PIXMA E201
- PIXMA E201 Inkjet Printer
- Setup CD-ROM
- Full Set of Ink Cartridges (PG-44/CL-54)
- Power Cord (USB cable not included)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
SIMPLE AFFORDABLE PRINTING
Meet the PIXMA E201 Inkjet Printer - your simple printing solution. With a Rear Paper Tray and a FINE Hybrid Ink System, the PIXMA E201 is a great compact printing solution for all your documents. The PIXMA E201 is also compatible with XL ink cartridges - which can help save you money, print more when you need to, and extend the time between replacing ink cartridges.
PIXMA E201 Inkjet Printer Features
- Quickly refill paper with the dedicated Rear Paper Tray.
- FINE Hybrid Ink System for detailed documents and photos.
- With Auto Power On/Off your printer will turn on when you need it and off when you don’t.
- Use Quiet Mode to reduce printer noise when you are worried about disturbing others.
- Scan and copy documents with Smartphone Copy using the Canon PRINT app3.
- Print quickly and easily with High Speed USB.
- Print 4"x6" Borderless Photos with ease.1
- With a great Compact Size the PIXMA E201 fits almost anywhere.
- The PIXMA E201 is an Energy Star® certified printer.
Your Simple Printing Solution
With a Rear Paper Tray and a FINE Hybrid Ink System, the E201 is a great, compact printing solution for all your documents.
- Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer, and Photo Stickers. The maximum borderless printing size is 4"x6".
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
- Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
- "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files. Print quality is determined by the video resolution.Function does not upscale video resolution.
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks and all of the software that came with the printer are properly installed.
- Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
- To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
| Print Speed Text | 10 X 15 Cm (4" X 6") Photo: Approx. 65 Seconds (Borderless)2 |
| Print Speed Choice | Black |
| Print Speed Text | ESAT: Approx. 7.7 Ipm2 |
| Print Speed Choice | Color |
| Print Speed Text | ESAT: Approx. 4.0 Ipm2 |
| Nozzle Text | Color: 960 / Pigment Black: 320 / Total: 1,280 |
| Resolution Text | Up To 4800 X 1200 Dpi3 |
| Ink Compatibility | INK TYPE PG-44BK/PG-44XL: Pigment Black Ink CL-54/CL-54XL Dye Based Inks INK TANK & FILL VOLUME PG-44 BK (5.6 Ml Std. | (15.0 Ml) XL CL-54 Color (6.2 Ml) Std. | (12.6 Ml) XL |
| Paper Sizes |
| Paper Compatibility | Plain: Plain Paper Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; |
| Print Features | Borderless Printing (Up To 4"X6" / 10 X 15 Cm)1, Document Printing, Photo Printing, Single Sided Printing |
| Output Tray Capacity | Rear Paper Tray: 60 Sheets Of Plain Paper OR 20 4" X 6" (10 X 15 Cm) Letter |
| Other Features | Auto Power On/Off, CREATIVE PARK PREMIUM6, FINE (Full-Photolithography Inkjet Nozzle Engineering) Hybrid Ink System, Energy Star® Certified, Quiet Mode, 4-Color Cartridge System |
| Os Compatibility | Windows:7 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:4 Mac OS® X V10.10.5 - MacOS V10.12 (Sierra) |
| Standard Interface | Hi-Speed USB |
| Software Included | (WINDOWS/MAC) PIXMA E201 Inkjet Printer Driver Master Setup CD-ROM My Image Garden7 (Creative Filters, Full HD Movie Print5, Image Cropping, Red-Eye Correction, Image Correction/Enhance, And Scanning Are Accessed Through My Image Garden) Quick Menu |
| Dimension W X D X H | 42.6cm (W) X 25.5cm (D) X 13.1cm (H) |
| Weight | 6.4 Lbs. / 2.5kg |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
