MAXIFY GX6010
- MAXIFY GX6010 Wireless Business All-in-One Printer
- Set of Ink Bottles (GI-16: BK, C, M, Y)
- Documentation
- Power Cord
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
A refillable ink tank printer for businesses that packs a heavyweight performance and excellent maintainability. Designed to meet the needs of small and medium size offices, the MAXIFY GX6010 delivers high-quality, low-cost printing, fast speed, and outstanding wireless connectivity. Get serious print productivity with a high page yield of up to 9,000 Black / 21,000 Color pages in economy mode per full ink bottle set7, and a combined 350 sheet plain paper capacity.
Ease of mind with less need for repairs due to a print head and a maintenance cartridge that are easy to replace by users in the comfort of their offices.
The MAXIFY GX6010 is easy to setup and maintain, and delivers superior versatility thanks to an auto document feeder for scanning, and copying — plus, print on a variety of media types and sizes, including labels, envelopes, and banners. Produce crisp, colorful documents quickly and cost-effectively thanks to fast print speeds and a 4-color pigment-based ink system. Connectivity is paramount with the GX6010, easily connect and print through high-speed USB, Ethernet, or wirelessly1 from computers or mobile devices.
- PRINT, COPY, and SCAN with the MAXIFY GX6010 All-in-One Printer.
- HIGH PAGE YIELD: Print up to 9,000 Black / 21,000 Color pages on just a single set of inks in economy mode.7
- HIGH-SPEED PRINTING9 of up to 45 ppm in Black and 25 ppm in Color, so you can respond as quickly as your business needs require.
- EXCELLENT MAINTAINABILITY with a print head and a maintenance cartridge that are easy to replace by end users.
- Get SHARP TEXT AND DOCUMENTS thanks to a 4 COLOR Pigment-Based ink system, including highlighter resistant text.
- Easy to use intuitive user interface on a 2.7” COLOR LCD TOUCHSCREEN.
- HIGH PAPER CAPACITY: Hold up 350 Sheets of plain paper thanks to a 250-Sheet bottom cassette and a 100-Sheet rear tray.
- Copy and scan multi-page documents fast and easy with the 50-Sheet AUTO DOCUMENT FEEDER!
- VERSATILE MEDIA SUPPORT – print on matte paper, envelopes, business cards, banners and more!
- EASY TO FILL with Keyed Bottle shape for each color to only fit and fill the correct ink tank.
- EASY SETUP for smartphone and computer so you can get to work faster.
- Easy Wi-Fi® setup with WIRELESS CONNECT. Connect to Wi-Fi® without the need for a computer.1
- MOBILE PRINTING: Print from your favorite mobile devices using the Canon PRINT app2, Apple AirPrint®3, and Mopria®4.
- Built-In ETHERNET connection for Wired LAN support.
- Print directly from a USB FLASH DRIVE reader.5
- Built-to last with a MONTHLY DUTY CYCLE of up to 45,000 pages!6
- STAY WASTE-CONSCIOUS. Thanks to high page yield ink bottles, keep waste and time spent refilling ink to a minimum.
- Packed with features in a SMALL FOOTPRINT to fit your workspace.
MAXIFY GX6010 Wireless Small Office All-in-One Printer
High volume, low-cost printing for small and medium size offices has arrived for next level MAXIFY productivity. Print more for less with MAXIFY!
High Page Yield
Print up to 9,000 Black / 21,000 Color pages with just a single set of inks in economy mode.7
350-Sheet Plain Paper Capacity
Load up to 250-Sheets of plain paper in the bottom cassette and another 100-Sheets of plain paper in the rear tray.
50-Sheet Auto Document Feeder (ADF)
Scan multi-page documents with ease with the 50-Sheet Auto Document Feeder (ADF).
Fast Print Speeds
Get the job done quickly with fast print speeds of up to 45 ppm in Black and 25 ppm in Color. 9
Media Versatility
Print business cards, menus, banners, signs, envelopes, and more! The MAXIFY GX6010 can print on a wide variety of media types and sizes including the ability to print up to 47” in length.
Sharp Text Documents
With a 4-Color Pigment Ink System you’ll get crisp color and black & white documents along with sharp highlighter resistant text.
