imageRUNNER ADVANCE C9270 PRO
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Untitled Document
| Model Name | ImageRUNNER ADVANCE C9270 PRO |
| Type | Color Digital Multifunction Imaging System |
| Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL 5c/6, Adobe® PostScript® 3™), Fax (Up To 4 Lines) |
| Operation Panel | 10.4" SVGA Full-Color, TFT Upright Screen |
| Image Server Memory | Standard: 2GB RAM Maximum: 2.5GB RAM |
| Hard Disk Drive | Standard: 160GB Maximum: 1TB |
| Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
| Network Interface Connection | Standard: 10Base-T/100Base-TX/1000Base-T |
| Other Interface | Standard: USB 2.0 (Host) X2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) X2], Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes |
| Max Pages Stored | 6,000 Maximum Pages Stored |
| Available Disk Space | Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows 2000/XP/7/8/Windows Vista) |
| Max Number Of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | USB Memory |
| Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
| Network Twain Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
| Letter | Up To 70/65 Ppm |
| Legal | Up To 41/38 Ppm 11" X 17": Up To 35/32 Ppm |
| First Copy Time | BW: 4.9 Seconds Or Less Color: 6.6 Seconds Or Less |
| Multiple Copies | 1 To 9,999 |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25% - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (20 Lb. Bond): Dual 1,100-Sheet Paper Drawers, Dual 550-Sheet Paper Cassettes, 100-Sheet Stack Bypass |
| Optional | 3,500-Sheet Paper Deck Unit, 3,500-Sheet POD Deck Lite, Or 6,000-Sheet Multi-Drawer Paper Deck |
| Maximum Paper Capacity | 9,300 Sheets (With Optional Multi-Drawer Paper Deck) |
| Output Paper Capacity | (20 Lb. Bond): 4,250 Sheets (With Staple Finisher Or Booklet Finisher) |
| Cassettes | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4")Drawers: Letter |
| Bypass | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelopes, Custom Size (4" X 5-7/8" To 13" X 19-1/4") |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
| Bypass | 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M²) |
| Paper Size | Standard Automatic Trayless Duplexing (Up To 13" X 19") |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
| Special Media Support | Thin [14 Lb. Bond To 16 Lb. Bond (52 To 63g/M²)], Plain 1 [17 Lb. Bond To 21 Lb. Bond (64 To 81g/M²)], Plain 2 [22 Lb. Bond To 28 Lb. Bond (82 To 105g/M²)], Heavy 1 [29 Lb. Bond To 40 Lb. Bond (106 To 150g/M²)], Heavy 2 [56 Lb. Cover To 80 Lb. Cover (151 To 220g/M2)], Heavy 3 [82 Lb. Cover To 140 Lb. Index (221 To 256g/M2)], Heavy 4 [140 Lb. Index To 110 Lb. Cover (257 To 300g/M2)], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab, Textured, Coated, Envelopes |
| Warm Up Time | From Power On: 31 Seconds Or Less From Sleep: 30 Seconds Or Less Quick Startup Mode: 7 Seconds* |
| Power Requirements | 208V AC, 60Hz, 12A,. 220-240V AC / 50/60Hz / 15A |
| Power Consumption | Maximum: 2.5kW Sleep Mode: 0.9W Or Less |
| Plug | NEMA 6-15P |
| Dim | 55-1/4" X 46-1/2" X 36-3/4"** |
| Installation Space | 63" X 36-3/4" |
| Weight | Approx. 615 Lb. (279kg)*** |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2kg)] |
| Maximum Original Size | Up To 11" X 17" |
| Basic Copy Features | Preset R/E Ratios By Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
| Special Copy Features | Two-Page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark And Date, Job Block Combination, Store In User Inbox |
