OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The compact and sustainably designed imageRUNNER C3125i offers printing speeds of up to 25 ppm (BW/color) and supports media up to 11" x 17" and A3 in various weights while offering finishing options. The C3125i also comes standard with 2 sided double pass ADF for scan speeds of 27.5ipm (300dpi) / 15ipm (600dpi) and the ability to send documents digitally for efficient results.
Workflow Efficiency
The imageRUNNER C3125i device holds up to 2,300 sheets at a time and produces high-quality color utilizing Canon's V2 imaging technology. For maximum workflow efficiency, this multifunction printer supports finishing options and can scan and convert documents to Searchable PDF. The imageRUNNER C3125i offers mobile printing and scanning capabilities, including Apple AirPrint™, Mopria printing, Canon PRINT Business Application and direct connection between mobile devices using a Wireless Lan.
Cost Management
This cost-efficient device offers Canon's signature reliability and when combined with remote diagnostics and assistance, can help reduce time spent resolving IT complications.
Security
Device and Fleet Management
Quality and Reliability
Sustainability
| Model Name | ImageRUNNER C3025i |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send Optional: Fax (1 Iine) |
| Operation Panel | 12.7 Cm (5 Inch) TFT LCD WVGA Color Touch Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 2.0 GB RAM |
| Hard Disk Drive | No HDD |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) |
| Other Interface | Standard: USB 2.0 X 2 (Host), USB 2.0 X1 (Device) Optional: Copy Control Interface |
| Common Protocol | SMB 3.0 |
| Standard | USB |
| Letter | Up To 25 Ppm (Letter/A4) |
| Letter R | Up To 20 Ppm |
| Legal | Up To 15 Ppm (Legal/11’x17’/A3) |
| Ledger | Up To 15 Ppm |
| First Copy Time | As Fast As 5.9 Seconds (BW)/8.2 Seconds (Color) |
| Multiple Copies | Up To 999 Copies |
| Copy Exposure | Automatic Or Manual (Inch 9 Levels, A/B 11 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | 1,200 Sheets |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | Standard: 250 Sheets With Inner Finisher: 600 Sheets *INNER FINISHER-K1 / COPY TRAY-J2 |
| Cassettes | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 8-1/2") Paper Cassette 2: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL], Custom Size (5-1/2" X 7-1/8" To 12" X 18") |
| Bypass | 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" X 3-7/8" To 12-5/8" X 18"), Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18"), Free Size (3-7/8" X 5-1/2" To 12-5/8" X 18") |
| Other Option | Cassette Feeding Unit-AP1: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 12" X 18") |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Bypass | 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Duplexing | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 30 Seconds Or Less4 From Sleep Mode: 10 Seconds Or Less |
| Power Requirements | 120-127V AC 60 Hz,7.5 A 220-240V AC 4.0A 50/60Hz |
| Power Consumption | Maximum: Approx. 1.5 KWh Standby: Approx. 31.0W (120v)/ 33.6W (230v) Sleep Mode: Approx. 1W7 Typical Electricity Consumption (TEC) Rating: 0.8 KWh (120v) / 0.9 KWh (230v) |
| Plug | NEMA 5-15P (120V) CEEE7/7 (230V) |
| Dim | 22-1/4" X 29-1/4" X 44-3/7"(565 Mm X 742 Mm X 1128 Mm)1 |
| Installation Space | Basic: Stack Bypass + Cassette Drawers Open: 38-1/2" X 43-31/32" (978 Mm X 1117 Mm) Fully Configured: 43-11/16" X 43-31/32" (1110 Mm X 1117 Mm)2 |
| Weight | Approx. 151.7 Lb (68.8 Kg) Including Toner3 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Job Build, N On 1, Add Cover, Insert Sheets, Different-Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Adjust One-Touch Color, Color Balance, Area Designation |
