PIXMA GM2010
- PIXMA GM2010 Wireless Single Function Printer
- Setup CD, Manual, and other documentation
- Black ink bottle (PGBK)
- Black Print Head
- Power Cord
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Smart, Simple, and Cost-effective printing with Printers with Refill Built-In Ink Tanks
The Canon PIXMA GM2010 Wireless Single Function Printer is designed for those who need a high-volume printer for documents with a large paper capacity. The PIXMA GM2010 Wireless Printer features a high page yield of up to 8,300 pages of black text1, a combined 350 sheet plain paper capacity, and simple connectivity - allowing you to print large volume jobs from all of your devices. The PIXMA GM2010 is a perfect Wireless Single Function Printer with Refill Built-In Ink Tanks that can keep up with all of your home or office printing needs.
A printer with Refillable Built-In Tanks means Ink Savings
You no longer have to worry about constantly running out of ink or buying costly replacement ink cartridges. The Canon PIXMA GM2010 Wireless Single Function Printer is great for everyday printing needs, such as business reports but also high-volume printing needs, such as brochures and multi-page documents.
Built for Print Productivity.
Make the most of your time with the Canon Wireless Printer PIXMA GM2010. With a combined 350 sheet plain paper capacity, and up to 8,300 black text pages1 of ink included in the box, you can print efficiently without sacrificing quality. With high volume ink tanks and a low cost-per-page, the PIXMA GM2010 gives you the flexibility to print what you need.
Connect & Print Easily.
Connect to the PIXMA GM2010 from your smartphone & tablet with ease using the Canon PRINT app2. The PIXMA GM2010 Printer also has a simple and easy set up process which only takes a few minutes thanks to Canon Wireless Connect4.
-logo.jpg)
PIXMA GM2010 Printer with Refill Built-In Ink Tanks Features
- Canon G Series Printers have Integrated Ink Tanks that allow you to conveniently view and refill ink using the compatible GI-10 ink bottles. The GI-10 ink bottles feature a specialized nozzle designed to pour easily without spills or messes!
- With an impressive high page yield, print up to 8,300 Black text pages.1
- With a combined 350 sheet plain paper capacity, print large multi-page documents without needing to stop to reload paper. With the clear paper cassette window, easily see how much paper is loaded in the front paper cassette.
- Connect to the PIXMA GM2010 using the Canon PRINT app3 to print conveniently from your smartphone or tablet.
- The PIXMA GM2010 Printer uses pigment-based ink. The pigment-based black ink formulation allows for long lasting and sharp black text.
- Simply connect your printer to either a Wi-Fi™ network6 to print in minutes, or Ethernet to connect to a high-speed wired network.
- Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 8,300 (black) printed page yields are approximate, based off document pages printed. Black & White page yield based on Economy Print Mode.
- Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7.0 or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n/ac/ad capability as your printer. Requires a compatible social media account and is subject to that social media account's Terms of Service. Certain exceptions may apply.
- Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires a smart device with the Canon PRINT Inkjet/SELPHY app installed and connected to the desired active wireless network to complete cableless setup.
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Duty Cycle is defined as the maximum number of printed pages for a single peak month.
- Canon Print Service is a print plug-in for Android smart devices, which enables printing from Android v4.4 - v5.0 devices to many Canon printers via a Wi-Fi network. The plug-in does not work as a standalone app. Available for free at Google Play.
- Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
- Some functions may not be available with these Operating Systems. Please refer to the manual or website for details.
- PosterArtist Lite software v2.60.00 is compatible with 64/32 bit versions of Microsoft®; Windows®; 10, Windows 8.1, Windows 8, Windows 7 and Windows Vista®;, and only compatible with Canon PIXMA (released after July 2015), MAXIFY, imagePROGRAF and Océ printers. Minimum computer system requirements: Pentium4 2.4Ghz CPU or higher with 1GB RAM, 1024x768 pixel display and 5GB of system hard drive space.
| Print Speed Text | First Print Out Time: Black Document: Approx. 9 Seconds / Color Document: Approx. 14 Seconds5 |
| Print Speed Text | Black Document (Letter/Simplex): Approx. 13.0 Ipm5 |
| Print Speed Text | Color Document (Letter/Simplex): Approx. 6.8 Ipm5 |
| Nozzle Text | Color: 1,152 / Pigment Black: 640 / Total: 1,792 |
| Resolution Text | Up To 600 X 1200 Dpi6 |
| Ink Compatibility | INK TYPE GI-10 Pigment-Based Black Ink Ink Bottles & Fill Volume GI-10 Pigment-Black Ink Bottle: 170.0 Ml High Page Yield Up To 8,300 (Black & White) |
| Paper Sizes | Rear Tray: A4, A5, B5, LTR, LGL, Envelopes (DL, COM10), Card Size(91 X 55mm). Custom Size: Width 55mm - 215.9 Mm, Length 89mm - 676mm Cassette: A4, A5, B5, LTR. Custom Size: Width 148.0 Mm - 215.9 Mm, Length 210mm - 297mm |
| Automatic Sheet Feeder | Paper Capacity Front Paper Cassette: 250 Sheets Of Plain Paper Rear Paper Tray: 100 Sheets Of Plain Paper |
| Paper Compatibility | Plain: Plain Paper, Canon High Resolution Paper (A4 And LTR (HR-101N) |
| Print Features | Canon PRINT App2, Document Printing, Economy Mode Printing, High Page Yield, PIXMA Cloud Link2, Wireless Printing3, PosterArtist Lite |
| Other Features | Automatic Ink Detection, Auto Power On/Off, Canon PRINT App2, Canon Print Service8, Hybrid Ink System, Standard MIB (Management Information Base) Support, PIXMA Cloud Link2, Quiet Mode, Wireless Connect4, Access Point Mode |
| Os Compatibility | Windows:9 Windows® 10, Windows 8.1, Windows 7 SP1 Mobile Operating Systems:10 IOS®, Android™ |
| Standard Interface | Hi-Speed USB Wi-Fi®2 (802.11b/G/N Wireless Networking, 2.4 GHz)3 Ethernet (100/10 Base-T) |
| Optional Interface | 2 Line Full-Dot Matrix Display |
| Software Included | (WINDOWS9) PIXMA GM2010 Wireless Single Function Printer Driver PosterArtist Lite Software (Windows Only)11 Master Setup My Printer (Windows Only) Network Tool Quick Menu |
| Dimension W X D X H | 15.9" (W) X 14.6" (D) X 6.6" (H) |
| Weight | 14.3 Lbs. |
GI-10PGBK
Black Ink Bottle
170 ml
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