| Standard S | Department ID Management, Single Sign-On H, Access Management System (Device And Function Level Log-In)◊, Secure Print, Trusted Platform Module, User Access Control Of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication Before SMTP, HDD Erase (Up To 3x), HDD Initialize (Up To 9x), HDD Lock, IPsec , Adobe LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria CertificationΔ |
| Environmental Features |
| Estimated Toner Yield | (Estimated Yield @ 5% Coverage): Black: 72,000 Images Color (C,M,Y): 54,000 Images |
| Acceptable Originals | 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R |
| Scan Method | Single-Pass Duplexing Automatic Document Feeder |
| Scanning Speed | (BW/Color; Letter): Simplex: Up To 120/120 Ipm (300 Dpi), Up To 120/70 Ipm (600 Dpi) Duplex: Up To 200/140 Ipm (300 Dpi), Up To 120/70 Ipm (600 Dpi) |
| Capacity | (20 Lb. Bond): 300 Sheets |
| Paper Weight | 1-Sided Scanning: 13 Lb. Bond To 80 Lb. Cover (50 To 220g/M²) 2-Sided Scanning (Black-And-White Original): 13 Lb. Bond To 80 Lb. Cover (50 To 220g/M²) 2-Sided Scanning (Color Original): 17 Lb. Bond To 80 Lb. Cover (64 To 220g/M²) |
| Description | Paper Deck Unit-C1 |
| Number Of Cassettes | 1 |
| Paper Capacity | 3,500 Sheets [20 Lb. Bond (80g/M²)] |
| Paper Size | Letter |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched |
| Power Source | From Main Unit |
| Power Consumption | Approx. 44W |
| Dimensions | 22-1/2" X 12-3/4" X 23" (570mm X 323mm X 583mm) |
| Weights | Approx. 81.6 Lb. (37kg) |
| Description | POD Deck Lite-A1 |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M²) |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Bond, Letterhead, Textured, Coated |
| Power Source | 120-127V AC, 60Hz, 2.4A, 220-240V AC, 50/60Hz, 1.2A |
| Power Consumption | Approx. 263W |
| Dimensions | 22-1/2" X 23-5/8" X 24-1/2" (570mm X 601mm X 621mm) |
| Weights | Approx. 110 Lb. (50kg) |
| Description | Multi-Drawer Paper Deck-A1 |
| Number Of Cassettes | 3 (2,000 Sheets Each) |
| Paper Capacity | 6,000 Sheets [20 Lb. Bond (80g/M²)] |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4") |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Bond, Letterhead, Tab, Textured, Coated |
| Power Source | 120-127V AC, 60Hz, 4A, 220-240 V, 50/60 Hz, 2 A |
| Power Consumption | Approx. 753W |
| Dimensions | 41" X 37-3/8" X 31-3/8" (1040mm X 950mm X 797mm) |
| Weights | Approx. 331 Lb. (150kg) |
| Description | Copy Tray-P1 |
| Total Output Capacity | Up To 250 Sheets [20 Lb. Bond (80g/M²)] |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelopes, Custom Size (4" X 5-7/8" To 13" X 19-1/4") |
| Dimensions | 6-7/8" X 16-1/2" X 15" (175mm X 420mm X 382mm) |
| Weight | Approx. 2.9 Lb. (1.3kg) |
| Description | Booklet Finisher-K1 |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab, Textured, Coated, Envelopes |
| Number Of Trays | 3 |
| Total Output Capacity | 4,250 Sheets (Letter) |
| Top Tray | 1,500 Sheets (Letter, Executive, Statement-R), 750 Sheets (13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter-R) |
| Middle Tray | 250 Sheets (Letter, Statement-R), 125 Sheets (11" X 17", Legal, Letter-R, Executive), 30 Sheets (13" X 19", 12-5/8" X 17-11/16", 12" X 18") |
| Lower Tray | 2,500 Sheets (Letter), 1,500 Sheets (Executive, Statement-R), 750 Sheets (13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter-R) |
| Saddle Stitch Tray | 20 Sheets [21 Lb. Bond (81g/M²), Including 1 Cover Sheet Up To 110 Lb. Cover (300g/M²)] |
| Paper Capacity Of Saddle Stitch Mode | 1 To 5 Sheets/25 Sets, 6 To 10 Sheets/15 Sets, 11 To 16 Sheets/10 Sets, 17 To 20 Sheets/5 Sets |
| Staple Capacity | Letter And Executive: 100 Sheets [20 Lb. Bond (80g/M²)] Or Up To 1/2" (11mm) For Heavier Paper 11" X 17", Legal, And Letter-R: 50 Sheets [20 Lb. Bond (80g/M²)] Or Up To 1/4" (5.5mm) For Heavier PaperPaper Capacity Of Staple Mode: (Top And Lower Trays): 1,500 Sheets/100 Sets (Letter, Executive), 750 Sheets/50 Sets (11" X 17", Legal, Letter-R) |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter-R, Custom Size [8-1/4" X 11" To 13" X 19-1/4" (210.0 Mm X 279.3 Mm To 330.2 Mm X 487.7 Mm)] |
