PIXMA MG6410
- PIXMA Printing Solutions (PPS) app easily lets you print and scan photos or documents from your mobile device. With the cloud print function you can print directly from online cloud services either at the printer itself or with your mobile device using the free PPS app.
- 5 individual ink tanks and ChromaLife100+ System gives you great plain paper and photo quality.
- 3.0" LCD and built-in card slots allows you to edit and print your photos right on your printer, no computer needed!
- AirPrint enabled! Print wirelessly from your iPhone, iPad or iPod touch directly to your MG6410, no drivers needed.
- PIXMA MG6410 Wireless Inkjet Photo All-In-One
- Manuals and other documents
- Contact CLA Information Sheet
- Printer Application Insert
- Bonus Paper (PP-201, 3 Sheets 4"x6")
- Setup CD-ROM
- Setup Ink Tanks
- Power Cord
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Envelopes and High Resolution Paper are NOT supported for borderless printing.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Compatible memory cards include SDTM Memory Card, SDHCTM, MultiMediaCard®;, MultiMediaCard®; Plus, CompactFlash®;, Microdrive®;, Memory Stick DuoTM and Memory Stick PRO DuoTM. The following can be used with the addition of a special adapter sold separately: miniSDTM Card, miniSDHCTM Card, microSDTM Card, microSDHCTM Card, RS-MMCTM, MMC mobileTM, Memory Stick Micro, xD-Picture Card®;, xD-Picture Card®; (Type M), and xD-Picture Card®; (Type H).
- Requires an internet connection and the PIXMA Printing Solutions ("PPS") app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 5.1 or later, and Android mobile devices running Android 2.3 or later. User must register printer with PPS and be a registered member of the compatible online cloud service(s) user chooses to access through PPS and is subject to the terms and conditions of those services. Certain functions (scanning and printing locally stored photos/documents) require your device to be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS, PowerShot and VIXIA digital cameras and camcorders. Requires PC, or Mac with Intel®; processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files.
- To install using Windows®; OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks are installed.
- ISO/IEC 24734, 24735 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 24735 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 24735, excluding time to copy the first set.
- Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. See www.cla.canon.com for additional information.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- Requires Canon Easy-PhotoPrint for Windows RT available for free in the Windows Store. Compatible with Windows RT devices.
- Requires an Internet Connection.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- DPS over IP compatible device required.
- For network users, Auto Scan Mode is available only when scanning at a computer using My Image Garden software and selecting the 1-click feature then "Save to PC".
- System requirements vary by application. For Mac OS, an Internet connection is required during software installation. For Windows OS, .NET Framework 4 is required to install My Image Garden, Quick Menu, and Easy-WebPrint EX software.
| Print Speed Text | 4" X 6" Borderless Photo: Approx. 44 Seconds10,11 |
| Print Speed Choice | Black |
| Print Speed Text | ESAT: Approx. 15.0 Ipm10,11 |
| Print Speed Choice | Color |
| Print Speed Text | ESAT: Approx. 9.7 Ipm10,11 |
| Nozzle Text | Color: 3,072 / Pigment Black: 1,024 / Total: 4,096 |
| Picoliter Size | 2 And 5 |
| Resolution Color Choice | Color |
| Resolution Text | Up To 4800 X 1200 Dpi3 |
| Resolution Color Choice | Black |
| Resolution Text | Up To 600 X 600 Dpi3 |
| Ink Compatibility | PGI-150 XL Pigment Black CLI-151 XL Cyan CLI-151 XL Magenta CLI-151 XL Yellow CLI-151 XL Black PGI-150 Pigment Black CLI-151 C Cyan CLI-151 M Magenta CLI-151 Yellow CLI-151 Black |
| Paper Sizes | A4, A5, B5, 4" X 6", 5" X 7", Letter, Legal, U.S. #10 Envelopes |
| Paper Compatibility | Plain: Plain Paper, Canon High Resolution Paper; Super High Gloss: Photo Paper Pro Platinum; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Matte: Matte Photo Paper; Envelope: U.S. #10 Envelope; Chlorine-Free Paper Can Be Used |
| Print Features | AirPrint6, Auto Duplex Print, Auto Photo Fix II, Borderless Printing2, Calendar Print, Cloud Link Printing14, Document Printing, Full HD Movie Print7, Fun Filter Effects, Google Cloud Print15, My Image Garden8, Mobile Device Printing13, Photo Direct Printing (Memory Card)4, Photo Printing, PIXMA Printing Solutions5, Print From Email, Red-Eye Correction, Template Print, Trimming Print, Quiet Mode, Web Template Print, Wireless PictBridge16, Wireless Printing1 |
| Output Tray Capacity | 100 Sheets Plain Paper -OR- 20 Sheets Of 4"X6" Photo Paper |
| Mono Copy Speed Up To | FCOT(Color): Approx. 18 Seconds11 |
| Reductions Enlargement | 25% - 400% |
| Copy Feature | 4-On-1 / 2-On-1 Copy, Auto Exposure Copy, Auto Photo Fix II, Borderless Copy, Fade Restoration, Fit-To-Page, Frame Erase Copy, Multiple Copy: 1-21 Pages, Photo Reprint, Preset Copy Ratios, Two-Sided Copy, Zoom |
| Scanner Type | Flatbed |
| Scanning Element | Contact Image Sensor (CIS) |
| Max Resolution Choice | Optical |
| Max Resolution Text | 1200 X 2400 Dpi12 |
| Max Resolution Choice | Interpolated |
| Max Resolution Text | 19,200 X 19,200 Dpi12 |
| Scanner Features | Auto Scan Mode17, Attach To E-Mail Scan, Network Scan, Push Scan, Scan To Memory Card, Wireless Scanning |
| Color Depth | 48-Bit Input / 24-Bit Output |
| Max Document Size | 8.5" X 11.7" |
| Support Media | SD™ Card4 SDHC™ Card4 MiniSD™ Card4 MiniSDHC™ Card4 MicroSD™ Card4 MicroSDHC™ Card4 Memory Stick Duo™4 Memory Stick PRO Duo™4 Memory Stick Micro4 |
| Other Features | 3.0" LCD, 5-Color Ink System, CREATIVE PARK PREMIUM9, Auto Power Off, Auto Power On, Dual Color Gamut Processing Technology, Snap Edge, Quiet Mode, PIXMA Printing Solutions5, QuickStart, Rated EPEAT Silver |
| Os Compatibility | Windows® 8, Windows 7, Windows 7 SP1, Windows Vista SP1, Vista SP2, Windows XP SP3 32-Bit18 Mac OS® X V10.6.8 - 10.818 Mobile Operating Systems: IOS, Android, Windows RT18 |
| Standard Interface | Wireless LAN (IEEE 802.11b/G/N)1 Hi-Speed USB Card Slots4 Wireless PictBridge16 |
| Dimension W X D X H | 18.0" (W) X 14.6" (D) X 5.9" (H) |
| Weight | 14.0 Lbs. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Locating and Installing Your Download Cómo Localizar e Instalar su Descarga Localizando e Instalando seu Download
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
