| Model Name
ImageRUNNER ADVANCE DX C7770i |
| Type
Color Laser Multifunctional |
| Functions
Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel
Standard: 10.1" TFT LCD WSVGA Color Touch-Panel Optional: 10.4" TFT LCD WSVGA Color Upright-Panel |
| Imaging System
Canon Dual Custom Processor (Shared) |
| Image Server Memory
4.0 GB RAM |
| Hard Disk Drive
Standard: 250 GB/Maximum: 1 TB |
| Network Interface Connection
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface
Standard: USB 2.0 (Host) X 1,USB 3.0 (Host)X 1, USB 2.0 (Device) X 1 Optional: Copy Control Interface |
| Max Mailboxes Supported
100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored
10,000 Pages (2,000 Jobs) Stored |
| Available Disk Space
Approx. 16 GB (Standard HDD)/Approx. 480 GB |
| Common Protocol
SMB Or WebDAV |
| Supported Client Pc
Windows (Windows 8.1/10) |
| Max Number Of Concurrent Connections
SMB: 64 WebDAV: 3 |
| Printing Resolution
2400 Dpi X 2400 Dpi |
| Letter
Up To 70/65 Ppm |
| Letter R
Up To 52/48 Ppm |
| Legal
Up To 41/38 Ppm |
| Ledger
Up To 35/32 Ppm |
| First Copy Time
As Fast As 4.8 Seconds (BW)/ 5.9 Seconds (Color) |
| Multiple Copies
Up To 9,999 |
| Magnification
25%-400% (1% Increments) |
| Preset Reductions
25%, 50%, 64%, 73%, 78%, 100% |
| Preset Enlargements
121%, 129%, 200%, 400% |
| Acceptable Originals
Sheet, Book, 3-Dimensional Objects |
| Standard Paper Capacity
3,550 Sheets |
| Maximum Paper Capacity
9,300 Sheets |
| Output Paper Capacity
250 Sheets (With Copy Tray-R2) 4,250 Sheets (With Staple Finisher-X1 Or Booklet Finisher-X1) |
| Cassettes
Multi-Purpose Tray: Standard Size: 13" X 19", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size/Free Size: 4" X 5-7/8" To 13" X 19-1/4", Envelope: COM10 No.10, Monarch, DL, ISO-C5, Envelope Custom Size: 3-1-/2" X 5-7/8" To 13" X 19-1/4" Paper Decks: Letter Paper Cassettes: 13" X 19", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size: 5-1/2" X 7-1/8" To 13" X 19-1/4", Envelope: COM10 No.10, Monarch, DL, ISO-C5, Envelope Custom Size : 3-7/8" X 5-7/8" To 13" X 19-1/4" |
| Cassette
Paper Drawers: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Paper Cassettes:14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Multi-Purpose Tray: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Duplexing
14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time
From Power On: Approx. 30 Seconds2 Quick Startup Mode: Approx. 4 Seconds3 From Sleep Mode: 30 Seconds Or Less4 |
| Power Requirements
110-127 V AC, 60 Hz,16 A |
| Power Consumption
Maximum: Approx. 2,000 W Standby: Approx. 119.2 W11 Sleep Mode: Approx. 0.9 W12 Typical Electricity Consumption (TEC) Rating13 1.23 KWh |
| Dim
27-1/8" X 36-7/8" X 46-5/8" (689 Mm X 937 Mm X 1,185 Mm) |
| Installation Space
Basic: 79-3/4" X 60" (2,026 Mm X 1,524 Mm) (With Front Cover Open + Multi-Purpose Tray/Upper-Right Cover Open + Buffer Pass+ Booklet Finisher-AC1/Extension Tray And Rotary Tray Extended) Fully Configured: 150-3/8" X 60" (3,818 Mm X 1,524 Mm) (With Front Door Open + Multi-Drawer Paper Deck-C1 + Buffer Pass + Document Insertion Unit-N1 + Multi Function Professional Puncher-B1 + Paper Folding Unit-J1+ Booklet Finisher-X1) |
| Weight
Approx. 562.2 Lb. (255 Kg)5 |
| Standard S
AUTHENTICATION: Universal Login Manager, UniFLOW Online Express,10 User Authentication, Department ID Authentication, Access Management System, Device And Function Level Log-In DATA: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System At Startup, McAfee Embedded Control NETWORK: Encrypted Secure Print,IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (V1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/MIME, SIEM Integration DOCUMENT: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature |
| Optional
AUTHENTICATION: UniFLOW DATA: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) |
| Toner
GPR-56 Toner |
| Estimated Toner Yield
(ESTIMATED @ 5% COVERAGE): Black: 82,000 Images Color (C,M,Y): 66,500 Images- Envelope Attachment-F1 Required.
- Time From Device Power-On, Until Copy Ready (Not Print Reservation).
- Time From Device Power On To When The Copy Icon Appears And Is Enabled To Operate On The Touch Panel Display.
- Time From Exiting Sleep Mode To When Printing Is Operational.
- Includes Main Unit, ADF, And Consumables.
- EPS Can Be Printed Directly Only From The Remote User Interface.
- Requires The Optional PCL International Font Set-A1.
- Requires The Optional Barcode Printer Kit-D1.
- Other Operating Systems And Environments Including AS/400, UNIX, Linux And Citrix May Be Supported. Some Of These Solutions Are Chargeable. SAP Device Types Are Available Via The SAP Market Place. For More Information, Contact Your Sales Representative.
- No Charge For This Solution; However Activation Is Required.
- Reference Value: Measured One Unit.
- 0.9 W Sleep Mode Is Not Available In All Circumstances Due To Certain Settings.
- Based On ENERGY STAR Product Specification For Imaging Equipment Version 3.0.