| Type Of Staple | Staple-N1 (5,000 X 3), Staple-P1 (5,000 X 2) |
| Power Source | 100-240V AC, 50/60Hz, 2.8A |
| Power Consumption | Approx. 380W (Including The Puncher Unit-BF1 And Inner Booklet Trimmer-A1) Approx. 349W (Excluding The Puncher Unit-BF1 And Inner Booklet Trimmer-A1) |
| Dimensions | 41" X 30-1/4" (35-1/4"ΔΔ) X 30-1/8" (1040mm X 767mm (896mmΔΔ) X 765mm) |
| Weight | Approx. 243 Lb. (110kg) |
| Description | Staple Finisher-K1 |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive |
| Type Of Staple | Staple-N1 (5,000 X 3) |
| Power Consumption | Approx. 286W (Including The Puncher Unit-BF1) Approx. 282W (Excluding The Puncher Unit-BF1) |
| Dimensions | 41" X 25-3/4" (30-3/4"ΔΔ) X 30-1/8" [1040mm X 654mm (782mmΔΔ) X 765mm] |
| Weight | Approx. 141 Lb. (64kg) |
| Description | Puncher Unit-BF1 |
| Paper Size | 11" X 17", Legal, Letter, Letter-R, Executive |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256g/M²) |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Bond, Letterhead, Tab, Textured, Coated |
| Punch Type | 2 Holes (Legal, Letter-R), 3 Holes (11" X 17", Letter, Executive) |
| Distance Between Punch Holes | 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm)Punch Waste Tray Capacity: Approx. 5,000 Sheets [20 Lb. Bond (80g/M²)] |
| Power Requirements | From The Finisher |
| Dimensions | Inside The Finisher [15-1/2" X 3-3/4" X 28-1/8" (392mm X 95mm X 715mm)] |
| Weight | Approx. 8.2 Lb. (3.7kg) |
| Description | Professional Puncher-C1/Professional Puncher Integration Unit-B1 |
| Paper Weight | LTR (3-Hole, 5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21/32-Hole, Color Coil 44-Hole): 20 Lb. Bond To 80 Lb. Cover (75 To 216g/M²) LTR (ProClick 32-Hole): 20 Lb. Bond To 65 Lb. Cover (75 To 176g/M²) |
| Punch Type | Thin, Plain, Heavy, Color, Recycled, Tab, CoatedAcceptable Punch Paper Size: Letter |
| Punch Patterns | Plastic Comb (19-Hole), Twin Loop (21/32-Hole), Color Coil (44-Hole), Velo Bind (11-Hole), Loose Leaf (3/5-Hole), ProClick (32-Hole)Punch Waste Tray Capacity: Approx. 25,000 Sheets |
| Power Requirements | Professional Puncher-C1: From The Professional Puncher Integration Unit-B1 Professional Puncher Integration Unit-B1: 120-127V AC/5.5A-60Hz |
| Power Consumption | Professional Puncher-C1: Approx. 300W Professional Puncher Integration Unit-B1: Approx. 135W |
| Dimensions | Professional Puncher-C1: 41" X 12" X 31-1/4" (1040mm X 305mm X 792mm) Professional Puncher Integration Unit-B1: 41" X 9-7/8" X 31-1/4" (1040mm X 250mm X 792mm) |
| Weight | Professional Puncher-C1: Approx. 176 Lb. (80kg) Professional Puncher Integration Unit-B1: Approx. 88.2lb (40kg) |
| Description | Inner Booklet Trimmer-A1 |
| Trimming Method | Face Trim |
| Trim Thickness | Up To 20 Sheets/40 Sheets When Folded (2-20mm) |
| Waste Tray Capacity | Approx. 1,500 Sheets Of Trimmed Strip [Width 3/4" (20mm), Letter, 20 Lb. Bond (80g/M²)] |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter-R, Custom Size (8-1/4" X 11" To 13" X 19-1/4") |
| Paper Weight | 16 Lb. Bond To 110 Lb. Cover (60 To 300g/M²) |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Bond, Letterhead, Textured, Coated |
| Dimensions | Inside The Finisher [15-7/8" X 9-7/8" X 24-5/8" (403mm X 251mm X 625mm)] |
| Weight | Approx. 70.5 Lb. (32kg) |
| Description | Document Insertion Unit-H1 |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Custom Size (7-1/8" X 7-1/8" To 13" X 19-1/4") |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Tracing, Bond, Letterhead, Tab, Textured, Coated |
