PowerShot D30
- Waterproof camera down to 82 ft. below sea level.
- Shockproof to 5.0 feet, and temperature-resistant from 14 degrees to 104 degrees Fahrenheit.
- 12.1 Megapixel High-Sensitivity CMOS sensor combined with the Canon DIGIC 4 Image Processor creates the Canon HS SYSTEM.
- Capture 1080p Full HD video with a dedicated movie button.
- PowerShot D30
- Battery Pack NB-6LH
- Battery Charger CB-2LY
- Wrist Strap WS-DC8
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Your Partner in Adventure
Now you can capture beautiful underwater stills and video without the need for a waterproof case down to 82 feet. That means that if you're a certified Open Water scuba diver, you can comfortably explore the certification's entire 59-foot range. The images and video you capture underwater will exhibit all the Canon quality you expect, with high resolution and vivid, natural color. And with the Movie Digest mode, you can record more of your dive without interrupting your enjoyment of it. The mode captures a still image plus up to 4 seconds of video prior to pressing the shutter, all without using the REC button.
The PowerShot D30 is built to come along on all your active pursuits. Whether you're skiing, cycling, climbing, hiking, even performing high movement activities in extreme temperatures, this camera can handle it. The PowerShot D30's extremely durable construction can withstand drops of up to 6.5 feet*. And with a temperature-resistant range of 14° to 104°F*, you'll be able to capture reliably beautiful images in both low and high-temperature environments. When adventure calls, the PowerShot D30 is ready.
The Canon HS SYSTEM on the PowerShot D30 lets you take bright, clear photos in an even wider range of shooting situations. The result of combining the camera's 12.1 Megapixel High-Sensitivity CMOS sensor and the DIGIC 4 Image Processor, the Canon HS SYSTEM makes possible beautiful low-light shots with minimal noise and maximum detail in highlight and shadow areas. The 12.1 Megapixel CMOS sensor in the PowerShot D30 incorporates advanced light reception technology that enhances sensitivity while the DIGIC 4 Image Processor actively reduces noise, expanding the usable ISO range to an amazing high of 3200. The Canon HS SYSTEM takes the frustration out of low-light shooting, delivering clear, blur-free images.
Record the fun and excitement of your outdoor adventures in crisp, clear high definition video on the PowerShot D30. A dedicated movie button means you're always ready to capture the movement as it happens. Full HD video on the PowerShot D30 means everything from amazing mountain heights to beautiful underwater depths will be preserved with spectacular realism and detail, perfect for watching on an HDTV or sharing with family and friends. In addition to being able to shoot Full HD 1080p video at 24* frames per second, the PowerShot D30 can also shoot 720p HD video at 30** frames per second. With the PowerShot D30, you can also shoot video in the Apple® iFrame format, which is a computer-friendly standard that speeds up importing and editing of videos, ideal for sharing to social networking sites and emailing.
* Actual frame rate is 23.976.
** Actual frame rate is 29.97.
The PowerShot D30 digital camera is equipped with Global Positioning System (GPS)* technology. You can travel the world and let the camera automatically record the locations and local times of your stills and videos. The camera can also use the GPS unit to automatically set the exact time. You can maximize the usefulness of the GPS feature by using the special bundled Map Utility software that makes it fun to share the memories of your world adventures. In addition to displaying all your photos' locations on a world map, the camera's GPS system can also track your route from photo to photo – a great way to visualize each trip! You can also create and share custom maps and personal mini-travel guides with friends and family members.
* In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated. GPS tracking does not work underwater.
The Map Utility software uses Google Maps for displaying maps.
The PowerShot D30 is the perfect companion even in the brightest sunlight. The camera has been equipped with a new Sunlight LCD mode that reduces glare, making the LCD monitor easy to see even in bright light. This enhanced visibility not only makes framing and shooting easier, but also makes it easy to review what you've captured and show it to others.
Sophisticated Canon technology that makes getting that great shot as simple as pressing the shutter button, Smart AUTO automatically detects scenes by assessing various factors in both the background and the subject. On the PowerShot D30, detected scenes are analyzed using 32 predefined shooting situations. The camera then makes optimal settings to ensure the best possible image capture, whether you're shooting stills or video. Smart AUTO also includes Advanced Subject Detection, which allows the camera to detect and track non-human moving subjects like animals and vehicles. With Smart AUTO, all you have to do is frame your shot and capture away.
Shooting Modes
Smart AUTO The camera automatically selects the best shooting settings for optimal quality based on subjects and environmental factors to provide point-and-shoot simplicity.
Program The camera automatically and intelligently selects the aperture/shutter speed combination based on the shooting conditions.
Movie Digest Automatically selects shooting settings for optimal quality and records a video clip every time you capture a still image. One day's worth of clips are then combined into a single video.
