| Model Name
ImageRUNNER ADVANCE DX 6765i |
| Type
Monochrome Laser Multifunctional |
| Functions
Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel
Standard: 10.1" TFT LCD WSVGA Color Flat Touch-Panel Optional 10.4" TFT LCD SVGA Color Upright Touch-Panel |
| Image Server Memory
3.0 GB RAM |
| Hard Disk Drive
Standard: 250 GB Maximum: 1 TB |
| Network Interface Connection
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface
Standard: USB 2.0 X1 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Copy Control Interface |
| Max Mailboxes Supported
100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored
Maximum 30,000 Pages (2,000 Jobs) Stored |
| Available Disk Space
Approx. 16 GB (Standard HDD); 480 GB (With Optional 1 TB HDD) |
| Common Protocol
SMB Or WebDAV |
| Supported Client Pc
Windows (Windows 8.1/10) |
| Max Number Of Concurrent Connections
SMB: 64 WebDAV: 3 (Active Sessions) |
| Letter
Up To 65 Ppm |
| Letter R
Up To 50 Ppm |
| Legal
Up To 39 Ppm |
| Ledger
Up To 32 Ppm |
| First Copy Time
As Fast As 3.3 Seconds |
| Multiple Copies
Up To 9,999 Copies |
| Magnification
25%-400% (1% Increments) |
| Preset Reductions
25%, 50%, 64%, 73%, 78% |
| Preset Enlargements
100%(1:1), 121%, 129%, 200%, 400% |
| Acceptable Originals
Sheet, Book, 3-Dimensional Objects |
| Maximum Original Size
Up To 11-3/4" X 17" (297 Mm X 431.8 Mm) |
| Standard Paper Capacity
4,360 Sheets |
| Maximum Paper Capacity
8,020 Sheets |
| Output Paper Capacity
With Copy Tray: 250 Sheets With External Finishers: 3,500 Sheets (With Staple Finisher-AC1 Or Booklet Finisher-AC1) |
| Cassettes
11"X17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 19-1/4") |
| Other Option
Multipurpose Tray: 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size/Free Size (4" X 5-7/8" To 11-3/4" X 19-1/4") Paper Decks: Letter |
| Cassette
14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Paper Decks: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Multipurpose Tray: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Duplexing
14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time
From Power On: Approx. 30 Seconds3 From Sleep Mode: Approx. 30 Seconds4 Quick Startup Mode: Approx. 4 Seconds5 |
| Power Requirements
110-127 V AC, 60 Hz, 16 A |
| Power Consumption
Maximum: Approx. 2,032 W Standby: Approx. 278 W15 Sleep Mode: 0.9 W16 |
| Plug
Maximum: Approx. 2,032 W Standby: Approx. 278 W12 Sleep Mode: 0.9 W13 Typical Electricity Consumption (TEC) Rating: 1.65 KWh |
| Dim
26-3/8" X 30-3/8" X 46-5/8" (670 X 770 X 1,185 Mm) |
| Installation Space
Basic: 60-3/8" X 53-1/4" (1,533 Mm X 1,353 Mm) (With Multi-Purpose Tray/Upper-Right Cover Open + Front Cover Open + Copy Tray) Fully Configured: 95-7/8" X 53-1/4" (2,436 Mm X 1,353 Mm) (With POD Deck Lite-C1 + Document Insertion/Folding Unit-J1 + Booklet FinisherAC1/Staple Finisher-AC1 + Main Unit Front Cover Open ) |
| Weight
Standard: Approx. 482.8 Lb (219 Kg)6 With Upright Touch Panel Approx. 491.6 Lb (223 Kg) 6 |
| Standard S
AUTHENTICATION: Universal Login Manager, UniFLOW Online Express,11 User Authentication, Department ID Authentication, (Device And Function Level Log-In), Access Management System Data: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System At Startup, McAfee Embedded Control2 Network: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (V1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/MIME, SIEM Integration Document: Secure Watermark, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature |
| Optional
AUTHENTICATION: UniFLOW Data: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) |
| Toner
GPR-38 Black Toner |
| Estimated Toner Yield
(Estimated @ 6% Coverage): 56,000 Pages - Tab Feeding Attachment-B1 Is Required.
- Some Types Of Tracing Paper Cannot Be Used.
- Time From Device Power-On, Until Copy Ready (Not Print Reservation).
- Time From Exiting Sleep Mode To When Printing Is Operational.
- Time From Device Power On To When The Copy Icon Appears And Is Enabled To Operate On The Touch Panel Display.
- Includes Consumables.
- EPS Can Be Printed Directly Only From The Remote User Interface.
- Requires The Optional PCL International Font Set-A1.
- Requires The Optional Barcode Printer Kit-D1.
- Other Operating Systems And Environments Including AS/400, UNIX, Linux And Citrix May Be Supported. Some Of These Solutions Are Chargeable. SAP Device Types Are Available Via The SAP Market Place. For More Information, Contact Your Sales Representative.
- No Charge For This Solution; However Activation Is Required.
- Standby Reference Value: Measured One Unit.
- 0.9 W Sleep Mode Not Available In All Circumstances Due To Certain Settings.