| Number Of Trays | 2 |
| Acceptable Media | Covers And Inserts |
| Tray Capacity | Upper/Lower Tray: 200 Sheets [20 Lb. Bond (80g/M²)] X 2 |
| Power Requirements | 100-240V AC, 50/60Hz, 2.8A |
| Power Consumption | Approx. 103W |
| Dimensions | 55-3/8" X 29-3/8" X 31-1/4" (1407mm X 746mm X 793mm) |
| Weight | Approx. 134 Lb. (61kg) |
| Description | Paper Folding Unit-G1 |
| Paper Size | Z-Fold: Letter-R, Legal, 11" X 17" C-Fold, Accordion Z-Fold, Half-Fold: Letter-R Double-Parallel Fold: Letter-R, Legal |
| Paper Weight | Z-Fold, C-Fold, Accordion Z-Fold, Half-Fold: 14 Lb. Bond To 28 Lb. Bond (52 To 105 G/M²) Double-Parallel Fold: 14 Lb. Bond To 24 Lb. Bond (52 To 90g/M²) |
| Paper Type | Thin, Plain, Color, Recycled, Bond |
| Fold Type | Z-Fold, C-Fold, Accordion Z-Fold, Double-Parallel Fold, Half-Fold |
| Folding Method | Roller Pressure Folding |
| Power Consumption | Approx. 132W |
| Dimensions | 46-7/8" X 13-1/4" X 31-1/4" (1190mm X 336mm X 793mm) |
| Weight | Approx. 157 Lb. (71kg) |
| Applicable Line | 4 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Fax Features | Job Forwarding, Different-Size Originals, Adjusting Overall Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Selecting The Telephone Line (When Sending Fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-Sided Original, Book To Two Pages |
| Processor | Canon Dual Custom Processor (Shared) |
| Standard Memory | 2GB RAM |
| Maximum Memory | 2.5GB RAM |
| Hard Disk | Standard: 160GB Maximum: 1TB |
| Engine Resolution | 1200 X 1200 Dpi |
| Pdl Support | Standard: UFR II Optional: PCL 5c/6, Adobe PS 3 |
| Print Controller Technology | UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7/8), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/ Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/ 6.0/6.5, Xen Desktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 Or Later, UFR II And PS 3 Only), VMware, SAP (PS And PCL Only)Direct Print Support: Standard: TIFF, JPEG Optional: PDF, EPS,† XPS†† |
| Print Features | Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secure Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Black-And-White Printing, Objective, Color/Black-And-White Auto Detect, Toner Reduction, Poster Printing |
| Description | ImagePASS-A2 Controller |
| Processor | Intel® Pentium® Processor E5300 2.6GHz |
| Type | Embedded |
| System | Fiery® System 10e |
| Standard Memory | 2GB |
| Maximum Memory | 2GB |
| Hard Disk | 160GB |
| Print Resolution | 1200 X 1200 Dpi, 2400 Dpi Equivalent X 600 Dpi |
| Pdl Support | Adobe PS 3, PCL 5c/6 |
| Interface Connections | (To LAN): 10Base-T/100Base-TX/1000Base-T |
| Utility Software |
| Print Features |
| Dimensions | 11-3/5" X 14-2/5" X 3-2/3" (295mm X 366mm X 93mm) |
| Description | ColorPASS-GX400 Controller |
| Processor | Intel® Core™ I5-660 Processor 3.33GHz |
| Type | External |
| System | Fiery® System 10 |
| Maximum Memory | 4GB |
| Hard Disk | 500GB |
| Pdl Support | Adobe PS 3 |
| Utility Software |
| Print Features |
| Dimensions | 19-15" X 8-1/2" X 19" (485mm X 215mm X 483mm) |
| Sending Method | E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional) |
| Color Mode | Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW |
| Scan Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Address Book Capacity | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
| Communication Protocol | File: FTP (TCP/IP), SMB (TCP/IP), WebDAV E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Searchable)◊, PDF (Apply Policy), PDF (Optimize For Web), PDF/XPS (OCR)◊, PDF/A-1b, XPS, XPS (Compact), OOXML (.Pptx And .Docx)◊ Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