Built to Last
Get the job done during those busy months with a monthly duty cycle of up to 45,000 pages.6
Stay Waste-Conscious
Replaceable Maintenance Cartridge & Print Heads
Both the print heads and maintenance cartridge in the MAXIFY GX6010 are easily replaceable should the need arise. No service visits or calls required!
Easy to Fill
The MAXIFY GX6010 uses ink bottles with a “keyed nozzle” design that can only be placed into the correct color tank. Once inserted, ink will flow automatically until the tank is full— no squeezing needed!
Easy Setup & Wireless Connect2
Get running quickly thanks to a streamlined and easy setup process out of the box. Setting up Wi-Fi®8 is just as simple with Wireless Connect2, allowing you to set up Wi-Fi® without a computer.
2.7” LCD Touchscreen
The MAXIFY GX6010 is easy to use thanks to an intuitive and easy to view 2.7” LCD Touchscreen.
Small Footprint
Not only is the MAXIFY GX6010 packed with features, it’s also designed small to fit your workspace.
Easy-PhotoPrint Editor
Take advantage of Canon’s free software to edit photos, size photos, or even create collages with the Easy-PhotoPrint Editor app.16
Mobile Device Options
Print from your favorite mobile devices using Apple AirPrint®3, Mopria® Print Service4, and the free Canon PRINT app.8
1. Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz or 5.0GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
2. Requires a smart device with the Canon PRINT Inkjet/SELPHY app installed and connected to the desired active wireless network to complete cableless setup.
3. AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
4. Requires Android™ mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria experience is also available on Android 4.4 or later mobile devices with a download of the Mopria Print Service from Google Play.
5. Supported file formats include: JPEG, TIFF and PDF.
6. Duty Cycle is defined as the maximum number of printed pages for a single peak month. Recommended monthly print volume is the number of printed pages per month within the stated range for optimum device performance based on several factors.
7. Page Yield of 21,000 pages in Color and 9,000 in black and white is based on Economy Print Mode. Page yield in standard mode corresponds to 14,000 pages in color and 6,000 pages in black and white. The economy mode reduces the ink consumption by lowering the density. 50% more pages can be printed by using this mode. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Actual page yield and cost per print will vary significantly based on content printed, ink levels maintained in all four ink reservoirs, and other factors. Page yield is the estimated value based on Canon individual testing method using ISO/IEC 24712 test chart and continuous printing simulation with full set of replacement ink bottles after initial setup.
8. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 12.0 or later, and Android™ mobile devices running Android 4.4 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. Requires a compatible social media account and is subject to that social media account's Terms of Service. Certain exceptions may apply.
9. PPM print speed is based on the highest speed settings using certain Canon standard patterns on A4 plain paper. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. ESAT print speed in B&W is approx. 24 ipm, in color is approx. 15.5 ipm. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time.
10. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
11. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
12. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
13. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
14. Some functions may not be available with these Operating Systems. Please refer to manual for details.
15. Requires an active smart assistant account linked and accompanying app enabled, the smart device and printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and the required action(s), skill(s), or applet(s) available/enabled to the compatible printer. Voice commands can not be displayed as text on Amazon smart devices with screens.
16. The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy-PhotoPrint Editor export data.
17. Canon Print Service is a print plug-in for Android smart devices, which enables printing from Android v4.4 - v5.0 devices to many Canon printers via a Wi-Fi network. The plug-in does not work as a standalone app. Available for free at Google Play.
18. Requires an Internet connection and the Creative Park app, available for free on the App Store and at Google Play. Requires an active 'Canon ID' available for free, and subject to 'Canon ID' Terms of Service.
19. PosterArtist Lite software v3.X is compatible with 64/32 bit versions of Microsoft® Windows® 10, Windows 8.1, Windows 7 and only compatible with select Canon PIXMA (released after July 2015), MAXIFY, imagePROGRAF and Océ printers. Minimum computer system requirements: Pentium4 2.8Ghz CPU or higher with 1GB RAM, 1024x768 pixel display and 5GB of system hard drive space.
20. Reference value based on Canon original methodology, not the product life cycle. Continuous A4 size printing on plain paper with 4-pages WORD file from ISO/IEC 24734. Depending on the printing environment and process, this may varies. It might require the replacement parts.
