MAXIFY MB5110
- MAXIFY MB5110 Wireless Small Office All-In-One Printer
- Setup CD-ROM
- Full Set of Ink Tanks
- Power Cord
- Telephone Line Cable
- USB Cable
- CLA Contact Information Sheet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Document print speeds are the averages of FPOT in Office Category Test for the default simplex mode, ISO/IEC17629:2014. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. During successive printing, the printer may slow down the operation to prevent the internal temperature from rising. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc., and does not take into account warming up time. When scanning or copying a certain volume of documents (approx. 150 sheets in default settings) continuously from the ADF the printer may switch to “waiting mode“ in which paper feeding stops for several tens of seconds after each scan to prohibit overheating the ADF.
- Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7.0 or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Duty Cycle is defined as the maximum number of printed pages for a single peak month.
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA/MAXIFY printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/600 inch at minimum.
- ADF scan speeds are the average of scESAT30secA in "ADF Productivity Measurement" test, ISO/IEC 17991:2015. Scan to network folder speeds with ADF are the average of scEFTP30secF in "Scan to Network Folder Productivity Measurement" test, ISO/IEC 17991:2015. ADF scan speeds/Scan to network folder speeds with ADF will vary depending on system configuration, interface, software, document complexity etc. When scanning or copying a certain volume of documents (Approx. 150 sheets in default settings) continuously from the ADF, the printer may switch to "waiting mode" in which paper feeding stops for several tens of seconds after each scan to prohibit overheating the ADF.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed varies depending on document complexity, fax setting at receiving end, and line conditions etc.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1. The number of pages able to be kept in memory will vary based on remaining memory capacity and document complexity.
- Requires an Internet connection.
- Acoustic Noise is measured based on ISO7779 standard.
- Operation can only be guaranteed on a PC with factory-installed Windows 10, Windows 8.1, Windows 8, Windows 7, Windows Vista or XP.
- Available from printer driver and fax driver only. XPS drive is not supported for Windows Server 2003 and 2003 R2.
- Internet Connection required during software installation.
- Some functions may not be available with these Operating Systems. Please refer to the manual or our website for full details.
- Requires a Windows RT compatible device with Windows 10, Windows 8.1 or Windows 8 and the Canon Easy-PhotoPrint app for Windows RT available for free in the Windows Store.
- PosterArtist Lite Software Disclaimer Only Available for download (Available on 64 and 32 bit versions of Microsoft Windows 10, Windows 8 and 8.1, Windows 7 and Windows Vista)
| Print Speed Text | FPOT (Black): 6 Seconds --- ESAT (Black): 24.0 Ipm1 |
| Print Speed Text | FPOT (Color): 7 Seconds --- ESAT (Color): 15.5 Ipm1 |
| Nozzle Text | Pigment Black: 1,280 / Color: 3,072 / Total: 4,352 |
| Resolution Text | Up To 600 X 1200 Dpi8 |
| Ink Compatibility | PGI-2100 Black - 29.1 Ml (Std) / 70.9 Ml (XL) PGI-2100 Cyan - 9.6 Ml (Std) / 19.3 Ml (XL) PGI-2100 Magenta - 9.6 Ml (Std) / 19.3 Ml (XL) PGI-2100 Yellow - 9.6 Ml (Std) / 19.3 Ml (XL) Up To 2,500 Black & White / 1,500 Color Pages When Using XL Ink Tanks. |
| Paper Sizes | A4, A5, B5, 4" X 6", 5" X 7", 8" X 10", Letter, Legal, U.S. #10 Envelopes |
| Print Features | 3.5” Touch LCD, AirPrint5, Auto 2-Sided Printing, Advanced Auto Sheet Feeder, Canon PRINT App3, Document Printing, Google Cloud Print6, Microsoft Mobile Print, Mopria Device Printing7, Quick Toolbox, Wireless Printing2 |
| Output Tray Capacity | Upper Cassette: 250 Sheets Plain Paper (Letter Or Legal) Or 20 Sheets Photo Paper 4" X 6" |
| Noise Level Approx | Approx. 56.0 DB(A)15 |
| Mono Copy Speed Up To | FCOT (Color): Approx. 11 Seconds1 |
| Reductions Enlargement | 25% - 400% |
| Copy Feature | Single Pass 2-Sided Copying, 2-On-1 Copy, 4-On-1 Copy, ID Card Copy, AE (Auto Exposure / Intensity) Copy, Collated Copy (ADF Only), Fit-To-Page, Frame Erase Copy (Flatbed), Preset Copy Ratios, Preview, Standard Copy, Zoom |
| Scanning Element | Contact Image Sensor (CIS) |
| Max Resolution Text | Optical: ADF & Flatbed: 1200 X 1200 Dpi10 |
| Max Resolution Text | Interpolated: 19,200 X 19,200 Dpi10 |
| Scanner Features | Single Pass 2-Sided Scanning, Push Scan, Scan To Memory (USB Flash Memory), Network Scan, Scan To Cloud, Scan To Email, Scan To Network Folder Scanner Speed: ESAT (Black): 19.0 Ipm9 ESAT (Color): 16.0 Ipm9 |
| Color Depth | 48-Bit Internal/24-Bit External |
| Max Document Size | Flatbed: 8.5" X 11" (Letter), A4; ADF - 50 Sheet Capacity ADF: 8.5" X 14" (Legal); ADF - 10 Sheet Capacity |
| Modem Speed | 33.6 Kbps (Super G3 Color FAX)11 |
| Transmission Speed Approx | Black: Approx. 3 Sec. Per Page12 Color: Approx. 1 Min. Per Page12 |
| Transmission Reception Memory | Approx. 250 Pages13 |
| Speed Dialing | 100 Locations |
| Fax Features | Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double-Sided Printing (Fax Images), FAX To Network Folder, Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry), Memory Transmission, Redial, Remote Reception |
| Other Features | Custom Profiles, 3.5" Touch LCD, Folder Setting Utility, Single Pass 2-Sided ADF, High Page Yield, Job Reservation, Low Cost Per Page Printing, Quick First Print, MAXIFY Cloud Link14, Quiet Mode, Standard MIB Support, SNMP Support, Records Of Use, Remote UI, Up To 30,000 Pages4, Auto Power On, Schedule On/Off |
| Os Compatibility | Computer Operating Systems: Windows:16,17 Windows® 10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista® SP1, Vista SP2, Windows Server® 2012, 2012 R217, Windows Server® 2008, 2008 R217 Mac:18 Mac OS® X V10.8.5 - 10.11 Mobile Operating Systems:19 IOS®, Android, Windows RT20 And Windows 10 Mobile |
| Standard Interface | Wireless LAN (IEEE 802.11b/G/N)2 Ethernet USB Flash Memory Hi-Speed USB |
| Software Included | WINDOWS16,17/MAC18 MAXIFY MB5110 Printer Driver Master Setup PosterArtist Lite21 (Windows Only) Scan Utility My Printer (Windows Only) Network Tool Speed Dial Utility |
| Power Consumption Approx | 25.0W Copying (0.9W Standby) |
| Dimension W X D X H | 18.3” (W) X 18.1” (D) X 11.5” (H) |
| Weight | 25.0 Lbs. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
