imageRUNNER ADVANCE DX C3826i
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Workflow Efficiency
10.1" intuitive touchscreen with smartphone-like usability. A unique, customized experience tailored to individual preferences using My ADVANCE. Supports mobile solutions and integration with many popular cloud services like Google Drive. Scan and convert documents to searchable digital files in a variety of file formats. Integration with Canon and various third-party software with embedded application platform. Hot Folders allow users to drag and drop a file into a hot folder, and automatically print with predefined settings such as number of copies and finishing requirements.
Security
Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance. Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers. Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications. Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices. Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
Quality and Reliability
Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources. Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile. Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement. imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
Device and Fleet Management
Designed for quick, easy deployment. Remote diagnostics and parts life management for proactive maintenance and rapid fixes. Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies. Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
Cost Management
Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects. Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency. Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity. Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
Sustainability
A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption. Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy. ENERGY STAR® certified and rated EPEAT® Gold.
- Envelope Feeder Attachment A (standard) is required.
- Time from device power-on until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when the copy icon appears and is enabled to operate on the touch panel display.
- Includes Single Pass DADF.
- With right cover open + Multi-purpose tray extension extened + paper cassette open.
- Includes Staple Finisher-AE1/Booklet Finisher-AE1 + Copy Tray-T1 extension extended + paper cassette open.
- Includes toner.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments, including AS/400, UNIX, Linux, and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- Detect Feeder Multi Sheet Feed is supported.
- No charge for this solution; however, activation is required.
- Requires uniFLOW Online/uniFLOW.
- Reference value (measured one unit).
- 0.8 W Sleep mode not available in all circumstances due to certain settings.
- Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
- GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images.
| Model Name | ImageRUNNER ADVANCE C3826i |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.1" TFT LCD WSVGA Color Touch-Panel |
| Image Server Memory | 3.5 GB RAM |
| Network Interface Connection | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface | Standard: USB 2.0 X1 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | Maximum 10,000 Pages (2,000 Jobs Stored) |
| Available Disk Space | Standard: 16 GB (With Option: Max. 480 GB) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows 8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Scanning Resolution | Scan For Copy: 600 X 600 Scan For Send: Push (600 X 600), SMB/FTP/WebDAV, Pull (600 X 600) Scan For Fax: 600 X 600 |
| Printing Resolution | 1200 X 600, 1200 X 1200 |
| Letter | Up To 26 Ppm |
| Letter R | Up To 20 Ppm |
| Legal | Up To 15 Ppm |
| First Copy Time | Approx. 6.1 Seconds (BW)/ 8.4 Seconds (Color) |
| Multiple Copies | Up To 999 |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 100% (1:1), 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects |
| Standard Paper Capacity | 1,200 Sheets |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | Standard: 250 Sheets Maximum: 3.450 Sheets (With Staple Finisher-AE1/Booklet Finisher-AE1 And Copy Tray-T1) |
| Cassettes | Multi-Purpose Tray: 12"X18", 11"X17", Legal, Letter, Letter-R, Executive, Statement, Statement-R Custom Size/Free Size: 4" X 5-7/8" To 12" X 18", Envelopes (COM10 No.10, Monarch, ISO-C5, DL), Envelope Custom Size ( 3-7/8" X 3-7/8" To 12-5/8" X 18") Upper Cassette: Letter, Executive, Statement-R Custom Size (4-1/8" X 5-7/8" To 11-3/4" X 8-1/2"), Envelopes (ISO-C5) Lower Cassette: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4-1/8" X 5-7/8" To 12" X 18"), Envelopes (COM10 No.10, Monarch, DL) |
| Cassette | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2 ) Multipurpose Tray: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2 ) |
| Duplexing | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2 ) |
| Warm Up Time | From Power On: Approx. 10 Seconds7 From Sleep Mode: Approx. 10 Seconds8 Quick Startup Mode: Approx. 4 Seconds9 |
| Power Requirements | 110V-127V, 60Hz, 8.5A 220V-240V, 50/60Hz, 5A |
| Power Consumption | Maximum: Approx. 1,500 W Standby: Approx. 43.9 W20 Sleep Mode: Approx. 0.8 W21 Typical Electricity Consumption (TEC) Rating22 0.30 KWh |
| Dim | 22-1/4" X 28-1/2" X 35-3/8" (565 Mm X 722 Mm X 897 Mm)10 |
| Installation Space | Basic: 38-1/2" X 44-1/8" (978 Mm X 1119 Mm)11 Fully Configured: 65" X 44-1/8" (1651 Mm X 1119 Mm)12 |
| Weight | Approx. 185.2 Lb. (84 Kg)13 |
| Toner | GPR-53 Toner BK/C/M/Y GPR-53L Toner C/M/Y |
| Estimated Toner Yield | GPR-53 Toner BK: 36,000 Pages GPR-53 Toner C/M/Y: 19,000 Pages GPR-53L Toner C/M/Y: 8,500 Pages |
- Includes toner.
