MAXIFY MB2010
- MAXIFY MB2010 Wireless Home Office All-In-One
- Setup CD-ROM
- Setup Ink Tanks
- Power Cord
- Telephone Line Cable
- CLA Contact Information Sheet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Requires an Internet connection and the PIXMA/MAXIFY Printing Solutions ("PPS") app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 5.1 or later, and Android mobile devices running Android 2.3 or later. User must register printer with PPS and be a registered member of the compatible online Cloud service(s) user chooses to access through PPS and is subject to the terms and conditions of those services. Certain functions (scanning and printing locally stored photos/documents) require your device to be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Duty Cycle is defined as the maximum number of printed pages for a single peak month.
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- ISO/IEC 24734, 24735 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 24735 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 24735, excluding time to copy the first set.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/600 inch at minimum.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed vary depending on document complexity, fax setting at receiving end, and line conditions etc.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
- Requires Canon Easy-PhotoPrint for Windows RT, available for free in the Windows Store. Compatible with Windows RT devices.
- Requires an Internet connection.
- Operation can only be guaranteed on a PC with factory-installed Windows 8.1, Windows 8, Windows 7, Windows Vista or XP.
- Available from printer driver and fax driver only. XPS drive is not supported for Windows Server 2003 and 2003 R2.
- Internet Connection required during software installation.
- During successive printing, the printer may slow down the operation to prevent the internal temperature from rising.
| Print Speed Choice | Black |
| Print Speed Text | Esat: Approx. 16.0 Ipm6 , 17 |
| Print Speed Choice | Color |
| Print Speed Text | Esat: Approx. 11.0 Ipm6 , 17 |
| Nozzle Text | Color: 3,072 / Pigment Black: 1,280 / Total: 4,352 |
| Resolution Text | Up To 600 X 1200 Dpi7 |
| Ink Compatibility | Pgi-1100 Bk Xl Pgi-1100 C Xl Pgi-1100 M Xl Pgi-1100 Y Xl Pgi-1100 C Pgi-1100 M Pgi-1100 Y Pgi-1100 Bk |
| Paper Sizes | 4" X 6", 5" X 7", 8" X 10", Letter, Legal, U.S. #10 Envelopes |
| Paper Compatibility | Plain: Plain Paper, High Resolution Paper; Glossy: Photo Paper Plus Glossy Ii, Photo Paper Glossy; Matte: Matte Photo Paper; Envelope: U.S.# 10 Envelope |
| Print Features | 2.5" Lcd, Airprint,3 Auto 2-Sided Printing, Advanced Auto Sheet Feeder, Document Printing, Google Cloud Print,4 Maxify Printing Solutions,1 Quick Toolbox, Web Template Print, Wireless Printing5 |
| Output Tray Capacity | Cassette: 250 Sheets Plain Paper (Letter Or Legal) Or 20 Sheets Photo Paper 4" X 6" |
| Mono Copy Speed Up To | Fcot(Color): Approx. 13 Seconds6 |
| Reductions Enlargement | 25% - 400% |
| Copy Feature | 2-On-1 Copy, 4-On-1 Copy, Ae (Auto Exposure / Intensity) Copy, Collated Copy (Adf Only), Frame Erase Copy, Fit-To-Page, Preset Copy Ratios, Preset Copy, Preview, Standard Copy, Zoom |
| Scanning Element | Contact Image Sensor (Cis) |
| Max Resolution Choice | Optical |
| Max Resolution Text | Flatbed: 1200 X 1200 Dpi8 Adf: 1200 X 1200 Dpi8 |
| Max Resolution Choice | Interpolated |
| Max Resolution Text | 19,200 X 19,200 Dpi8 |
| Scanner Features | Push Scan, Scan To Memory (Usb Flash Memory),Scan To Email, Scan Solution, Scan To Cloud, Scan To Network Folder |
| Color Depth | 48-Bit Internal/24-Bit External |
| Max Document Size | Flatbed: 8.5" X 11.7" Adf: 8.5" X 14" |
| Modem Speed | 33.6 Kbps (Super G3 Color Fax)9 |
| Transmission Speed Approx | Black: Approx. 3 Sec. Per Page10 Color: Approx. 1 Min. Per Page10 |
| Transmission Reception Memory | Approx. 250 Pages11 |
| Speed Dialing | 100 Locations |
| Fax Features | Answering Machine Connectivity, Caller Rejection, Check Rx Fax Info., Dial Search, Double Sided Printing (Fax Images), Fax To Network Folder, Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, F/T Changing (Manual), Memory Transmission, Redial, Remote Reception |
| Other Features | Airprint,3 Custom Profiles, Google Cloud Print,4 Wireless Printing,5 2.5" Lcd, Folder Setting Utility, Highlighter And Smudge Resistant Ink, High Page Yield, Job Reservation, Low Cost Per Page Printing, Mobile Device Printing,12 15,000 Page Duty Cycle, 2 Quick First Print, Maxify Cloud Link13 |
| Os Compatibility | Windows:14 Windows® 8, Windows 8.1 Windows 7, Windows 7 Sp1 Windows Vista® Sp1, Vista Sp2 Windows Xp Sp3 32-Bit Windows Server 2012, 2012 R215 Windows Server 2008, 2008 R215 Windows Server 2003, 2003 R215 Mac: 16 Mac Os® X V10.6.8 - 10.9 Mobile Operating Systems: Ios®, Android™, Windows Rt |
| Standard Interface | Wireless Lan (Ieee 802.11b/G/N)5 Usb Flash Memory Hi-Speed Usb |
| Dimension W X D X H | 18.3" (W) X 18.1" (D) X 10.3" (H) |
| Weight | 23.4 Lbs. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
