PIXMA MX531
- PIXMA Printing Solutions (PPS) lets you print or scan photos or documents from your mobile device using the free PPS app.
- Auto Duplex Printing allows you to automatically print on both sides of the paper and can help reduce paper usage and cost by up to 50%.
- The Automatic Document Feeder holds 30 sheets, making it easier to copy, scan or fax multiple documents.
- PIXMA MX531 Wireless Office All-In-One Printer
- Power Cord
- FINE Cartridges
- Setup CD-ROM
- Telephone Line Cable
- Manuals and Other Documents
- Office Application Insert
- CLA Contact Sheet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires an Internet connection and the PIXMA Printing Solutions ("PPS") app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 5.1 or later, and Android mobile devices running Android 2.3 or later. User must register printer with PPS and be a registered member of the compatible online Cloud service(s) user chooses to access through PPS and is subject to the terms and conditions of those services. Certain functions (scanning and printing locally stored photos/documents) require your device to be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- “ISO/IEC 24734, 24735 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 24735 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 24735, excluding time to copy the first set.
- Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used, and page coverage. See Print Speed page for additional information.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks and all of the software that came with the printer are properly installed.
- For network users, Auto Scan Mode is available only when scanning at a computer using MP Navigator EX software and selecting the 1-click feature then "Save to PC."
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Requires smartphone or tablet and with compatible PPS app and internet connection.
- Envelopes and High Resolution Paper are NOT supported for borderless printing.
- "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files. Print quality is determined by the video resolution. Function does not upscale video resolution.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed vary depending on document complexity, fax setting at receiving end, and line conditions etc.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
- Requires mobile phone (or other device) equipped with Bluetooth v2.0 technology and optional Canon Bluetooth Unit BU-30. Bluetooth operation depends on the device and software version used. Operating distance is approx. 10 meters but may vary due to obstacles, radio signals, locations where radio interference occurs, magnetic fields from microwave ovens, device sensitivity and/or antenna performance.
- System requirements vary by application. For Mac OS, an Internet connection is required during software installation. For Windows OS, .NET Framework 4 is required to install My Image Garden, Quick Menu, and Easy-WebPrint EX software.
- Easy-WebPrint EX requires Internet Explorer 7 or 8 for Windows, Internet Explorer 9 for Windows Vista SP2 (or later) or Windows 7, or Safari 4.0 - 5.0 for Mac OS X v10.5 - 10.6.x.
| Print Speed Text | 4" X 6" Borderless Photo: Approx. 46 Seconds4,5> |
| Print Speed Choice | Black |
| Print Speed Text | ESAT: Approx. 9.7 Ipm4,5 |
| Print Speed Choice | Color |
| Print Speed Text | ESAT: Approx. 5.5 Ipm4,5 |
| Nozzle Text | Black: 1,152 Color: 640 Total: 1,792 |
| Picoliter Size | 2 And 5 |
| Resolution Color Choice | Color |
| Resolution Text | Up To 4800 X 1200 Dpi3 |
| Resolution Color Choice | Black |
| Resolution Text | Up To 600 X 600 Dpi3 |
| Ink Compatibility | PG-140XXL Black Ink Cartridge PG-140XL Black Ink Cartridge PG-140 Black Ink Cartridge CL-140XL Color Ink Cartridge CL-141 Color Ink Cartridge |
| Paper Sizes | 4" X 6", 5" X 7", 8" X 10", A4, Letter, Legal, U.S. #10 Envelopes |
| Automatic Sheet Feeder | 100 Sheets ADF:30 Sheets |
| Paper Compatibility | Plain: Plain Paper, High Resolution Paper; Super High Gloss: Photo Paper Pro Platinum; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Matte: Matte Photo Paper; Envelope: U.S. #10 Envelope |
| Print Features | Auto Document Feeder, AirPrint10, Auto Duplex Print, Borderless Printing13, Document Printing, Full HD Movie Print14, Fun Filter Effects, Google Cloud Print11, My Image Garden7, Photo Printing, PIXMA Printing Solutions2, Wireless Printing1 |
| Mono Copy Speed Up To | ESAT: Color: 4.7 Ipm4 |
| Reductions Enlargement | 25% To 400% |
| Copy Feature | Auto Document Feeder (ADF), AE (Auto Exposure) Copy, Borderless, Fit-To-Page, Preset Copy Ratios, Frame Erase Copy, Zoom |
| Scanning Element | Contact Image Sensor (CIS) |
| Max Resolution Text | Optical: 1200 X 2400 Dpi16 |
| Max Resolution Text | Interpolated: 19,200 X 19,200 Dpi16 |
| Max Resolution Text | ADF: 600 X 600 Dpi (Optical)16 |
| Scanner Features | Auto Scan Mode9, Network Scan, Push Scan, Scan To Memory (USB) |
| Color Depth | 48-Bit Internal/24-Bit External |
| Max Document Size | Flatbed: 8x5" X 11.7" ADF: 8.5" X 14" |
| Modem Speed | 33.6 Kbps (Super G3 Color FAX)15 |
| Transmission Speed Approx | Black: Approx. 3 Sec Per Page16 Color: Approx. 1 Min Per Page16 |
| Transmission Reception Memory | Approx. 50 Pages17 |
| Group Dialing | 19 |
| Fax Features | Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Fax Reception Reject, Fax Number Re-Entry, Memory Transmission, Redial, Remote Reception |
| Other Features Networking | 2-Line LCD, Dual Color Gamut Processing Technology, Fully Integrated Auto Document Feeder (ADF), PIXMA Cloud Link12, Wireless Printing1 |
| Os Compatibility | Computer Operating Systems: Windows® 8, Windows 8.1, Windows 7,19 Windows 7 SP1, Window Vista SP1, Vista SP2, Windows XP SP3 32-Bit19 Mac OS X V10.6.8- V10.919 Mobile Operating Systems: |
| Standard Interface | Wireless LAN (IEEE 802.11b/G/N)1 Hi-Speed USB USB Flash Memory Bluetooth® V2.0 (Optional)18 |
| Dimension W X D X H | 18.1" (W) X 15.2" (D) X 7.9" (H) |
| Weight | 18.7 Lbs |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
