PIXMA PRO-100
- PIXMA PRO-100 Wireless Professional Inkjet Printer
- CD/DVD Disc Printing Tray
- Manuals and other documents:
CLA Contact Information Sheet - Setup CD-ROM
- Setup Ink Tanks
- Power Cord
- Print Head
- USB Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
High performance professional photo printing up to 13" x 19".
The PIXMA PRO-100 shares technology with the rest of the PIXMA PRO line utilizing the Optimum Image Generating System to ensure what you envision is exactly what you get. The OIG System analyzes each area of the print and chooses the best ink mixture so you see the colors you expect to see in your print.
The new Print Studio Pro2 plug-in software makes it even easier to get amazing results from your favorite photo applications. Add to that connectivity options like Wi-Fi, Ethernet and USB and you have a professional machine that easily fits into your workflow that you can place anywhere around the studio.
For media support, the PIXMA PRO-100 features two paper trays. A rear tray for a variety of fine art and glossy photo papers, and a manual slot for thicker media to meet your printing needs.
Print your Vision up to 13" x 19":
Print professional quality photos on various media up to 13" x 19".
Professional Quality, Built-in:
Canon Full-photolithography Inkjet Nozzle Engineering (FINE) features a patented print head that enables printing with microscopic droplets and high resolution up to 4800 x 2400 dpi.4
True Monochrome Prints:
The 3 monochrome inks which are part of the 8-ink ChromaLife 100+ system3 consist of Black, Gray, and Light Gray. These inks deliver enhanced, deep black density to raise your level of professional print quality when creating the dramatic expression of grayscale photography.
Optimum Analysis and Mixture of Color:
The Optimum Image Generating (OIG) System utilizes two major technologies: The first is a sophisticated mixing balance of inks determined from numerous ink combinations and advanced analysis. During this analysis, the OIG System carefully calculates the best results for each print mode and paper type used while looking at various image factors including color reproduction, tonal gradations, black density, low graininess, glossiness, anti-bronzing and anti-metamerism. These critical ink balancing principles are derived from Canon's expertise in imaging technology, as well as the familiar colors of life that people see and remember on a daily basis. The second is the balancing of color reproduction, tonal gradations, and uniform glossiness. The genius and power of the OIG System is truly showcased when your image is printed, exhibited, and is seen exactly as you envisioned it.
Pro Printing:
The powerful Print Studio Pro plug-in software2 provides professional photographers effective printing solutions and can directly hand-over image data. Print Studio Pro is compatible with Digital Photo Professional (ver 2.1 or later), Adobe® Photoshop® CS, Adobe® Photoshop Elements®, and Adobe® Photoshop® Lightroom®.
Versatile Paper Handling:
Two-way paper feeding provides a rear tray for most supported media types and a dedicated manual feed in the back of the printer for easy loading of thicker papers.
Built-in CD and DVD Printing:
Conveniently print onto your printable CD, DVD or Blu-ray Discs and jackets.
Built-in Wi-Fi:
The built-in Wi-Fi1 gives you the freedom to place the printer where it's convenient and allows multiple users to seamlessly print from several computers.
Built-in Ethernet Connectivity:
The built-in Ethernet port allows multiple users to seamlessly print from several networked computers in any environment.
Computer-free Printing:
A PictBridge connection lets you print photos directly from your compatible digital camera, DV camcorder, or camera phone.
Hi-Speed USB:
Plug the cable into your PC for a super-fast connection for your data transfers.
AirPrint:
Enables you to print photos, email, Web pages and documents from your Apple device directly to your printer - without installing a driver.5
- Wireless printing requires a working Ethernet network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. Wireless products are not available in some countries.
- Print Studio Pro plug-in software is compatible with Adobe Photoshop CS4/CS5/CS5.1, Adobe Photoshop Elements 8/9/10, Adobe Photoshop Lightroom 2.7/3 and Canon Digital Photo Professional 3.12 or later.
- Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, drying time, display/storage conditions, and environmental factors.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Printer firmware update may be necessary for AirPrint function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.5.8 or later and USB cable required to perform firmware
update. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. See www.cla.canon.com for additional information.
- To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- Print Your Days requires Microsoft Silverlight 5, an Internet connection and runs on Windows Internet Explorer 8, 9 and Google Chrome on a PC running Windows 7 or Windows Vista. Will also work in Firefox under Windows 7 (32-bit) and Windows Vista (32-bit).
- "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS, PowerShot and VIXIA digital cameras and camcorders. Requires a PC, or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files.
- Envelopes, High Resolution Paper and certain fine art papers are NOT supported for borderless printing.
- Requires Canon Easy-PhotoPrint for iPhone app, available for free on the App Store, or Canon Easy-PhotoPrint for Android app available for free on Google Play. Compatible with iPhone 3G, 3GS, 4, 4S, iPod touch and Android devices running Android OS 1.6 or later.
- System requirements vary by application. For Mac OS, an Internet connection is required during software installation. For Windows OS, .NET Framework 4 is required to install My Image Garden and Quick Menu.
