sharpness, Saturation, Red, Green, Blue And Skin Tone Are Available |
Self Timer | Approx. 10-Sec. Delay/Approx. 2-Sec. Delay/Custom*. *Delay Time (0-15 Sec. (In One-Second Increments), 20/25/30 Sec.) And Number Of Shots (1-10 Shots (In One-Shot Increments)) Can Be Specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 1.9 Shots/Sec. (In P Mode) Approx. 5.2 Shots/Sec. (In High-Speed Burst Mode) - Under Conditions Where The Flash Does Not Fire Automatically. - Differs According To Zoom Position. |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design Rule For Camera File System, DPOF (Version 1.1) Compliant |
Image Recording Format | Superfine, Fine |
Jpeg Compression Mode | Still Image: Exif 2.3 (JPEG) Video: MOV (Image: H.264; Audio: Linear PCM (2-Channel Stereo)) |
Number Of Recording Pixels | Still Images: [16:9] Large: 4608 X 2592, Medium 1: 3264 X 1832 Medium 2: 1920 X 1080, Small: 640 X 360 [3:2] Large: 4608 X 3072, Medium 1: 3264 X 2176 Medium 2: 1600 X 1064, Small: 640 X 424 [4:3] Large: 4608 X 3456, Medium 1: 3264 X 2448 Medium 2: 1600 X 1200, Small: 640 X 480 [1:1] Large: 3456 X 3456, Medium 1: 2448 X 2448 Medium 2: 1200 X 1200, Small: 480 X 480 Videos: [IFrame Movie] 1280 X 720 (30 Fps*1) [Super Slow Motion Movie] 640 X 480*2, 320 X 240*3 [Miniature Effect] 1280 X 720*4, 640 X 480*4 [Other Than The Above] 1920 X 1080 (24 Fps*5), 1280 X 720 (30 Fps*1), 640 X 480 (30 Fps*1) *1 Actual Frame Rate Is 29.97 Fps. *2 Shooting: 120 Fps., Playback: 30 Fps*1 *3 Shooting: 240 Fps., Playback: 30 Fps*1 *4 Shooting: 6 Fps, 3 Fps, 1.5 Fps Playback: 30 Fps*1 *5 Actual Frame Rate Is 23.976 Fps. |
Content |
*When In High-Speed Burst Or Low Light. The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
Content |
Playback Modes File | Stills & Videos: Auto Rotate (Automatic Vertical/Horizontal Detection), Image Advance (Operation Tools, Transition Effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Image Search, Movie Digest, Slideshow (Playback Interval, Repeat, Effect, Playlist) Still Images: Single, Index (6-130 Thumbnails), Magnification (2-10x), Information Display, Red-Eye Correction, I-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 - Displays Playback Position And Shooting Time Using The Software Included With The Camera (ImageBrowser EX), There Are 8 Levels (1/8x To 1x) Of Playback Speed For Super Slow Motion Movies Possible On A Computer. *1 Audio Settings Available In 5 Levels *2 Approximately 4 Seconds *3 Slow Motion Available |
Erase Modes | Select*1, Select Range, Select All Images*2 - The Image Data In The Memory Card Stored With The Design Rule For Camera File Systems Format Can Be Erased (However, Protected Images Cannot Be Erased). *1 Movies Can Be Erased Individually. *2 When Images Have Been Selected In Image Search, Only Those Images Will Be Erased. |
Computer Interface | Hi-Speed USB (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video |
Video Out | NTSC/PAL (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video) |
Audio Out | 2-Channel Stereo (Dedicated Connector (Female) With Unified Type Of Digital, Audio, And Video) |
Other | Mini-HDMI Cable: Connection To High Definition Monitor; SD Memory Card Slot; Direct Connection To Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers And PictBridge-Compatible Printers Via Camera's USB 2.0 Hi-Speed Cable |
Power Source | Battery Pack NB-11L, Compact Power Adapter CA-DC10 (Included With AC Adapter Kit ACK-DC90) |
Shooting Capacity Bp 511 | Approx. 170 Shots |
Playback Time Bp 511 512 | Approx. 3 Hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions W X H X D | 3.68 X 2.24 X 0.82 In. / 93.5 X 56.8 X 20.8mm |
Weight | 5.11 Oz. / 145g (Including The Batteries And Memory Card) 4.95 Oz. / 130g (Camera Only) |