Portrait Brings the subject into focus while beautifully blurring the background.
Smart Shutter The camera automatically takes the photo when people smile, wink, or get into frame.
Handheld Night Scene Take clear and steady pictures at night without the use of a tripod.
Low Light For high quality image capture in an amazing range of dimly lit situations.
Fisheye Effect Now you can get the fisheye effect – a classic photographic distortion – without a fisheye lens.
Miniature Effect Give images a miniature look with an effect that emphasizes perspective by blurring the top and bottom of the image.
Toy Camera Effect Simulates photos taken with "toy" or pinhole cameras, darkening the image at the edges to create a vignette effect.
Monochrome Choose from three single-tone effects: Black-and-White, Sepia, or Blue.
Super Vivid Super Vivid intensifies existing hues, saturating the scene with bright colors.
Poster Effect Poster Effect combines several similar shades into one color, turning subtle gradations into eye-catching, scene-popping contrasts.
Color Accent Choose to retain a single color in your image while other colors turn monochrome.
Color Swap Select a color and replace it with a color you specify for special effects.
Underwater Capture underwater images with reduced backscatter effect.
Underwater Macro Enables close-ups by capturing a magnified image of the subject.
Snow Shoot clear snow scenes without darkened subjects or an unnatural bluish tint.
Fireworks Create brilliant images of skyrocketing fireworks.
Long Shutter Use to blur moving subjects for artistic effect, ideal for urban night photography.
Stitch Assist Easy-to-use guidelines simplify the shooting of aligned multiple frames that can later be combined (using bundled software) to create panoramic photos.
Movie Record video; unwanted scenes can be deleted in playback mode.
iFrame Movie The Apple® movie format, iFrame, makes it easier and quicker to import and upload videos while retaining high image quality.
Super Slow Motion Movie Record your clips in high speed (approx. 240 fps), and then watch your videos in slow motion.
Actual results may vary from examples shown above.
Final image may vary depending on picture composition.
The innovative Canon Optical Image Stabilization technology, Intelligent IS, analyzes camera movement and applies the best shake correction method for the shooting situation. For stills, the system automatically selects among Normal, Panning, Macro (Hybrid) and Tripod modes. When shooting video, the system automatically selects among Dynamic, Powered, Macro and Tripod modes. With Intelligent IS, you can concentrate on image capture, letting the camera make the most effective IS settings to help capture the steadiest possible image.
Normal Corrects for a wide range of camera movement when shooting stills.
Panning Panning motion is detected so that IS does not interfere with desired camera movement.
Macro (Hybrid) Corrects for shift-type camera shake, which typically occurs in macro (close-up) shooting.
Dynamic Effective for video shooting at wide-angle focal lengths, eliminating the unwanted shaking that typically occurs while walking.
Powered Compensates for hand movement when shooting video at the telephoto end of the zoom range, where camera shake is magnified.
Tripod When tripod use is detected, the Image Stabilizer is stopped because it is not needed.
** In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated. GPS tracking does not work underwater.
| Type Of Camera | Compact Digital Still Camera With Built-In Flash, 5x Optical, 4x Digital And 20x Combined Zoom With Optical Image Stabilizer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | 12.1 Megapixel, 1/2.3-Inch CMOS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 12.8 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | Approx. 12.1 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focal Length | 5.0 (W) - 25.0 (T) Mm (35mm Film Equivalent: 28-140mm) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Digital Zoom | 4.0x | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Range | Auto: 0.4 In. (1 Cm) - Infinity (W); 3.3 Ft. (1 M) - Infinity (T); Macro/Underwater Macro: 0.4 In. - 1.6 Ft. (1-50 Cm) (W); Normal: 2.0 In. (5 Cm) - Infinity (W), 3.3 Ft. (1 M) - Infinity (T); Quick: 9.8 Ft. (3 M) (W,T) |
| Autofocus | TTL Autofocus | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Optical Viewfinder | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Monitor | 3.0-Inch TFT Color With Wide-Viewing Angle | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Pixels | Approx. 461,000 Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Coverage | Approx. 100% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maximum Aperture | F/3.9 (W), F/4.8 (T) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speed | 1-1/1600 Sec. 15-1 Sec. (Shooting Long Exposures) |
