OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
As part of the imageRUNNER ADVANCE C7500 Series, the imageRUNNER ADVANCE C7580i II model offers speeds of up to 80/70 ppm in black and white/color and the capability to scan up to 240/220 ipm (black and white/color, 300 dpi). This Canon printer also supports a wide range of media and paper sizes, up to 13" x 19", with a maximum capacity of 9,300 sheets. Built on the third generation imageRUNNER ADVANCE platform, the device operates on intelligent information management principles, designed to meet a variety of needs with an intuitive, customizable user interface that supports outstanding uptime and continuity.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires additional option.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - Available 2Q 2018.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Time from device power-on to when copy jobs can be programmed.
| Model Name | ImageRUNNER ADVANCE C7580i |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | Standard: 10.1" TFT LCD WSVGA Color Touch-Panel Optional: 10.4" TFT LCD WSVGA Color Upright-Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 4.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional (250 GB, 1 TB) Method: Raid1 |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth |
| Other Interface | Standard: USB 2.0 X2 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows Vista/7/8/8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | Standard: USB |
| Printing Resolution | 2400 Dpi X 2400 Dpi |
| Letter | Up To 80/70 Ppm / A4 Up To 80/70 Ppm |
| Letter R | Up To 60/52 Ppm |
| Legal | Up To 47/41 Ppm |
| Ledger | Up To 40/35 Ppm |
| First Copy Time | As Fast As 4.4 Seconds (BW)/ 5.4 Seconds (Color) |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Maximum Original Size | Paper Drawers (1/2): Letter, A4 Paper Cassettes (3/4): 13" X 19", 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4"), Envelope Custom Size (3-7/8" X 5-7/8" To 13" X 19-1/4") Stack Bypass: 13" X 19", 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (4" X 5-7/8" To 13" X 19-1/4"), Envelope Custom Size (3-1/2" X 3-7/8" To 13" X 19-1/4"), Free Size (4" X 7-1/8" To 13" X 19-1/4") |
| Standard Paper Capacity | 3,550 Sheets |
| Maximum Paper Capacity | 9,300 Sheets |
| Output Paper Capacity | 250 Sheets (With Copy Tray-R2), 3,500 Sheets (With External Finisher-V2), 4,250 Sheets (With External Finisher-X1) |
| Cassette | Paper Drawers: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Paper Cassettes: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Stack Bypass: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) Duplexing: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 30 Seconds Or Less From Deep Sleep Mode: 30 Seconds Or Less Quick Startup Mode: 4 Seconds5 |
| Power Requirements | 208 V AC, 60 Hz,12 A 220-240 V AC, 50/60 Hz, 11A |
| Power Consumption | Maximum: Approx. 2.5 KWh Standby: Approx. 119.2 Wh (208V) 136.6Wh (230V) Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (TEC) Rating: : 5.5 KWh (208V) 5.6 KWh (230V) |
| Plug | NEMA 6-15P (208V) CEE 7/7 (230V) |
| Dim | 27-1/8" X 37-1/8" X 48" (689 Mm X 941 Mm X 1,220 Mm) |
| Installation Space | Basic [With Booklet Finisher-V2 (Stack Bypass And Cassette Drawers Open)]: 75-3/8" X 60" (1,913 Mm X 1,524 Mm) Fully Configured [With Multi-Drawer Paper Deck-C1+Document Insertion Unit-N1+Multi Function Professional Puncher-A1+Document Insertion Unit-N1+ Booklet Finisher-X1 (Cassette Drawers Open)]: 150-3/8" X 60" (3,818 Mm X 1,524 Mm) |
| Weight | Approx. 595.2 Lb. (270 Kg) |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
| Toner | GPR-56 Toner |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 82,000 Images Color (C,M,Y): 66,500 Images |
GPR-56 Toner Black
Estimated Toner Yield: 82,000 Copies/Bottle (Estimated @ 5% Coverage)
GPR-56 Toner Magenta
Estimated Toner Yield: 66,500 Copies/Bottle (Estimated @ 5% Coverage)
GPR-56 Toner Cyan
GPR-56 Toner Yellow
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
