PIXMA G5010
- PIXMA G5010 Wireless Inkjet Single Function Printer
- Setup CD, Manual, and other documentation
- Full Set of Ink Bottles (PGBK, C, M, Y)
- Black Print Head
- Color Print Head
- Power Cord
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Smart, Simple and Cost-effective printing with Refillable Built-In Tanks
The Canon PIXMA G5010 Wireless Single Function Printer is designed for those who need a high-volume printer for both documents and photos with a large paper capacity. The PIXMA G5010 Wireless Printer features a high page yield of up to 8,300 pages of black text or up to 7,700 vivid color pages1, a combined 350 sheet plain paper capacity, and simple connectivity - allowing you to print large volume jobs from all of your devices. The PIXMA G5010 is a perfect Wireless Single Function Printer that can keep up with all of your home or office printing needs.
A printer with Refillable Built-In Tanks means Ink Savings
You no longer have to worry about constantly running out of ink or buying costly replacement ink cartridges. The Canon PIXMA G5010 Wireless SFP is great for everyday printing needs, such as business reports and borderless photos but also high-volume printing needs, such as full-color flyers, brochures and multi-page documents.
Great Value from Refillable Built-In Tanks
Make the most of your time with the Canon PIXMA G5010. With a combined 350 sheet plain paper capacity, and up to 8,300 black text pages or 7,700 color pages1 of ink included in the box, you can print efficiently without sacrificing quality. With high volume ink tanks and a low cost-per-page, the PIXMA G5010 gives you the flexibility to print what you need.
Connect & Print Easily.
Connect to the PIXMA G5010 from your smartphone & tablet with ease using the Canon PRINT app3, AirPrint™4, and Mopria® Print Service5 via Wi-Fi®6. You can also use your Google Assistant7 or Alexa-enabled7 devices to check ink levels, review notifications and print hands-free. The PIXMA G5010 Printer also has a simple and easy set up process which only takes a few minutes thanks to Canon Wireless Connect8.
-logo.jpg)
PIXMA G5010 Printer with Refill Built-In Ink Tanks Features
- Canon G Series Printers have Integrated Ink Tanks that allow you to conveniently view and refill ink using the compatible GI-10 ink bottles. The GI-10 ink bottles feature a specialized nozzle designed to pour easily without spills or messes!
- With an impressive high page yield, print up to 8,300 Black text pages or 7,700 Color pages per each full ink bottle set.1
- Print beautiful borderless photos from 3.5" x 3.5" square to 8.5" x 11" letter size.8
- With a combined 350 sheet plain paper capacity, print large multi-page documents without needing to stop to reload paper. With the clear paper cassette window, easily see how much paper is loaded in the front paper cassette.
- Connect to the PIXMA G5010 using the Canon PRINT app3 to print conveniently from your smartphone or tablet. Even make a 'copy' using the smartphone copy feature in the app!
- Wirelessly print from smartphones and without downloading additional apps using AirPrint™4 from your iPhone™ or iPad™ and Mopria™ Print Service5 from your favorite Android devices!
- The PIXMA G5010 Printer uses both pigment-based and dye-based inks. The pigment-based black ink formulation allows for long lasting and sharp black text. The dye-based color ink formulation allows for rich and vibrant full-color images.
- Simply connect your printer to either a Wi-Fi™ network6 to print in minutes, or Ethernet to connect to a high-speed wired network.
- Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 8,300 (black)/7,700 (color) printed page yields are approximate, based off document pages printed. Black & White page yield based on Economy Print Mode.
- Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 8.5"x11".
- Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7.0 or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n/ac/ad capability as your printer. Requires a compatible social media account and is subject to that social media account's Terms of Service. Certain exceptions may apply.
- AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to Mac running MacOS X 10.9 or later supports AirPrint via USB connection. A printer connected to the USB port of your PC, AirPort Base station, or Time Capsule is not supported.
- Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
- Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires an active smart assistant account linked and accompanying app enabled, the smart device and printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and the required action(s), skill(s), or applet(s) available/enabled to the compatible printer. Voice commands cannot be displayed as text on Amazon smart devices with screens.
- Requires a smart device with the Canon PRINT Inkjet/SELPHY app installed and connected to the desired active wireless network to complete cableless setup.
- The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy-PhotoPrint Editor export data.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Requires an Internet connection and the Message In Print app (Version 1.1), available for free on the App Store and at Google Play. Compatible with iPad and iPhone 6 or later devices running iOS 10 or later, and Android mobile devices running Android 5.1 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n/ac/ad capability as your printer. Requires original content to be created using the Message In Print app/service, then printed on a compatible Canon Printer released in August 2009 or later and delivered to recipient, who views image and content through the compatible Message In Print app on their compatible device. Compatible paper sizes include 3.5"x x3.5", 4" x 4" Square, 4" x 6" and 5" x 5" Square only, and compatible media types include Genuine Canon Photo Paper Glossy, Photo Paper Semi-Gloss, Photo Paper Luster and Photo Paper Matte only. Certain exceptions may apply.
