IVY 2 Mini Photo Printer
- Turn your favorite memories in your smartphone into personalized photo stickers via the Canon Mini Print App with the compact mini photo printer that fits in your pocket!
- No ink needed! The IVY 2 Mini Photo Printer uses ZINK™ (Zero Ink) technology.
- Get creative! Decorate your world with the sticky back ZINK photo paper.
- Canon IVY 2 Mini Photo Printer
- ZINK™ Photo Paper Pack (10 Sheets & 1 SMART SHEET™)
- USB Charging Cable (USB A to USB C)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
QUALITY PRINTS FOR THE WILDLY CREATIVE
SHOWCASE THE MEMORIES THAT LIGHT UP YOUR LIFE
Be unapologetically you. Turn your favorite memories into personalized stickers with the compact mini photo printer that fits in your pocket! With the IVY 2 Mini Photo Printer choose a photo from your camera roll, customize it in our free and easy-to-use app, and print it instantly.
QUALITY THAT SHINES
We’re not saying that quality prints make your memories better–but we’re not NOT saying that. We worked hard to make sure that the IVY 2 Mini Photo Printer delivers even higher quality prints that bring your memories to life.
LED LIGHT PARTY
Bring the party to your print experience with The IVY 2 Mini Photo Printer’s brand new multicolor LED light bar. Because why not?
CARRY IT ANYWHERE
Fits in your hand, your pocket, and likely any other carrying case you choose. Be ready to create memorable stickers wherever adventure takes you.
PRINT. PEEL. STICK. GO.
Phone, helmet, laptop… These are just a few places we’d recommend sticking your new creations, but get creative! We’re sure you can come up with a whole lot more.
FAST CHARGING*
The IVY Mini 2 Photo Printer charges up in as little as 45 minutes2, so you’ll be ready to capture any magical moment the comes your way.
GOOD TIMES LIVE ON
No judgment if your phone’s camera roll is an endless void, but your favorite photos deserve better. Decorate your world with prints of the people, places, and moments that make you smile.
YOUR IVY 2 MINI PHOTO PRINTER IN ACTION
SAVE YOUR FAVORITE RECIPES
PERSONALIZE YOUR GIFT WRAP
DOCUMENT YOUR TRAVEL MEMORIES
IF YOU’RE SO OVER RECTANGLES
We get it. Sometimes you need more flexibility than 90 degree angles can offer. For circular surfaces–or surfaces that could use a bit more flair–choose our ZINK ® Pre-Cut Circle Stickers. (Sold Separately)
NO INK? NO PROBLEM.
Actually, this printer doesn’t use any ink at all! That’s because ZINK® (Zero Ink) technology features colorful dye-based crystals embedded inside the paper itself. Plus, ZINK® Photo Paper is super durable, tear-resistant, and smudge-free. (Sold Separately)
Specifications are subject to change without notice. All viewscreen and output images are simulated.
* The IVY Mini 2 Photo Printer is designed to be charged with a USB Charging Adaptor. If it is charged using a laptop USB port, there may not be sufficient electrical power to charge the IVY Mini 2 Photo Printer.
- Requires a mobile device to be connected to the Canon IVY Mini Photo Printer Second Generation via Bluetooth® Wireless technology and the Canon Mini Print App, available for free on the App Store and at Google Play. Compatible with mobile devices running iOS 9.0 or later, and Android devices running Android 4.4 or later.
- Charging time may vary significantly depending on the type of USB charging adapter used and other factors.
- Depending on operating temperature.
| Printing Technology | ZINK™ - "Zero Ink" |
| Print Speed | 50 seconds or less3 |
| Print Resolution (Up to) | 313 x 512 dpi |
| Borderless Printing | Yes |
| Connectivity | Bluetooth® 5.01 |
| Printer Connection | Bluetooth® - using the Canon Mini Print app1 |
| Automatic Paper Sensor | Yes |
| Battery | Built-in Rechargeable Lithium-ion |
| Control Panel | Power Button |
| Wi-Fi® Capable | No |
| Memory Card Compatible | No |
| Supported Media Type | Canon ZINK™ Photo Paper, Canon ZINK™ Pre-Cut Sticker |
| Maximum Paper Size | 2.0” x 3.0” |
| Paper Capacity | Up to 10 Sheets of Canon ZINK™ Photo Paper or Canon ZINK™ Pre-Cut Sticker + 1 SmartSheet® |
| 2 LED Light System |
| OS Compatability | Compatible OS
| Battery Information |
| Recommended Operating Environment |
| Storage Environment |
| ZINK Photo Paper Information |
Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (“Canon USA”) with respect to the Canon-brand IVY 2 Mini Photo Printer (the “Products”) manufactured or supplied by Canon USA and sold through Canon USA’s Authorized Distributors in Latin America and Caribbean markets. This limited warranty covers the Products sold only in South and Central America, Mexico and the Caribbean islands of Curacao, Aruba, St. Thomas, the Virgin Islands and Saint Maarten. This limited warranty does not cover the Products sold in the U.S.A. and Canada. Under this warranty, the Products will only be serviced by Service Facilities located in South and Central America, Mexico and the Caribbean.
Canon USA warrants the Products are free from defects in materials and workmanship under normal use and service for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container following and in accordance with the product specifications and usage recommendations.
A Product returned to the retail store where purchased and proven to be defective upon inspection may be exchanged for a new or refurbished Product. Upon inspection by Retailer the Product may also be sent to a local Canon Authorized Service Facility (“ASF”) or Canon Authorized Service Provider (“ASP) for replacement.
Warranty replacement or exchange does not extend the original warranty period for the Product. A dated proof of purchase is required at the time of warranty service. This warranty does not cover any accessories for the Product, or any consumables used with the Product (e.g., paper), as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible devices, peripheral equipment and software, as to which items Canon USA shall have no responsibility. Non-Canon brand equipment and software that may be distributed with the Product, or with which the Product may be integrated, are sold “as is” and without warranty of any kind by Canon USA, including any implied warranty or condition regarding merchantability or fitness for a particular purpose, and all such warranties and conditions are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
- Damage produced after the expiration of the warranty period.
- Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than an ASF or ASP. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the printer, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts, supplies or consumables (other than those sold by Canon USA through its Authorized Distributors) that cause damage to the Product or cause abnormally frequent service calls or service problems.
- If the Product has had its serial number or dating defaced, altered or removed.
- If the Product is used for commercial or industrial use.
THIS LIMITED WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, REPRESENTATIONS AND CONDITIONS, EXPRESS OR IMPLIED. NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCTS AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY, GUARANTY OR CONDITION, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON. (CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