| Sensitivity | Auto, ISO 100-3200 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Light Metering Method | Evaluative*, Center-Weighted Average, Spot** * Facial Brightness Is Evaluated In Face Detection AF ** Metering Frame Is Fixed To The Center |
| Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Still Images: ±2 Stops In 1/3-Stop Increments Videos: ±2 Stops In 1/3-Stop Increments (Not Available During Shooting) |
| White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Underwater, Custom * Camera Automatically Sets The Optimal ISO Speed According To Shooting Mode. |
| Built In Flash | Auto, Flash On, Slow Synchro, Flash Off |
| Flash Range | 1.0 Ft. - 11 Ft. (W), 3.3 - 9.8 Ft. (T) (30cm - 3.5m (W), (1.0m - 3.0m (T)) Image Brightness May Diminish Depending On The Shooting Distance |
| Recycling Time | 10 Sec. Or Less (Battery Voltage: 3.7 V) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Modes | Auto, P, Movie Digest, Portrait, Smart Shutter*1, Handheld Night Scene, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Underwater, Underwater Macro, Snow, Fireworks, Long Shutter, Stich Assist, IFrame Movie, Super Slow Motion Movie *1 Smile, Wink Self-Timer, Face Self-Timer |
| Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* * Adjustment Of Contrast, Sharpness, Saturation, Red, Green, Blue And Skin Tone Are Available. |
| Self Timer | Approx. 10-Sec. Delay/Approx. 2-Sec. Delay/Custom* * Delay Time (0-15 Sec. (In One-Second Increments), 20/25/30 Sec.) And Number Of Shots (1-10 Shots (In One-Shot Increments)) Can Be Specified. |
| Wireless Control | Not Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting | Normal: Approx. 1.9 Shots/Sec. (In P Mode) Normal: Approx. 1.9 Shots/Sec. (In Low Light Mode) |
| Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Format | Design Rule For Camera File System, DPOF (Version 1.1) Compliant | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Jpeg Compression Mode | Still Image: Exif. 2.3 (JPEG) Video: MOV (Image: MPEG-4 AVC/H.264; Audio: Linear PCM (Monaural)) |
| Number Of Recording Pixels | Still Images: 1) 16:9 - Large: 4000 X 2248; Medium 1: 2816 X 1584; Medium 2: 1920 X 1080; Small: 640 X 360 2) 3:2 - Large: 4000 X 2664; Medium 1: 2816 X 1880; Medium 2: 1600 X 1064; Small: 640 X 424 3) 4:3 - Large: 4000 X 3000; Medium 1: 2816 X 2112; Medium 2: 1600 X 1200; Small: 640 X 480 4) 1:1 - Large: 2992 X 2992; Medium 1: 2112 X 2112; Medium 2: 1200 X 1200; Small: 480 X 480 * 1984 X 1488 (M) When In Low Light Mode. Videos: Full HD 1920 X 1080: 24 Fps (23.976) IFrame Movie 1280 X 720: 30 Fps (29.97) HD 1280 X 720: 30 Fps (29.97) Miniature Effect 1280 X 720*1: 6 Fps, 3 Fps, 1.5 Fps Miniature Effect 640 X 480*1: 6 Fps, 3 Fps, 1.5 Fps Super Slow Motion 640 X 480*1: 120 Fps Super Slow Motion 320 X 240*1: 240 Fps Digest Movie 640 X 480: 30 Fps (29.97) 640 X 480: 30 Fps (29.97) *1 Playback: 30 Fps (29.97) |
| Content |
Note: F=Fine * When In Low Light. • The Approximate Number Of Images Recordable On Memory Cards Other Than The Above Can Be Calculated By Using The Above Figures As A Reference And Extrapolating Accordingly. |
| Content |
*1 Playback Frame Rate Is 30 Fps*2. |
| Playback Modes File | Stills & Videos: Auto Rotate (Automatic Vertical/Horizontal Detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, Smart Shuffle, Group Playback, Slideshow (Repeat, Interval, Effect) Still Images: Single, Index (4-100 Thumbnails), Magnification (2-10x), Information Display, Red-Eye Correction, I-Contrast, Resize, My Colors, Histogram, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 *1 Audio Settings Available In 5 Levels *2 Approximately 4 Seconds *3 Slow Motion Available |
| Erase Modes | Select Image, Select Range, Select All Images |
| Video Out | Analog: NTSC Or PAL, Digital: HDMI (HDMI™ Mini Connector) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Audio Out | Monaural (Dedicated Connector (Female) With Unified Type Of Digital, Audio And Video) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other | SD Memory Card Slot; Direct Connection To Canon SELPHY, PIXMA Photo Printers & PictBridge Compatible Printers | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Source | Battery Pack NB-6L/NB-6LH, AC Adapter Kit ACK-40 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shooting Capacity Bp 511 | Approx. 300 Shots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Playback Time Bp 511 512 | Approx. 6 Hours | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature | 14-104°F/10-40°C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity | 10-90% | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | 4.31 X 2.68 X 1.08 In. / 109.4 X 68.0 X 27.5mm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | 7.69 Oz. / 218g (CIPA Standard) 6.84 Oz. / 194g (Body Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
