| Model Name
ImageRUNNER ADVANCE DX C478iF |
| Type
Color Laser Multifunctional |
| Functions
Print, Copy, Scan, Send, Store, Fax |
| Operation Panel
10.1" TFT LCD WSVGA Color Touch-Panel |
| Imaging System
1.75GHz Dual Core Processor |
| Image Server Memory
4.0 GB RAM |
| Hard Disk Drive
Solid State Drive: 256 GB |
| Network Interface Connection
Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface
Standard: USB 2.0 (Host) X 2, USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Copy Control Interface |
| Max Mailboxes Supported
LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| Common Protocol
File: FTP (TCP/IP), SMB V3.0, WebDAV Email: SMTP, POP3 |
| Printing Resolution
1200 X 600, 600 X 600 Direct |
| Letter
Up To 50 Ppm |
| Legal
Up To 39 Ppm |
| First Copy Time
Approx. 5.1/5.8 Seconds Or Less |
| Multiple Copies
Up To 9,999 |
| Magnification
25%-400% (1% Increments) |
| Preset Reductions
25%, 50%, 64%, 78% |
| Preset Enlargements
100% (1:1), 129%, 200%, 400% |
| Acceptable Originals
Sheet, Book |
| Standard Paper Capacity
650 Sheets |
| Maximum Paper Capacity
2,300 Sheets |
| Output Paper Capacity
Standard Model: 400 Sheets Finisher Model: 900 Sheets (400 Sheets: Base Tray, 400 Sheets: Upper Tray, 100 Sheets: Lower Tray) |
| Cassettes
Cassettes: Legal, Letter, Executive, Statement, Custom Size: 4" X 5-7/8" To 8-1/2" X 14" (101.6 X 148.0 Mm To 216.0 X 355.6 Mm) Multi-Purpose Tray: Legal, Letter, Executive, Statement, Envelopes [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size: 3" X 5" To 8-1/2" X 14" (76.2 X 127.0 Mm To 216.0 X 355.6 Mm) |
| Cassette
Cassettes: 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) Multi-Purpose Tray: 16 Lb. Bond To 79 Lb. Cover (60 To 216 G/M2) |
| Duplexing
16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Warm Up Time
From Power On: Approx. 10 Seconds1 From Sleep Mode: Approx. 10 Seconds2 Quick Startup Mode: Approx. 4 Seconds3 |
| Power Requirements
110 V-127 V, 60 Hz, 10 A 220 V-240 V, 50/60Hz, 4.3A |
| Power Consumption
Maximum: Approx. 1,500 W Standby: Approx. 49 W10 Sleep Mode: Approx. 1.0 W11 Typical Electricity Consumption (TEC) Rating:12 0.67 KWh |
| Plug
C478i: CEE7/7 C478iF/C478iFZ: NEMA 5-15P |
| Dim
Standard Model: 20-1/2" X 25-1/4" X 26-3/8" (521 Mm X 642 Mm X 668 Mm) Finisher Model: 20-1/2" X 25-1/4" X 34" (521 Mm X 642 Mm X 864 Mm) |
| Installation Space
37-3/8" X 33-1/8" (950 Mm X 840 Mm) (With Left Cartridge Door Open + Right Door Open + The Cassette Drawer Open) |
| Weight
Standard Model:4 Approx. 101.4 Lb. (46 Kg) Finisher Model:4 Approx. 121.3 Lb. (55 Kg) |
| Toner
TONER T04 BK/C/M/Y13 |
| Estimated Toner Yield
TONER T04 BK: 33,000 Pages14 TONER T04 C/M/Y: 27,500 Pages14 |
