PIXMA MX391
- PIXMA MX391 Office All-In-One Printer
- Document Kit:
- Cross Sell Sheet
- Getting Started
- Important Information Sheet
- Contact Information Sheet
- Printer Application Insert
- Setup Software & User's Guide CD-ROM
- Ink Tanks:
- PG-140 (Black Cartridge)
- CL-141 (Color Cartridge)
- Power Cord
- Telephone Line Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Fast and easy business-quality printing is closer than you think with the affordable PIXMA MX391. An integrated 30-sheet Auto Document Feeder and 2-line LCD help increase functionality and efficiency to your home office. Another feature the PIXMA MX391 has is the FastFront system, which conveniently allows you to change ink and paper from the front of the printer.
4800 x 1200 maximum color resolution1 and the FINE Cartridge System means superb business document printing and efficiency while built-in imaging technology insures the integrity of originals are preserved with each copy and scan.
The PIXMA MX391 also allows you to turn your office into a photo lab. Print crisp beautiful, borderless2 photo lab quality images up to 8.5" x 11" in size. My Image Garden3 software makes organizing and printing your photos fun and easy with great facial recognition, Fun Filters, Calendar Organization, Automatic Layout Suggestions and more.
The PIXMA MX391 delivers the business imaging quality and versatile solutions that can assist you in bringing your business to the next level.
High Performance Ink Cartridges: These two genuine Canon ink cartridges contain specially formulated inks for great document and photo quality. One is a Pigment Black cartridge for crisp, professional text and one is a multi-color cartridge for pictures and graphics. Both are easy to use and replace.
Beautiful, Borderless Photos Fast: Print a borderless, 4" x 6" photo in approximately 46 seconds.2
ChromaLife100: This system combines enhanced FINE print head technology with select genuine Canon photo papers and inks for beautiful borderless photos that will last up to 100 years when stored in an archival-quality photo album.4
My Image Garden: My Image Garden software makes organizing and printing your photos fun and easy with great facial recognition, Fun Filters, Calendar Organization, Automatic Layout Suggestions and so much more!
Fully-Integrated, 30-sheet Auto Document Feeder: Easily copy, scan and fax multiple documents without having to load them one page at a time. Enjoy full integration so the printer can better fit in tight workspaces.
FastFront: This innovative design feature allows for even easier replacement of your Genuine Canon Ink and papers right from the front of the machine.
Full HD Movie Print: Full HD Movie Print software turns your favorite HD movie clips captured with compatible Canon EOS Digital SLR, PowerShot cameras, or VIXIA camcorders into beautiful prints.9
2-Line LCD: Easily set print and copy quantities while also viewing the printer's status.
Auto Document Fix: This built-in software automatically analyzes and corrects both text and image documents so text will remain clear and easy to read with pronounced edges, and pictures will keep their true color with highlights, shadows, and dots being smoothed out.
Quick Start: After pressing the power button you can begin inputting commands in mere seconds so full operation is possible in a much shorter time.
Auto Photo Fix II: This built-in technology automatically categorizes your images into one of five types - Portrait, Scenery, Night Scenery, Snapshot with Scenery, and Snapshot with Night Scenery - then applies optimal image and multi-zone exposure correction. So, unexposed areas of the photo will be optimized, area by area and faces that are backlit and under-exposed will automatically be brightened with correct color cast to help ensure more accurate skin tones for gorgeous images.
Evernote: Quickly and easily scan your documents and papers from your printer or scanner. Evernote will make your documents searchable, so you can always find what you need at anytime, on any device.
USB 2.0 Hi-Speed: Plug the cable into your PC for a super-fast connection for your data transfers.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Envelopes and High Resolution Paper are NOT supported for borderless printing.
- To install using Windows®; OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, drying time, display/storage conditions, and environmental factors. See www.cla.canon.com/chromalife100 for additional details.
- "Full HD Movie Print" is available from "MOV" movie files created by Canon digital cameras. From PC, or Mac with Intel®; processor. Requires Canon ZoomBrowser EX 6.5 or later, or Canon ImageBrowser 6.5 or later.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
- Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. See www.cla.canon.com/printspeed for additional information.
