PIXMA E481
- E481 Wireless Office All-In-One Printer
- Power Cord
- Ink Tanks
- Setup CD-ROM
- Telephone Line Cable
- Manuals and other documents
- Office Application Insert
- CLA Contact Sheet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- ISO/IEC 24734, 29183 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 29183 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 29183, excluding time to copy the first set.
- Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, type of paper used, and page coverage.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- Envelopes and High Resolution Paper are NOT supported for borderless printing.
- For network users, Auto Scan Mode is only available when scanning at a computer using MP Navigator EX software and selecting the 1-click feature then “Save to PC.”
- To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks and all of the software that came with the printer are properly installed.
- “Full HD Movie Print” is available from “MOV” and “MP4” movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for “MOV” files, or Canon ImageBrowser EX 1.0 or later for “MOV” or “MP4” files. Print quality is determined by the video resolution. Function does not upscale video resolution.
- Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires an Internet connection and the PIXMA Printing Solutions (“PPS”) app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 5.1 or later, and Android mobile devices running Android 2.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- PIXMA Cloud Link requires an Internet connection.
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed may vary depending on document complexity, fax setting at receiving end, and line conditions etc.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
- System requirements vary by application. Operation can only be guaranteed on a PC with factory-installed Windows 8.1, Windows 8, Windows 7, Windows Vista or XP. For Mac OS, an Internet connection is required during software installation. For Windows OS, .NET Framework 4 is required to install My Image Garden, Quick Menu, and Easy-WebPrint EX software.
- Easy-WebPrint EX requires Internet Explorer 7 or 8 for Windows, Internet Explorer 9 or 10 for Windows Vista SP2 (or later) or Windows 7.
- ADF holds up to 20 sheets A4/LTR, or up to 5 sheets of LGL plain paper.
| Print Speed Text | 4" X 6" Borderless Photo: Approx. 70 Seconds2,3 |
| Print Speed Choice | Black |
| Print Speed Text | ESAT: Approx. 8.8 Ipm2,3 |
| Print Speed Choice | Color |
| Print Speed Text | ESAT: Approx. 4.4 Ipm2,3 |
| Nozzle Text | Color: 960 / Pigment Black: 320 / Total: 1,280 |
| Picoliter Size | 2 And 5 |
| Resolution Color Choice | Color |
| Resolution Text | Up To 4800 X 1200 Dpi1 |
| Resolution Color Choice | Black |
| Resolution Text | Up To 600 X 600 Dpi1 |
| Ink Compatibility | PG-44XL XL Black Ink Cartridge PG-44 Black Ink Cartridge CL-54XL XL Color Ink Cartridge CL-54 Color Ink Cartridge |
| Paper Sizes | A4, A5, B5, 10 X 15cm (4” X 6”), 13 X 18cm (5” X 7”), 8” X 10” (20 X 25cm) Letter, Legal, U.S. #10 Envelopes |
| Automatic Sheet Feeder | 100 Sheets ADF20: 20 Sheets |
| Paper Compatibility | Plain: Plain Paper, High Resolution Paper; Super High Gloss: Photo Paper Pro Platinum; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Matte: Matte Photo Paper; |
| Print Features | AirPrint13, Borderless Printing5, Document Printing, Full HD Movie Print9, Special Filters, Google Cloud Print14, My Image Garden7, Photo Printing, PIXMA Printing Solutions11, Template Print, Quiet Mode, Wireless Printing10,Pixma Cloud Link12, Creative Park Premium8 |
| Mono Copy Speed Up To | ESAT: Color: 3.6 Ipm2 |
| Reductions Enlargement | 25% - 400% |
| Copy Feature | Auto Document Feeder (ADF), AE (Auto Exposure) Copy, Borderless Copy, Collated Copy, 2-On-1 Copy, 4-On-1 Copy, Fit-To-Page, Preset Copy Ratios, Frame Erase Copy (Flatbed), Zoom |
| Scanning Element | Contact Image Sensor (CIS) |
| Max Resolution Text | 1200 X 2400 Dpi (Optical)4 |
| Max Resolution Text | 19,200 X 19,200 Dpi (Interpolated)4 |
| Max Resolution Text | ADF: 600 X 600 Dpi (Optical)4 |
| Scanner Features | Auto Scan Mode6, Network Scan, PDF Password Security, Push Scan, Send To Cloud |
| Color Depth | 48-Bit Internal/24-Bit External |
| Max Document Size | Flatbed: 8.5” X 11” (21.6 X 27.94cm) ADF: 88.5” X 14” (21.6 X 35.56cm) |
| Modem Speed | 33.6 Kbps (Super G3 Color FAX)15 |
| Transmission Speed Approx | Black: Approx. 3 Sec Per Page16 Color: Approx. 1 Min Per Page16 |
| Transmission Reception Memory | Approx. 50 Pages17 |
| Group Dialing | 19 Locations |
| Fax Features | Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Extra Fine Mode, Fax Reception Reject, Fax Num¬Ber Re-Entry, Memory Transmission, Redial, Remote Reception |
| Other Features | Full Dot Matrix LCD, Access Point Mode, Auto Power Off, Dual Color Gamut Processing Technology, Fully Integrated Auto Document Feeder (ADF), Quiet Mode, Wireless Printing10 |
| Os Compatibility | Computer Operating Systems: Windows® 8, Windows 8.1, Windows 7,18 Windows 7 SP1, Window Vista SP1, Vista SP2, Windows XP SP3 32-Bit18 Mac OS X V10.7.5 - V10.1018 Mobile Operating Systems: IOS, Android, |
| Standard Interface | Wireless LAN (IEEE 802.11b/G/N)10 Hi-Speed USB |
| Dimension W X D X H | 17.2" (W) X 11.7" (D) X 7.5" (H) |
| Weight | 17.2 Lbs. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