21. Canon cannot provide technical support for problems related to Linux driver.
| Print Speed Choice | Black | ||||
| Print Speed Text | 45.0 Ppm1 FPOT (Black): 7 Seconds - ESAT (Black): 24.0 Ipm1 |
| Print Speed Choice | Color | ||||
| Print Speed Text | 25.0ppm1 FPOT (Color): 8 Seconds - ESAT (Color): 15.5 Ipm1 |
| Nozzle Text | Total 4,352 Nozzles (BK: 1,280 Nozzles, C/M/Y: 1,024 Nozzles) | ||||
| Resolution Text | Up To 600 X 1200 Dpi10 | ||||
| Ink Compatibility | GI-16 Black GI-16 Cyan GI-16 Magenta GI-16 Yellow
| Paper Sizes | A4, A5, A6, B5, LTR, LGL, B-Oficio, M-Oficio, Foolscap, FS, Executive, #10 Envelope, DL Envelope, C5 Envelope, Monarch Envelope, 4” X 6”, 5” X 7”, 7” X 10”, 8” X 10”, Square (127 Mm X 127 Mm), Custom Size (Width: 89 Mm - 216 Mm, Length: 127 Mm - 1,200 Mm) | ||||
| Automatic Sheet Feeder | A4, LTR, LGL | ||||
| Paper Compatibility | Plain: Plain Paper, High Resolution Paper Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster Matte: Matte Photo Paper Other: Envelope, Magnetic Photo Paper, Removable Photo Stickers, Restickable Photo Paper, Greeting Card, Business Card, Photo Stickers, Light Fabric Iron On Transfers, Double Sided Matte Paper |
| Output Tray Capacity | Total Paper Capacity: 350 Sheets Plain Paper Bottom Cassette: 250 Sheets Plain Paper Rear Tray: 100 Sheets Plain Paper |
| Noise Level Approx | Approx. 49.0 DB(A) | ||||
| Mono Copy Speed Up To | FCOT (Color/Simplex): Approx. 12 Seconds9 | ||||
| Copy Size | A4 / LTR | ||||
| Copy Feature | 4-On-1 / 2-On-1 Copy, Document Copy, Fit-To-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Multiple Copy (Up To 99 Pages), Photo Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Standard Copy | ||||
| Scanner Type | Flatbed & ADF (Auto Document Feeder) | ||||
| Scanning Element | Contact Image Sensor (CIS) | ||||
| Max Resolution Choice | Optical | ||||
| Max Resolution Text | 1200 X 1200 Dpi (Optical)11 | ||||
| Scanner Features | Single Sided (Simplex) Scanning, Save To PC, Attach To E-Mail, Multi-Page PDF, Save To USB Flash Drive, Unsharp Mask, Descreen, Reduce Slow-Through, Rescan, Rotate, Auto Crop, Scan To Folder | ||||
| Color Depth | Grayscale: 16-Bit/8-Bit Color: 16-Bit/8-Bit (Per Color) |
| Max Document Size | Flatbed: A4 / LTR (216 Mm X 297 Mm) ADF: A4 / LTR / LGL |
| Other Features | Auto Power On/Off, Print/Scan/Copy, Quiet Mode, Wireless Direct Connection, Wireless Connect2, Auto Paper Width Detection, Energy Star® Certified, User Replaceable Print Head, User Replaceable Maintenance Cartridge, Pigment Ink For All Colors, Automatic Ink Detection, Canon PRINT App8, Quiet Mode, Smart Assistance & Automation Support18 (Amazon Alexa, Google Assistant) | ||||
| Os Compatibility | Windows:12 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:13 MacOS V10.12.6 -10.15 (Catalina) Linux:21 Fedora, Ubuntu (Distribution) Mobile Operating Systems:14 IOS®, IPadOS, Android™, Chrome OS |
| Standard Interface | Hi-Speed USB Wi-Fi® (Wireless LAN, 2.4/5 GHz, IEEE 802.11a/B/G/N)1 Wired LAN (100BASE-TX) / 10BASE-T) |
| Software Included | Printer Driver, Easy-PhotoPrint Editor Sofware16, PosterArtist Lite Software19 | ||||
| Power Consumption Approx | 23.0W Copying (0.9W Standby) | ||||
| Dimension W X D X H | 16.2" (W) X 15.8" (D) X 10.0" (H) | ||||
| Weight | 25.6 Lbs |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