- "ISO/IEC 24734, 24735 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 24735 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 24735, excluding time to copy the first set.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed vary depending on document complexity, fax setting at receiving end, and line conditions etc.
- Print Your Days requires Microsoft Silverlight 5, an Internet connection and runs on Windows Internet Explorer 8, 9 and Google Chrome on a PC running Windows 7 or Windows Vista. Will also work in Firefox under Windows 7 (32-bit) and Windows Vista (32-bit).
- System requirements vary by application.
| Print Speed Text | 4" X 6" Borderless Photo: Approx. 46 Seconds8 |
| Print Speed Choice | Black |
| Print Speed Text | ESAT: 8.7 Ipm9 |
| Print Speed Choice | Color |
| Print Speed Text | ESAT: 5.0 Ipm9 |
| Nozzle Text | Black: 640 Color: 1,152 Total: 1,792 |
| Picoliter Size | 2 And 5 |
| Resolution Color Choice | Color |
| Resolution Text | Up To 4800 X 1200 Dpi1 |
| Resolution Color Choice | Black |
| Resolution Text | Up To 600 X 600 Dpi1 |
| Ink Compatibility | PG-140XXL Black Ink PG-140XL Black Ink PG-140 Black Ink CL-141XL Color Ink CL-141 Color Ink |
| Paper Sizes | 4" X 6", 5" X 7", 8" X 10", Letter, Legal, U.S. #10 Envelopes |
| Automatic Sheet Feeder | 100 Sheets ADF: 30 Sheets |
| Paper Compatibility | Plain: Plain Paper, High Resolution Paper; Super High Gloss: Photo Paper Pro Platinum; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Matte: Matte Photo Paper; Envelope: U.S. #10 Envelope Chlorine-Free Paper Can Be Used. |
| Print Features | Auto Document Feeder, Auto Photo Fix II, Auto Sheet Feeder, Borderless Printing2, Document Printing, Full HD Movie Print5, Photo Printing, Template Print, Evernote |
| Mono Copy Speed Up To | ESAT: Color: 4.0 Ipm9 |
| Reductions Enlargement | 25% - 400% |
| Copy Feature | Auto Document Fix, Copy, Borderless, Gutter Shadow Correction Copy, Image Repeat, Intensity Multiple Copy: 1-99 Pages, Preset Copy Ratios, Sort (ADF), Zoom |
| Scanning Element | Contact Image Sensor (CIS) |
| Max Resolution Text | Optical: 1200x2400 Dpi10 |
| Max Resolution Text | Interpolated: 19,200x19,200 Dpi10 |
| Max Resolution Text | ADF: 600x600 Dpi (Optical)10 |
| Scanner Features | Auto Scan Mode, Push Scan |
| Color Depth | 48-Bit Internal/24-Bit External |
| Max Document Size | Flatbed: 8.5" X 11.7" ADF: 8.5" X 14" |
| Modem Speed | 33.6 Kbps (Super G3 Color FAX)6 |
| Transmission Speed Approx | Black: Approx. 3 Sec Per Page11 Color: Approx. 1 Min Per Page11 |
| Transmission Reception Memory | Approx. 50 Pages7 |
| Speed Dialing | 19 Locations |
| Fax Features | Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Fax Reception Reject, Fax Number Re-Entry, F/T Changing(Manual), Group Dialing, Memory Transmission, Redial, Remote Reception |
| Other Features | 2-Line LCD, Dual Color Gamut Processing Technology, Full HD Movie Print5, Fully Integrated ADF, Print Your Days12, FastFront, Quick Start |
| Os Compatibility | Windows® 8, Windows RT, Windows 7, Windows 7 SP1, Windows Vista SP1, Vista SP2, Windows XP SP3 32-Bit Mac OSX 10.6.8 Or Later |
| Dimension W X D X H | 18.1" (W) X 15.2" (D) X 7.9" (H) |
| Weight | 19.0 Lbs |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