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Duty Cycle is defined as the maximum number of printed pages for a single peak month.
- DPS over IP compatible device required.
- Canon Print Service is a print plug-in for Android smart devices, which enables printing from Android v4.4 - v5.0 devices to many Canon printers via a Wi-Fi network. The plug-in does not work as a standalone app. Available for free at Google Play.
- Requires an active IFTTT account, the printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and an IFTTT 'applet' installed/enabled and required active account/service linked to the printer.
- Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
- Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
- Some functions may not be available with these Operating Systems. Please refer to the manual or website for details.
- Requires "Canon Print Plug-in" available for free from the Amazon Appstore and an Amazon Fire Phone, Amazon Kindle Fire HD6 or HDX7 device or later running Fire OS 4.0 or later.
- PosterArtist Lite software v2.60.00 is compatible with 64/32 bit versions of Microsoft®; Windows®; 10, Windows 8.1, Windows 8, Windows 7 and Windows Vista®;, and only compatible with Canon PIXMA (released after July 2015), MAXIFY, imagePROGRAF and Océ printers. Minimum computer system requirements: Pentium4 2.4Ghz CPU or higher with 1GB RAM, 1024x768 pixel display and 5GB of system hard drive space.
| Print Speed Text | First Print Out Time: Black Document: Approx. 9 Seconds / Color Document: Approx. 14 Seconds12 |
| Print Speed Text | 4" X 6" Borderless Photo (PP-201): Approx. 37 Seconds12 |
| Print Speed Text | Black Document (Letter/Simplex): Approx. 13.0 Ipm12 |
| Print Speed Text | Color Document (Letter/Simplex): Approx. 6.8 Ipm12 |
| Nozzle Text | Color: 1,152 / Pigment Black: 640 / Total: 1,792 |
| Resolution Text | Up To 4800 X 1200 Dpi13 |
| Ink Compatibility | INK TYPE GI-10 Pigment-Based Black Ink GI-10 Dye-Based Color Inks Ink Bottles & Fill Volume GI-10 Pigment-Black Ink Bottle: 170.0 Ml GI-10 Dye-Based Color Ink Bottles: 70.0 Ml High Page Yield Up To 8,300 (Black & White) / 7,700 (Color) Pages |
| Paper Sizes | 3.5" X 3.5", 4" X 4", 4" X 6", 5" X 5", 5" X 7", 7" X 10", 8" X 10", Letter (8.5"X11"), Legal (8.5"X14"), U.S. #10 Envelopes |
| Automatic Sheet Feeder | Paper Capacity Front Paper Cassette: 250 Sheets Of Plain Paper Rear Paper Tray: 100 Sheets Of Plain Paper OR 20 Sheets Of 4" X 6" / 10 Sheets Of 5" X 7" Photo Paper |
| Paper Compatibility | Plain: Plain Paper, Canon High Resolution Paper; Super High Gloss: Photo Paper Pro Platinum; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper; Other: Greeting Cards, Magnetic Photo Paper, Restickable Photo Paper, U.S. #10 Envelopes |
| Print Features | AirPrint4, Borderless Printing2, Canon PRINT App3, Document Printing, Economy Mode Printing, Easy-PhotoPrint Editor Software/App9, Google Cloud Print10, Greeting Card Printing, High Page Yield, Message In Print App11, Mopria Print Service5, Photo Printing, PIXMA Cloud Link3, Wireless Printing6 |
| Other Features | 4-Color Continuous Ink Supply System (CISS), Automatic Ink Detection, Auto Power On/Off, Canon PRINT App3, Canon Print Service16, Hybrid Ink System, Standard MIB (Management Information Base) Support, PIXMA Cloud Link3, Quiet Mode, Wireless Direct Connection, Wireless Connect8 |
| Os Compatibility | Windows:18 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:19 Mac OS® X V10.10.5 - MacOS V10.14 (Mojave) Mobile Operating Systems:20 IOS®, Android™, Windows 10 Mobile, And Fire OS (Amazon Fire) Devices21 |
| Standard Interface | Hi-Speed USB PictBridge / Wireless PictBridge15 Wi-Fi®3 (802.11b/G/N Wireless Networking, 2.4 GHz)6 Ethernet (100/10 Base-T) |
| Optional Interface | 2 Line Full-Dot Matrix Display |
| Software Included | (WINDOWS18/MAC19) PIXMA G5010 Wireless MegaTank Single Function Printer Driver Easy-PhotoPrint Editor Software9 PosterArtist Lite Software (Windows Only)22 Master Setup My Printer (Windows Only) Network Tool Quick Menu |
| Dimension W X D X H | 15.9" (W) X 14.6" (D) X 6.6" (H) |
| Weight | 14.3 Lbs. |
GI-10Y
Yellow Ink Bottle
70ml
GI-10M
Magenta Ink Bottle
70ml
GI-10PGBK
Black Ink Bottle
170 ml
GI-10C
Cyan Ink Bottle
70ml
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