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks are installed.
| Printer Type | Wireless Professional Inkjet Printer |
| Features | AirPrint Auto Photo Fix II Borderless Printing Optimum Image Generating System Photo Printing Grayscale Photo Printing Wireless Printing |
| Print Speed Text | 8" X 10" Image On A4 With Border: Approx. 51 Seconds Seconds6 |
| Print Speed Text | 11" X 14" Image On A3+ With Border: Approx. 1 Minute 30 Seconds6 |
| Nozzle Text | 6,144 |
| Resolution Text | Color: Up To 4800 X 2400 Dpi4 |
| Resolution Text | Black Up To 4800 X 2400 Dpi4 |
| Os Compatibility | Windows® 7, Windows 7 SP1, Windows Vista SP1, Vista SP2, Windows XP SP3 32-Bit Mac OS® X V10.5.8, 10.6, 10.77 |
| Standard Interfaces | Wireless LAN (IEEE 802.11 B/G/N) Ethernet Hi-Speed USB PictBridge (Cable Not Included) |
| Ink Compatibility | CLI-42 |
| Ink Droplet Size | Picoliter Size 3pl |
| Ink Capacity | 8 |
| Paper Sizes | A4, A5, B5, 4" X 6", 5" X 7", 8" X 10", Letter, Legal, 11" X 17", 13" X 19" |
| Paper Compatibility | Plain: (Plain Paper, Canon High Resolution Paper Super High Gloss: Photo Paper Pro Platinum Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy Matte: Matte Photo Paper Fine Art Paper: Fine Art "Museum Etching"; Other Fine Art Papers CD/DVD: Printable CD/DVD/Blu-Ray Disc |
| Maximum Paper Size | 13" X 19" |
| Output Tray Capacity | Auto Sheet Feeder: 150 Sheets Of Plain Paper 20 Sheets Photo Paper (4"X6"); 10 Sheets (Letter/8"X10"); 1 Sheet (A3+) Manual Feeder: 1 Sheet Of Photo Paper (All Sizes) |
| Noise Level Approx | Approx. 38.5 DB(A) |
| Physical Dimensions | 27.2" (W) X 15.2" (D) X 8.5" (H) |
| Weight | 43.2 Lbs. |
| Power Consumption | 19 W (2.3 W Standby) |
| Software Included | Setup Software & User's Guide CD-ROM PIXMA PRO-100 Printer Driver My Image Garden12: Full HD Movie Print, CREATIVE PARK PREMIUM13, Fun Filter Effects And Image Correction/Enhance Are Accessed Through My Image Garden Print Studio Pro Quick Menu |
CLI-42 BK
Black Ink Tank 13ml
CLI-42 M
Magenta Ink Tank 13ml
CLI-42 LGY
Light Gray Ink Tank 13ml
CLI-42 PC
Photo Cyan Ink Tank 13ml
CLI-42 C
Cyan Ink Tank 13ml
CLI-42 Y
Yellow Ink Tank 13ml
CLI-42 PM
Photo Magenta Ink Tank 13ml
CLI-42 GY
Gray Ink Tank 13ml
Everyday Use Glossy Photo Paper 4x6
GP-501
Glossy photo paper for printing everyday photographs and reprints with photo-lab quality. "Everyday Use" photo paper provides economical way to produce your holiday photos with glossy finish at home.
High Resolution Paper A3
HR-101N
This coated paper is designed to produce brilliant colours and sharp, vivid images. Ideal for printing high quality documents, spreadsheets and presentations containing photos and graphics.
Glossy II Photo Paper Plus A4
PP-201
Photo Paper Plus Glossy II yields a glossy finish and exceptionally rich colors, giving your images the look and feel of a traditional photograph.
Pro Platinum Photo Paper A3+
PT-101
When ChromaLife100+ inks and Photo Paper Pro Platinum are used together your photos can achieve over a 200 year life in an album
Pro Platinum Photo Paper A4
PT-101
Pro Platinum Photo Paper LTR (8.5x11)
PT-101
Matte Photo Paper LTR (8.5x11)
MP-101
Matte Photo Paper produces high quality photographs, graphics and text with a matte finish. Also suitable for more creative uses, such as greetings cards, displays and paper craft.
Glossy II Photo Paper Plus LTR (8.5x11)
PP-301
Glossy II Photo Paper Plus A3
PP-201
Everyday Use Glossy Photo Paper A4
GP-501
High Resolution Paper A4
HR-101N
High Resolution Paper LTR (8.5x11)
HR-101N
Pro Platinum Photo Paper 4x6
PT-101
Glossy II Photo Paper Plus A3+
PP-201
Glossy Photo Paper LTR (8.5x11)
GP-601
Great Photo Paper for Everyday Projects. This vibrant, glossy paper gives you crisp, clear pictures that are high quality without the high cost - an economical choice for great prints.
Glossy II Photo Paper Plus 4x6
PP-301
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