| Standard S | AUTHENTICATION Standard: Embedded Universal Login Manager (EULM), User Authentication, Department ID Authentication Optional: UniFLOW |
| Environmental Features | OPERATING ENVIRONMENT Temperature: 50 To 86 ºF Humidity: 20 To 80 % RH (No Condensation) |
| Toner | GPR-53 Toner11 Black Toner 36,000 Impressions C/M/Y Toner 19,000 Impressions |
| Description | SCAN SPECIFICATIONS TYPE Color Platen And Duplexing Automatic Document Feeder DOCUMENT FEEDER PAPER CAPACITY 150 Sheets (20 Lb. Bond, 80g/M2) DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, A3, B4, A4R, A4, B5R, B5, A5R, A5, B6 DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT Document Feeder Media Weight : 1-Sided Scanning: 13 Lb. Bond To 34 Lb. Bond (50 To 128 G/M2) (BW, Inch) 1-Sided Scanning: 10 Lb. Bond To 34 Lb. Bond (38 To 128 G/M2) (BW, AB) 1-Sided Scanning: 17 Lb. Bond To 34 Lb. Bond (64 To 128 G/M2) (CL, Inch And AB) 2-Sided Scanning: 13 Lb. Bond To 34 Lb. Bond (50 To 128 G/M2) (BW) 2-Sided Scanning: 17 Lb. Bond To 34 Lb. Bond (64 To 128 G/M2) (CL) PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] PULL SCAN Color Network ScanGear2 For Both Twain And WIA Supported OS: Windows Vista/7/8/8.1/10 SCAN RESOLUTION 600 X 600, 400 X 400, 300 X 300, 200 X 400, 200 X 200, 200 X 100, 150 X 150, 100 X 100 SCAN SPEED (LETTER) Single-Sided Scanning (BW/Color): 55 Ipm (300 Dpi)/30 Ipm (600 Dpi) Double-Sided Scanning (BW/Color): 27.5 Ipm (300 Dpi)/15 Ipm (600 Dpi) |
| Description | FAX SPECIFICATIONS MAXIMUM NUMBER OF CONNECTION LINES 1 MODEM SPEED Super G3: 33.6 Kbps G3: 14.4 Kbps COMPRESSION METHOD MH, MR, MMR, JBIG RESOLUTION 400 X 400, 200 X 400, 200 X 200, 200 X 100 SENDING / RECORDING SIZE Statement-R To 11" X 17" FAX MEMORY Up To 512 Pages SPEED DIALS Max. 281 GROUP DIALS / DESTINATIONS Max. 299 Dials SEQUENTIAL BROADCAST Max. 310 Addresses MEMORY BACKUP Yes |
| Description | PRINT SPECIFICATIONS PRINT RESOLUTION (Dpi) 1200 X 1200 STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3 DIRECT PRINT Available From USB SUPPORTED FILE TYPES FOR DIRECT PRINT PDF, TIFF, JPEG, XPS PRINTING FROM MOBILE AND CLOUD Provide Printing From Mobile Devices Or Internet-Connected Devices And Cloud-Based Services Depending On Your Requirements. FONTS PCL Fonts: 93 Roman, 10 Bitmap Fonts, 2 OCR Fonts, Barcode Fonts3 PS Fonts: 136 Roman OPERATING SYSTEM6 UFRII: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7.5 Or Later), Linux PCL: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 PS: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7.5 Or Later) PPD: MAC OS 9.1 Or Later, MAC OS X (10.3.9 Or Later), Windows Vista/Windows 7/Windows 8/Windows10 |
| Print Features | Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
| Description | SEND SPECIFICATIONS DESTINATION E-Mail/Internet Fax (SMTP), SMB, FTP, Super G3 Fax (Optional), COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-And-White), Full Color, Grayscale, And Black-And-White ADDRESS BOOK LDAP (50)/Local (300)/Speed Dial (281) SEND RESOLUTION 204 X 196 Dpi, 300 X 300 Dpi COMMUICATION PROTOCOL File: FTP, SMB V3.0 E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple) FILE FORMAT Standard: TIFF, JPEG, PDF(Compact, Searchable, Optional: PDF (Encrypted, Digital Signature) |
| Description | Footnotes |
GPR-53L Cyan
Estimated Toner Yield: 8,500 Copies/Bottle (Estimated @ 5% Coverage)
GPR-53L Yellow
GPR-53 Toner Magenta
Estimated Toner Yield: 19,000 Copies/Bottle (Estimated @ 5% Coverage)
GPR-53 Toner Black
Estimated Toner Yield: 36,000Copies/Bottle (Estimated @ 5% Coverage)
GPR-53L Magenta
GPR-53 Toner Yellow
GPR-53 Toner Cyan
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
