/content/cla/en/cla-test/cla-testing/haibd4-testing
/content/cla/en/cla-test/cla-testing/support/p/Software-Applications/1259B003
imageRUNNER ADVANCE DX C3725i
The imageRUNNER ADVANCE DX C3730i is color copier produces an output of up to 25 ppm.
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires Unified Firmware Platform v3.9 or greater.
- Requires additional option.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Envelope Feeder Attachment A (standard) is required.
- Time from device power-on, until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when the copy icon appears and is enabled to operate on the touch panel display.
- Includes Single Pass DADF.
- With right cover open + Multi-purpose tray extension extened + paper cassette open.
- Includes Staple Finisher-AA1/Booklet Finisher-AA1 + Copy Tray-J2 extension extended + paper cassette open.
- Includes toner.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- Detect Feeder Multi Sheet Feed is supported.
- No charge for this solution; however activation is required.
- Reference value (measured one unit).
- 0.8 W sleep mode not available in all circumstances due to certain settings.
- Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
- GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images.
| Model Name | ImageRUNNER ADVANCE DX C3725i |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.1" TFT LCD WSVGA Color Flat-Panel |
| Imaging System | 1.75 GHz Dual Core Processor |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB/Maximum: 1 TB |
| Network Interface Connection | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface | Standard: USB 2.0 X1 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | Maximum 10,000 Pages (2,000 Jobs Stored) |
| Available Disk Space | Approx. 16 GB (Standard HDD) Approx. 480 GB (With Optional 1 TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows 8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Scanning Resolution | Scan For Copy: 600 X 600 Scan For Send: Push (600 X 600), SMB/FTP/WebDAV, Pull (600 X 600) Scan For Fax: 600 X 600 |
| Printing Resolution | 1200 X 1200, 600 X 600 |
| Letter | Up To 25 Ppm |
| Letter R | Up To 20 Ppm |
| Legal | Up To 15 Ppm |
| Ledger | Up To 15 Ppm |
| First Copy Time | As Fast As 5.9 Seconds (BW)/8.2 Seconds (Color) |
| Multiple Copies | Up To 999 |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78%, |
| Preset Enlargements | 100%(1:1), 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects |
| Standard Paper Capacity | Standard: 1,200 Sheets |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | Standard: 250 Sheets Maximum: 3,450 Sheets (With Staple Finisher-AA1/Booklet FinisherAA1 And Copy Tray-J2) |
| Cassettes | Multi-Purpose Tray: 12"X18", 11"X17", Legal, Letter, Letter-R, Executive, Statement, Statement-R Custom Size/Free Size: 3-7/8" X 5-1/2" To 12-5/8" X 18", Envelopes (COM10 No.10, Monarch, ISO-C5, DL), Envelope Custom Size ( 3-7/8" X 3-7/8" To 12-5/8" X 18") Upper Cassette: Letter, Executive, Statement-R Custom Size (4-1/8" X 5-7/8" To 11-3/4" X 8-1/2"), Envelopes (ISO-C5) Lower Cassette: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4-1/8" X 5-7/8" To 12" X 18"), Envelopes5 (COM10 No.10, Monarch, DL) |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Multipurpose Tray: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Duplexing | Single-Pass Duplexing Automatic Document Feeder16 |
| Paper Size | 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom Size: 2-3/4" To 12" X 17" (128 Mm X 139.7 Mm To 304.8 Mm X 431.8 Mm) |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: Approx. 10 Seconds6 From Sleep Mode: Approx. 10 Seconds7 Quick Startup Mode: Approx. 4 Seconds8 |
| Power Requirements | 110V-127V, 60Hz, 7.5A |
| Power Consumption | Maximum: Approx. 1,500 W Standby: Approx. 47.0 W18 Sleep Mode: Approx. 0.8 W19 Typical Electricity Consumption (TEC) Rating:20 0.30 KWh |
| Dim | 22-1/4" X 28-1/2" X 34-7/8" (565 Mm X 722 Mm X 887 Mm)9 |
| Installation Space | Basic: Multi-Purpose Tray + Cassette Drawers Open: 38-1/2" X 44" (978 Mm X 1118 Mm)10 Fully Configured: 65" X 44" (1651 Mm X 1118 Mm)11 |
| Weight | Approx. 175.5 Lb. (79.6 Kg)12 |
| Standard S | Authentication: Universal Login Manager, UniFLOW Online Express,17 User Authentication, Department ID Authentication, Access Management System, Device And Function Level Log-In Data: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System At Startup, McAfee Embedded Control2 Network: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (V1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/MIME, SIEM Integration Document: Secure Watermark, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Digital Signature, User Signature |
| Optional | Authentication: UniFLOW Data: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) |
| Environmental Features | ENERGY STAR® Certified Rated EPEAT® Gold4 |
| Toner | GPR-53 Toner21 |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 36,000 Images Color (C,M,Y): 19,000 Images |
- Includes toner.
ABOUT CANON
PRODUCT RESOURCES
ABOUT CANON
PRODUCT RESOURCES
Ⓒ 2026
